| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
3Likes ![]() |
| Approved MSF Vendor ![]() Join Date: Nov 2011
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score What is VersaTuner? In a nutshell, VersaTuner is software (Windows application) that can connect to your car and change the way your engine operates to give you more power, better fuel economy and greater control. How can it do that? At the heart of each modern car lies an engine electronic control unit (ECU) that governs all aspects of your engine operation. It is a small computer that constantly receives data from various sensors (engine speed, fuel pressure, air pressure, etc.) and sends commands to multiple outputs (injects fuel, ignites a spark or adjusts the speed of the turbocharger). The logic that describes how your engine operates is stored in the flash memory of the ECU and can be altered by VersaTuner. As a result, the ECU will raise the boost pressure, inject more fuel and make any other changes to make your car run faster than before. Isn’t the engine already optimized to run at max power? Engines are programmed at the factory to run well in all climates (from Africa to Siberia), high up in the mountains and at sea level and on different grades of fuel. There is also a conservative safety margin to account for differences in build and wear of mechanical parts. Some car makers release different models with the same engine, but rated at different power levels. Quite often, the calibration of the ECU is the only thing that accounts for this difference. Additionally, car owners might allow for higher power levels by physically modifying their cars (like adding a high flow intake or exhaust) or using premium fuel. For all of the above, there is nearly always some spare power that can be extracted from your engine with the right changes in ECU programming. How do I use VersaTuner?
What else can VersaTuner do? VersaTuner allows you to:
Who can use it? VersaTuner's robust feature set accommodates every level of tuning expertise. With just a few mouse clicks, first time users can install VersaTuner and flash one of the included pre-built tunes to achieve significant power increases. No knowledge of tuning or automotive engines is required to get started. Users who are familiar with custom tuning can use VersaTuner's data logging, graphing, and built-in tune editor to create custom tunes optimized for their individual car. VersaTuner's intuitive user interface reduces the complexity of logging, analyzing, and tuning, making custom tuning easier to learn. Professional tuners can also use the data logging, graphing, and built-in tune editor features of VersaTuner to create fully customized tunes for customers. The easy to use interface helps professionals tune faster resulting in faster turnaround time for customers. Is it safe? ECUs are designed to be reprogrammed in the field by dealerships. VersaTuner connects to your vehicle in the same way as the dealer’s diagnostic tool and uses industry standard protocols to access and flash the firmware of the ECU. There are built-in fail safe mechanisms in the ECU that will allow you to repeat a flash even if it fails in the middle of the process. VersaTuner always backs up your factory configuration first, so you can return your car to stock any time. All the base tunes provided in our online database have been thoroughly tested. When you decide to modify the tunes yourself, always make your changes in small increments and data log the results. Why VersaTuner? VersaTuner has been designed to make it stand out from the competition in many ways:
Want to know more? Read more about VersaTuner at www.versatuner.com and check out our user support forum at www.versatune.net/forum. VersaTuner on an HP Stream 7 tablet Connected to a 2011 Mazdaspeed3 Using a VersaLink J2534 interface cable |
| The Following 11 Users Say Thank You to Steve@VersaTune For This Useful Post: | Enki (04-15-2016), mazdakaps (04-16-2016), Mazdazilla6 (04-15-2016), Micha (04-22-2016), Polish_Eagle (04-15-2016), sh4d0w (04-19-2016), SpeedRebirth (04-15-2016), Thepedigree13 (04-19-2016), tmillner (04-15-2016), WetzMS3 (04-20-2016), xfeejayx (04-18-2016) |
| Not Ranked : 0 score Hey Steve, I'm looking to make the jump soon. I plan to do all of my monitoring and logging with a tablet. Price is the largest factor for me but I don't want the tablet to compromise performance. What's a good, affordable option?
(Thread Starter) | Not Ranked : 0 score Any decent Windows tablet will work. 8 inch is a bit small. 10 inch or larger will work better. |
| The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post: | Enki (04-19-2016), Mazdazilla6 (04-19-2016) |
| Not Ranked : 0 score I think I've found one that suits my needs. It's a good price and the feature that drew me to it most is that it can run windows and android. I'll be using a tuning solution for my 135i which uses android so now I can run 1 tablet for both my cars, and hopefully VT will eventually get something out for android too ![]()
(Thread Starter) | Not Ranked : 0 score Look for 2 USB ports. One for charging and one for VersaLink. |
| The Following User Says Thank You to Steve@VersaTune For This Useful Post: | Mazdazilla6 (04-19-2016) |
| Not Ranked : 0 score Will a y cable not work?
(Thread Starter) | Not Ranked : 0 score Not very well. Sent from my SM-G900V using Tapatalk |
| Not Ranked : 0 score Or just have one with a battery large enough to run for several hours.
__________________ |
| The Following User Says Thank You to Enki For This Useful Post: | xfeejayx (04-20-2016) |
![]() ![]() Join Date: Jun 2010 Location: Morton Grove, il
Rep Power: 1485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,886
Groans: 78
| Not Ranked : 0 score I use a cheap 8" chinatab. They fit well in the MS6 center cubby. If any serious tune modification or data checks need need to be done it's easy to transfer to the laptop. Edit: Use bluetooth while logging. I'vehad had no issues with it.
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT Last edited by xfeejayx; 04-20-2016 at 06:35 AM. |
| The Following 2 Users Say Thank You to xfeejayx For This Useful Post: | Mazdazilla6 (04-20-2016), WetzMS3 (04-20-2016) |
| Not Ranked : 0 score Do you use an OBD2 wireless adapter or something?
Groans: 78
| Not Ranked : 0 score Don't have this specific one, but any of them should work. Veepeak Mini Bluetooth OBD2 OBDII Diagnostic Code Reader for Android Windows https://www.amazon.com/dp/B011NSX27A..._.f6fxbMN88S8S Don't let Steve's modesty fool you. It logs plenty fast for monitoring, and for tuning specifics such as dialing in AFR, throttle control, etc. But who uses a tablet to tune, anyway? Sent from my Nexus 5 using Tapatalk
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT |
| The Following User Says Thank You to xfeejayx For This Useful Post: | Mazdazilla6 (04-20-2016) |
(Thread Starter) | Not Ranked : 0 score We currently support ELM based bluetooth OBDII loggers. The logging rate is slower over luetooth due to wireless latency. |
| The Following User Says Thank You to Steve@VersaTune For This Useful Post: | Mazdazilla6 (04-20-2016) |
| Not Ranked : 0 score Can the monitoring be done wirelessly only thru bluetooth or can you use wifi? Edit: Looks like it's just bluetooth after looking at the website. Looking at the supported wireless devices on the site and saw the OBDLink scan tools listed. Would those provide a faster sampling rate for logging than a generic ELM327 bluetooth device? I also started wandering about the OBDLink website and saw that they list a TON of tables for the Mazda specific stuff that can be monitored. Saw a table for flex fuel in there as well as some other interesting ones. Do you think that those might be buried somewhere in our ECU or no? http://www.palmerperformance.com/sup...zda_engine.txt
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings Last edited by Mazdazilla6; 04-21-2016 at 04:39 PM. |
| Approved MSF Vendor ![]() Join Date: Dec 2011
Rep Power: 189 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
Chinese ELM327 clones offer a logging rate of around 20 requests/s, OBDLink devices - around 40-50 requests/s. The max rate for gen 1 MZR DISI ECUs is 50 requests/s, gen 2 is 100 requests/s IIRC, SkyActiv ECUs offer a rate of 200 requests/s. Max rate is currently only achievable using a wired interface. Palmer Performance listed all possible Mazda PIDs from all Mazda models, however, in reality, the ECU of each specific model only has only a fraction of them implemented. We have exposed most of the important ones. There are no flex fuel PIDs in MZR DISI ECUs. What others seemed interesting to you? | |
| The Following 3 Users Say Thank You to Ugnius@VersaTune For This Useful Post: |
- Fuel Pump Monitor and Fuel Pump (not sure how they're different but it'd be nice to be able to see how hard the ITFP is working) - Cylinder Head Temperature (pretty sure it'd just be the same as ECT though) - CMP and CKP Synchronized - Fuel Temperature - Transmission Fluid Temperature (don't think our trans even has a temp sensor) - Clutch Pedal Position Switch (useful to ensure stuff like FFS is working properly) - Injector Timing Before Top Dead Center - Spark Duration of Cylinder 1-4 - Learned Value of Throttle Angle Offset (I'm curious if this or something like it plays a part in the odd phenomenon where the ECU uses a certain APP for boost reference, i.e. the pedal may be to the floor but the ECU is looking at the 68%line instead. I know @phate; and a couple others had issues with that. Or maybe it was just Cobb related.) Lastly, would it be possible to get into other modules like the 4x4? It'd be totally sweet to be able to control duty cycle on the rear diff and stuff.
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | |
| Not Ranked : 0 score No sensors for this, it would have to be estimated based on massflow and would need its own table (which would have to be modified when your turbo changes) ...?? What are you looking for here? We don't have any kind of fuel pressure sensor other than the one in the rail...no real good logging metrics for either pump other than pressure.
CKP = RPM, CMP = VVT No sensor for this
Injector timing window math in general would be nice; open point in crank degrees + duration of pulse in crank degrees, though we already have spray time in MS so that could be converted to crank degrees pretty easily Spark is instant but duration depends on how much energy is stored in the coil pack; no sensor exists to measure spark duration, but it might be possible to log how much dwell is being fed to the coil packs (more dwell = hotter spark); it's entirely possible there's only one dwell setting and it doesn't change the energy fed to the spark plug no matter what, however. I don't follow what you're asking for here.... We can already change the throttle angle vs pedal position via tables in the tune, and I think there's a hard limit on how far the ECU will allow the throttle plate to open (and IIRC, this is a standard on electronic throttle bodies to prevent them from getting stuck open).
__________________ | |||
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Mazdazilla6 (04-22-2016), Ugnius@VersaTune (04-22-2016) |
| Not Ranked : 0 score @Enki; I know that there isn't a lot of sensors for this stuff but if there are tables then sometimes these values are looked upon for certain calculations. Some stuff is for things I have personal interest in like the ITFP, I'm not dying for that info since I can back calculate fuel flow based off power but it'd still be a convenience. The synchronized CKP and CMP seem like they'd be a useful back check to be sure everything is timed properly. I was unaware VT could already monitor clutch position. A binary switch on/off sort of deal was all I was looking for. I think that the spark duration (or a dwell time) could be useful for examining spark time vs TDC time. As for the last one, it's been noted by a couple of people. And it's very random, some 6's don't follow APP correctly on certain tables. For example, if you've got the pedal floored and APP is at 100%, for some unknown reason, the ECU will look at a different row. On some cars that row is maybe 68%, on others its 75% despite the fact that actual APP is 100%. I don't know if it's Cobb specific or if there's just some hidden table messing with it but it makes tuning a pain. Phate would know more than I on it though.
![]() Join Date: May 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Anyone use Versatuner to tune the Corksport drop in turbo? I dont want to trust my car to a random tuner, especially if they are not in my state, never mind $300 every time you make some mod requiring a tune update. Id rather do it myself. However, I have never tuned a car before. I noticed that the posts on VERSATUNER forums are really old. What gives? |
![]() | | #19 | ![]() |
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
![]() | | #20 | ![]() |
| Not Ranked : 0 score Corksport recommended a few Cobb Protuners whom I spoke to and they only use AccessPort. Which tuners in Maryland use VersaTuner? |
![]() | | #21 | ![]() |
Freektune, Hypnotic and Dizzy Tuning, others can do Versatunes. just email them and they should be able to do it. i don't know of any physical locations that can do it.
![]() | | #22 | ![]() |
| Not Ranked : 0 score As someone who has watched more than one person take an aftermarket tuner/builder to court for bad work, Id prefer to do it myself. IF POSSIBLE. If not, Id prefer someone in my state. Freektune is in New Hampshire. Again, Id prefer to do it myself and I'm just confused about why I'm not finding others members that are using Versatuner to self tune the Corksport drop in turbo. |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score If you can't find support on the forum, I'm happy to help you self-tune. You can also find help on the VersaTune user forum www.versatune.net/forum |
| The Following User Says Thank You to Steve@VersaTune For This Useful Post: | xfeejayx (10-12-2016) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Thanks Steve. Are tunes shareable between Versatune users? In otherwords, if I was to create a decent tune with the Corsksport drop in turbo and HPFP internals, could I share it with others? Does the tuning software work that way? |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Tunes are completely shareable between users. Tuning boost control for a new turbo is not that hard. Start off with low wastegate duty cycle to be safe, and then dial it in based on logs. |
![]() | | #26 | ![]() |
| Not Ranked : 0 score You can tune in real time yes? While someone else is driving? |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score You need to stop and shut the engine off to reflash. The ecu runs from flash memory. You can't live tune. You can monitor realtime data with the dashboard, but typically, you log a few pulls then stop and analyze the data and create a new tune and flash it. rinse and repeat. |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Thanks Steve. |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Steve, have a few rookie questions: - does Versatuner recognize the Corksport 3.5 bar MAP Sensor? I assume its a requirement for a larger turbo so you the ECU can receive the higher boost signals? Or does your software work better with a BOSCH 3 or 3.5 unit (which is much cheaper ut I think needs a harness to convert the wiring which ends up being similar price) - does Verastuner work with the Corksport Electronic Boost Control Solenoid (EBCS)? -does Versatuner work with Stratified Automotive Guardian Angel V3 Overboost Protection w/ 4 Bar MAP Sensor? do you recommend it? |
![]() | | #30 | ![]() |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // | |
![]() | | #31 | ![]() |
I just added a logging PID for it so that you can log MAP over 255 kPa with that sensor. It will be in the next release. Any aftermarket EBCS will work with VT. You just need to adjust the BCS DC tables. The ECU has redundant safety measures built in. If you want a third level of protection, feel free to get the Guardian Angel. The ECUs built-in protection mechanisms are described here: MAZDA MZR DISI 2.3L TURBO ECU SAFETY FEATURES | |
![]() | | #32 | ![]() |
| Not Ranked : 0 score thanks Steve. |
![]() | | #33 | ![]() |
![]() Join Date: Sep 2017 Location: The netherlands
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score so if i"m right i can also still use my "auto meter OBD II bleutooth logger" for my android tablet, for real time logging? is the versa tune program for windows also dutch? my 3 mps has now 300PK on the crank. this is whats don with the engine Wiseco pistons K1 connecting rods ecu remap corkspork rear motor mount increase gasoline pressure Sure earos intake kit, with turbo pipe - black Sure silicone intercooler pipes - red sure silicone return pipe - red Sure silicone vacuum pipe - red Sure ventus blow off valve bigger top mount intercooler
__________________ IN the netherlands RHD uk spec 300bhp Wiseco pistons K1 connecting rods ecu remap corkspork rear motor mount increase gasoline pressure Sure earos intake kit, with turbo pipe - black Sure ventus multiport blow-off Sure silicone intercooler pipes - red sure silicone return pipe - red Sure silicone vacuum pipe - red bigger top mount intercooler |
![]() | | #34 | ![]() |
| Not Ranked : 0 score You can use a auto meter logging device until you need to hook up your tuning device.
![]() | | #35 | ![]() |
![]() Join Date: Dec 2017 Location: Idaho
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
| Not Ranked : 0 score As in, they cannot be used at the same time... either actively tunning/scanning with versatune, or actively scanning with autometer
__________________ 2011 MS3 Tech - 2008 Jeep Grand Cherokee CRD - 1989 Crown Vic LTD LX - 1985 Lincoln Town Car Signature The key to happiness is owning a car ridiculously slower than your 'fast' car. |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Correct. You would have to unplug your Bluetooth dongle and plug in the tuning cable to laptop or tablet.
![]() | | #37 | ![]() |
| Not Ranked : 0 score i have the bleutooth autometer dongle, and with my android tablet works great, i know is't the autometer dongle or the versatune not together. 1 thong that i miss one the autometer you can't see the oil temp or press, but i think that the OBD those can't read?
| Display Modes | |
| AP vs Versatuner | smileyIV | MazdaSpeed 3/6 - ECU Computer Tuning | 17 | 06-07-2018 07:36 PM |
| Versatuner GB | aviator79 | CX-7 > General Lounge + New Member Welcome | 5 | 03-12-2013 01:10 PM |
| VersaTuner for CX-7 | steve12345 | CX-7 > Turbo Induction & ECU Tuning | 50 | 07-07-2012 08:42 AM |
