| Ford Focus ST Ecoboost - General Discussion Discussion of Ford Ecoboost Engines |
![]() | | #41 | ![]() |
![]() Join Date: Feb 2010 Location: Lynn, MA
Rep Power: 3402 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,058
Groans: 76
Groaned at 22 Times in 20 Posts
| Not Ranked : 0 score
__________________ 2006 Mazdaspeed 6 BNR S4 and supporting mods 2007 Mazdaspeed 3 Bolt on's and tune 2015 Taurus S.H.O Intake/Tune 2016 Ford Explorer Sport Stock |
![]() | | #42 | ![]() |
Groans: 370
| Not Ranked : 0 score 13.6, yes you need a BT at a minimum to hit those kind of times on da speeds. |
| The Following User Says NO Thank You to aaronc7 For This Un-useful Post: | Neverlift (08-07-2014) |
![]() | | #43 | ![]() |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score No you don't.
__________________ 3rd rebuild on the way...maybe... |
| The Following User Says Thank You to Cheapspeed For This Useful Post: | Cevaes_64 (08-07-2014) |
![]() | | #44 | ![]() |
![]() Join Date: Apr 2012
| Not Ranked : 0 score It almost makes sense to just go big BT first. $2k on bolt-on ATP kit + tuning will put you at around 320 hp. You have to tune to get any meaningful benefits out of any of the other upgradse anyway and the stock fuel system is robust enough to handle it. |
![]() | | #45 | ![]() |
Groans: 370
![]() | | #46 | ![]() |
| Not Ranked : 0 score Won't dispute that i have had about as many trips to the track as you have fingers in the past year. No skill. But my car doesn't need more power to achieve faster times. @Smelson; broke 12's on k04 with similar mods.
![]() | | #47 | ![]() |
Groans: 370
![]() | | #48 | ![]() |
Practice, weight reduction, and track tune would be the other.
__________________ 3rd rebuild on the way...maybe... | |
![]() | | #49 | ![]() |
| Fux Wit It ![]() ![]() Join Date: Mar 2008 Location: Li
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,795
Groans: 175
| Not Ranked : 0 score The old man is getting soft like a flaccid penis
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous |
![]() | | #50 | ![]() |
| Not Ranked : 0 score Nator AZ has a member flirting with 12s stock turbo on street tires.
__________________ |
![]() | | #51 | ![]() |
![]() | | #52 | ![]() |
Groans: 76
__________________ 2006 Mazdaspeed 6 BNR S4 and supporting mods 2007 Mazdaspeed 3 Bolt on's and tune 2015 Taurus S.H.O Intake/Tune 2016 Ford Explorer Sport Stock | |
![]() | | #53 | ![]() |
| Not Ranked : 0 score Stock turbo MS3 that got 11:97 https://www.youtube.com/watch?v=l-f-DTAS0Sg |
| The Following User Says Thank You to lug For This Useful Post: | Neverlift (08-07-2014) |
![]() | | #54 | ![]() |
![]() Join Date: May 2012 Location: fontana, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 893
Groans: 68
Groaned at 62 Times in 29 Posts
| Not Ranked : 0 score Here at the auto club speedway in Fontana DA is always 2500+ no track prep and at a slight incline i see bolted/tuned ST's run mid 14s. The quickest one ran a 13.6 @ 106 on a GT28, not that impressive if you ask me.
__________________ [SIGPIC][/SIGPIC]2012 Black Mica JBR WP intake// JBR RMM 80 duro// JBR Heavy knob// JBR Boost tubes + Recirc Hose// JBR Spacers// ETS Tmic// UR catless Dp// UR catless Tp// Custom 3in Catback// Go Fast Bits BOV 50/50// Autotechs// NGK one step colder// Megan Coilovers 324whp 368tq Vdyno CF 1.01 268whp 300tq AWD Mustang Dyno 3 GAL. E85 mix STRATIFIED 13.10 @ 108.1 (Nt05's) Auto Club Speedway |
![]() | | #55 | ![]() |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score I recall a stock MS3 running a 13.8-9 back in the day @ Fontana. It was a red Gen1, and some total faggot who can't drive named Philly did the run.
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
| The Following User Says Thank You to Neverlift For This Useful Post: | predapio (08-07-2014) |
![]() | | #56 | ![]() |
Groans: 76
| Not Ranked : 0 score I'm .5 seconds behind you with about 20% the mods you have.... lol What I have noticed that most ST drivers are awful drivers. Most of them are coming from old focus or svt and its their legit first "fast" car.
![]() | | #57 | ![]() |
Groans: 68
Stock 5.0's run 13.5's out here! Sorry to burst your bubble but you would have a 14+ second car out here.... HAHAHAHAHAHa........... And as far as driver mod is concerned how do you explain a BT ST trapping 106?????? The more you spin the higher you trap! SLOW = SLOW
__________________ [SIGPIC][/SIGPIC]2012 Black Mica JBR WP intake// JBR RMM 80 duro// JBR Heavy knob// JBR Boost tubes + Recirc Hose// JBR Spacers// ETS Tmic// UR catless Dp// UR catless Tp// Custom 3in Catback// Go Fast Bits BOV 50/50// Autotechs// NGK one step colder// Megan Coilovers 324whp 368tq Vdyno CF 1.01 268whp 300tq AWD Mustang Dyno 3 GAL. E85 mix STRATIFIED 13.10 @ 108.1 (Nt05's) Auto Club Speedway | |
![]() | | #58 | ![]() |
Edit: DA at my track here is almost always 5kft +
__________________ | |
![]() | | #59 | ![]() |
![]() Join Date: Oct 2013 Location: Lehigh Acres, Fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
Damn after I hit post I was yours lol @Enki;
__________________ 2013 CWP Mazdaspeed3 Bnr S3 v2//Cobb AP//Autotech internals//3 BAR MAP sensor//3 port EBCS//CNT catback//Ebay catless DP//Tr8 core with cxracing piping kit//Hks bpv//Jbr True 3.5" intake//Jbr ssp//Jbr shift knob//Jbr Trilogy//XXR 527 habanero 18x8.75 +35//H&R springs//385/370 AWD mustang dyno Last edited by joeyspeed3; 08-07-2014 at 12:25 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #60 | ![]() |
Groans: 76
![]() | | #61 | ![]() |
![]() Join Date: Jun 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,747
| Not Ranked : 0 score I have a buddy here that has went 12.9's on factory tires. @Livingframe; Believe he has cut numerous 1.9 sixties, so he is well above the norm for street tire guys.
__________________ 2013 CWP - HPFP - 80d RMM - 3.5" INTAKE - CAT LESS EXTENDED DOWN PIPE - 3PORT - METH/WATER INJ D03 [SIGPIC][/SIGPIC] First 11 sec stock turbo MS3: 1.688, 7.676 @ 91.71 11.977 @ 113.85 |
| The Following User Says Thank You to MZRSPEED For This Useful Post: | BigJimMs3 (08-07-2014) |
![]() | | #62 | ![]() |
Groans: 76
| The Following User Says Thank You to BigJimMs3 For This Useful Post: | MZRSPEED (08-07-2014) |
| Report: Ford prepared for slow sales with Focus Electric | Haltech | Automotive News | 0 | 04-19-2012 11:40 AM |
| DASHHAWK IS A TURD | johnsonroda27 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 9 | 05-13-2009 09:38 PM |
