| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
(Thread Starter) | Not Ranked : 0 score It happens, almost without fail, in big left handed turns where I'm straightening out and going full throttle. The 'Disable Torque Limiter' toggle is checked. I've attached logs, but here's a couple screenshots of the issue. I've attached my tune file and 3 logs. The particular ranges I'm looking at in each of the logs: 1_31_57: 142-144s 1_38_58: 712-715 1_55_31: 732-754 @Steve@VersaTune; @Ugnius@VersaTune; I don't see anything in the tune that would cause it, so I'm curious what you guys think. Thanks for all your help!
| The Following 7 Users Say Thank You to phate For This Useful Post: | dsb_chicago (05-02-2016), Enki (03-24-2016), Mazdazilla6 (03-24-2016), MS3Shadow (03-24-2016), SofaKingAwesome (03-24-2016), Vansquish (03-24-2016), xfeejayx (03-24-2016) |
![]() Join Date: Mar 2011 Location: Cambridge, Ontario, Canada
Rep Power: 221 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score I've experienced this too, and I'm pretty sure I've mentioned before as well. Since the SWAS disable doesn't 100% work I still use the SWAS disable switch unfortunately. Here's the link and also, when I was testing I had semi slick track tires which didn't slip: 2011 SWAS Issue Oh, I also think you need to push the "DSC Off" button in the car so DSC isn't interfering. Try pushing that button and then taking logs to see if that helps. I know for me it didn't as I had my AFR's dip into the 9's and you can feel SWAS affecting things.
__________________ 2011 MAZDASPEED3 Hypnotic Tuned - Rob CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) - |
(Thread Starter) | Not Ranked : 0 score DSC is most definitely always off, so not a worry about that. The SWAS sensor in ms6's controls part of the awd system. Unhooking it disables awd, so that's out of the question.
| The Following 2 Users Say Thank You to phate For This Useful Post: | Enki (03-24-2016), TiGraySpeed6 (03-24-2016) |
| Approved MSF Vendor ![]() Join Date: Nov 2011
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score The ECU is definitely pissed off. It fuel cut at 142.626s in 1_31_57. RPMs are up and down. Were you spinning an inside wheel? edit: same thing in 1_38_58. Sharp rpm rise then fuel cut. Could also be a lateral G force limit induced torque reduction by the DSC module that the button doesn't mask. Last edited by Steve@VersaTune; 03-25-2016 at 05:42 PM. |
We pull over 1g lateral, and it only happens after sustained cornering, not after quick maneuvers. All of my videos from Saturday were corrupt, so I don't have a good example (you can hear the car pop and stutter when it happens). If it is g-force induced, is there any hope of it getting tuned out?
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
| Not Ranked : 0 score I'm looking at it. I have an idea that I need to do some testing with. |
(Thread Starter) | Not Ranked : 0 score Awesome, thanks. We autocross every 2 weeks or so during the season, so if you need testing done I can help with whatever you need.
| The Following User Says Thank You to phate For This Useful Post: | Enki (03-25-2016) |
![]() ![]() Join Date: Jun 2010 Location: Morton Grove, il
Rep Power: 1485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,886
Groans: 78
| Not Ranked : 0 score Leave it to phate to find a lateral G force limit. In for testing if you need/want/would like a second car.
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT |
(Thread Starter) | Not Ranked : 0 score We're autocrossing on Sunday, again. Steve, if you would like us to try anything or capture anything specific in the data, let us know and we'll do it! I'll have my accelerometer logging this time around, so that data should be available, too.
| Not Ranked : 0 score Working on a new build for you with some new tables. |
| The Following 9 Users Say Thank You to Steve@VersaTune For This Useful Post: | Enki (03-30-2016), mazdakaps (03-31-2016), meicalnissyen (08-28-2016), MS3Shadow (04-01-2016), phate (03-30-2016), Polish_Eagle (03-30-2016), SofaKingAwesome (03-30-2016), WetzMS3 (03-30-2016), xfeejayx (03-30-2016) |
| Not Ranked : 0 score Sent you a link to a new VT to test. Check your spam folder if you don't see it. |
| Not Ranked : 0 score Any improvement? |
| The Following User Says Thank You to Steve@VersaTune For This Useful Post: | phate (04-04-2016) |
(Thread Starter) | Not Ranked : 0 score No, still cutting after long left handers. I'll send (or post) data logs and the tune file for you guys to check out. Long day yesterday, still went fast enough to take the class
| The Following 2 Users Say Thank You to phate For This Useful Post: | Enki (04-04-2016), SofaKingAwesome (04-05-2016) |
(Thread Starter) | Not Ranked : 0 score I've attached all of the logs from Sunday. Here's the summary (included in the .rar): Essentially, I took anything and everything that might be causing an issue out of the tune. Tune file included, please let me know if I missed any tables that you were thinking of. You can see and hear in this video around 32s where it happens after the big left hander:
| The Following 3 Users Say Thank You to phate For This Useful Post: |
| Not Ranked : 0 score Christ almighty.
__________________ |
![]() Join Date: Jun 2012 Location: Asia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 112
| Not Ranked : 0 score Off topic: The video log looks cool. What software / hardware is this? |
| The Following User Says Thank You to KCi For This Useful Post: | phate (04-05-2016) |
(Thread Starter) | Not Ranked : 0 score Race Render 3 is the video software. It can handle time based data, so data logs are perfect to overlay. In my case, I have a GoPro taking video, VT logs exported to CSV format, and a GCDC 3-axis 2g accelerometer for the G-G plot (smoothed from 128Hz sample rate in this case).
| The Following User Says Thank You to phate For This Useful Post: | KCi (04-05-2016) |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score @mazdakaps you might need to download it again
| The Following 5 Users Say Thank You to phate For This Useful Post: | Enki (04-05-2016), mazdakaps (04-06-2016), MS3Shadow (04-06-2016), SofaKingAwesome (04-05-2016), WetzMS3 (04-05-2016) |
![]() | | #20 | ![]() |
![]() Join Date: Feb 2012 Location: Thessaloniki Greece
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 147
| Not Ranked : 0 score Lol how did this happen? I only download it once. Oh well!!!
__________________ mazdaspeed3 Gen1: Manley pistons, eagle rods, L19 studs, 3.5" intake, FMIC AMS, map 3.5 bar, Cobb accessport, Cobb solenoid valve, 3" catless DP, HKS exhaust, EFR 7163 |
| The Following User Says Thank You to mazdakaps For This Useful Post: | phate (04-06-2016) |
![]() | | #21 | ![]() |
| If the downloader uses multi-threading to increase downloads, it'll appears as a another download for each connection. sent from my Nexus 6P
![]() | | #22 | ![]() |
Groans: 78
| Not Ranked : 0 score @Steve@VersaTune; Weather depending, racing this weekend. Anything specific you want to see? Will attempt phate type log, but...slower.
| The Following User Says Thank You to xfeejayx For This Useful Post: | phate (04-08-2016) |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Nothing right now. I am still looking. Thanks for the offer. Sent from my SM-G900V using Tapatalk |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score @xfeejayx, have you gotten any cuts in either of the 6's? @Steve@VersaTune, I'll be autocrossing again this coming Sunday, do you want me to test any tables or grab different fields in the data logs?
![]() | | #25 | ![]() |
Groans: 78
Have an ax Saturday, and potentially one Sunday. Sent from my Nexus 5 using Tapatalk
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT | |
| The Following User Says Thank You to xfeejayx For This Useful Post: | phate (04-12-2016) |
![]() | | #26 | ![]() |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score May have found the culprit and might owe the VT guys some beers for creating extra work. I popped a P2088 code a few weeks ago, but cleared it because it was pretty random. It came back after the car was cutting especially hard this weekend, so thought I better check it out... I'll repin tonight and see how it goes.
| The Following 8 Users Say Thank You to phate For This Useful Post: | broda (04-19-2016), Code Monkey (04-19-2016), Enki (04-19-2016), mazdakaps (04-20-2016), Nliiitend1 (04-19-2016), SofaKingAwesome (05-03-2016), Ugnius@VersaTune (04-22-2016), WetzMS3 (04-19-2016) |
![]() | | #28 | ![]() |
Groans: 78
| Not Ranked : 0 score Just checked our logs from the weekend. No RTP reduction below 6k; slaloms, sweepers, whatever. I imagine this will address your issue. Sent from my Nexus 5 using Tapatalk
| The Following 4 Users Say Thank You to xfeejayx For This Useful Post: |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score I reworked that connector and the car is pulling cleanly now in straight lines. Dragon this weekend, then another autocross the weekend after. I'm going to revert back to the current public release of VT and my old tune to test things out. Hopefully everything is fixed!
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score I won't call yesterday's event conclusive, because there weren't any long left handers. But, the car pulled cleanly every time we asked for it ![]() Next event in 2 weeks.
| The Following 2 Users Say Thank You to phate For This Useful Post: | Enki (05-02-2016), SofaKingAwesome (05-03-2016) |
![]() | | #31 | ![]() |
![]() Join Date: Jul 2011 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
| Not Ranked : 0 score Shouldn't you be Skyping with Fiat right now??
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." |
| The Following User Says Thank You to MSP6 For This Useful Post: | phate (05-03-2016) |
![]() | | #32 | ![]() |
![]() Join Date: Aug 2014 Location: Astoria, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score I get this cut-off on sweeping turns on power as well. I haven't done this, but I've heard you have to completely disable the SWAS sensor which is under the steering column but you need to remove all the shrouding to get to it. What I've done is on startup hold the DSC button and that will disable both DSC and Traction Control. I've gotten good results this way, but you have to be careful of lift-off oversteer!
__________________ 2008 Cosmic Blue MS3 GT // CS TD05-18G Turbo // Freektuned //Denso ITV22 // CS DP // CS 3.5" Full Intake // CS 3.5 Bar Map // CNT Catback // CS HPFP // JBR FMIC Piping // Treadstone TR8 FMIC // CS OCC // CS Heat Sheilds // CS boost hoses // CS ECU relocation // Cobb AP3 // Cobb RMM // HKS SSQV 4 // CS Short Shifter // CS Short Shift plate // Fifteen52 18x9 Tarmacs // Hankook RS3 235/40 // Koni Yellows // GC Coilovers // CS F&R Sway Bars // CS front Endlinks // Whiteline rear Endlinks // GC bump stops // CS mid chassis brace // Megan front H brace // CS rear strut tower bar // Stoptech rotors/pads/ss lines // DG carbon spoiler // DG carbon bumper cover // V2 Side Skirts // STi Lip // CS Antenna // CS Lisence plate relocator // CS LED Fogs // PIAA yellow high beams // Pioneer NEX-7100 // Prosport Premium gauges (Boost/OP/OT) // CP-E Gauge Pod // TWM Shift Knob // Sparco Pedals // Royal Purple 5w/30 |
| The Following User Says NO Thank You to c_bye For This Un-useful Post: | SofaKingAwesome (05-03-2016) |
![]() | | #33 | ![]() |
Groans: 78
Don't have to hold button on MS6, just tap it. It does NOT disable SWAS cut. Disabling that sensor does more than just disable SWAS, I think. Sent from my Nexus 5 using Tapatalk
| The Following User Says Thank You to xfeejayx For This Useful Post: | phate (05-03-2016) |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score Done!
![]() | | #35 | ![]() |
__________________ 2008 Cosmic Blue MS3 GT // CS TD05-18G Turbo // Freektuned //Denso ITV22 // CS DP // CS 3.5" Full Intake // CS 3.5 Bar Map // CNT Catback // CS HPFP // JBR FMIC Piping // Treadstone TR8 FMIC // CS OCC // CS Heat Sheilds // CS boost hoses // CS ECU relocation // Cobb AP3 // Cobb RMM // HKS SSQV 4 // CS Short Shifter // CS Short Shift plate // Fifteen52 18x9 Tarmacs // Hankook RS3 235/40 // Koni Yellows // GC Coilovers // CS F&R Sway Bars // CS front Endlinks // Whiteline rear Endlinks // GC bump stops // CS mid chassis brace // Megan front H brace // CS rear strut tower bar // Stoptech rotors/pads/ss lines // DG carbon spoiler // DG carbon bumper cover // V2 Side Skirts // STi Lip // CS Antenna // CS Lisence plate relocator // CS LED Fogs // PIAA yellow high beams // Pioneer NEX-7100 // Prosport Premium gauges (Boost/OP/OT) // CP-E Gauge Pod // TWM Shift Knob // Sparco Pedals // Royal Purple 5w/30 | |
| The Following User Says Thank You to c_bye For This Useful Post: | phate (05-03-2016) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score From what I remember, holding the button only turns on the lights for testing and doesn't actually fully disable anything. I've had my light come on simply because I hit the button too fast after starting it, no holding needed. Car didn't behave any differently either.
![]() | | #37 | ![]() |
It was probably just me, but I did notice the back end stepping out a bit more on track than with both DSC off and traction control light on.
![]() | | #38 | ![]() |
| Not Ranked : 0 score My 2011 MS3 suffers from powerless mid corner (rich AFR's and little power), once I straighten the wheel out I feel full power. I then disable my SWAS with the switch I wired in and the powerloss no longer happens.
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score No dice on the connector being the culprit. I flashed back to the pre-beta tune and autocrossed yesterday with a HUGE nascar style left handed oval. After straightening out into the next section, the car cut out just like it used to. I'll work back through to see if I can find a fix. I'll start with the tables that became available in 1.10.11, then move to the tables available in 1.10.13. Video of the course. Too much wind noise to hear the cut, this time.
| The Following 2 Users Say Thank You to phate For This Useful Post: | Code Monkey (05-24-2016), Enki (05-24-2016) |
![]() | | #40 | ![]() |
Groans: 78
| Display Modes | |
| I need SWAS pictures! | mexicant | MazdaSpeed 3/6 - ECU Computer Tuning | 33 | 10-26-2016 07:23 PM |
| SWAS question. | JSmith | Gen2 MS3 General Discussion | 3 | 12-22-2012 01:13 PM |
| WTF is happening? SWAS? | jordan11b | 2010 MS3 - ECU Computer Tuning | 31 | 05-01-2012 08:39 PM |
| Going over ~19psi, SWAS issues | adlpb | 2010 MS3 - ECU Computer Tuning | 15 | 11-22-2011 04:04 PM |
