Other Platforms
> Ford Focus ST Ecoboost - Turbo Induction
 Old 02-21-2014, 04:32 PM   #1
robspeed3's Avatar
Posts: 477   (View Stats)
robspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond repute
Groans: 58
Groaned at 286 Times in 281 Posts
Default Gtx2867 vs gt3071r
I'm getting ready to pull the trigger on a big turbo for the st. Which do you think is better to hit my power goal of 390whp on 93 when the fueling problem has been solved and about 430whp with e85. I've been researching for days now mostly on here to look at peoples build and the gains they are getting. I'm just torn on which one to buy. Any help here would be appreciated in deciding.
Don't make me pop the trunkt!!
robspeed3 is offline   Reply With Quote
 Old 02-21-2014, 06:20 PM   #2
pharaoh313's Avatar
Posts: 120   (View Stats)
pharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the world
the gtx2867r flows like a 3071 but comes on sooner, so the ? is how soon do you want your boost to hit? i vote gtx*
2013 Mazdaspeed 3 W/Tech
1st trip 2 the 1/4m: 1.89 60ft 12.87@109.62 VD* 289hp- HpFp - Trilogy 70D -E85(Freek)Tune - QTPs
2nd time 1/4m: 1.91 60ft 12.49@113.59 Dynojet 335.48hp- HpFp - Trilogy 70D - E85+M(Sn@il)Tune - QTPs - 3 port - SE/TBE - TMIC - 3.5Intake
Audio: 2 x Kicker Cvr 12s, Hif 1500D, Hif 800.4, Bx-15, 4x Infinity Kappa 60.11cs rewired w/12G
@FB Allan Langston
~4 Bangin Ain't EZ~
pharaoh313 is offline   Reply With Quote
 Old 02-21-2014, 06:48 PM   #3
robspeed3's Avatar
Groans: 58
Searching the forum I'm trying to find if some one is making 390whp off of 93 most guys I see on here making that power are using the gt3071r
 Old 02-22-2014, 05:07 PM   #4
robspeed3's Avatar
Groans: 58
Well I'm going the with the gt3071r seen good result here shouldn't be disappointed
 Old 02-23-2014, 12:56 PM   #5
lug
lug's Avatar
Posts: 315   (View Stats)
lug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the world
DYNO-DATA - 2013 FOCUS ST 2.0L TURBO : atpturbo.com
though a bit lower, I actually like the look of the GTX3067 in ATP's results.
lug is offline   Reply With Quote
 Old 02-23-2014, 01:16 PM   #6
There are a lot of variables that haven't been sorted out on the road to 400whp. The Ecoboost at the low power levels we're seeing on the K03 is a bit more efficient than that DISI. This means that it will make more power with a smaller turbo so in theory the GTX2867 should get you there. The spool will however also be slower. There is a big difference in boost threshold between the GTX2867 and the OEM K03. Bigger difference than from the K04 to the same GTX turbo.
For that reason alone I prefer to stick to the smaller frame turbo.
The other thing that worries me is the exhaust manifold. We don't know at what point it will choke off flow. If it chokes top end and you bought a big top end turbo you're screwed in both ways.
So I would personally choose the smaller GTX2867 before the older and larger GT30 anyday especially on that platform.
alaskazero (02-28-2014), breakfstincluded (02-27-2014), cshunter (02-23-2014), Easter Bunny (02-27-2014), robspeed3 (02-23-2014)
 Old 02-23-2014, 07:00 PM   #7
robspeed3's Avatar
Groans: 58
Thanks lex this is what I was looking for ill prob go with the gtx.
 Old 02-27-2014, 04:40 PM   #8
On the development car we are going with the GTX or the EFR 6258.
 Old 02-27-2014, 04:19 PM   #9
sidekick's Avatar
Posts: 3,093   (View Stats)
EDIT: NVM.
 Old 04-04-2014, 03:39 PM   #10
robspeed3's Avatar
Groans: 58
So I went with the gt3071 here is my vdyno with the turbo at 21psi
The Following 2 Users Say Thank You to robspeed3 For This Useful Post:
bstover17 (04-04-2014), NCspecV81 (04-05-2014)
 Old 04-04-2014, 03:57 PM   #11
Matrix311's Avatar
Posts: 2,133   (View Stats)
AWesome! on the road to making power.
What are the limits of the stock block does anyone know yet? Ours is like 400lb-ft torque. Curious if your limits are a lot higher on stock block.
The Following User Says Thank You to Matrix311 For This Useful Post:
robspeed3 (04-04-2014)
 Old 04-04-2014, 05:24 PM   #12
robspeed3's Avatar
Groans: 58
Well I'm out of fuel up top right now getting ready to order the bigger injectors and see how far they get me I'll keep this thread updated.
 Old 04-08-2014, 09:14 AM   #13
For now we are not sure about where the limits to the stock block are, but fueling is the biggest problem. Very similar to the mazda, but the cap is a bit lower on the factory injectors. It will be interesting to see how much more room we get out of the mountune injectors. The ST also seems to be able to be ran considerably leaner so that gives a bit more room to make more power on the factory injectors if you are brave enough to run 12.6-13.0 afr at WOT. But so far from some things I've seen and heard the ST should be capable of handling it. I would like to back this up with first hand experience before I start recommending it though.
robspeed3 (04-08-2014)
 Old 04-08-2014, 01:13 PM   #14
robspeed3's Avatar
Groans: 58
Sounds good I'm waiting to see your results before I pull the trigger on them. I want to see if my power goals are realistic with those new injectors. Or do I need to go a different route.
NATOR CO GTX2867 Mortose MazdaSpeed 3/6 - Big Turbo Builds 93 02-04-2014 01:19 PM
Gtx2867 445hp atvfreek 2010 MS3 - Dyno Sheets/Discussions 89 01-28-2014 08:14 PM
GTX2867 ready to go in resilientone 2010 MS3 - Big Turbo Builds 50 01-14-2014 05:22 AM
GTX2867 417hp atvfreek 2010 MS3 - Dyno Sheets/Discussions 227 11-05-2013 12:09 PM
GTX2867! EdgeAutosport.com EdgeAutosport.com 237 12-10-2012 10:33 PM
Page generated in 0.33816 seconds with 27 queries
