Tunes now bundled with the 3 Port Solenoid and Guardian Angel Just updated the products on the site as promised to make one stop shopping easier and save you guys a few $$ for the support. When you purchase a Stratified Tune you can now choose to also buy a 3 Port EBCV or a Guardian Angel at a discount from listed price! |
what if we want both the GA and the EBCS with the tune? any more-special discount? :) |
Does the GA work with a synapse bpv? |
Quote:
Quote:
Synapse can be configured in push or pull, that is correct. To quote an old thread... "Push vs. Pull mode - The Diverter Valve can be configured to run in either "Push" or "Pull" mode. In speaking with David from Synapse, he says Push mode is not recommended for high boost installations where the boost pressure could force the piston open resulting in a boost leak. "Pull" mode is recommended because as boost increases, it exerts more force onto the piston, making the seal even tighter. " |
What would be considered as '' high ''? |
20-21 psi...as this is right around where the factory push configured valve tends to have issues...that's how I personally would determine high when running this valve. |
| All times are GMT -7. The time now is 02:35 AM. |
