> 2010 MS3 - Appearance > Exterior
 Old 01-28-2010, 07:23 PM   #1
ILoveSpeed's Avatar
Posts: 114   (View Stats)
ILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond repute
Groaned at 24 Times in 4 Posts
Default HID installation....HELP!
Ok, so I just bought a HID kit and have no clue where to begin and I know others have discussed this before but I need help knowing exactly what I need to do first. How do I remove the old bulbs? I looked at the stock setup last night and it looked complicated. Please help!
2010 Celestial Blue Speed3, Corksport SRI w/TIH, Ultimate Racing CBE w/Ti. tips, DDM 6k HID Lows, Cobb AP, AutoTech Internals
ILoveSpeed is offline   Reply With Quote
 Old 01-28-2010, 08:35 PM   #2
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groaned at 72 Times in 51 Posts
its in ur manual.
JS + MS3 is offline   Reply With Quote
 Old 01-29-2010, 08:49 PM   #3
ILoveSpeed's Avatar
I figured it out. No help needed.
 Old 02-10-2010, 07:40 AM   #4
harrae's Avatar
Posts: 25   (View Stats)
harrae will become famous soon enough
just wondering, when u guys installed your HID's did you have to take off the cover for it or did you guys drill bigger holes in the cover?
harrae is offline   Reply With Quote
 Old 02-10-2010, 08:13 AM   #5
mzdaspeed3's Avatar
Posts: 425   (View Stats)
mzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond repute
I didnt drill anything it was pretty easy man to tell you the truth.
mzdaspeed3 is offline   Reply With Quote
 Old 02-10-2010, 01:03 PM   #6
Dre
Dre's Avatar
Posts: 1,651   (View Stats)
Dre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the world
Groans: 48
Groaned at 16 Times in 14 Posts
I over thought my install at first.. It came with the wires for the fuses and i was like "wtf??? they said this shit was gonna be easy.." .. after about 30 minutes i realized i didnt need that fucking thing and that the hardest part was tucking the wires so they couldnt be seen that easily.. looks pretty sharp.. just wish i could tick the headlight angle up a couple of degrees.. they shoot straight into the ground like yosemite sam..
"Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is."
-TTT
Dre is offline   Reply With Quote
 Old 02-10-2010, 01:20 PM   #7
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
you could try silicone caulk to angle things in the direction you want it to go. i've never tried this, but it's worth a shot, since you shouldn't need to angle things much to change it enough to be livable.
Sacrilicious is offline   Reply With Quote
The Following User Says Thank You to Sacrilicious For This Useful Post:
Dre (02-11-2010)
 Old 02-11-2010, 04:29 AM   #8
Dre
Dre's Avatar
Groans: 48
you spelled caulk wrong sac
-TTT
 Old 02-11-2010, 09:37 AM   #9
pewpew
maybe i spelled it wrong for YOUR needs...
 Old 02-11-2010, 09:41 AM   #10
06spped6's Avatar
Posts: 161   (View Stats)
06spped6 is the leader of the world06spped6 is the leader of the world06spped6 is the leader of the world06spped6 is the leader of the world06spped6 is the leader of the world06spped6 is the leader of the world06spped6 is the leader of the world06spped6 is the leader of the world06spped6 is the leader of the world06spped6 is the leader of the world06spped6 is the leader of the world
So when you upgrade your hids do you have to buy a kit or can you just change bulbs?
MazdaSpeed6
Cobb CAI : Cobb AP Stage 2 91 : Denso ITV-22 : SU TMIC : SU Testpipe : TS Dualport Bov : SU Boost Tubes : H&R Lowering Springs : Riax 18x9 Wheels : Escta ASX 225/45/18 Still To Come : DevilsOwn Meth Kit : GS BCS
06spped6 is offline   Reply With Quote
 Old 02-11-2010, 10:19 AM   #11
Hank3's Avatar
Posts: 516   (View Stats)
Hank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the world
You'll need an entire kit (bulbs, ballasts, plug-n-play wires).
5% off Redline leather goodies HERE. Pics of them installed in my Speed3 HERE.
Hank3 is offline   Reply With Quote
 Old 03-02-2010, 10:43 AM   #12
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
BlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the world
Groaned at 32 Times in 11 Posts
actually i have talked to HID sellers before about upgrading to a different K rating and they said all you need is the bulb the ballast doesn't really do anything but help supply the power to the bulb or something like that. the bulb is where the main k rating and all that jazz is at.. who knows though other HID manufacturers may say different to try to get more money out of you
BlueDmnSpeed is offline   Reply With Quote
 Old 03-02-2010, 06:21 PM   #13
pewpew
a different K rating only means that you have a different colored light bulb. HID lights are not the same as regular incandescent lights. incandescents use a standard filament that gets toasted up until it starts glowing...much like your normal household light bulb. an HID light bulb is filled with vapor (xenon) and produces its light via an electric arc between two electrodes...much like street lamps. in order to pull off the arc, the electrodes need to have a massively high voltage difference between them (10s of thousands), which requires a ballast to pull off.
K rating really only tells you the color of the light. a real HID light, however, will give you 3x the light of a standard 55w incandescent headlight while only using 35w of power.
EDIT: now that i reread, it sounds like both hank3 and i read that 06spped6 was asking about upgrading TO an HID kit from stock incandescents, but bluedmnspeed read that he was asking how to "upgrade" already-HID stock lights to a different color. in that case, a different bulb would work.
CP-E SRI Installation Issues NightFlight 2010 MS3 - Turbo Induction 24 01-27-2010 05:12 AM
CPE HPFP installation Trader MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 10 10-22-2009 01:00 PM
Hid Installation help AmillieMS6 MazdaSpeed 3/6 - Car Audio & Electronics 7 04-05-2009 10:05 PM
H&R Coilover Installation Help JCMS07 MazdaSpeed 3/6 - Suspension & Brakes 23 11-29-2008 12:08 PM
MBC Installation How To Ghetto Mods MazdaSpeed 3/6 - Turbo Induction 6 04-25-2008 07:49 PM
Page generated in 0.32749 seconds with 28 queries
