Like Tree10Likes
 Old 11-13-2011, 06:22 PM   #1
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Neutral  :  0 score
Default HOW TO: Remove & Disassemble HPFP Spill Valve
Tools:
1. 10mm socket and ratchet
2. 32mm combination wrench
3. medium-size standard (flat-head) screwdriver
Procedure:
1. Using the 10mm socket and ratchet, remove the two 10mm bolts that hold the shroud on over the TMIC and remove the shroud (if required).
2. Unplug electrical connector to the spill valve on the top of the HPFP.
3. Using the 32mm combination wrench, unscrew the spill valve from the HPFP housing.
4. Using the flat-head screwdriver, carefully pry up between the spill valve base and collar as seen below. Do this in steps, rotating the spill valve as you pry to pull the collar out evenly.
5. Carefully remove the collar, plunger, c-clip, and spring from the spill valve and clean.
Reinstallation:
For reinstallation, simply reassemble the collar, plunger, c-clip, and spring in the order it was pulled out of the spill valve, and press the collar back into the spill valve base. There is no need to press the collar all the way back in; when you screw the spill valve back into the HPFP, you will reseat the collar. Apply a bit of clean engine oil on the spill valve O-ring prior to putting the spill valve back into the HPFP. There is no need for any thread sealant, as the O-ring provides the seal.
NOTE: The electrical connector for the spill valve should be pointing straight towards the radiator when the spill valve is tightened all the way down. This can take a bit of force.
Livingframe and thatfoofez like this.
The Following 55 Users Say Thank You to silvapain For This Useful Post:
1stMS3 (06-27-2015), 802MS3 (12-23-2011), Andjo (07-27-2015), Arnie1229 (03-23-2015), BlueStreak (11-13-2011), burn813 (04-08-2012), Captain KR (11-13-2011), charlesfist (11-21-2011), Ckmazdaspeed3 (04-04-2012), cld12pk2go (11-19-2011), Dahouse702 (07-02-2012), daztdMS6 (01-19-2012), djuosnteisn (11-14-2011), dougefresh_ (12-13-2011), dsb_chicago (01-19-2013), eljefe62 (01-09-2013), Enki (11-13-2011), GLORIFIEDBOZO (11-15-2011), Grab21 (01-24-2012), hnda etr (02-02-2012), ItsNox (08-25-2014), JLee1469 (11-14-2011), kritz (11-14-2011), LatinKraze (12-19-2012), Livingframe (04-14-2015), MD1032 (05-06-2015), meicalnissyen (05-05-2014), Menace1 (12-19-2012), Ms3_Miami (12-11-2012), Nataphen (11-17-2011), p057 (12-26-2011), peo (07-01-2017), phate (11-15-2011), Pointless (09-04-2012), psychophyr (09-04-2013), Raider (11-13-2011), rfinkle2 (11-23-2011), rghispanic88 (11-20-2011), Rokusek (01-14-2013), Sergeant_M (03-18-2014), SJP0tato (12-22-2011), skiptowncat (02-19-2012), spdtrux (12-14-2013), SpeedRebirth (01-07-2015), speed_freak91 (05-14-2014), SpencerC (08-13-2014), Spoolnak (05-27-2014), taf0422 (01-15-2013), tclegg (02-28-2016), Tifosi42 (03-22-2016), TiGraySpeed6 (12-28-2011), Tokay444 (11-22-2013), Vinnie (05-06-2012), WetzMS3 (10-07-2013), [R]usty (07-13-2015)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/how-remove-disassemble-hpfp-spill-valve-96970/
engine tappping (sorry i know its been done before).... ? Mazda MPS Owners Club This thread Refback 02-25-2015 04:24 PM
engine tappping (sorry i know its been done before).... This thread Refback 02-27-2014 09:26 AM
speed3 wont accelerate past 4k - Page 4 - DFW Mazdas This thread Refback 05-10-2013 03:25 PM
My project: Non-boosted DISI motor - Page 7 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 12-06-2012 02:45 PM
Okay, WTF was this? - Page 5 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-12-2012 02:31 PM
How do you disassemble a forge? red07 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 03-29-2009 10:28 AM
Cleanup on I-80: Oreo spill snarls traffic in IL Haltech Automotive News 0 05-19-2008 11:10 AM
Page generated in 0.68699 seconds with 34 queries
