> Gen2 MS3 General Discussion
  • 1 Post By 4G63
 Old 10-07-2011, 06:33 AM   #1
Port90's Avatar
Posts: 23   (View Stats)
Port90 can only hope to improve
Default 15k miles?
Did I make a bad choice in not going with the dealerships full service maintaince for my car because it hit 15k miles. It would have included air filter, rotation but I that myself. So with those taken out the 324 price went down to 284. So I told them thats still expensive and I decided the cabin filter and wipers I could do myself. so in the end I'm paying 94 bucks for a oil change and the brake check and cleaner. I also paid 94 last time for the air filter and oil change. Is my dealership oveercharging for this stuff?
Port90 is offline   Reply With Quote
 Old 10-07-2011, 06:38 AM   #2
mingenyx's Avatar
Posts: 268   (View Stats)
mingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the world
Yes
mingenyx is offline   Reply With Quote
 Old 10-07-2011, 06:41 AM   #3
Boost Addict's Avatar
Posts: 1,327   (View Stats)
Boost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the world
I take my own filter and oil to the dealer and they charge me $13 for a change.
2008.5 BM MS3 // Cobb AP V3// JBR 3.5" WP Full Intake // CXRacing Piping/Godspeed Core // CNT 3" Catted Downpipe // Custom 3" CBE // KMD v2.1 Fuel Pump Internals // Turbosmart Dual Port BOV // Airlift Suspension // Corksport Skid Plate // JBR 88Duro Dogbone RMM // JBR SSP // SURE AGS Knob // Denso ITV22 // STACK Boost Gauge // DDM 6k Low HID's // CP-e Towplate // 15% Tint // 18x10 Blitz Type 03
FREEKTUNE
Boost Addict is offline   Reply With Quote
 Old 10-07-2011, 06:47 AM   #4
4G63's Avatar
Posts: 1,479   (View Stats)
Groans: 123
Or u could spend 20 mins and do it yourself and use the $13 on condoms and KY Jelly. I'm not saying, I'm just saying
2003 Evo VIII
The Following 4 Users Say Thank You to 4G63 For This Useful Post:
adlpb (10-07-2011), m249saw (10-15-2011), Stwok240 (10-07-2011), _riskibus_MS3 (10-07-2011)
 Old 10-07-2011, 06:57 AM   #5
Condoms are overrated anyway
FREEKTUNE
 Old 10-07-2011, 07:04 AM   #6
4G63's Avatar
Groans: 123
Yea so is lube. I like making bitches bleed
Boost Addict likes this.
2003 Evo VIII
 Old 10-07-2011, 07:08 AM   #7
Touche
FREEKTUNE
 Old 10-07-2011, 07:08 AM   #8
Most of the cost of dealer oil changes is the oil mark up.
You could either do the oil changes yourself, or ask the service advisor if you may bring your own oil.
 Old 10-08-2011, 09:48 AM   #9
Burger2002's Avatar
Posts: 33   (View Stats)
Burger2002 is a glorious beacon of lightBurger2002 is a glorious beacon of lightBurger2002 is a glorious beacon of lightBurger2002 is a glorious beacon of lightBurger2002 is a glorious beacon of lightBurger2002 is a glorious beacon of light
Do your own fluid changes. Dealers are retarded and wont be as careful or precise as you'd be.
Burger2002 is offline   Reply With Quote
 Old 10-08-2011, 09:54 AM   #10
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
Agreed. Switch to a spin on filter and its even that much easier. When you buy good oil changes are expensive enough as it is. And when you go to a dealership you never know if you are getting what you pay for...
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline   Reply With Quote
 Old 10-11-2011, 06:25 AM   #11
Jake5713's Avatar
Posts: 1,775   (View Stats)
Completely agree with that being said I have oil changes free for a year so I bring my own oil :-)
Yay for laziness
-Jake
 Old 10-11-2011, 06:33 AM   #12
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
For reference, Gen2's already have a spin-on filter. No need to convert.
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline   Reply With Quote
The Following 2 Users Say Thank You to skeurton For This Useful Post:
rfinkle2 (10-11-2011), thatsmrgimp2u (10-11-2011)
 Old 10-11-2011, 09:17 AM   #13
thank you sir
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
The Following User Says Thank You to thatsmrgimp2u For This Useful Post:
skeurton (10-11-2011)
Poor gas mileage from 260-280 miles on a tank down to 200-220 miles per tank? Matrix311 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 18 08-27-2011 07:59 PM
How Many Miles... NinjaT1985 2010 MS3 - Suspension & Brakes 5 07-28-2011 10:04 AM
Page generated in 0.32531 seconds with 28 queries
