> 2010 MS3 - Appearance > Exterior
 Old 02-16-2012, 12:56 PM   #1
Sigmabond's Avatar
Posts: 47   (View Stats)
Sigmabond is just really niceSigmabond is just really niceSigmabond is just really niceSigmabond is just really niceSigmabond is just really nice
Default Gen2 Tow Plate
What's up guys,
Just picked up my new 12 Speed3 about a month ago and decided to move from an old forum to here. Just picked up a CS SRI (installing on saturday) and a few other non-performance mods (led fogs, led interior lights, stubby, etc) and was wondering if anyone has a towplate on the gen2 speed and if you left the bumper piece off or cut a hole in it. CPE or CS? Any pictures would be appreciated.
Sigmabond is offline   Reply With Quote
 Old 02-16-2012, 01:06 PM   #2
bigriver's Avatar
Posts: 1,123   (View Stats)
bigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the world
Cs and i cut a hole with hole saw. Easy. Just use template.
2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. .
bigriver is offline   Reply With Quote
 Old 02-16-2012, 02:44 PM   #3
Sigmabond's Avatar
Do the bumper plugs look okay?
 Old 02-16-2012, 04:51 PM   #4
bigriver's Avatar
Yes because the plate hides the plug. This is better than not drilling the plug because you can see part of the tow hook hole which is not covered by the plate.
The template is not 100% accurate so you may have to use a dremel or similar tool to adjust the hole. Just do a little at a time. The plastic is soft and east to grind out.
 Old 02-16-2012, 07:15 PM   #5
silentwolf8's Avatar
Posts: 1,986   (View Stats)
silentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the world
Groans: 44
Cp-e bolted straight up.. no issues. took tow hole plug out and screwed right in. Thats an old picture but it shows the TP none the less
ZOOM ZOOM left the Room
2013 SPW STi // COBB SRI w/Box // COBB BPV // UR Catless DP// UR CBE // COBB Lowering Springs // COBB Sway Bars // +1 NGK // DW65c FP
AWDTuning Tuned
silentwolf8 is offline   Reply With Quote
 Old 02-23-2012, 04:17 PM   #6
MS_Driver's Avatar
Posts: 142   (View Stats)
MS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond repute
Groaned at 26 Times in 5 Posts
I got CP-E as well. Took off the plastic plug and didn't bother cutting a hole (figured I'd keep it in tact for whatever reason)
Nice thing about the CP-E is that you don't have to take the whole thing off and you can still put the tow hook on (although it sticks out like a joust)
2010 Black Mazdaspeed3 | DDM 6K HID lows and 3K fogs | 15% Tint | CP-E Tow plate | Corksport SRI + TIP | Corksport race pipe | Corksport RMM inserts | JBR SSP | JBR shift knob | Progress RSB | H&R springs | Enkei MM2 18x7.5 +38 | Katzkins full leather interior (done by me)
MS_Driver is offline   Reply With Quote
 Old 02-27-2012, 10:35 AM   #7
Grim_BL3FW's Avatar
Posts: 103   (View Stats)
Grim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond repute
I just ordered the CP-E one. I refuse to put holes in the front of my car and I might be moving to TN in the next few years. So i figured this will be the best $80 dollars I can spend.
Grim_BL3FW is offline   Reply With Quote
 Old 02-27-2012, 03:49 PM   #8
You can leave out the factory tow hook bolt cover with the installation of our kit. It is a personal preference to drill out the hole for the mounting bolt on our Lic kit.
-Derrick
Raider (02-27-2012)
 Old 02-27-2012, 04:20 PM   #9
bigriver's Avatar
-Derrick
I have the corksport kit and it works great. But, if you dont use the bolt cover, there is about 1/2" that is not concealed by the license plate. So for a "clean" appearance, it is mandatory to cut a hole in the cover using the current design. Maybe you guys can take another look at the relative position of the plate on the tow bolt and raise it up a little so it conceals the entire gap under the bolt hole cover.
 Old 03-22-2012, 10:02 PM   #10
ruthless013's Avatar
Posts: 603   (View Stats)
ruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the world
Originally Posted by MS_Driver View Post
wow.
really?
2010 Black Mica Mazdaspeed3
2009 Black Cherry CX-9 AWD
1997 Classic Red Miata
ruthless013 is offline   Reply With Quote
CS RSB on GEN2 ebnash 2010 MS3 - Suspension & Brakes 9 12-12-2010 11:50 AM
K&N Intake for gen2 Dfresh619 2010 MS3 - Turbo Induction 103 07-13-2010 07:38 PM
Page generated in 0.30745 seconds with 27 queries
