![]() Join Date: Jun 2013
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score As the title suggests, I have an intermittent knock/rattle/chatter from the area around the hpfp or it could be coming from behind/under the engine. In the video you can hear that it comes and goes, and I can really only hear it at idle, especially after the car has been driven for awhile. Fuel pressure holds at WOT, experiencing slight increase in knock retard spikes up to 3 or 4, at low rpms, once or twice per drive, but car drives and sounds fine besides at idle. Mods: CS SRI, CS hpfp internals, CS TMIC, Cobb AP Any help or ideas would be much appreciated. |
| Is there always a chatter at idle? (VVT vs. Normal vs. HPFP)? | milkyway | CX-7 > Issues & Troubleshooting | 3 | 08-21-2016 11:42 AM |
| Intermittent 9:1 AFR at idle | BuddySpeed3 | MazdaSpeed 3/6 - ECU Computer Tuning | 14 | 04-24-2016 06:38 AM |
| Intermittent Clack / Rattle, Timing Chain Area | Eskareon | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 15 | 04-22-2016 11:43 AM |
| Intermittent metallic rattle from driver front corner | Dumbguy | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 08-06-2014 10:02 AM |
| High STFT at idle... Intermittent fault. | KevMS6 | Mazdaspeed3/6 General Discussion | 11 | 07-24-2012 06:34 PM |
