Like Tree10Likes
 Old 11-22-2011, 05:32 PM   #41
laxplayermjd's Avatar
Posts: 779   (View Stats)
laxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the world
It comes out very easily with a jewelers screwdriver. I've pulled mine out before to inspect it.
It's not a normal toroidal O-ring. The edges are flattened, where the cross-section is square not circular.
Tapadatass
well then i dont think ill have any orings like that around, but that doesnt mean you couldnt just put a slighter larger reg one and squeeze it in.
Also i dont think measuring the o ring would be that accurate, especially if we think oil is leaking by it. Oil will almost always swell the o ring or atleast deform it slightly.
All this talk makes me want to jump on the band wagon, although i would need to move back home, there is no close stations near memphis
2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune
laxplayermjd is offline   Reply With Quote
The Following User Says Thank You to laxplayermjd For This Useful Post:
rfinkle2 (11-23-2011)
 Old 12-13-2011, 07:40 PM   #42
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
So what specifically do you guys use to clean the spill valve? I didn't see anything mentioned... I like brake cleaner, but I wouldn't use that by the o-ring part.
Also, is the seafoam in the tank only necessary over 50/50?
TIA
EDIT: You guys have 2 maps handy in case you're on a trip and can't plan E85 stations? I plan on have 93 the a mix map. Not sure of mix, maybe E30.
The Following 2 Users Say Thank You to dougefresh_ For This Useful Post:
phate (12-13-2011), rfinkle2 (12-14-2011)
 Old 12-13-2011, 07:48 PM   #43
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Seafoam doesn't do a fucking thing. Trust me.
Use 91 pump gas and a toothbrush/lint free cloth to wipe the sticky off of everything and you'll be good.
dougefresh_ (12-13-2011)
 Old 12-13-2011, 07:58 PM   #44
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
TIA
I use brake cleaner, but gas works, as well.
I have a 93 octane map, a 50/50 shitty map, an E70 (winter) map, and my E85 (summer) map
I picked up a can of seafoam last time I was in town. I'm going to get a gunk specimen and see what the seafoam does to it, directly.
-06 MS6
-Corn fed 07 MS3 - Sold
dougefresh_ (12-13-2011), rfinkle2 (12-14-2011)
 Old 12-13-2011, 08:18 PM   #45
Cool, thanks. What's a 50/50 shitty map? lol Something like my current 93 shitty map?
 Old 12-14-2011, 01:56 AM   #46
jroc's Avatar
Posts: 1,482   (View Stats)
kind of going along with the last sentence, when i had my engine apart, i had put a stock piston in a bowl of seaform and let it sit for a full day. SOME carbon deposits came off, not a whole lot/what i had hoped for.
JDMFresh.com 1990 Mazda Miata
The Following 2 Users Say Thank You to jroc For This Useful Post:
Enki (12-14-2011), phate (12-14-2011)
 Old 12-14-2011, 07:03 AM   #47
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
I use gasoline and Qtips to clean my spill valve, and I keep a 93 Octane pump tune on my AP just in case I'm stuck in an area without an E85 pump.
Tapadatass
dougefresh_ (12-14-2011), phate (12-14-2011), rfinkle2 (12-14-2011)
 Old 04-08-2012, 10:33 PM   #48
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
subbed... for reference... thank you @silvapain !!!!
2008 MS3 gt
470hp/463tq on GT35r at 29psi
 Old 05-06-2012, 02:33 PM   #49
Vinnie's Avatar
Posts: 714   (View Stats)
Vinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the world
Groans: 76
you're the best!
'12 speed 3 CWP w/tech: DIZZY Tuned by Phate!,cobb AP,Autotech internals, cp-e nano, cp-e TIP, JBR 88 dogbone, JBR SSP/bushings, JBR rear sway bar, UR test pipe
RIP '08 speed 3 silver cp-e 75 duro RMM, cp-e intake, cp-e TIP, Jbarone SSP and bushings.
Vinnie is offline   Reply With Quote
 Old 12-12-2012, 09:40 PM   #50
Redline143's Avatar
Posts: 930   (View Stats)
Redline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the world
I broke the plastic connector off the top of the spill valve when replacing my internals with Autotechs. Help! Do you think the dealer will have it in stock? Does any one know a fast, cheap fix?
Redline143 is offline   Reply With Quote
 Old 12-12-2012, 09:43 PM   #51
Eth Fiend
phate's Avatar
You're sol unless you find someone with just a solenoid laying around. They only sell complete pumps.
-06 MS6
 Old 12-12-2012, 09:46 PM   #52
Redline143's Avatar
Are you serious?!? What would you do?
 Old 12-12-2012, 09:59 PM   #53
MSP611's Avatar
Posts: 2,291   (View Stats)
So this is the only part u need to clean when going 100% e85...
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
In progress:
 Old 12-12-2012, 10:00 PM   #54
jseams's Avatar
Posts: 1,414   (View Stats)
jseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the world
Used Mazda High Pressure Fuel Pump mazdaspeed 3 CX 7 mazdaspeed 6 | eBay
0 bids... at $150 atm.
CRMetallic 2019 Mercedes C43 AMG
SOLD MNBlue 2012 S4 Prestige... a few mods
SOLD IB 2015 3.8 Gencoupe Ultimate
BLOWED UP DIB 2014 Mustang 5.0... a few mods
SOLD - LS 2012 MS3
Cobb AP//SF//CAB
Autotech HPFP
Corksport TMIC//BPV//TIP//BTbs
JBR 88a RMM
Sure M3 TP
OBX CBE
Tanabe NF210's
ADVAN RG-D 18x8 +38
Freektuned 50/50 E85
jseams is offline   Reply With Quote
 Old 12-12-2012, 10:06 PM   #55
Redline143's Avatar
Originally Posted by jseams View Post
Thx... bidded. I'm hoping for a faster solution, though...
 Old 12-13-2012, 02:09 PM   #56
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Just out bid you by $1
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
ABSpeed3 (12-13-2012), burn813 (12-23-2012), socks (09-09-2013), speed14 (12-20-2012), Stangcobra (12-15-2012)
 Old 12-22-2012, 07:38 AM   #57
Island mazda's Avatar
Posts: 59   (View Stats)
Island mazda is infamous around these partsIsland mazda is infamous around these partsIsland mazda is infamous around these partsIsland mazda is infamous around these partsIsland mazda is infamous around these partsIsland mazda is infamous around these partsIsland mazda is infamous around these parts
Nice.
I was previously mis-understanding Phate's instructions, but this pic straightened me out and I cleaned mine up fully this morning as I had been having 2-3 excursions to RV lift pressure during pulls where as this used to be ~0 when targeting 1750PSI.
TBD if the issue is resolved.
Edit: On a side note, when did I go Orange?
What does that part makes u car do?
Island mazda is offline   Reply With Quote
 Old 12-23-2012, 08:52 PM   #58
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
The spill valve controls the high pressure rail pressure. The relief valve on the high pressure rail is the last line of defense to prevent an excessive overpressure scenario that could result in bursting of parts in the high pressure rail if the spill valve isn't controlling pressure adequately.
 Old 12-23-2012, 11:07 PM   #59
Thank u .. That info was great.. But how do I know it's mess up
 Old 12-23-2012, 11:30 PM   #60
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
if you notice your car wont go above like 60 psi of fuel(meaning only the intake pump is pumping) and the HPFP pump is not working
seems to only happen to people using E85
 Old 12-23-2012, 11:36 PM   #61
Ok thank u I learn something new .. I appricated
 Old 01-15-2013, 04:01 PM   #62
Captain
I'm gonna switch to 100% e85 once i'm done with my new fuel setup. Just reviving the thread in case there's been any new results from the various theories. As it stands now, am i right in thinking that oil seeping past the o-ring is still the primary culprit?
www.permtuning.com
 Old 01-15-2013, 04:03 PM   #63
Enki's Avatar
I'll be able to confirm it in a couple of months.
djuosnteisn (01-15-2013)
 Old 01-15-2013, 04:06 PM   #64
Captain
Are you running the secondary scraper?
www.permtuning.com
 Old 01-15-2013, 04:10 PM   #65
Eth Fiend
phate's Avatar
Its still the best theory we have.
-06 MS6
 Old 01-15-2013, 04:13 PM   #66
Enki's Avatar
No, I took it out as the pump had issues immediately again after; I probably tightened it too much and it retracted from the internals themselves, losing the scraping capability.
 Old 01-15-2013, 04:35 PM   #67
What's e85???
The Following User Says NO Thank You to Island mazda For This Un-useful Post:
SWAY (01-15-2013)
 Old 01-15-2013, 04:37 PM   #68
Search
djuosnteisn (01-15-2013), faeker (01-16-2013), phate (01-15-2013)
 Old 01-15-2013, 04:41 PM   #69
Thanks for nothing!!
The Following 2 Users Say NO Thank You to Island mazda For This Un-useful Post:
Raider (01-15-2013), SWAY (01-15-2013)
 Old 01-15-2013, 04:44 PM   #70
Captain
Search google.
www.permtuning.com
phate (01-15-2013), Raider (01-15-2013)
 Old 01-15-2013, 05:49 PM   #71
Enki's Avatar
Search
Lmfao.
djuosnteisn (01-15-2013), Raider (01-15-2013)
 Old 01-15-2013, 05:54 PM   #72
I do not care where you are in the world. You were sent this when you signed up:
http://www.mazdaspeedforum.org/forum/foru...-email-132738/
This key advice you have ignored repeatedly:3
Please visit the MSF Knowledge Base Section - MSF KB - Read me First!
If you do not follow this advice, i hope you have VERY thick skin... because you WILL get flamed.
It is also located here, where I have tried to send you unsuccessfully.
Start Here - Mazdaspeed Forums
So stop your whining and do some reading.
burn813 (01-15-2013), Enki (01-15-2013)
 Old 01-15-2013, 09:50 PM   #73
Redline143's Avatar
Wow, so I guess I joined the club today--that of needing to pull my spill valve and clean it out. I've been getting 60s in my idle fuel pressure for a few minutes on cold (~35 degree) startups over the last couple of days. I'm hoping this means I only need to clean the spill valve. I'd been running a 50/50 (E40) mix without any issues. ~2 month old internals and no super loud (internals failing) clicking noise is present. Maybe I just need to add cleaning my spill valve to my regular maintenance tasks.
So, you guys that have repeatedly had to disassemble and clean spill valves, does my experience fit the MO? I'm hoping it's just this spill valve. And this is all I can expect, not having to do the same to the internals too, over and over?
If all of this is indeed caused by a silly o-ring, gosh, what a pain! The powa is definitely worth it, though!
The Following User Says Thank You to Redline143 For This Useful Post:
phate (01-15-2013)
 Old 01-15-2013, 10:06 PM   #74
SWAY's Avatar
Posts: 2,517   (View Stats)
Groans: 190
This has been known, you shouldn't run e without the knowledge of what it's doing and what's going on.
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 01-15-2013, 10:11 PM   #75
Redline143's Avatar
I hear ya. What I was understanding was that I could avoid those issues if I stuck to a 50/50 mix or below. That's why I stuck with a 50/50 mix. If it's just the spill valve and a simple r&r/cleaning procedure that takes 20 minutes is the only trade-off, I have to say that this is a wonderful deal.
As I appraised all of the data prior to running ethanol, though, I had no idea that regular spill valve cleanings were part of the picture. Like I said, I was under the impression that all issues were averted at 50/50 and below mix levels... Lots of what's been said strongly suggests this. Oh well, you live and you learn. I'm fully warrantied until 100k anyways, so I may just get tired of dealing with it and take the car/fuel pump to a dealer at an "opportune" time That is, if all the suggestions that new fuel pumps won't encounter these issues is accurate...
The Following 2 Users Say Thank You to Redline143 For This Useful Post:
phate (01-15-2013), SWAY (01-15-2013)
 Old 01-15-2013, 10:49 PM   #76
Eth Fiend
phate's Avatar
Yeah, every once in a while someone running a 5050 or so mix will get a sticky spill valve. It usually takes quite a while between cleanings, unlike how it is with straight e85. I think it's dependent on just how much oil is getting past the O-Ring, and how much ethanol you're actually putting in (it fluctuates, no biggie).
-06 MS6
djuosnteisn (01-16-2013)
 Old 01-16-2013, 06:33 AM   #77
silvapain's Avatar
Groans: 136
Yes. Even with a second normal O-ring wedged in with the quad ring, I still had my spill valve stick when I was doing MAF calibration logs. I've stated in other threads on here that the likelyhood of the spill valve sticking increases significantly when the engine is running in high RPM, low load conditions. I believe it's oil leaking past the piston seals and coming back up into the spill valve due to the high HPFP cycle rate and low fuel demand.
 Old 01-16-2013, 10:12 AM   #78
Captain
It's obvious that the spill valve is sticking in it's "deenergized" state, since fuel pressure drops, rather than sky rockets.
I know this is all common knowledge already.. but i'm just kinda recapping to refresh my thoughts on it.
Here's the spill valve operation:
When the solenoid is energized, it allows the spill valve to operate like a check valve, forcing the compressed fuel into the rail, building pressure.
When the spill valve is de-energized, the check valve never seals, and allows the compressed fuel to flow back up stream, reducing pressure.
There are two opposing springs, one on the top of the plunger, and one below the check valve. Obviously the one on the plunger is much more stiff than the one below the check valve, otherwise the check valve would still seal in the de-energized state.
One option may be playing with the spring stiffness to see if we can help avoid the sticking. Either by making the spring under the check valve a lil bit stiffer (in a sense helping the solenoid drive the piston upward), or making the spring on top of the plunger a lil weaker. Dunno.
Another option would be potentially increasing the current flow through the solenoid giving it more power to break loose. This could be a pita, and might risk damaging the solenoid.
Obviously the ideal solution is to avoid the oil contamination... but if that's too difficult, then maybe we can work around it. I remember some people were talking about coating the plunger or whatever pieces get sticky with some sort of super slick coating. Anyone ever try that yet?
Hmmm.... i dunno, gotta get busy at day job. I'm kinda excited to run 100% e85 now. If this is our only real problem, and cleaning it periodically works... then that's not a huge deal imo. But i bet we can all come up with a proper solution.
redneck4Christ likes this.
www.permtuning.com
 Old 01-16-2013, 10:26 AM   #79
Am so happy I got my pump working now am seeing 438psi @ idle... Before I was seeing 68 to 75 psi
 Old 01-16-2013, 10:44 AM   #80
Captain
I'm happy for you too.
www.permtuning.com
Enki (01-16-2013), phate (01-16-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/how-remove-disassemble-hpfp-spill-valve-96970/
engine tappping (sorry i know its been done before).... ? Mazda MPS Owners Club This thread Refback 02-25-2015 04:24 PM
engine tappping (sorry i know its been done before).... This thread Refback 02-27-2014 09:26 AM
speed3 wont accelerate past 4k - Page 4 - DFW Mazdas This thread Refback 05-10-2013 03:25 PM
My project: Non-boosted DISI motor - Page 7 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 12-06-2012 02:45 PM
Okay, WTF was this? - Page 5 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-12-2012 02:31 PM
How do you disassemble a forge? red07 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 03-29-2009 10:28 AM
Cleanup on I-80: Oreo spill snarls traffic in IL Haltech Automotive News 0 05-19-2008 11:10 AM
Page generated in 0.61248 seconds with 36 queries
