> MSF KB - Mazdaspeed 3/6 - Engine/Turbo Builds
 Old 01-03-2011, 11:54 AM   #1
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
who knows how this car reacts to high timing....
I have an idea.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
djuosnteisn is offline
 Old 01-03-2011, 12:01 PM   #2
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
I have an idea.
high boost, high timing it's either gonna unlock power or melt a piston. I think both will happen in or around the same time lol
Carry on citizens....
10.7 @ 133 auto 1G DSM
Darksun280 is offline
 Old 01-03-2011, 12:14 PM   #3
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
I always thought the fuel pumps had to be different but now I learned the stock ones are ok. So now its a matter of Driver feeling frisky and throwing 25 Degrees of timing at the car. Good luck who knows how this car reacts to high timing.
I have an idea.
My dyno's at cpe were done on 20* of timing at redline on pump gas.
socks is offline
 Old 01-03-2011, 12:17 PM   #4
Fux Wit It
Darksun280's Avatar
Groans: 175
you didn't happen to know power increase vs lets say stock with just timing advance and what EGT's were at do you? I know it was a long time ago but its a long shot.
Don't forget cars like the srt-4 run freaking 30-32 degrees advance stock granted they have a lower compression but I fell like that has something to do with them making easy power when push comes to shove and boost is raised plus having an iorn block to take the abuse.
P.S thats a real general statement so don't go picking it apart....
 Old 01-03-2011, 12:21 PM   #5
socks's Avatar
Groans: 125
well, dont forget that i also had 8.8:1 pistons.
the power increase was something like 360whp to 394whp, but im pretty sure that was after all the other optimization was done like fueling and fuel pressure, etc.
i could be remembering this wrong, it was almost a year ago.
socks is offline
 Old 01-03-2011, 12:24 PM   #6
Captain
Sean had 8.8 : 1 compression as well, which probably helped with that much timing and no meth.
When you start adding timing, the power will pick up real fast.... but eventually, it'll plateau. That plateau will last for a surprising amount of further advance... until you finally blow up the motor (rod usually). When i was tuning my car i was up to like 19 degrees (plateau started around 16 ish), on 91 octane and 50/50 wmi. I had no active knock sensor at those rpms so i decided it was only stupid to push it further. But i never saw any signs of detonation... just no more signs of power.
www.permtuning.com
 Old 01-03-2011, 12:26 PM   #7
socks's Avatar
Groans: 125
yea, we saw it plateau around 20. jason (the tuner) said he had run as high as 27* on robbies car with no additional gains, so we stuck to 19-20*
socks is offline
 Old 01-03-2011, 02:03 PM   #8
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Cant wait to see what 50% and a dyno comparison show, good stuff Anthony!
NJSPEED3 is offline
 Old 01-03-2011, 02:06 PM   #9
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
pish posh, enough tuning..lets see you run already anthony..i got $50 on you cracking 11s b4 anyone else
rodrigo is offline
 Old 01-03-2011, 02:25 PM   #10
driver311's Avatar
Posts: 1,769   (View Stats)
19-20 huh! I dont see why my setup on 50% e85 couldnt handle that. I will play with it on the dyno when I go here soon. This tank is about gone so Im gonna add another gallon of e85 to my tank and see how it likes it. Even if I cant go farther than 25% e85, I will continue to run it. Car seems to like it and it gives me a little more peace of mind knowing my octane is around 96. 50% would have me over 100 octane. e85 is only 2.50 a gallon here in boise so at .80 cents cheaper than 93 octane, the mileage I lose will be countered by price difference. Im pretty excited about it. LOL
Thats if I can get to sacramento soon enough. I see alot of guys right on the threshold. I hope to be the first 3 atleast. Would be fitting i was the first in the 12s. LOL
Mazdaspeed
driver311 is offline
 Old 01-03-2011, 03:06 PM   #11
cageyvet's Avatar
Posts: 715   (View Stats)
Just use the e85 to lean the car even more.
cageyvet is offline
 Old 01-03-2011, 05:48 PM   #12
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Anthony, you still running without meth?
seems to me meth is a better way but what do I know...you are using gas 100% of the time whereas meth only at WOT...
Does meth not add more octane/cooling than an e85 mix.
not hating over here just axing.
Dano is offline
 Old 01-03-2011, 06:15 PM   #13
driver311's Avatar
From what Ive seen over in the evo community, they can push e85 far past water/meth injection. I dont know from experience but I definately havent seen any of you guys do anything special on meth but clean your motor. LOL
Just teasin, I know meth can do cool things past straight pump but I can get e85 right at pump and its way cheap. And all I know is everyone of my friends that have switched from meth to e85 is pushing there tuning way farther and detonation is non existent. From what I understand its damn near impossible to detontate on straight e85.
Mazdaspeed
 Old 01-03-2011, 08:29 PM   #14
Trail of Fail
Dano's Avatar
Well I went from 14* advance at 6.5K on 100% meth to barely 11* advance without...now I know 14 aint nothing special but I lost 3* of total advance and ~4* in the 4-5.5 range.
jussayin
signed
E85 hater LOL
Dano is offline
 Old 01-03-2011, 07:10 PM   #15
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
does E85 have a much lower stoich? you should adjust your AFR accordingly to maximize power/fuel economy......
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
superskaterxes is offline
 Old 01-03-2011, 07:20 PM   #16
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Yeah, stoich for E85 is more like 6:1.
bmylez is offline
 Old 01-03-2011, 07:21 PM   #17
Trail of Fail
Dano's Avatar
Hater. Meth hater that is. LOL
Dano is offline
 Old 01-03-2011, 09:30 PM   #18
driver311's Avatar
I run 14 degrees on straight pump gas no problem.
Mazdaspeed
 Old 01-03-2011, 09:40 PM   #19
Trail of Fail
Dano's Avatar
Well I guess my car just sucks. Haha
Dano is offline
 Old 01-03-2011, 10:50 PM   #20
Captain
Indeed e85 has a lower stoich point... but AFAIK the o2 sensor reads in labda... in terms of stoich, regardless what that ratio may be. So whenever it's reporting 14.7... it's basically just saying, "the mixture it stoich".
The only reason it says 14.7 is cause mazda figures people will be running gasoline.
www.permtuning.com
 Old 01-04-2011, 07:26 PM   #21
bmylez's Avatar
Groans: 31
Yeah, the O2 sensor doesn't know the difference. The lambda x 14.7 is built into the sensor, so you can't change that aspect. When tuning for E85, it's best to have the gauge display lambda instead of AFR.
bmylez is offline
 Old 01-03-2011, 11:18 PM   #22
kylemzspd3@gmail.com's Avatar
Posts: 90   (View Stats)
kylemzspd3@gmail.com is a splendid one to beholdkylemzspd3@gmail.com is a splendid one to beholdkylemzspd3@gmail.com is a splendid one to beholdkylemzspd3@gmail.com is a splendid one to beholdkylemzspd3@gmail.com is a splendid one to beholdkylemzspd3@gmail.com is a splendid one to beholdkylemzspd3@gmail.com is a splendid one to behold
Groaned at 52 Times in 16 Posts
Ive been running 93oct mixed 50/50 with 110leaded racegas. and its beautiful. everybody is scared but gas is f**king gas.......just dont put 87. lol. leaded gas just burns dirty thus failing cats and 02 sensors. other then that. up the f**kin timing n quit crying. wana go fast? experiment.....i never posted it, cause who wants to hear discouragement? anyway. point is dont be afraid ppl.
;Injen Intake, Turbo Inlet; 3in Custom catless DP; Cobb AP- Street Tuned by me at 20psi; HKS Bov Vta; EGR delete; 5w 30 Mobil 1; Hawk Hp Pads;
800k HID; SU rear Motor Mount
NGK 1step colder spark plugs.
Custom Front Mount Intercooler.
AEM Meth Kit-315cc nozzle
(Cobb's new Jacket.)
(Cobb Shift Knob.)
kylemzspd3@gmail.com is offline
 Old 01-03-2011, 11:34 PM   #23
gonads and strife
Matt's Avatar
Posts: 274   (View Stats)
Matt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the world
I like the sounds of this. So, you guys running e85, any fears of fuel line degradation or excessive CDFP wear?
My only concern would be ending up in the middle of nowhere someday with only 91 octane gas available. If it happened to also be a hot day your ECU would be pissed. Creating separate maps for such an occasion would be ideal.
Matt is offline
 Old 01-04-2011, 07:51 PM   #24
Must Have Teh 10's!
lol kinda like owning a PTP pump haha
 Old 01-04-2011, 08:04 PM   #25
driver311's Avatar
You aint bullshitting, LOL Thats why I keep an extra pump with me at all times now. LOL HOw sad. Hopefully I dont have to use it.
I got one even better for you. Im gonna be putting a ptp rail valve on my car this weekend and try to get my car to hold 2000psi across the board. Ill put that info in its own thread though. God knows how thatll spiral!!!
Mazdaspeed
 Old 01-04-2011, 08:19 PM   #26
mason's Avatar
Posts: 946   (View Stats)
PTP started doing some cool stuff, different stuff that was very needed...... just sucks they went down like that! wish the shit was legit!
mason is offline
 Old 01-04-2011, 08:28 PM   #27
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
i just want to say this....
PEEEEEE TEAAAAAAAAAA PEEEEEEEEEE
rodrigo is offline
 Old 01-04-2011, 09:15 PM   #28
Captain
Hope you have an e-torx bit duct taped to the spare pump, cause you aren't gonna swap that shit out with a leatherman lol.
And ask erich about the rail valve... he's been running one for a while, and is seeing a lil weird stuff...
He was running more pressure than the pressure sensor could even read (maxed out basically), and was actually disrupting the injectors from opening properly, and leaning way the fuck out. He's fine with doin it cause he has a spare motor sitting around, and he's not making anywhere near the power you are (which means less fuel demand).
Just be careful being PTP's "learning" car. Esp if your so concerned about your block. Just cause he gets all excited and talks all loud about how fucking cool his products are, doesn't mean he's thought them through entirely, or tested em out thoroughly. That's essentially what you'll be doing, haha.
But shit... who knows... maybe he's running that valve on his srt...
www.permtuning.com
 Old 01-04-2011, 10:29 PM   #29
driver311's Avatar
Sooooo your saying theres a chance???? LOL
Quote the movie????
Mazdaspeed
 Old 01-04-2011, 10:42 PM   #30
zx2man's Avatar
Posts: 1,356   (View Stats)
zx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the world
Quote the movie????
Dumb&Dumber
So How many maps are you running Anthony? I thought you were @20 psi last time I checked, How does Tim feel with e85 on this car?
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO*
zx2man is offline
 Old 01-04-2011, 10:48 PM   #31
driver311's Avatar
He doesnt know lol. I have 3 maps. I just posted two vids of me at 18psi and 19psi. I can set me boost where ever I want. My tune allows me to put my boost where ever I want with my mbc and its dialed in.
Mazdaspeed
 Old 01-04-2011, 11:46 PM   #32
zx2man's Avatar
Haha...Yeah Father Tim tends to be a conservative man,only because he cares about his customer's cars alot. But sometimes I feel like he is overly conservative with the ms3/6 platform.
nice to see you trying new things There is shell station near by with e-85, might have to give it a shot.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
zx2man is offline
 Old 01-13-2011, 08:27 AM   #33
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
what kinda MBC do you use ?
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
jracer is offline
 Old 01-13-2011, 09:15 PM   #34
driver311's Avatar
Turbosmart but looking to experiment with hallman pro. My car didnt have any spikes when temps were above 50 degrees but now that its cold it spikes a few when i shift. I doubt the hallman will fix that. Its just the nature of the beast(cold weather)
Mazdaspeed
 Old 01-04-2011, 11:35 PM   #35
gonads and strife
Matt's Avatar
Apparently there's already some guy in Everette WA that's running 100% E85 at 26.5 PSI on stock internals. He lists his mods as "CS FMIC kit / Turbosmart - BOV , Eboost Street 40 EBC , ProGate 50 EWG / DNP header / CS power catless exhaust w/ a straight cutout in the race pipe / GT3076R / CP-e - Standback 2 , Profuel / Walbro 255 x2 / HKS twin power ignition / water meth kit / SS braided fuel line."
I asked him if he's adding lubricant to the fuel, but he doesn't have very much info yet. He's having MSP in Arlington WA (Subie shop) build the car while he's deployed in Iraq.
Matt is offline
 Old 01-13-2011, 08:19 AM   #36
Tripple OG
NJSPEED3's Avatar
Groans: 113
Anthony any updates homie?
NJSPEED3 is offline
 Old 01-13-2011, 09:09 PM   #37
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
For what its worth, I added two gallons of e85 with a tank of regular gas, and a bit of marvels oil, and the car is just as slow as ever.
madvillain is offline
 Old 01-13-2011, 10:34 PM   #38
Matrix311's Avatar
Posts: 2,133   (View Stats)
shit not my car man. I put 3 gallons of e85 in and the rest 91 and after about 25 miles my shit was crazy fast. Not to mention I got 0 knock while monitoring on the AP. I rarely got any knock the entire take of gas. I'll put more e85 in again at some point. You just need your shit tuned ASAP and you wont be slow no moooooo
Matrix311 is offline
 Old 01-13-2011, 10:42 PM   #39
driver311's Avatar
Thats crazy cause I kinda felt the same way. Just putting 3 gallons in my take the car felt faster and logs showed some gains and this was vs running 93octane with 10%ethanol already.
Mazdaspeed
 Old 01-13-2011, 09:13 PM   #40
driver311's Avatar
Thats what Im talking bout. Thanks for breaking it down. The shits legit for real. Just takes more than internet racers to know that. LOL
My first tank was 2.5 gallons and no issues. This tank was 3 gallons and car runs just as good. Next tank will be 3.5 gallons. im gonna slowly work my way up and make adjustments as needed. But thus far none have been needed. Car is just straight up ripping.
Mazdaspeed
My second attempt on a Datalog. ARES28 MazdaSpeed 3/6 - ECU Computer Tuning 9 03-30-2012 06:04 AM
1st attempt at vd tooslow10 2010 MS3 - ECU Computer Tuning 5 01-13-2012 05:25 AM
Drivers attempt at E85 driver311 MazdaSpeed 3/6 - Big Turbo Builds 448 09-29-2011 07:21 AM
British study suggests that older drivers are safer drivers Haltech Automotive News 0 05-01-2008 05:50 AM
Page generated in 0.76400 seconds with 37 queries
