| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
| Approved MSF Vendor ![]() Join Date: Nov 2011
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score VersaTune has released VersaTuner Professional today. The professional version of VersaTuner enables professional tuning shops and eTuners to provide tuning services for all of the VersaTuner supported vehicle platforms. For those of you uncomfortable with self-tuning, this is great news as there will soon be a wide range of tuning providers to help you accomplish your performance tuning goals. If you are a professional tuner interested in VersaTuner Professional, please contact VersaTune at sales@versatune.net or PM me here. We are committed to the Mazda community and improving the Mazda tuning experience. Thanks, Steve |
| The Following 5 Users Say Thank You to Steve@VersaTune For This Useful Post: | Bexar (08-30-2017), Code Monkey (07-27-2017), DingoDave (08-31-2017), JSmith (07-28-2017), Polish_Eagle (07-29-2017) |
![]() Join Date: Apr 2013 Location: Evanston, IL
Rep Power: 1329 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 938
| Not Ranked : 0 score Damn. Wish I had known about this earlier
__________________ "you, sir, are the most knowledge slow guy I know. Stop fucking around and drive faster." -feejay "if anyone else acts a fool, we'll punish them to Roberts oil hut to discuss string alignment technique" -wetzel |
![]() Join Date: Feb 2015 Location: Waukegan, IL
Rep Power: 74 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
| Not Ranked : 0 score I was just refunded by Stratified tuning because they stated that VersaTune doesn't have sufficient logging resolution and not as many datalogging parameters in comparison to Accesport. Does VersaTune professional have improvements which narrow the gaps between AP and VersaTune and entice other professionals to want to tune with it?
__________________ |
![]() Join Date: Mar 2011 Location: Cambridge, Ontario, Canada
Rep Power: 221 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
__________________ 2011 MAZDASPEED3 Hypnotic Tuned - Rob CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) - | |
Groans: 111
I'm curious what problem do you have and trying to fix and the logging resolution of the Versatuner is not enough (It logs like 12 params 4-5 times every second).
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI Last edited by mituc; 08-31-2017 at 01:07 AM. | |
(Thread Starter) | Not Ranked : 0 score I have never had any issue tuning a car with the logging resolution of VersaTuner. It allows up to 16 concurrent logging parameters. 2.3 DISI doesn't have an in-cylinder pressure transducer, so I'm not sure what the extreme logging resolution is needed for. |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score I think the real reason is that Stratified are just Accessport only tuners.
__________________ 94 M MS6 IS350 |
Groans: 111
| Not Ranked : 0 score I think they were the first Versatuner e-tuners actually, and they currently have quite a few customers with VT.
Groans: 546
| Not Ranked : 0 score Interesting, maybe they are transitioning. I went to their website and this is the first thing I see when I look at DISI custom tunes: "How to Get Started on a Stratified Tune: - First, make sure you have a Cobb AccessPort. If you do not have a COBB AP, we can deliver these to you along with any other aftermarket parts you may need for your Mazda."
Groans: 111
| Not Ranked : 0 score Their site has always been like this, no mention on Versatuner anywhere.
| VersaTuner 1.9.3 Released | Steve@VersaTune | CX-7 > Turbo Induction & ECU Tuning | 1 | 11-22-2014 08:13 AM |
| VersaTuner v1.9 Released! | Steve@VersaTune | 2010 MS3 - ECU Computer Tuning | 1 | 11-04-2014 07:43 PM |
| VersaTuner 1.8.5 Released | Steve@VersaTune | VersaTune | 28 | 11-03-2014 01:42 PM |
| VersaTuner for Gen1 CX-7 released today | Steve@VersaTune | CX-7 > Turbo Induction & ECU Tuning | 48 | 10-01-2013 02:02 AM |
| VersaTuner 1.8.5 Released | Steve@VersaTune | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 03-21-2013 09:45 AM |
