| HTP (Hi-Tuned Performance) HTP (Hi-Tuned Performance) is dedicated to providing the automotive community with quality performance products and the highest level of customer service and support. Whether you're local or overseas, we like to approach each customer as though they're sitting right in front of us at the shop. Whether you're a long time customer or if you're new to HTP, we look forward to having the opportunity to prove our commitment to quality and service. |
![]() | | #161 | ![]() |
![]() Join Date: Mar 2012 Location: Cary NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score
__________________ 2010 - BMW 335i M-Sport - Lemans Blue Metallic 2005 - Kawasaki ZX-6R 636 - Magma Red |
![]() | | #162 | ![]() |
This is probably why people going from a Stock size MAF to the 3.5" are seeing pretty big gains. That's a jump of about .7", where as the jump from stock to 2.87" is only about .2". The MAF size isn't the only thing that matters here though. The whole entire intake is a larger diameter surely flows more than stock and most SRI+TIP combos. The MAF really only needs to be larger if you've maxed out your current MAF housing in terms of flow. Has anyone measured the ID of the SURE ID300? It is made from solid chunk of billet as far as I know, so it probably has an ID of 3.00".
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | |
| The Following User Says Thank You to sidekick For This Useful Post: | Dr. Speed (01-24-2013) |
![]() | | #163 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
| Not Ranked : 0 score They post the MAF housing being ID of 3" but it looks like everything behind it goes down to stock size.
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
![]() | | #164 | ![]() |
![]() Join Date: Apr 2012 Location: Barrie, Ontario, Canada
ImageUploadedByTapatalk1359080892.328000.jpg Tappin
__________________ [SIGPIC][/SIGPIC] 2007 Mazdaspeed 6 - Bolted, Methed, Tuned | |
| The Following User Says Thank You to DamagedGoods For This Useful Post: | Dr. Speed (01-24-2013) |
![]() | | #165 | ![]() |
| Not Ranked : 0 score Assuming the I.D. of the 3" HTP is 2.8", the area of the HTP housing is about 14% larger than stock. On the stock maf curve, that buys you about 45 g/s more mass airflow before pegging the maf sensor. (some rough assumptions made to arrive @ this #, but a good estimate). |
![]() | | #166 | ![]() |
| Not Ranked : 0 score Increasing the piping diameter all the way to the turbo will certainly help. There is no questioning that here. What is going on here however is that the MAF curve itself does not match other MAF curves in the voltage -> mass airflow relationship. Ideally you can scale any MAF housing to any other MAF housing by knowing both their diameters. All that the MAF sensor does is "sample" a part of the airstream. So the percentage that it samples is proportional to the cross sectional area of the pipe. When scaling an existing MAF table to the HTP intake (whether using 3" or 2.87" as the diameter) it becomes clear that the scaling factor is not the same across the board. This means that the voltage -> mass airflow relationship is different with these intakes and it is likely related to the honeycomb and pieces in place to hold it in like the glue and pipe bead. I am personally not a fan of hacking MAF curves too much on a vehicle simply because you can run yourself into tuning something really wacky that can backfire (tuning around a leak or some other issue). On top of this we get such few breakpoints in the car with trims acting all the time that it really is hacking up the curve in a piecewise fashion and this is where a lot of people have become stumped with this intake. However, if the curve has to be piecewise scaled, this can still be done as long as it is consistent from one intake to the next. This has not come out of the woodwork just yet because we don't know if people were having leaks or if it was the MAF cal - this is why I must go back on the importance of a solid MAF cal that is scalable because then you can properly diagnose other issues such as leaks. It would be good to hear back from HTP with some of their own in-house MAF cals so that we can compare and see if we find something that consistently works well on their intakes.
| The Following 9 Users Say Thank You to Lex For This Useful Post: | beachshoer (01-25-2013), faeker (01-25-2013), JDW1 (01-25-2013), magicka (01-25-2013), Mike@Stratified (01-25-2013), ms3blackmica (01-25-2013), rfinkle2 (01-25-2013), sidekick (01-25-2013), TiGraySpeed6 (01-25-2013) |
![]() | | #167 | ![]() |
Groans: 731
| Not Ranked : 0 score Sigh. Intake just arrived. Sad I cannot put it on. Hope this gets figured out soon. tappy-tap-tappytalk
![]() | | #168 | ![]() |
![]() Join Date: Nov 2009 Location: Pensacola FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 659
Why not? I've been going back and forth with Lex tuning my car with this intake and there's no reason why you can't run it. Im even racing with mine this weekend.
__________________ 2010 BM MS3 BNR S3 HTP 3" Intake(Granny Smith Green PC) CS RP Ebay DP Res Delete JBR shift kit Fully JBR mounted Turbosmart BPV DDM 6K Lows 3K fogs H&R Springs CS RSB CXRacing FMIC AT Internals DIY PnP IM w/ VTCS delete. CS OCC Stratified 3port EBCS HTP Batt Tray Bosch 3bar MAP SS brake lines Works emotions cr-kai 18x7.5 ventus v12s for the street TRM C3s 17x9 Hankook RS3s for track days ![]() STRATIFIED TUNED Other Mazdas in my stable 2010 VR MS3 Wifes Ride ETS TMIC JBR RSB JBR SSP JBR knob AT internals 1999 Miata gtx2867 1.9L VVT built like a brick shithouse 2001 Miata LS RB FSB Hawk HP+ pads Dunlop ZII | |
| The Following User Says Thank You to beachshoer For This Useful Post: | Lex (01-25-2013) |
![]() | | #169 | ![]() |
Groans: 731
| Not Ranked : 0 score My tune is being worked on as this plays out. I don't usually go full on with a part unless I know for sure I wont an issue. tappy-tap-tappytalk
| The Following User Says Thank You to faeker For This Useful Post: | rfinkle2 (01-25-2013) |
![]() | | #170 | ![]() |
I don't know the entire story (and respect Lex's decision), nor do I want to turn this into "tuner wars", but I asked Faeker to wait to install the intake until Godspeed7 gives me some data from his. | |
![]() | | #171 | ![]() |
| Not Ranked : 0 score I posted a beta CAL for the HTP 3" here if you want to try it or take a look. MAF calibrations for bigger intakes Rob, I've had quite a few cars that I've tuned with this intake and I am using data from several - both gen1 and gen2. If the datalogs look good (the due diligence is there) there's no reason to not drive the car.
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
![]() | | #172 | ![]() |
I sometimes feel as if I should put in the work rather than gank an maf curve from you. Seems a little "hackish" to me, but I guess I need to get over that. @faeker; if you'd like, I can insert Lex's values into your map and you can install your intake. 100% up to you. | |
![]() | | #173 | ![]() |
![]() Join Date: Sep 2011 Location: SCOTLAND
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 469
| Not Ranked : 0 score My Cpe nano intake measured in at 2.72" ID, my HTP tip measured 2.83" ID
__________________ Cpe tmic&sri, 3" HTP tip, 3" ebay downpipe, BNR stage1, Autotech internals, Snow stage 2 meth with Aqaumist jet/parts, GoFastBits Respons BOV, Grimmspeed ebcs 3-port, Turbinetech diff mount, Cpe diff brace, Whiteline rarb, Bilstein B8's, Eibach springs, NGK iridium IX plugs, Corksport Mods, JBR mods... 324whp 361lb/ft Tuned with by |
![]() | | #174 | ![]() |
![]() | | #175 | ![]() |
Groans: 731
| Not Ranked : 0 score Let's do it up rob. I'm down for guinea pigging today. tappy-tap-tappytalk
![]() | | #176 | ![]() |
| Not Ranked : 0 score @Lex; i remember you saying you had a curve that worked perfect on a BNR spd6 with this intake, but that same curve didnt work on a BNR spd3 or something like that. Are there drastic inconsistancies between different vehicles running these same intakes? Honey combs are not exactly rigid, they're quite fragile. Is it possible that the honey combs are getting bent / mishaped somehow during production / shipping / instillation, whichever and thats whats causing these weird readings since basically no two intakes would flow the same? for instance, say my intake has a perfect ideal honeycomb, and you base a maf cal off my car. You then take that same MAF cal and put it on someones car with janky fins, and their computer thinks they are getting more air flow than they actually are which explains why they're getting High g/s readings but not making the equivilant power?
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
![]() | | #177 | ![]() |
| Approved MSF Vendor ![]() Join Date: Dec 2010
Rep Power: 675 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
Since we outsource our tuning, and will not have him available to us until Monday, I need as much info from you as possible. Who are the customers that are having issues? I know of 3 that you are tuning (1 local to us), please PM me this. Since you say that there are inconsistencies between our intakes, I need to know exactly what data leads you to that conclusion (logs please) so that our tuner can address it. If there is a problem with one of our products, we want to get to the bottom of it immediately. On Monday we will be using our original test intake as well as several others from the shelf to verify whether there are any inconsistencies or not. This will take out the differences from one cars setup to another, and focus on the whether every intake is performing the same as it did during testing. Per my conversation with our tuner this morning, he scales the maf, then tunes any points that don't fall in line. He didn't have much time to talk since they have a subaru dyno day in full swing. Though, he said it was completely crazy to just scale across the board and expect for everything to be perfect, which I am sure you just aren't doing with your tunes. He also said that our intakes are reading the airflow differently due to the honeycomb and he adjusts the tunes accordingly. It was a lengthy process to dial in at first, but its not expected that this product will be a drop in. I will post up a calibration as soon as possible, and go one further. We will start posting all data from development from our products including dyno results (not virtual dyno). I await your pm. Matt | |
| The Following 12 Users Say Thank You to HTP For This Useful Post: | aldekei (01-25-2013), beachshoer (01-25-2013), Code Monkey (01-25-2013), faeker (01-25-2013), Hush (01-25-2013), Lex (01-25-2013), magicka (01-25-2013), memin (01-25-2013), ms3blackmica (01-25-2013), rfinkle2 (01-25-2013), sidekick (01-25-2013), speed_freak91 (01-26-2013) |
![]() | | #178 | ![]() |
![]() | | #179 | ![]() |
MAF calibrations for bigger intakes If you have your own MAF cal or want to use what I posted you can check for consistency (ie swap several intakes on the same car), learn trims, verify WOT if a gen1, then this would be a good check and something you can post. The consistency data is very important. Also be aware even the air filter will affect MAF calibration - especially at low airflow rates. Also, don't take this as a criticism. I am helping you and the users of these intakes have an easier time with the tune and install.
![]() | | #180 | ![]() |
![]() Join Date: Mar 2011 Location: Birmingham, Al
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 278
__________________ 07 Liquid Plat Silver W/BNR S3 ~325/340 Pump gas AlphaTuned. Parting out. 11 Mustang GT current. | ||
![]() | | #181 | ![]() |
![]() | | #182 | ![]() |
| Not Ranked : 0 score I know I can monitor it but I compared your beta scale to the one I revised and there was a good bit less g/s at the top of it and like I said, my WOT AFR's are already ~11.7 +/- .2.
![]() | | #183 | ![]() |
| Not Ranked : 0 score Wouldn't setting up a FTCL map be a pretty good way to figure something like this out? You'll be able to see trims for every breakpoint/MAF reading and adjust accordingly. It'll probably give us a better look into what is going on with this intake. Has anyone tried that yet?
| The Following User Says Thank You to sidekick For This Useful Post: | rfinkle2 (01-25-2013) |
![]() | | #184 | ![]() |
As soon as he gets me the data, I will be happy to post it. | |
![]() | | #185 | ![]() |
| Not Ranked : 0 score A European MS6 was spot on with those values at WOT and that's as close as I can get to your particular car/setup. Up to you if you want to try.
| The Following User Says Thank You to Lex For This Useful Post: | rfinkle2 (01-25-2013) |
![]() | | #186 | ![]() |
![]() Join Date: Jul 2010 Location: Rowland Heights, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 121
| Not Ranked : 0 score Hopefully it gets all sorted soon! Intake coming tomorrow |
| The Following User Says Thank You to fredricktsang For This Useful Post: | rfinkle2 (01-25-2013) |
![]() | | #187 | ![]() |
![]() Join Date: Nov 2011 Location: Minooka, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Tapatalk LIKE A BOSS!
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. | |
| The Following User Says Thank You to GODspeed7 For This Useful Post: | rfinkle2 (01-25-2013) |
![]() | | #188 | ![]() |
| Not Ranked : 0 score I'm going to be installing mine today, assuming it stops raining, so I'll post some logs later. I'll be using a MAF cal scaled for a 2.8" MAF housing, so hopefully that works out.
![]() | | #189 | ![]() |
![]() | | #190 | ![]() |
| Not Ranked : 0 score Just a little rush? Lol Tapatalk LIKE A BOSS!
![]() | | #191 | ![]() |
| Not Ranked : 0 score What is your starting MAF cal that you are scaling?
![]() | | #192 | ![]() |
Groans: 731
| Not Ranked : 0 score almost done installing mine. I'll load up the map after I'm done and get some miles on it. I'll post the logs I pull later today. FWIW, I'm sick as shit. I've been sick all week with what may have been the flu. It's also colder than my wife's shoulder today. I'm getting this done though because I want to lend a hand in regards to getting this intake calibration solid. I'm no tuner for sure, but I'll put some manual labor in to help get this right.
![]() | | #193 | ![]() |
| Not Ranked : 0 score I'll post it up when I get to my house. I'll post the scaled one as well.
![]() | | #194 | ![]() |
| Not Ranked : 0 score I don't know a whole lot about tuning but I have a 3.5" coming for my Pu next week. I have a test pipe plus the mods in my sig. Would I be safe to start off with the usual MAF CAL scaling process? If I can help in any way to get data for the 3.5" on a gen 2 let me know. ( Side note: I'm hoping to sign up for a Stratified Tune in a month or so, should I just wait to install the intake then?)
![]() | | #195 | ![]() |
Groans: 731
| Not Ranked : 0 score Well the weather did me in. It started snowing as I finished up the work. If the roads are clear tomorrow I'll get a couple logs done. tappy-tap-tappytalk
tappy-tap-tappytalk
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. Last edited by faeker; 01-25-2013 at 02:34 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 2 Users Say Thank You to faeker For This Useful Post: | jdmage_mx5 (01-25-2013), rfinkle2 (01-25-2013) |
![]() | | #196 | ![]() |
That isn't really true. You can throw it on and tune for it just like any other intake. It may take a little more work and require a little more caution, but it really isn't that big of a deal.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | ||
| The Following User Says Thank You to sidekick For This Useful Post: | jdmage_mx5 (01-25-2013) |
![]() | | #197 | ![]() |
Groans: 731
| Not Ranked : 0 score if it takes any work, then it's not plug and play. Cobb, Sure, CS, K&N all make intakes that are plug and play. When we have to tune for a bigger diameter, then it goes beyond the pnp namesake. Me personally, I love having to tune for my parts. It makes my car feel more personal. BTW, did you get your logs loaded up yet? I'm curious to see how things came out.
| The Following 3 Users Say Thank You to faeker For This Useful Post: |
![]() | | #198 | ![]() |
| Not Ranked : 0 score ^^^^What are your thoughts @Lex; about waiting until I start my tune or just dive in and watch my parameters as I go?
| The Following User Says Thank You to jdmage_mx5 For This Useful Post: | sidekick (01-25-2013) |
![]() | | #199 | ![]() |
| Not Ranked : 0 score FWIW, Smoogs12 is running a 4" version of this intake, which was easy enough to dial in. Personally, if you aren't self tuning, I would always wait to install a different diameter intake until the person creating your maps is ready. Changing the maf diameter and mass airflow readings has an effect on calculated load and of course, fueling in general. |
| The Following 4 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #200 | ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f579/intakes-now-available-134325/ | ||||
| JBR Wide path VS Cobb SRI+TIP? | This thread | Refback | 01-28-2013 08:55 AM | |
| Out of stock intakes!!!!!! | Toymachinespeed | 2010 MS3 - Turbo Induction | 26 | 07-30-2011 06:34 AM |
| CorkSport SRI Intakes | CorkSport | CorkSport | 3 | 08-04-2010 03:54 PM |
