> MSF KB - Mazdaspeed 3/6 - Engine/Turbo Builds
Like Tree3Likes
 Old 09-14-2011, 10:07 PM   #41
racingred's Avatar
Posts: 154   (View Stats)
racingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond repute
Nice write Ziggo....I hope to be following this one day....Any subtle differences in drivability that you notice thus far over the K04?
2008 MAZDASPEED 3 METRO GREY SOLD
2009 BMW 335i STOCK FOR NOW
racingred is offline
 Old 09-15-2011, 07:05 AM   #42
Ziggo's Avatar
Posts: 3,843   (View Stats)
Not really, it doesn't spool as fast as the k04, it's just a gnats ass slower and drivability is just fine. It won't spool if you floor it at 2k rpm but that's not a minus in my book. My wife bitches about it, says it feels slower than the stock turbo, but thats because she refuses to downshift cause "it makes the engine make too much noise."
Zigatapatalka
Gitcherex likes this.
Ask Me About My:
Ziggo is offline
 Old 09-15-2011, 06:41 PM   #43
racingred's Avatar
Apparently with a little more funds you can get other turbos but this is the one I have my eyes set on...Big turbo but keeping stock location, manifold, my stock appearance, etc. seems to peak my interest.
 Old 09-17-2011, 02:22 AM   #44
Dahouse702's Avatar
Posts: 487   (View Stats)
Dahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the world
Great write up.
2007 MS3 Black Mica-Totaled @98500 on 09/2014
Current Car...
2009 MS3 Black Mica GT JBR TRU 3.0 Widepath full intake, BNR S3 v1, GS EBCS, 3 BAR , Forge BPV V2, Autotech internals , Denso Itv22, CNT Downpipe, CX-Racing piping with Cobb v2 core, Cobb AP v2, JBR RMM, JBR PMM, JBR TMM, JBR Oil Catch Can, EGR Delete, JBR TIG, Toyota Seals, HTP battery tray, DashHAWK
Zoom Zoom
Dahouse702 is offline
 Old 09-17-2011, 04:17 PM   #45
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Awesome write up.
Love this turbo...
cld12pk2go is offline
 Old 09-24-2011, 08:43 AM   #46
Eth/Meth Junkie
cld12pk2go's Avatar
I am going to forgo writing the EGT install portion as it doesn't really belong here and will require quite a different toolset. I am considering this done, if anyone has any comments let me know. Its the first time I have done anything like this so I bet there are easier ways to do much of it.
I would be very interested in the EGT install info...
 Old 09-25-2011, 04:17 PM   #47
Ziggo's Avatar
Step 1: Install EGT
Lol, just PM me any questions you have. Its really pretty simple. My Bung location sucks, but puts the probe right in the middle of the collector. I ran the leads from the probe thru the hole in the firewall for the hood release. There are plenty of gauge install threads, I put mine in the vent pod, and used the 12V, ground & headlight switch harness I made for my oil pressure and temperature gauges.
Ask Me About My:
Ziggo is offline
 Old 09-25-2011, 04:18 PM   #48
Step 1: Install EGT
Lol, just PM me any questions you have. Its really pretty simple. My Bung location sucks, but puts the probe right in the middle of the collector. I ran the leads from the probe thru the hole in the firewall for the hood release. There are plenty of gauge install threads, I put mine in the vent pod, and used the 12V, ground & headlight harness I made for my oil pressure and temperature gauges.
A heads up on the lean spool condition...
Check out Bucker and Blakkat's threads for some strange LTFT breakpoint talk.
rfinkle2 is offline
 Old 09-26-2011, 05:50 AM   #49
Eth/Meth Junkie
cld12pk2go's Avatar
Step 1: Install EGT
What is poor about your bung placement (center of collector sounds good?) and where would you put it if you had to do it again?
 Old 09-26-2011, 06:44 AM   #50
Ziggo's Avatar
I will grab a picture of it later. Its sticking out of the manifold directly towards the firewall so I had to cut a slit for it in that heatshield.
As for where I would do it with another shot, I would have it stick out at an angle between where it is, and straight out the turbine side. Straight out the turbine side would be best, but the #4 runner makes that weld difficult to access.
Zigatapatalka
Ask Me About My:
Ziggo is offline
 Old 09-26-2011, 05:37 PM   #51
Ziggo's Avatar
Here is a picture of it, you can see how I had to cut a slit in my heatshield so the sensor will have room to move with the engine. If you were to move it towards the 02 sensor more you could avoid this.
You can see the uninstalled bung location in this picture:
Looking at it, the best EGT Bung location is pointing straight towards the compressor side of the turbo. I was worried about spacing to the compressor housing outlet (I didn't have my turbo yet when I specified the bung location) so I didn't put it over there, but there is plenty of room.
Ask Me About My:
Ziggo is offline
 Old 09-26-2011, 09:48 PM   #52
Eth/Meth Junkie
cld12pk2go's Avatar
What EGT's are you seeing?
 Old 09-27-2011, 05:58 AM   #53
Ziggo's Avatar
@22psi, redline, 8* timing and 11.3 AFR I was seeing 1750, at 20.5psi, 10.5* timing it's more like 1700.
E85/Meth is in my future, from my tuning thread you can see BATs are getting out of hand, causing knock on the top end. I may have a leaky BPV though.
Zigatapatalka
Ask Me About My:
Ziggo is offline
 Old 09-27-2011, 05:22 PM   #54
Eth/Meth Junkie
cld12pk2go's Avatar
I have added ~6° over the past couple of months. It is a shame I don't have EGT data to note the impact.
 Old 10-04-2011, 04:35 PM   #55
Domino81's Avatar
Posts: 5,081   (View Stats)
Good work and thanks for the write up. :tup:
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
Domino81 is offline
 Old 10-04-2011, 04:44 PM   #56
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
das turbo
forcedinduktion is offline
 Old 10-27-2011, 04:48 PM   #57
driver311's Avatar
Posts: 1,769   (View Stats)
Give us some updates chief. Logs, VD, etc etc
Mazdaspeed
driver311 is offline
 Old 10-27-2011, 06:06 PM   #58
Ziggo's Avatar
As you saw I have not updated this thread or the tuning one recently. I found that premium gas was not up to snuff @ 22psi so I have been using a 3/9 mix of ethanol. I will post logs in the tuning thread, but leave this here. Initial torque "bulge" was due to a slight downhill at the start of the log. Tuned using load with a 22psi boot (cap) that results in a flat 400wtq curve. You can see it spools slightly before 3000RPM and between the extra timing from ethanol, and the VVT changes I made, throttle is VERY responsive.
Ask Me About My:
Ziggo is offline
 Old 10-27-2011, 06:14 PM   #59
IMO, with the positive results that e-85 is getting, and the creep issues (and necessary adjustments *ahem*) of the gtx3071, this is an all around great option.
Thanks again for the thread Ziggo.
rfinkle2 is offline
 Old 10-27-2011, 06:44 PM   #60
Ziggo's Avatar
GTX3071 is a great turbo. But is "bolt-on" chops are not quite established. Plus you really need a new MAP sensor, big MAF, and meth/aux fueling to get the most out of it. It doesn't spool *much* slower than this one, ~500 rpms, but unless you are going to upgrade those other items, it doesn't make much sense. I don't trust meth as AUX fueling, and unless some magical solution arises before next march or so, (read injectors) I am going to be using this setup as a testbed for a proper PWM controlled secondary injection system.
This turbo is likley capable of maxing the stock maf if BATs are much below 80* so I will have to keep an eye on it.
Ask Me About My:
Ziggo is offline
 Old 11-05-2011, 05:37 AM   #61
G Sp33dy's Avatar
Posts: 337   (View Stats)
G Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the world
Groaned at 7 Times in 3 Posts
thanks again for this write-up mang. BNR s3 is currently en-route by tuesday, installed by thursday/friday/ saturday pending no hiccups in the removal/installation. lately this fucker has been fighting me on everything i do to it...
G Sp33dy is offline
 Old 11-05-2011, 06:01 AM   #62
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
MT seems to be a good way to go for the d.d. thanks for the great write up with your trials and tribs!
@Ziggo
Nator is what it does.
kritz is offline
 Old 11-05-2011, 05:32 PM   #63
KostasCX-7's Avatar
Posts: 125   (View Stats)
KostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond repute
Tomorrow Im going to swap mine. I hope everything goes well.
CX-7 2008 awd manual bnr s3
KostasCX-7 is offline
 Old 11-05-2011, 11:14 PM   #64
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Very nice write up Chris
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
Boosted Beluga is offline
 Old 11-08-2011, 02:42 AM   #65
paveltol's Avatar
Posts: 520   (View Stats)
paveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the world
Groaned at 23 Times in 2 Posts
Just FYI
I have a BNR S3 installed on my ms6 for more than 10k miles and it is very nice for a dd car. The car pulls pretty well and makes no smoke. My friend's Infiniti g37s stays behind in a traffic light race (I launch at 2-2,5k rpm).
With a very conservative tune it makes 300 hp at 1bar of boost and 91 octane instead of 93 stock. Later, with carillo rods installed, I'll try to push the limits of the setup of mods I have.
Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc..
paveltol is offline
 Old 11-08-2011, 11:32 PM   #66
KostasCX-7's Avatar
I had various problems with the swap of BNR3. First I couldnt approach underneath the turbo, oil drain line and bracket because it is the transfer case there. I did most of work from above.
Also at my stock turbo, the routing of the oil feed line is different than ms3/6. The metal line is embracing the stock compressor and I had to cut and fab this line. I used 6mm reinforced oil hose and double clamps.
Do you think is it a safe connection?
 Old 11-09-2011, 08:00 PM   #67
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Picture of custom oil feed line? Clamps aren't gonna cut it. You're talkin 95psi of oil pressure at red line. It's going to leak if it's just clamps. Maybe you can order an OEM feed line for an MS3/6 and if it doesn't bolt up, have a shop cut it in half and weld a -4AN fitting on it, then run a -4AN steel braided line to the turbo. You can use the factory feed banjo bolt but you'll need a -4AN banjo fitting.
2007 CTS-V - Trying to sell
bmylez is offline
 Old 11-10-2011, 12:44 AM   #68
KostasCX-7's Avatar
95psi oil pressure? This is high! Unfortunately I dont have clear pictures of the custom oil feed line here are some
The length of the oil hose is about 4 inches. I used 2 triple clamps to secure on the metal line.
Is it required the uninstallation of the alternator in order to remove the stock oil feed line?
 Old 11-10-2011, 01:01 PM   #69
bmylez's Avatar
Groans: 31
Interesting. I wonder if there is something in the way on the CX-7 to prevent the use of the regular oil feed line. Anyway, it's a really bad idea to use clamps with rubber hose for a high pressure line. It's going to leak. Yes, our motors hit about 95psi oil pressure at red line.
It is technically not necessary, but you would be an idiot not to remove the alternator to work on the stock oil line. Getting the alternator out really isn't that hard. You need a 14mm wrench for the belt tensioner and then I think 12mm socket for the alternator nuts. Just make sure you disconnect both connections from the alternator before trying to remove it.
bmylez is offline
 Old 11-15-2011, 06:28 AM   #70
G Sp33dy's Avatar
thanks to your write-up, my BNR swap went as smooth as two half drunk guys could do. only issue so far is I am only hitting 14psi with my OTS tune set at 19psi. I know I know, ATR right? I've got some reading to do...
G Sp33dy is offline
 Old 11-15-2011, 10:52 AM   #71
Navy_Mech2's Avatar
Posts: 484   (View Stats)
WGDC tables^^
KILLAH BUILT
Navy_Mech2 is offline
 Old 11-15-2011, 11:34 AM   #72
KostasCX-7's Avatar
For those who have the same problem than me I modified the stock oil feed line and I solved the issue.
 Old 11-16-2011, 12:00 AM   #73
G Sp33dy's Avatar
Originally Posted by Navy_Mech2 View Post
WGDC tables^^
LOL Yeaaaah. I'm pretty sure if I fuck with any tables besides the idle, this thing will barf rods all over I290 haha. Phate is working on it for me. I'm expecting issues, as I'm still using the OTS stg2 tune. Can't wait to dyno omgggg
G Sp33dy is offline
 Old 11-16-2011, 07:27 AM   #74
Domino81's Avatar
That's why when I do go BT I'm going to sit down with a tuner and have him walk me through it. Because I'd like to understand how to do this for myself.
Domino81 is offline
 Old 11-16-2011, 07:50 AM   #75
Navy_Mech2's Avatar
honestly its not that difficult. download and read through abilor's tuning guide and he explains everything pretty well. enough to where you can start tweaking and not be afraid of blowing shit up.
http://www.mazdaspeedforum.org/forum/foru...e-noobs-83959/
KILLAH BUILT
 Old 11-16-2011, 08:01 AM   #76
Domino81's Avatar
I learn SO much more and SO much easier with visual aid. I can gernally do anything if I've seen it done once.
Domino81 is offline
 Old 11-16-2011, 08:11 AM   #77
Navy_Mech2's Avatar
his guide has screen shots of ATR in it for help. its not just a bunch of words. if anything its a good read just for the knowlege in case something stupid goes wrong so you can fix it yourself and not have to wait on someone else to help you.
KILLAH BUILT
 Old 11-16-2011, 08:25 AM   #78
Domino81's Avatar
Will try.
Domino81 is offline
 Old 11-16-2011, 03:09 PM   #79
Navy_Mech2's Avatar
no problem man. let us know how it goes.
KILLAH BUILT
 Old 01-25-2012, 06:55 PM   #80
TexasSpeed3's Avatar
Posts: 1,996   (View Stats)
TexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the world
Groans: 273
subbed
2011 Black Mica - Daily
JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp
TexasSpeed3 is offline
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f626/bnr-s3-swap-how-125223/
Turbo ausbauen?? - Seite 2 This thread Refback 10-21-2014 02:18 AM
BNR S3 Swap How To Ziggo MazdaSpeed 3/6 - Big Turbo Builds 244 12-13-2016 09:07 PM
LSD Swap out Tomas MazdaSpeed 3 - How-To's 81 10-08-2012 09:16 PM
BNR GTX Swap Possible? Kydizzle MazdaSpeed 3/6 - Turbo Induction 12 03-28-2012 12:24 PM
HID swap TXspeed3 MazdaSpeed 3/6 - Appearance 19 06-28-2009 05:04 PM
Page generated in 0.56771 seconds with 36 queries
