> HTP (Hi-Tuned Performance)
Like Tree3Likes
  • 1 Post By breakfstincluded
  • 1 Post By HTP
  • 1 Post By HTP
 Old 02-18-2013, 03:37 PM   #1
Speedie6's Avatar
Posts: 1,838   (View Stats)
Default My 3.5" intake isn't long enough for my Steedspeed manifold
Note that this is NOT HTP or Matt's fault. It is my fucking Steedspeed manifold. SS recommended their swept-back version of their manifold, saying it gives more room to work. Its must proved to be nothing but a PIA. In another thread I raised an issue about the intake hitting the shifter support bracket. For now, I've just removed the bracket, to do test fitment of the intake otherwise. And it seems I need to have the intake several inches longer. You can see it'll be a nice fit and nice setup when it is modified to fit.
But, for now, I can't use it. Again, this isn't Matt's fault. But I'll need to get it fixed.
The Following 2 Users Say Thank You to Speedie6 For This Useful Post:
Micha (02-18-2013), SPEED6 KILLAH (03-14-2013)
 Old 02-18-2013, 03:48 PM   #2
Micha's Avatar
Posts: 3,436   (View Stats)
That sucks man.
Not to rub it in but I hove my @HTP; 3.5 inch intake.
I am slow again.
I modded it a little.
 Old 02-18-2013, 07:45 PM   #3
HTP
HTP's Avatar
Posts: 210   (View Stats)
Give me a holla tomorrow and we'll figure out how to fix you up.
Matt
The Following 16 Users Say Thank You to HTP For This Useful Post:
802MS3 (02-18-2013), ABolewski (03-12-2013), breakfstincluded (02-18-2013), CtrlAlt1337 (02-20-2013), Dmurray06 (02-18-2013), Easter Bunny (02-18-2013), mazdafreak (10-28-2013), Menace1 (04-01-2013), Micha (02-20-2013), rfinkle2 (02-20-2013), robry (10-01-2013), silvapain (02-20-2013), smoogs12 (02-21-2013), speed23 (02-18-2013), Speedie6 (02-18-2013), uncorked11 (03-12-2013)
 Old 02-18-2013, 08:10 PM   #4
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
^ good service
I'm gonna buy the shit outta that meth tank
The Following 5 Users Say Thank You to breakfstincluded For This Useful Post:
ABolewski (03-12-2013), CtrlAlt1337 (02-20-2013), Dmurray06 (02-18-2013), Micha (02-20-2013), smoogs12 (02-21-2013)
 Old 02-18-2013, 08:16 PM   #5
Dmurray06's Avatar
Posts: 3,279   (View Stats)
^ good service
Shit I almost forgot about that.
 Old 02-19-2013, 09:13 AM   #6
Speedie6's Avatar
I talked to Matt. He said he made one for a Speed 3 with that manifold I got. He said he had to add four inches to it. He asked me to measure to double check. Once I measure, he'll make me a custom one.
The Following 6 Users Say Thank You to Speedie6 For This Useful Post:
CtrlAlt1337 (02-20-2013), kritz (02-20-2013), Menace1 (04-01-2013), Micha (02-20-2013), smoogs12 (02-21-2013), superskaterxes (02-19-2013)
 Old 02-20-2013, 07:10 AM   #7
Speedie6's Avatar
I measured it. 4" is correct. I'll post updated pics when I get the updated unit.
The Following 3 Users Say Thank You to Speedie6 For This Useful Post:
Jh8909 (02-20-2013), Micha (02-20-2013), Mr Wilson (02-20-2013)
 Old 03-11-2013, 09:30 AM   #8
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
2 weeks?
it's fun to do bad things
 Old 03-11-2013, 09:37 AM   #9
ccspeed3's Avatar
Posts: 561   (View Stats)
ccspeed3 is the leader of the worldccspeed3 is the leader of the worldccspeed3 is the leader of the worldccspeed3 is the leader of the worldccspeed3 is the leader of the worldccspeed3 is the leader of the worldccspeed3 is the leader of the worldccspeed3 is the leader of the worldccspeed3 is the leader of the worldccspeed3 is the leader of the worldccspeed3 is the leader of the world
Interested in out come of this becasue I will be putting on the same setup within a couple of weeks.
New - 2006 mazdaspeed 6 AP - INTAKE - RMM
Old - 2007 MS3 - PTE 5557 - Steedspeed manifold - Tial 38mm wastegate - Perm v-band downpipe - HTP 3" intake - Grimmspeed ebcs - CPE injector seals - SSP OCC - Treadstone TR10 - 3 bar map sensor - battery relocation
ccspeed3 is offline   Reply With Quote
 Old 03-12-2013, 08:35 PM   #10
Speedie6's Avatar
I was told that it would be around 2 weeks to get the updated intake. And, its been close to that. So, I should be getting it pretty soon.
 Old 03-12-2013, 09:03 PM   #11
HTP
HTP's Avatar
Your intake is done and will be rolling out the door. Hopefully this one does the trick for ya!
Matt
Jh8909 likes this.
The Following 5 Users Say Thank You to HTP For This Useful Post:
Hush (03-12-2013), Jh8909 (03-12-2013), KusteLokal (03-19-2013), mazdafreak (10-28-2013), Micha (11-03-2013)
 Old 03-25-2013, 08:11 PM   #12
Speedie6's Avatar
I received my intake. It is a very good quality piece! But now its a bit too long. I swear I measured it and the 4" looked right to me that was suggested. And, it would be fine as is, but, its too close to my CPE FMIC. Now, I figure that one of the next upgrades I will do is I will eventually need to replace that. But, the CPE is what I've got at least for now. I will post below some pictures that show it installed, and basically fitting. But, if the pipe was about 1.5" shorter, it would move the filter closer to the fuse box and have more room for the hot pipe of the FMIC.
I will of course pay to have it modified. Again. What I figure you will do is just take the one I got, cut out 1.5" and reweld it and refinish it. Here are the pics. And, FYI, the filter is a AFE Dryflow filter that I sourced myself.
 Old 03-29-2013, 11:41 AM   #13
HTP
HTP's Avatar
Please measure the distance from the filter to the fuse box. I don't wanna make it too short. If you noticed I put a different angle on the intake to point it more towards the headlight to try and clear your ic piping.
Also, maybe try rotating the intake upwards and see if that gives you any additional clearance.
Matt
Micha likes this.
Micha (03-31-2013), SLOWHATCH (04-01-2013), Speedie6 (04-01-2013)
 Old 04-01-2013, 07:29 PM   #14
Speedie6's Avatar
Here are some pics. The super close up looks only a bit over 2" but the others look about 3". In any case, I'm confident that 1.5" cut will be perfect. Here are the pics:
 Old 04-01-2013, 09:22 PM   #15
Speedie6's Avatar
Oh, and, I've taken the intake off. I'm putting back on my old intake for now.
 Old 10-28-2013, 10:14 AM   #16
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Just rotate the intake upwards a tad bit and itll clear the piping.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
GT2871R - Best manifold ? DNP, steedspeed or OBX AXELATNO MazdaSpeed 3/6 - Big Turbo Builds 29 05-09-2012 02:04 PM
steedspeed manifold mazda2011 2010 MS3 - Engine, Transmission & Driveline 8 10-24-2011 03:59 AM
steedspeed manifold ebay ms3boost MazdaSpeed 3/6 - Turbo Induction 4 05-25-2009 02:31 PM
Page generated in 0.37104 seconds with 27 queries
