| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
| View Poll Results: What color would you prefer, or think is best? | |||
| Black | | 13 | 46.43% |
| Gold | | 9 | 32.14% |
| NCE cant see it | | 6 | 21.43% |
| Voters: 28. You may not vote on this poll | |||
13Likes ![]() |
| Name is longer than yours ![]() Join Date: Mar 2013 Location: Chicago, IL
Rep Power: 785 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
(Thread Starter) | Not Ranked : 0 score Key features: -Main thing with our PCV plate is that it can use an OEM PCV valve. We designed the PCV valve port to the exact dimensions of the OEM PCV box, allowing for a perfect fitment of the factory PCV valve and o-ring. The main reason to use a PCV valve is to meter the amount of air pulled from the crankcase under vacuum, keeping it as a sustained level, especially under WOT to closed throttle transitions and engine braking, where manifold vacuum is at its highest. -OEM Gasket, you can reuse yours, or opt to have one included -Two 3/8" NPT ports for fittings, plugs, checkvalves -Anodized with engraved DM logo Price is TBA, but it won't break the bank. And there will be options, to add a PCV valve or use the one you have, plugs, fittings, gaskets, checkvalves, whatevs. I'm going to be working on a full blog/forum post on different PCV and OCC configurations, and updating the ones I have, so keep an eye out for that. We're getting them anodized, and we'd like to hear y'all's opinion on what color you'd prefer or feel looks best. Hence the poll. |
| The Following 17 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | 5doorsoffury (09-23-2015), CMajor (09-23-2015), Code Monkey (09-23-2015), davychronic (09-24-2015), g00s3y (09-23-2015), Justin@Freektune (09-25-2015), lolwrx (09-23-2015), macdiesel (09-23-2015), Mauro_Penguin (09-23-2015), Micha (09-26-2015), MS3Shadow (09-23-2015), nekret (09-24-2015), Poohster (09-29-2015), sho (09-23-2015), SpeedRebirth (09-23-2015), Turbo_Steve (09-23-2015), WetzMS3 (09-23-2015) |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
| Not Ranked : 0 score Ginger Red. It'll be sexy in any color man!
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
| The Following 2 Users Say Thank You to WetzMS3 For This Useful Post: | macdiesel (09-23-2015), monkey.bones.007 (09-23-2015) |
| Gold or Blue would be nice. I was looking into a dual OCC from you. sent from my HTC One M9
| The Following User Says Thank You to MS3Shadow For This Useful Post: | xfeejayx (09-23-2015) |
![]() Join Date: May 2013 Location: CO
Rep Power: 2407 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
| Not Ranked : 0 score I'm so glad I've not bought a perm plate yet. tapatalk, it sucks |
![]() Join Date: Jun 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,365
Groans: 171
| Not Ranked : 0 score As long as it's cheaper than the damn perm plate. I'm glad you're going to be able to put to use all the data you've gathered on the PCV system over the years. You haven't found any problems with the PCV valve binding or getting stuck while being sideways?
__________________ -Fearless vampire killers, banned in DC, how low can a punk get? -Delray/Grieco Mazda or Direct Auto Body, ask me why you should NOT take your car to either. ![]() -It is more fun to drive a slow car fast, than it is to drive a fast car slow |
| BrownBear ![]() Join Date: Apr 2014
Rep Power: 632 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 468
| Not Ranked : 0 score Have had one running for months. No issues thus far.
__________________ |
| The Following 4 Users Say Thank You to Farhan@DM For This Useful Post: | Mauro_Penguin (09-23-2015), monkey.bones.007 (09-23-2015), MS3Shadow (09-23-2015), WetzMS3 (09-24-2015) |
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
| Not Ranked : 0 score Can't not offer gold.
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals |
| Feline Führer ![]() Join Date: Feb 2013 Location: Jacksonville, FL
Rep Power: 2280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,422
| Not Ranked : 0 score This is how I'm planning on running the plate I have now. How would one utilize a 3rd port on the new plate?
__________________ Official CatDickRacing Sales Rep - All products backordered. |
| Not Ranked : 0 score How do you plan on preventing the intake leak that will happen then you route the hose from intake to vta can?
| The Following User Says Thank You to jdmage_mx5 For This Useful Post: | neganox (09-24-2015) |
| Not Ranked : 0 score Theres a checkvalve under the breather on the can. Forgot to draw that in. Good catch!
| The Following 5 Users Say Thank You to neganox For This Useful Post: | Easter Bunny (09-24-2015), jdmage_mx5 (09-24-2015), Mauro_Penguin (09-24-2015), MS3Shadow (09-24-2015), WetzMS3 (09-28-2015) |
![]() Join Date: Jan 2013 Location: Vancouver, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 130
| Not Ranked : 0 score Black please! Sent from my SM-G900V using Tapatalk
__________________ 2011 Mazdaspeed3 non-tech package Drivetrain CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune Chassis JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace Rice LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers |
![]() Join Date: Mar 2014
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score I think black is the obvious choice, but using the same gold as the mounts would be nice, if you're going to offer options. |
(Thread Starter) | Not Ranked : 0 score Yeah we're going to do both. It doesn't matter all too much what color it is, cause it's hardly visible. |
![]() Join Date: Jun 2011 Location: Beach Park Illinois
Rep Power: 2610 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46,278
| Not Ranked : 0 score PINK!!! |
| The Following 3 Users Say Thank You to Micha For This Useful Post: |
![]() Join Date: Jan 2013 Location: Pocatello, ID
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
| Not Ranked : 0 score Black. Looking forward to seeing the occ setups you have in the works Sent from my ONE A2005 using Tapatalk
__________________ Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff |
| The Following User Says Thank You to superman For This Useful Post: | BeastlyZoomZoom (09-15-2016) |
| Not Ranked : 0 score HEY. You answer my question right meow.
| The Following 3 Users Say Thank You to WetzMS3 For This Useful Post: |
| The Following 3 Users Say Thank You to neganox For This Useful Post: |
![]() | | #19 | ![]() |
| The Following 2 Users Say Thank You to MS3Shadow For This Useful Post: | Easter Bunny (09-28-2015), Mauro_Penguin (09-28-2015) |
![]() | | #20 | ![]() |
We consider the stock PCV valve as a way to meter air, in addition to it's function as a check valve. We generally don't like a wide open path from the crankcase to an IM under relatively high vacuum. Therefore, the recommendation would be to utilize the normal function of the PCV valve and system, and use an additional port for added venting. You've then effectively addressed crankcase venting issues in boost, and in vacuum. There do exist the minority for whom that isn't enough venting. They will see benefit from a third port. You don't need a valve cover breather, a new hole in the valve cover, or any other added port. It's already there. If desired, put a check valve on it, and run a hose to wherever you want to vent it. Of course, for those who prefer the PCV valve left out, the plate can be the normal, dual vent plate. All the options, fittings, etc. will be available with this.
__________________ Last edited by Farhan@DM; 09-29-2015 at 11:49 AM. | |
![]() | | #21 | ![]() |
| Not Ranked : 0 score Soooo.
| The Following 2 Users Say Thank You to neganox For This Useful Post: | monkey.bones.007 (09-29-2015), Speed3Pedro (05-21-2016) |
![]() | | #22 | ![]() |
| Not Ranked : 0 score I may, or may not have made this suggestion to a test car. Remember that some/most/all drag strips will frown on what might result from that.
| The Following 4 Users Say Thank You to Farhan@DM For This Useful Post: | Mauro_Penguin (09-29-2015), monkey.bones.007 (09-29-2015), MS3Shadow (09-29-2015), neganox (09-29-2015) |
![]() | | #23 | ![]() |
| Not Ranked : 0 score INB4 DM names this product "Spy Hunter Mode"
| The Following 5 Users Say Thank You to neganox For This Useful Post: | Mauro_Penguin (09-29-2015), monkey.bones.007 (09-29-2015), MS3Shadow (09-29-2015), WetzMS3 (09-29-2015), Yatta (09-29-2015) |
| Display Modes | |
| Damond Motorsports MS3 PMM | Matt@DamondMotorsports | Damond Motorsports | 141 | 10-16-2019 05:40 AM |
| Damond Motorsports - What the f*ck? | ItsNox | Damond Motorsports | 3 | 12-02-2014 12:31 PM |
| Welcome Damond Motorsports | Haltech | Damond Motorsports | 46 | 08-25-2013 09:56 AM |
