![]() | | #401 | ![]() |
| Approved MSF Vendor ![]() Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 425
![]() | | #402 | ![]() |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score Subscribed.
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() | | #403 | ![]() |
![]() Join Date: Dec 2008 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 541
| Not Ranked : 0 score +1 Any info would be great.
__________________ GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP Bitwise Motorsports http://www.bitwise-motorsports.com - Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!) |
![]() | | #404 | ![]() |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 124
| Not Ranked : 0 score I pulled these dynos from CP-E's website: If you search around here and the other forums you'll find some reviews. I want to get it but am waiting b/c im hoping by next year to go BT and will need the XL flash. dont want to do this twice.
__________________ ^^USE THIS LINK AND COUPON CODE SURIOT AT CHECKOUT FOR A DISCOUNT!^^ |
![]() | | #405 | ![]() |
![]() Join Date: Oct 2008 Location: merida yucatan mexico
Rep Power: 139 ![]() Thanks: 4
| Not Ranked : 0 score HI GUYS , IM NEW IN THIS WITH THE STANDBACK , I DID A LOG ON 3RD GEAR WITH THE PRIMARY MAP ON THE STANDBACK, MY MODS ARE : STANDBACK , CP-E FULL CONTROL FLASH , CAI INJEN, TURBOBACK 3" , AEM WATER METH INJ KIT, BOOST TUBES SILICONE, LAUNCH CONTROL, REAR ENGINE MOUNTH , OIL CATCH CAN, NGK ONE STEP COLDER. ( CDFP STOCK , BOV STOCK ), IF SOMEBODY CAN HELP ME UP TO MAKE A TUNE FOR THIS MODS I PRECIATE SO MUCH, I NEED AN AGGRESSIVE TUNE FOR 1/4 MILE . THANKS!!! |
![]() | | #406 | ![]() |
| Not Ranked : 0 score SORRY I FORGOT TO TELL YOU I LIVE IN CANCUN CITY , WE ARE AT THE SEA LEVEL... I THINK THIS IS IMPORTANT TO BUILD A TUNE ON THIS PLACE . THANKS!! |
![]() | | #407 | ![]() |
![]() Join Date: Jul 2009 Location: Baltimore, MD
Rep Power: 253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 157
| Not Ranked : 0 score First of all please don't type in all caps. It would be helpful to put the cursor ( the red line on the graph) into the relevant area to help us read what you have. Also please post you base tune screen shots from the standback so we can see what were working with. Looking at the graph you AFR seems to be settling at about 13+ which I think is much leaner than you want to be(atleast for safety sake). I would add fuel incrementally until you AFR is below 12. Fortunately I see no knock in this graph. After your AFR is safer you can add timing slowly until up to the point where you see knock to get a bit more power. What boost pressure are you running?
__________________ 2009 MazdaSpeed3 | True Red 35% Tint CP-E Engine Mount - CP-E XCel Intake - COBB AP - CP-E TMIC |
![]() | | #408 | ![]() |
| Not Ranked : 0 score HI FEARUNDERSTEER!! THANKS FOR YOUR SOON REPLY!! I USED THE PRIMARY MAP WHICH IS SET TO 15 PSI AND BOOST CLIP AT 13 PSI,ALL TIMING TABLES ARE CERO VALUES , MAF TABLES CERO TOO , I ONLY RUN THE FIRST MAP ONTHE STANDBACK..BEFORE THIS I WAS USING A MBC SET TO 20 PSI WITH THE FCD AT ATP ,AND THE CAR WAS AT 10,5 AFR WITH METH . DO I NEED TO SETUP AT 20 PSI THE STANDBACK ? AND THE BOOST CLIP HOW MANY PSI? AFTER THAT DO I NEED TO DO A LOG ON 3RD GEAR TO SEE HOW IS THE CAR RUNNING?? SORRY MAN IM CONFUSED... |
![]() | | #409 | ![]() |
| Not Ranked : 0 score ![]() |
![]() | | #410 | ![]() |
| Not Ranked : 0 score The psi the SB is at is fine to start. once you get the AFR down you could add a lb or two and retune the AFR. The boost clip is simply the most psi the SB will tell your car its getting. Mine is still stock so its clip is at 13, despite the fact the SB comes tuned to 15psi my dashhawk will only read 12.9, you can raise the clip to say 16, and the DH should read the full 15 coming from the car. The reason they do this though is that some ppl have fueal cut issues if they raise the boost too much.
![]() | | #411 | ![]() |
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Hi! Can someone help me with SB-tuner. I installed SB today for my car and that was very easy but now I have problems with the program v2.59. When I start the program everything works great. But when I hook up SB to my laptop with USB-cable the program crashes everytime. I have tried two different cables for every USB-ports and still crashing. I have framework 3.5 and I have Windows XP. I have also tried to update drivers but it says that there's no better available. Program works great with my table computer but I would like it to work rather with my laptop. Has anyone had same kind of problem? |
![]() | | #412 | ![]() |
| Not Ranked : 0 score Idk how to fix it on the laptop really but i do know you can unplug the SB from your car and take it in to your desktop and the USB will power it to connect to the software... Try getting in touch with CPE. Lou knows his stuff about the SB and might be able to help with the laptop.
![]() | | #413 | ![]() |
| Not Ranked : 0 score I've mailed to CPE, but they are quite busy and reply takes some time so I tried if someone here have been the same problem than me. Maybe the problem is with my USB ports because they are only 1.1 on my 5 year old laptop, but I'll wait what CPE says about my problem. |
![]() | | #414 | ![]() |
| Not Ranked : 0 score Are the ports on your desktop 2.0? |
![]() | | #415 | ![]() |
Did you try a search on the forum? ive seen a few threads, one by me even, about getting the SB and DH to run right on and vista. Also on the laptop are you logged in as a full administrator? windows sometimes gives you a hard time if you arent...
__________________ ^^USE THIS LINK AND COUPON CODE SURIOT AT CHECKOUT FOR A DISCOUNT!^^ | |
![]() | | #416 | ![]() |
| Not Ranked : 0 score I'm not so good in English that I could call them. Mailing is better and I don't have any complainings about CPE service. I just meant that like any other company sometimes reply to the mail can take some time. I'll try to first update my USB ports to 2.0 if its possible. But if someone have also older computer and have update ports to 2.0, could try to erase them and try with 1.1 if the program works. I don't want to buy new parts or new laptop if USB aren't the problem. I can't understand why this program would need so high data transfer. I have also tried USB TV tuner and that works well. I think that would need much higher data transfer than this program. But I'll keep trying... |
![]() | | #417 | ![]() |
![]() Join Date: Apr 2009 Location: Bethpage, New York
Rep Power: 4481 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,850
Groans: 778
__________________ 2003 SilverStone Grey Honduh S2000 ![]() ![]() | |
![]() | | #418 | ![]() |
| Not Ranked : 0 score I'm from Finland |
![]() | | #419 | ![]() |
| Not Ranked : 0 score ITs probably going to be hard to update a laptops usb ports... the internal cards are usually built with the laptop they are going into in mind. Or at least thats always been my understanding.
![]() | | #420 | ![]() |
| Not Ranked : 0 score What do you mean by that? I put printscreen on my USB controllers. I think I have USB 2.0? Also I put the picture about the error what Windows says always when I hook up the SB to the laptop. |
![]() | | #421 | ![]() |
![]() | | #422 | ![]() |
| Not Ranked : 0 score The person ive always dealt with for the SB related stuff is lou. IDK if he has a seperate email but id try to get a hold of him. Just email sales@cp-e.com and have them get you his email i guess...
![]() | | #423 | ![]() |
I'll have to try to change my table computer USB ports back to 1.1. That computer is also couple years old. I remember that first there was only USB 1.1 and then I updated those to 2.0. SB even with zero maps are so awesome that I can't wait until I can tune my car. | |
![]() | | #424 | ![]() |
Groans: 778
| Not Ranked : 0 score Hyvää päivää, Mitä kuuluu? Mikä sinun nimesi on? Nimeni on Eric En puhu suomea. but i'm learning Onko teillä vapaita huoneita? I want to visit Suomi.
![]() | | #425 | ![]() |
| Not Ranked : 0 score Como se dice?
![]() | | #426 | ![]() |
Groans: 778
| Not Ranked : 0 score it's Finnish dude. I been teaching myself for a while now. no espanol TY. only languages I'm interested in right now and teaching myself are Finnish, German and Japanese. after I master these 3 I'll move on to French or something else.. FUCK, i'm a retard...My step sister is brazilian and I can easily learn Portuguese... BUT, eh they all sound like retards even worse then Mexicans. so NO TY
![]() | | #427 | ![]() |
| Not Ranked : 0 score yea ive picked up a little spanish and polish from working on construction sites. Never really wanted to learn either though.
![]() | | #428 | ![]() |
![]() Join Date: May 2010
| Not Ranked : 0 score Hi all, I'm new on the forum and a recent 05 mps6 owner. Performance mods are CS FMIC, cat bak 3inch, Standback, PNP. I have read the majority if this thread. Attached is my recording in 3rd gear, Can anyone give me there thoughts on it. |
![]() | | #429 | ![]() |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
| Not Ranked : 0 score I don't see the log. I would love to help though. NM I see it. Alright well you can't do much tuning without a dashhawk. We need to see afr. Also is your target boost 20psi? With stock turbo the most I would do is 17. Do you have an upgraded fuel pump or stock?
__________________ 2012 WRX HB w/mudflaps yo! |
![]() | | #430 | ![]() |
| Not Ranked : 0 score No I don't have a dashhawk. Yes stock turbo, standard fuel pump and yes it was set at 20psi for that run. I usually run 14psi on one map (for everyday) and 18 on another map. |
![]() | | #431 | ![]() |
| Not Ranked : 0 score Well you're fuel pump is holding but it dips way down. You could take some stress off it if we lean the car out but you don't have a dashhawk so we can't. Also don't run 20psi on stock turbo I would stick with 17 tops. You can get some more power out of that car but you need to buy a dashhawk first.
![]() | | #432 | ![]() |
| Not Ranked : 0 score ok - all points noted, thanks for the help. |
![]() | | #433 | ![]() |
![]() Join Date: Feb 2010 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
| Not Ranked : 0 score great thread. sub'd. |
![]() | | #434 | ![]() |
![]() Join Date: Sep 2009 Location: Austin, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 289
Groans: 40
| Not Ranked : 0 score CP-E i need to know if the software is the same for all platforms or not. I got the disc it has the label for the MS3 but the installation file is labeled for BMW, also how do I get instructions for the MS6? |
![]() | | #435 | ![]() |
![]() | | #436 | ![]() |
![]() Join Date: Nov 2010 Location: South Africa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Hi i dont know if i am just stupid but i cant see the parameter for kr is it under something else? |
![]() | | #437 | ![]() |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score sb cant monitor kr along with many other parameters. You need a dashhawk or dashdak to monitor and log all parameters, thats if you have a gen1. if you have a gen2 there is no way to monitor kr or afr unless you get an aftermarket wideband/gauge . Hope this helps you. Now go donate to the forum please. |
![]() | | #438 | ![]() |
| Not Ranked : 0 score Hi Guys I need some help with the tuning on my standback please.Mods are 76mm full cat back exh,cai,d/pipe,dashhawk,fmic,gt35 turbo,8.8 comp arias pistons and pauter rods.I did a log on the dashhawk,everything is still on zere on the standback.It is a mazdaspeed 3 or here we call it the mps 2007 model |
![]() | | #439 | ![]() |
![]() | | #440 | ![]() |
| Not Ranked : 0 score Do a log using these parameters on the dashhawk: rpm, afr, timing, knock, and boosted air temp
| "Standback Tuning For Dummies Guide" The Official Q&A... | AutoXRacer | MazdaSpeed 3/6 - ECU Computer Tuning | 929 | 06-19-2012 10:07 AM |
| Official: How do you say "Chrysler minivan" in Italian? "Lancia Voyager" | Haltech | Automotive News | 0 | 10-20-2011 02:20 PM |
| Standback Tuning for Dummies thread?? | vbt101 | MazdaSpeed 3/6 - ECU Computer Tuning | 12 | 09-02-2009 09:13 AM |
| Saudi government bans "lewd" personalized license plates including: "SEX," "ASS," and "USA" | Haltech | Automotive News | 0 | 04-14-2009 01:40 PM |
| Automotive Traveler offers "Car photography for dummies" | Haltech | Automotive News | 0 | 06-28-2008 03:50 PM |
