| Stratified Automotive Controls We offer Vehicle Specific Street, Remote E-tuning, Dyno Services for Mazdaspeed 3 and Mazdaspeed 6 vehicles using the COBB AccessPort and VersaTuner. We specialize in control systems, engine management, instrumentation and turbocharging and offer a variety of products and services, from standalone ECUs to build-consulting services. |
(Thread Starter) | Not Ranked : 0 score ![]()
| The Following 9 Users Say Thank You to Lex For This Useful Post: | Dimenus (02-13-2013), exentix (12-15-2012), Menace1 (01-31-2013), Mike@Stratified (12-15-2012), MS6 Sanchez (04-28-2013), NoRegrets (04-24-2013), obijack (04-24-2013), Pointless (12-15-2012), snailD (04-24-2013) |
![]() Join Date: Aug 2012 Location: Bellevue, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
| Not Ranked : 0 score what if we want both the GA and the EBCS with the tune? any more-special discount?
__________________ 2011 Black Mica MazdaSPEED3 // CS SRI // CS TIP // HKS SSQV-IV VTA w/ CP-E flange // CP-E FMIC // CP-E Triton CBE // CP-E Catted DP // CP-E HPFP // CP-E Stage 2 RMM // COBB AP With Lex Tunes // JBR SSP // JBR 88DM TMM //JBR 80DM PMM // JBR custom cylindrical shift knob // JBR SSB's // Rally Armor Mudflaps // ISC Coilovers and front end links // Denso ITV-22's // SPC Camber Arms // Michelin Pilot SuperSports // STRATIFIED LEX TUNED FTMFW Mustang Dyno Results: 301WHP 334WTQ on 35% E85 282WHP 325WTQ on 92oct |
| The Following User Says Thank You to Sum1UDidntC For This Useful Post: | Lex (04-24-2013) |
![]() Join Date: Nov 2009 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
| Not Ranked : 0 score Does the GA work with a synapse bpv? |
| The Following User Says Thank You to cletusb For This Useful Post: | Lex (04-24-2013) |
(Thread Starter) | Not Ranked : 0 score From what I saw, the Synapse is not a push type valve. It is similar to the HKS which does not work unfortunately due to the valve design.
| The Following User Says Thank You to cletusb For This Useful Post: | Lex (04-28-2013) |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score Synapse can be configured in push or pull, that is correct. To quote an old thread... "Push vs. Pull mode - The Diverter Valve can be configured to run in either "Push" or "Pull" mode. In speaking with David from Synapse, he says Push mode is not recommended for high boost installations where the boost pressure could force the piston open resulting in a boost leak. "Pull" mode is recommended because as boost increases, it exerts more force onto the piston, making the seal even tighter. "
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
| Not Ranked : 0 score What would be considered as '' high ''? |
| Not Ranked : 0 score 20-21 psi...as this is right around where the factory push configured valve tends to have issues...that's how I personally would determine high when running this valve.
| Guardian Angel VTA...how? | iammike | 2010 MS3 - Engine, Transmission & Driveline | 21 | 11-23-2012 12:41 AM |
| A Guardian Angel Looking Over Me...... | Novej | Stratified Automotive Controls | 3 | 09-07-2012 05:22 PM |
| Guardian Angel help? | MS6FL | Mazdaspeed3/6 General Discussion | 2 | 04-28-2012 07:13 PM |
| How-To Install Guardian Angel | Dano | Stratified Automotive Controls | 5 | 03-31-2012 03:04 PM |
| Guardian Angel Install | the_rolex_guy | Stratified Automotive Controls | 7 | 03-25-2012 06:03 AM |
