| HTP (Hi-Tuned Performance) HTP (Hi-Tuned Performance) is dedicated to providing the automotive community with quality performance products and the highest level of customer service and support. Whether you're local or overseas, we like to approach each customer as though they're sitting right in front of us at the shop. Whether you're a long time customer or if you're new to HTP, we look forward to having the opportunity to prove our commitment to quality and service. |
![]() | | #121 | ![]() |
![]() Join Date: Mar 2011 Location: Birmingham, Al
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 278
| Not Ranked : 0 score
__________________ 07 Liquid Plat Silver W/BNR S3 ~325/340 Pump gas AlphaTuned. Parting out. 11 Mustang GT current. |
![]() | | #122 | ![]() |
| Not Ranked : 0 score Yup something is off and the strange thing is that different cars are off by different amounts. What is worse is that the higher the airflow the more off the curve becomes. Ugh. Sorry for the guys chasing boost leaks. We'll get this sorted.
![]() | | #123 | ![]() |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | GODspeed7 (01-24-2013) |
![]() | | #124 | ![]() |
| Not Ranked : 0 score I find it odd that at 20 psi and 93 octane alone you're running a Higher IDC than i was at 23 psi on 4 gallons of E85... i was barely in the Mid 80's at a 12.4 AFR, but you're seeing over 90 at an 11.8 on 93. I hate to come in here and sound like i'm the one that figured everything out because lex pretty much already nailed it :/ off MAF curve, or more ethanol in the fuel than we're lead to believe. Interesting.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
| The Following User Says Thank You to Voltwings For This Useful Post: | rfinkle2 (01-24-2013) |
![]() | | #125 | ![]() |
![]() Join Date: Nov 2011 Location: Minooka, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Tapatalk LIKE A BOSS!
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. | |
| The Following User Says Thank You to GODspeed7 For This Useful Post: | rfinkle2 (01-24-2013) |
![]() | | #126 | ![]() |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | ricknm (01-24-2013) |
![]() | | #127 | ![]() |
![]() Join Date: Jan 2012 Location: Pensacola, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score I'm having my car smoked right now to definitively rule out a leak and will report back when I pick up my ride. On the 2 piece bikini model, I'm measuring 2.846" ID. tapawhat
__________________ HTP 3" MAF and Turbo Inlet in Candy Blue over Chrome Smoke CP-E Downpipe /w Custom Cat | Corksport Catback Exhaust Beachshoer Intake Manifold P/P /w VTCS Delete Sure Shortcut | Sure Anchors | Sure 1/8 TIG Cobb AP | Cobb FMIC | Cobb Sport Springs ATP GT3071R /w Stratified Boost Dial Stratified Automotive Guardian Angel Go Fast Bits Respons (100% VTA) Autotech Internals I tune myself, bitches |
![]() | | #128 | ![]() |
As for a boost leak, again AFR in spec, WGD barely working to hold my 20 and decreasing through the range. I'll do a test this weekend and report back.
__________________ 07 Liquid Plat Silver W/BNR S3 ~325/340 Pump gas AlphaTuned. Parting out. 11 Mustang GT current. | |
![]() | | #129 | ![]() |
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
![]() | | #130 | ![]() |
![]() | | #131 | ![]() |
| Not Ranked : 0 score Yeah just checked my last set of logs and again, 25 psi im only hitting max 2.65 load. The awd must have something to do with it im guessing.
| The Following User Says Thank You to Voltwings For This Useful Post: | JDW1 (01-24-2013) |
![]() | | #132 | ![]() |
| Not Ranked : 0 score There is an inconsistency that bothers me. I have an MS6 that the following MAF cal works well for for the HTP 3" Code: 0 0 0 0 0 0 0 0 0 0.02288 0.0572 0.08008 0.13728 0.19448 0.27456 0.35464 0.4576 0.56056 0.69784 0.84656 1.00672 1.16688 1.36136 1.56728 1.80752 2.0592 2.33376 2.6312 2.95152 3.30616 3.69512 4.15272 4.62176 5.0908 5.74288 6.267386 6.791893 7.316399 8.233679 8.867039 9.554999 10.34124 11.20392 12.08844 13.09308 14.18508 15.288 16.4892 18.10536 19.14276 20.16924 21.19572 22.23312 23.76192 25.389 27.0816 28.8834 30.75072 32.71632 34.76928 36.89868 39.10452 41.3868 43.76736 46.23528 48.79055 51.44412 54.19596 57.057 59.08812 61.10831 63.13943 66.19703 69.30923 72.48695 75.75204 79.09355 82.53336 86.06051 89.71872 98.20355 102.3095 106.5246 110.838 115.2824 119.8033 124.4006 129.0635 133.8355 138.7277 143.729 148.8614 151.1225 153.3836 155.6446 161.0809 166.7025 172.4683 178.3988 184.4631 190.6716 197.0242 203.5313 210.1825 216.9779 223.8968 230.9496 238.1568 245.5184 253.0242 260.705 268.5506 276.5608 284.7462 293.1065 301.6316 310.342 319.2172 328.2777 334.1381 343.4851 352.9951 362.6888 372.5862 382.6671 392.9315 403.4099 414.0719 424.9377 I am asking these guys if the have the straightener and if both intakes are powdercoated.
| The Following User Says Thank You to Lex For This Useful Post: | rfinkle2 (01-24-2013) |
![]() | | #133 | ![]() |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
-Derrick | |
| The Following User Says Thank You to CorkSport For This Useful Post: | HTP (01-24-2013) |
![]() | | #134 | ![]() |
![]() | | #135 | ![]() |
| Not Ranked : 0 score Can one of you guys with the intake take a picture straight on looking into the intake to have a good look at this straightener?
![]() | | #136 | ![]() |
![]() | | #137 | ![]() |
| Not Ranked : 0 score No, the pipe is smaller to begin with, and the straightener is probably adding to the problem.
| The Following User Says Thank You to Lex For This Useful Post: | Voltwings (01-24-2013) |
![]() | | #138 | ![]() |
| Not Ranked : 0 score like it would be diverting air away from the MAF at high load so it reads less? or just the fact its taking up space?
![]() | | #139 | ![]() |
| Not Ranked : 0 score The honeycome style is def taking up space.
| The Following User Says Thank You to JDW1 For This Useful Post: | Voltwings (01-24-2013) |
![]() | | #140 | ![]() |
| Not Ranked : 0 score Duh, brain fart i forgot they use honeycombs. i was thinking it was like the Sure, corksport... ones that have like a crosshairs design. Was thinking if it wasnt pointing exactly straight it could push air away from the sensor but that apparently isnt the case.
![]() | | #141 | ![]() |
![]() Join Date: Dec 2009 Location: Minneapolis, MN
Rep Power: 390 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,607
| Not Ranked : 0 score Just throwing this out there. Lex and finkle are going to be the experts here, but I have seen a few mentions of OL trimming in here and references to Gen2 vs Gen1 vs MS6 differences. Obvioulsy @Lex; has tuned a ton more cars than I, but I know for a fact my MS6 does at least some OL trimming. Been running a 3/10 E85/93 mix since summer, now it is dead of winter in MN so we are surely on E70. I have also gone to 2.5/10.5 recently and no matter what, my WOT OL trims are always spot on my 12.0 target. Even when I first started running E way back, I think I started by dumping 2gal in a full tank and made no adjustments to the tune. Still was hitting WOT targets like a boss. Just wondering if this could be contributing to some of the discrepencies, especially with JDW1 and his high flow numbers
__________________ 2006 BCM MS6 GT CS SRI/TIP Jbarone SSP/bushings cp-e RMM, TMIC, Stiff Diff AP KMD V2.whatever Ebay Catless DP Grom Ipod |
![]() | | #142 | ![]() |
![]() Join Date: Jan 2010 Location: Annapolis, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 326
| Not Ranked : 0 score @Lex; Here is the picture you asked for. It's not the clearest but hopefully this will help.
__________________ 2008.5 Mazdaspeed 3 GT True Red BNR S3. HTP Full 3.5" Intake. Self Ported Intake Mani. CorkSport Catless DP. UR Test Pipe. CXRacing Piping w/ TR8. GFB Respons BPV. Autotech HPFP. Stratified 3 Port EBCS. Stratified Guardian Angel. 3 Bar MAP Sensor w/ PnP Harness. |
![]() | | #143 | ![]() |
Overall none of them seem to adjust more than 10-12% above or below the MAF curve. As I get more data I will post but I must say I'm a little miffed by this issue. Inserting a honeycomb, not having a 3" ID as implied by the name really affects the fluid dynamics of the pipe and MAF curve and not in a nice way.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Lex; 01-24-2013 at 10:55 AM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to Lex For This Useful Post: | BigjohnB20 (01-24-2013) |
![]() | | #144 | ![]() |
| Not Ranked : 0 score An inch deep and looks like glue and a lip right behind the straightner hold it in.
| The Following User Says Thank You to Cyclops For This Useful Post: | Lex (01-24-2013) |
![]() | | #145 | ![]() |
![]() | | #146 | ![]() |
| Not Ranked : 0 score It definitely is on the outside..
![]() | | #147 | ![]() |
| Not Ranked : 0 score I digress, @HTP; if you have a MAF cal developed for the intakes please post it or provide some information. It will be very helpful is putting the data we have together and getting a solid MAF cal for these intakes.
| The Following User Says Thank You to Lex For This Useful Post: | sidekick (01-24-2013) |
![]() | | #148 | ![]() |
| Approved MSF Vendor ![]() Join Date: Dec 2010
Rep Power: 675 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
The local that you are tuning was in yesterday and had 3 very bad boost leaks. When Jarod comes in he will post up a calibration. Matt | |
| The Following 3 Users Say Thank You to HTP For This Useful Post: |
![]() | | #149 | ![]() |
![]() | | #150 | ![]() |
| Not Ranked : 0 score Which local is that? PM me if you like please.
![]() | | #151 | ![]() |
| Not Ranked : 0 score FWIW, @JDW1; I'd suggest waiting to see what core MAF Cal numbers are posted by HTP later, and if the talented ones here like lex don't rip them to shreds, then you should use those numbers and simply re-do your MAF Cal from scratch just to see where you end up. Couldn't hurt and is easy enough to do. And, of course, the usual old stand-by's of being sure that you've got no leaks, either pre or post turbo (ninja edit: intake & exhaust) and the MAF is good etc. If it stays funky you might want to take an afternoon and reinstall your old intake set-up and map just to be sure everything returns to known good values, verify the mechanical end of things, then reinstall the HTP taking the opportunity to be doubly sure of the install being good.
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq Last edited by TiGraySpeed6; 01-24-2013 at 01:36 PM. |
![]() | | #152 | ![]() |
| Not Ranked : 0 score I think the MAF Cal. problems are caused more by the slightly smaller ID than anything else. I think the problems you're having with top-end MAF cals may be caused by the honeycomb though. I wouldn't be surprised at all if the honeycomb style air straighter hindered flow slightly in the top end vs the "cross hair" style air straightener. Although, despite these "problems", it seems like people are still getting decent gains with these intakes.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
![]() | | #153 | ![]() |
![]() | | #154 | ![]() |
| Not Ranked : 0 score It may be that we aren't picking up as many G/s as we originally thought, but quite a few have picked up at least 10WHP. So that has nothing to do with whether or not the mass airflow numbers are correct.
![]() | | #155 | ![]() |
| Not Ranked : 0 score 10whp is definitely the ballpark that I have seen with larger intakes 3"+ on the K04 and this is what I posted a long time ago. 30whp on the other hand is a little optimistic.
![]() | | #156 | ![]() |
![]() Join Date: Nov 2009 Location: Pensacola FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 659
| Not Ranked : 0 score So basically after reading all this: I've been chasing leaks in two cars for nothing I'm about to cut holes in my honeycomb straightner 3" doesn't really mean 3" And all this ridiculous extra HP is coming from this lex tuned BNR and not from my ALMOST 3" intake. WOW what a day.
__________________ 2010 BM MS3 BNR S3 HTP 3" Intake(Granny Smith Green PC) CS RP Ebay DP Res Delete JBR shift kit Fully JBR mounted Turbosmart BPV DDM 6K Lows 3K fogs H&R Springs CS RSB CXRacing FMIC AT Internals DIY PnP IM w/ VTCS delete. CS OCC Stratified 3port EBCS HTP Batt Tray Bosch 3bar MAP SS brake lines Works emotions cr-kai 18x7.5 ventus v12s for the street TRM C3s 17x9 Hankook RS3s for track days ![]() STRATIFIED TUNED Other Mazdas in my stable 2010 VR MS3 Wifes Ride ETS TMIC JBR RSB JBR SSP JBR knob AT internals 1999 Miata gtx2867 1.9L VVT built like a brick shithouse 2001 Miata LS RB FSB Hawk HP+ pads Dunlop ZII |
![]() | | #157 | ![]() |
![]() Join Date: Nov 2011 Location: Alberta, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 621
| Not Ranked : 0 score ~2.8" isn't even that much bigger than the stock MAF housing is it? I know this is kind of the general trend (doesn't the JBR 3.5" have an ACTUAL ID of 3.3-something?)... but it still is a bit disappointing. Intake diameter should definitely be advertised using ID numbers.
__________________ | 2012 CWP | Cobb AP + AT Internals | HTP 3" Intake | 91oct + DO WMI (D07, 50/50) + 3gal E85 | UR Test Pipe | cp-e TMIC | JBR Trilogy, OCC, EGR Block, SSB | TBC Bypass | Freektuned - 313/351 - Stock DP |
| The Following User Says Thank You to Dr. Speed For This Useful Post: | DamagedGoods (01-24-2013) |
![]() | | #158 | ![]() |
![]() Join Date: Sep 2011 Location: SCOTLAND
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 469
| Not Ranked : 0 score I'll measure my Cpe intake tomorrow to check also
__________________ Cpe tmic&sri, 3" HTP tip, 3" ebay downpipe, BNR stage1, Autotech internals, Snow stage 2 meth with Aqaumist jet/parts, GoFastBits Respons BOV, Grimmspeed ebcs 3-port, Turbinetech diff mount, Cpe diff brace, Whiteline rarb, Bilstein B8's, Eibach springs, NGK iridium IX plugs, Corksport Mods, JBR mods... 324whp 361lb/ft Tuned with by |
![]() | | #159 | ![]() |
3.0" - 2.87" 3.5" - 3.37" 4.0" - 3.83" The original post and our website will updated. Matt | |
![]() | | #160 | ![]() |
| Not Ranked : 0 score Boost leak test done. 0 leaks found. tapawhat
| The Following 3 Users Say Thank You to aldekei For This Useful Post: |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f579/intakes-now-available-134325/ | ||||
| JBR Wide path VS Cobb SRI+TIP? | This thread | Refback | 01-28-2013 08:55 AM | |
| Out of stock intakes!!!!!! | Toymachinespeed | 2010 MS3 - Turbo Induction | 26 | 07-30-2011 06:34 AM |
| CorkSport SRI Intakes | CorkSport | CorkSport | 3 | 08-04-2010 03:54 PM |
