> MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline
 Old 03-29-2010, 10:55 AM   #121
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
First, they told me to use what's specified in the manual.
They also informed me that Mazda makes the transmission themselves.
After calling them out, they told me to ask the dealership. (hah.)
They then sent me to MazdaTechInfo.com.
They said to use what's in the manual.
*facepalm*
Straight GL-4 75W90......... doesnt call for addition of friction modifier.
The Gen2's call for 75W80 IIRC
Suspension:
FreeFlyFreak is offline
 Old 03-29-2010, 11:43 AM   #122
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
no no, I know what it calls for. The Motorcraft fluid, from what I've found, is only kind-of GL-4. Either way, the reason people get diff-whine is because the OE fluid has a friction modifier and the Motorcraft stuff doesn't.
At any rate, I'd just like to know if it's really an Aisin BG6 with different ratios among the vehicles. Also, I'd like to see if the 75W-80 would be suitable long-term in the Gen1 to see if it would help the syncros spin-up faster due to less resistance.
Mizzle is offline
 Old 03-29-2010, 12:30 PM   #123
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
how often r u guys swaping tranny fluid?
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
superskaterxes is offline
 Old 03-29-2010, 12:53 PM   #124
The Kamikaze King!
Groans: 754
After having a long discussion with a transmission and axle rebuilder a while back.
He recommended change at 20k miles and then treat it as a lifetime fill.
He said most break-in and wear occurs in the first 20K, so dump that fluid to get the metal particles out, and then that replacement fluid is all you will need.
Suspension:
 Old 03-29-2010, 02:57 PM   #125
MileHighM6's Avatar
Posts: 7   (View Stats)
MileHighM6 will become famous soon enough
Will the warranty cover the switch from Gen1 to Gen2 fluid?
MileHighM6 is offline
 Old 03-29-2010, 03:30 PM   #126
meatball18's Avatar
Posts: 138   (View Stats)
meatball18 is the leader of the worldmeatball18 is the leader of the worldmeatball18 is the leader of the worldmeatball18 is the leader of the worldmeatball18 is the leader of the worldmeatball18 is the leader of the worldmeatball18 is the leader of the worldmeatball18 is the leader of the worldmeatball18 is the leader of the worldmeatball18 is the leader of the worldmeatball18 is the leader of the world
put the motorcraft in last weekend and it is pretty good stuff. havent really seen such a dramatic difference in it like some guys are sayin but it is a little better. good enough i would recommend whenever it is time to swap out fluids, but not rush out and buy it on a whim IMHO
meatball18 is offline
 Old 03-29-2010, 05:23 PM   #127
dixie789456's Avatar
Posts: 635   (View Stats)
dixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the world
Groaned at 25 Times in 15 Posts
i'm uding royal purple in my tranny and its suppoesed to have friction modifiers in it, but it still wines like a bitch and grinds first when cold sometimes. no wonder people are breaking shifters in this car!!!!
dixie789456 is offline
 Old 04-01-2010, 01:12 PM   #128
Hank3's Avatar
Posts: 516   (View Stats)
Hank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the world
I find this interesting. I can't seem to find the maintenance interval for the tranny fluid in our Owner's Manual, but it seems like everyone says to change it out every 30K. Is the 30K interval kinda like how everyone says you need to change out the oil every 3K? Curious to find out out how 30K came about.
Not trying to argue as I plan to change mine out at 30K. I did the same with my WRX when I owned it for six years - changed out the fluid every 30K.
5% off Redline leather goodies HERE. Pics of them installed in my Speed3 HERE.
Hank3 is offline
 Old 04-01-2010, 01:20 PM   #129
BUNGEEZZ's Avatar
Posts: 426   (View Stats)
BUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the world
Groaned at 49 Times in 36 Posts
I have a stage 1 short throw shifter with base+ bushings along with the ford fluid and let me tell you...
AMAZING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!! =)
It may be Impossible to mis-shift!!! SO SMOOTH AND PRECISE!
MUST HAVEE!!
Mazdaspeed6,2006, 46k miles.
COBB AP*
Gt3076, 19psi. CPE dp (catless), Dnp Mani 38-EWG, CorkSport Dual CB, CPE BIG MAF SRI, Big Turbo Inlet, CPE Fuel Pump, HKS SSQ Black out edition, Ported stock intake Mani, Intake mani spacer (PT), 2 step colder plugs, FMIC Custom 3.5 inch core, Meth (PT), OCC, BSD, TTFMM, CPE Rear Diff, CPE engine Mount, H&R Springs, Whiteline Rear Sway Bar, Stage 1 short shifter kit Base+bushings, Rotora Break Rotors All 4 (Slotted), Techna fit Brake Lines, Ebc red Stuff pads All 4, Enkei PF01 18's Wrapped in 245/40/18 Falkanzzzz ... Stock clutch until i get some funds.
I HAZ THE FASTEZ CAR ALIVE!!!!!!!!!!!! REDBULL FTW
BUNGEEZZ is offline
 Old 04-05-2010, 10:14 PM   #130
Mizzle's Avatar
Groans: 324
Everything I've read elsewhere puts the Ford fluid in the Focus transmission category, which is a different trans than we have. That being said, Amsoil is likely better than anything Motorcraft.
Anyone have contact info for Aisin? Let's just ask them.
Mizzle is offline
 Old 04-19-2010, 06:20 PM   #131
Arrowpoint's Avatar
Posts: 364   (View Stats)
Arrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the world
2008 MS3 here and I recently changed to the XT M5 QS Motorcraft fluid at 37000 miles. I have rear and side motor mounts as well as solid shifter bushings and a home made shift plate. I have become used to the constant transmission whine and sloppy shifting although the shifting was somewhat improved by the plate. I was skeptical about the Motorcraft fluid but I can tell you that the improvement with this fluid was immediate and very noticable. The tranny is much quieter now. Shifting has a different feel. It's a subtle difference but it is an improvement. I'll report any changes over time.
Arrowpoint is offline
 Old 04-22-2010, 11:24 AM   #132
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
Anybody swapped out the transmission fluid in a Gen2? Is this motocraft stuff 75/90? Is there an equivalent motocraft fluid, or would it be better to go with amisol? If you have tried an alternative transmission fluid, have you noticed an improvement?
I'm all about improving the shifting feel in the car, I just don't want to make it worse if the stuff in there is already good.
Speed3eak is offline
 Old 05-11-2010, 03:37 AM   #133
soulefx's Avatar
Posts: 30   (View Stats)
soulefx will become famous soon enoughsoulefx will become famous soon enough
so do we need to add a friction modifier or not? i read through this whole thread and didn't see any definite answer as to whether we need to add it or not.
soulefx is offline
 Old 05-11-2010, 04:59 AM   #134
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
No.
cld12pk2go is offline
 Old 05-11-2010, 08:34 AM   #135
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
don't do that. Long story short...it may diminish the LSD noise, but it will decrease the effectiveness of your transmission's synchros, shortening their life.
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
Cataphract_40 is offline
 Old 06-08-2010, 07:54 PM   #136
BMSPEED3's Avatar
Posts: 20   (View Stats)
BMSPEED3 is an unknown quantity at this point
Im about to change my trans fluid to the motor craft, hopefully this helps. This may be a stupid question but when i looked up the R & R on all data it said you should replace the plug and washer in the drain and fill hole, is that really necessary?
BMSPEED3 is offline
 Old 06-08-2010, 10:23 PM   #137
div2's Avatar
Posts: 273   (View Stats)
div2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the world
No.
Cosmic Blue Mica 2007 MS3 GT- MSCAI, HT, E-Focus RMM, FSDs, JBR Rear ARB and billet mounts
Hellrot 1995 318ti Club Sport- Turner/Conforti chip, Turner SS clutch line, UUC Motorwerks pedal bushings, clutch stop, and RK II
Desert Sand Pearl 1999 Wrangler Sahara- Banks SS Exhaust manifold, Hella H4 E-Codes, Bilstein HDs
Fireball Orange 1996 Speed Triple 900- Alcon six-pot front calipers, Sebring 3 into 1 "Off Road" exhaust
div2 is offline
 Old 06-08-2010, 10:29 PM   #138
Groans: 30
If by 'replace' you mean buy a brand new one, no.
If by 'replace' you mean 'screw the old one back in the drain hole once i'm done draining', then yes, otherwise things will go very wrong very quickly
1995 Miata
 Old 06-09-2010, 11:37 AM   #139
BMSPEED3's Avatar
Lol I ment by getting a new one but thanks!
BMSPEED3 is offline
 Old 06-09-2010, 04:18 PM   #140
P5_2_MS3's Avatar
Posts: 111   (View Stats)
P5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant future
So, none of you have bothered to replaced the crush washers? I think they're like a $1 part. I just picked up some of the Motorcraft fluid but am wondering if I should wait till I can get some new washers before draining and refilling.
P5_2_MS3 is offline
 Old 06-09-2010, 04:50 PM   #141
NCZ13's Avatar
Posts: 1,268   (View Stats)
I didnt replace mine when i did the swap.
2008 Cosmic Blue Mazdaspeed3
1986 Mazda RX7
NCZ13 is offline
 Old 06-09-2010, 10:43 PM   #142
div2's Avatar
Me either; if you do want to replace it you should be able to find one at most any auto parts store.
div2 is offline
 Old 06-09-2010, 10:54 PM   #143
801MS3's Avatar
Posts: 453   (View Stats)
801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world
Groans: 30
I was one click away from buying the motorcraft now im second guessing, and considering the amsoil.
Anyone else tried both?
I really want a smoother quieter tranny BUT i DO NOT want the whiney diff.
Anyone running the amsoil having noise problems?
08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS:
465whp 468 wtq Best e.t 11.9 Best trap 123mph
801MS3 is offline
 Old 06-10-2010, 09:05 AM   #144
div2's Avatar
I run the Ford synthetic and the only time I notice any whine is when the fluid is cold and/or I'm making a very sharp turn at parking lot speeds.
div2 is offline
 Old 06-10-2010, 09:13 AM   #145
BMSPEED3's Avatar
i have royal purple in mine now and i get the same result, not much improvement over the stock feel though thats why im switching to the ford fluid.
BMSPEED3 is offline
 Old 06-10-2010, 04:04 PM   #146
div2's Avatar
In my case the feel improved to the point that I found the car to be much more enjoyable to drive.
div2 is offline
 Old 06-10-2010, 06:25 PM   #147
retrobmx63's Avatar
Posts: 436   (View Stats)
retrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the world
Subbed for future maintenance
Hey, do my fingers smell like your mother?
retrobmx63 is offline
 Old 06-13-2010, 05:41 PM   #148
P5_2_MS3's Avatar
Swapped out the MT-90 for the Motorcraft stuff yesterday. Turns out the dealer who changed the fluid for me last time over-torqued the drain plug, AND forgot to put in the crush washer. Some of the fluid may have leaked out, contributing to my rough shifting. When I poured the used oil back into the containers, I had only a bit more than 2 qts. I moved the crush washer from the fill plug to the drain plug, since I can replace the fill plug washer anytime without losing oil.
Last night, shifting felt the same as with the old MT-90, but today it seems to have improved noticeably. I guess there's some truth in what everyone's saying about it taking a while to for the new oil to work in.
P5_2_MS3 is offline
 Old 06-15-2010, 09:48 PM   #149
801MS3's Avatar
Groans: 30
Have you noticed the low speed tight turn "whine"?
801MS3 is offline
 Old 06-15-2010, 10:15 PM   #150
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
super_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the world
alright so i just read this entire thread and im convinced i should give it a try... ive been recently grinding 3rd when flooring it, and the 1st-2nd shift is loud as fuck.
i found the link for the motorcraft shit, but wheres the link for the amsoil one everyone thinks is better...
i dont wanna read the hole shit again.. anyone post the link?
thanks
super_pablo_ is offline
 Old 06-15-2010, 11:10 PM   #151
anyone?
 Old 06-16-2010, 10:10 AM   #152
come ON!!!... link for amsoil?
 Old 06-17-2010, 02:40 PM   #153
Speed3eak's Avatar
Groans: 82
scan through and look for links - they're a different color.
Seriously, it's only 4 pages.
 Old 06-18-2010, 09:53 AM   #154
801MS3's Avatar
Groans: 30
I have it bookmarked on my home computer, but im at work, ill post it later.
I too am torn on amsoil vs motorcraft.
Anyone running the amsoil getting the low speed tight turn diff whine?
801MS3 is offline
 Old 06-18-2010, 11:31 AM   #155
morgan2112's Avatar
Posts: 29   (View Stats)
morgan2112 is on a distinguished road
Groaned at 7 Times in 4 Posts
Arrow
I have had the amsoil in for 8K and I don't have any whine or noise problems, but I didn't have any with the OEM either. The Amsoil made my shifting feel marginally better/smoother.
My issue is the resistance I still feel when going into 2nd gear. I wonder if this FORD Focus special GL-4ish would help me slide into 2nd any smoother??
Thanks!!!
morgan2112 is offline
 Old 06-18-2010, 08:01 PM   #156
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
its redline mt-90 can be found at streetunit, jsc speed, maybe pg along with ebay and amazon. su was cheapest at the time when i purchased mine about a month ago.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline
 Old 06-18-2010, 10:13 PM   #157
Speed3eak's Avatar
Groans: 82
I'd like to see some posts by people who have tried more than one type, so far there seems to be 3 types people like:
Motorcraft
MT-90
Amisol
If anybody has swapped out one for the other, I would love to get your impressions and before/after comparisons.
 Old 06-18-2010, 10:21 PM   #158
nyghtryder's Avatar
isnt the amsoil and mt90 the same thing? I looked for amsoil and the redline kept coming up so i assumed they were the same. several places i found the product titled as amsoil but the pic was redline.
NATOR PA
 Old 06-19-2010, 08:34 AM   #159
Groans: 30
I've tried MT-90 and XT-M5-QS. The redline gave me LSD chatter. The Motorcraft does not. Case closed in my book
1995 Miata
 Old 06-19-2010, 11:05 AM   #160
P5_2_MS3's Avatar
I'm glad you asked, because I didn't even notice it was gone! I guess it's easier to notice new noises than the absence of old ones. It was always there with the MT-90, but I can't seem to reproduce it with the Motorcraft.
P5_2_MS3 is offline
*Only* the transmission Ingle Mazdaspeed3/6 General Discussion 10 07-30-2018 08:39 AM
Transmission Cured FreeFlyFreak MazdaSpeed 3 - Engine, Transmission & Driveline 305 11-08-2017 08:36 AM
Rattle Not Cured TRex MazdaSpeed 3 - Engine, Transmission & Driveline 35 09-16-2011 07:20 AM
Page generated in 0.57113 seconds with 42 queries
