![]() Join Date: Jan 2015 Location: Holden Louisiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 182
__________________ 2012 MS3 VRM/w Tech Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom 1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather Plugs-NGK LTR7IX-11(6510) Oil-RP 10/30 Tires-235 40 18 Federal 595 rsrr Brakes-EBC Yellow pads with ATE 200 fluid Check out my wheelwell page here. If your a member hit me up. https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/ Last edited by voodoo2crue; 02-26-2016 at 10:07 PM. Reason: Fail |
| The Following 2 Users Say Thank You to voodoo2crue For This Useful Post: | Boost_creep (03-08-2016), KiwiFlavor (02-26-2016) |
![]() Join Date: Mar 2012
Rep Power: 0 ![]() Thanks: 5
| Not Ranked : 0 score good score |
![]() Join Date: Nov 2011 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,624
Groans: 63
| Not Ranked : 0 score you can pick up a full set of OEM wheels for ~$300. Unless your other 3 are absolutely perfect I wouldn't spend that on one when so many sets are available for not much more
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." |
![]() Join Date: May 2013 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,449
OP, rim looks good though. I always approach Ebay stuff with caution but looks like this was legit.
__________________ 2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017 2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned 2004 Yamaha R6 - Micron Ricer Pipe / PC 2005 Honda CBR 600 F4i - R.I.P. 10/29/13 | |
![]() Join Date: May 2013 Location: Santa Cruz, Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
| Not Ranked : 0 score For that 200 bucks you could have just had your rim fixed. I'll bet the one you bought looked just like your bent one at some point. Maybe have it fixed as a back-up? https://www.google.com/?gws_rd=ssl#q...r+pennsylvania The new one looks nice and clean though!
__________________ '93 RX-7: 100% CARB approved. Just some wheels and stuff. ![]() '03.5 Mazdaspeed Protege: Custom clunk and turkey call. '12 4Runner Limited: Hollister Hills pinstripes, dog hair, beach sand, melted surf wax, a few french fries under the seat... |
![]() Join Date: Nov 2010 Location: Chatsworth, CA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score How well does the color match your original wheels? |
(Thread Starter) | Not Ranked : 0 score The new rim matches perfect and was flawless. My other wheels are in great shape so there wasn't no reason for me to buy a whole set. I'd say if someone has good wheels and one gets bent this would be a great option to get a like new wheel for just under 200$. They also included a pre payed shipping label to send the old one back and get 20$ credit if it was in good enough shape to use, so that would bring the total to 170$ after that credit. I elected to keep my bent wheel in my shed. Like someone above said though, if all of your wheels look like crap finding a new set locally if possible would probably be the best option.
__________________ 2012 MS3 VRM/w Tech Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom 1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather Plugs-NGK LTR7IX-11(6510) Oil-RP 10/30 Tires-235 40 18 Federal 595 rsrr Brakes-EBC Yellow pads with ATE 200 fluid Check out my wheelwell page here. If your a member hit me up. https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/ |
| The Following User Says Thank You to voodoo2crue For This Useful Post: | J.Dy (03-07-2016) |
(Thread Starter) | Not Ranked : 0 score It's been over a year and wanted to come back and give a short review on them. I put this wheel on in march of 2016 and it's holding up great. The finish is still as good as it was in the above photos and the wheel still doesn't have 1 chip on it. So, for a person like me that likes the stock wheel and may have messed 1 up I'd say this could be a good option.
| The Following User Says Thank You to voodoo2crue For This Useful Post: | BlueDreams (01-28-2019) |
| Refurbished OEM wheels | Neuspeed | Appearance - RED | 4 | 02-18-2013 09:24 PM |
| Report: No all-wheel drive option in sight for 2014 Chevrolet Impala | Haltech | Automotive News | 0 | 04-06-2012 02:00 PM |
| Refurbished iMac 20 $999 | Haltech | Hot Deals Section | 0 | 04-01-2008 10:00 AM |
