> MSF KB - Mazdaspeed 3/6 - Engine/Turbo Builds
 Old 12-08-2011, 12:02 AM   #161
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Just incase someone is wondering, a GT35 fits just fine on this setup. Playing with one right now just to try it out.
Dude, I saw you mention the 35 in another thread, but thought you were fooling. Good shit!
dougefresh_ is offline
 Old 12-08-2011, 12:38 AM   #162
Schmitty5's Avatar
Posts: 979   (View Stats)
Schmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the world
Groaned at 20 Times in 12 Posts
subbed for coming back to when I need to see winning in mazdaspeed6 form.
incredible how to. Only read the 1st page
2010 MS3 - 13.42 at 107 - street tires - 306whp/338tq Moore automotive (dynojet)
Roadcoursing > all http://www.youtube.com/watch?v=GO-xoFpsgj4
Schmitty5 is offline
The Following User Says Thank You to Schmitty5 For This Useful Post:
dougefresh_ (01-12-2013)
 Old 12-18-2011, 04:03 PM   #163
steedspeed's Avatar
Posts: 582   (View Stats)
steedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the world
Here's the new top mount with 44mm V-band at angle to fix the clearance issue. Angles away from the alternator and also away from the block.
steedspeed is offline
The Following User Says Thank You to steedspeed For This Useful Post:
 Old 12-18-2011, 09:27 PM   #164
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
very nice. what about for the t4 flange did you fix the Angle on that so it does it hit the cly head
SPEED6 KILLAH is offline
The Following User Says Thank You to SPEED6 KILLAH For This Useful Post:
 Old 12-19-2011, 09:37 AM   #165
steedspeed's Avatar
Haven't had another T4 order yet but I've tilted the flange away from the head a little on the CAD drawing.
 Old 01-17-2012, 01:45 PM   #166
Just a heads up... @crazyp brought up in his thread that his turbo nuts bad backed off (a ton) as a result of the washers we both used (listed in OP, but edited w/ this warning). My turbo was off recently at the dealer, but one had still recently backed out a bit (back left one here):
@jmhinkle said to use lock washers instead, and that should do the trick.
 Old 01-17-2012, 04:22 PM   #167
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
I've never had one back out, but I did have the lock nuts seize up and cause the studs to back out when I was trying to swap turbos. That, in turn, caused the studs to gall inside the manifold and break off two of them. Best bet is probably loc-tite on the bottom of the stud into the manifold, and use a lock washer and regular nut on top. Coat the top in anti-seize as well so the nuts don't corrode to the studs.
jmhinkle is offline
The Following User Says Thank You to jmhinkle For This Useful Post:
 Old 02-26-2012, 03:09 PM   #168
aviator79's Avatar
Posts: 3,934   (View Stats)
Im throwing the idea around of going with a GTX3071R with a top mount like this, throwing some rods and the new mazda pistons in my spare long block (if block OK) with the big valve head and using the spearco 1-992 FMIC. Ive always wanted to do this as that was why I was stockpiling parts, but it is a lot to take on at the moment. Im trying to figure out costs on a spreadsheet. Can I get a twin scroll GTX3071? I think cause the isn't the difference on the compressor side only? Also Ive got to locate a machine shop around here, but should be too much of a problem being right next to Sikorsky.
aviator79 is offline
 Old 02-26-2012, 05:08 PM   #169
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
cost wise a gtx3071 is the same as a gtx3076. edgeautosports had the best price when I was turbo shopping
crazyp is offline
The Following User Says Thank You to crazyp For This Useful Post:
 Old 04-10-2012, 11:09 PM   #170
hedgehog7's Avatar
Posts: 16   (View Stats)
hedgehog7 will become famous soon enoughhedgehog7 will become famous soon enough
wow, even doing the install outside. clearly you don't mess around!
hedgehog7 is offline
 Old 08-30-2012, 06:50 PM   #171
ESB Jiu JItsu's Avatar
Posts: 492   (View Stats)
ESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the world
every time i get angry or upset at the world I look at the pics in this thread and think of a day when i too will be top mount and all is well!
2006 Mazdaspeed6 GT Liquid Platinum Metallic
"because racecar!" " I love this $%&*ing car"
-Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps
-2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete
-TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender
-Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod
-Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge
ESB Jiu JItsu is offline
 Old 09-20-2012, 08:18 AM   #172
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: HOW TO: TOP MOUNT TURBO SET UP!!
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
HOW TO: TOP MOUNT TURBO SET UP!! dougefresh_ MazdaSpeed 3/6 - Big Turbo Builds 187 10-22-2014 05:42 PM
Top Mount Turbo Speed3 JacksonMS30 MazdaSpeed 3/6 - Big Turbo Builds 157 04-29-2013 06:21 AM
Top mount turbo setups djuosnteisn MazdaSpeed 3/6 - Big Turbo Builds 1856 09-18-2011 08:46 AM
Page generated in 0.33754 seconds with 30 queries
