Like Tree38Likes
 Old 09-22-2014, 09:34 AM   #1
sho
sho's Avatar
Posts: 537   (View Stats)
sho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the world
Default Sho's 2007 MS3 project
Picked up a 2007 Sunlight Silver MS3 GT August 3rd, 2012 after putting 217k miles on my '98 Saturn SL.
I got the MS3 with 25,314 miles on it after spending months searching for the right deal.
I'll be updating this thread as I do things with the car, and hopefully it'll be on the road for a long time!
Also a big shout out to NATOR OH, the guys here have helped me a ton with this car, and I couldn't be more grateful for their help!
Current Mods:
Suspension/Braking/Handling:
-Mazdaspeed Accessory Coilovers
-SPC Camber Arms
-Hotchkis 32mm Front and Rear Sway Bars, rear is on stiffest setting
-OEM Mazda Brake Rotors
-Hawk HP+ Front and Rear Brake Pads
-Stock MS6 wheels with 215/45/18 Michelin X-Ice tires
Engine/exhaust goodies:
-Manley Platinum Series 88mm Pistons
-Manley H-Beam Rods
-Autotech HPFP Internals
-HTP 3.5" Intake
-COBB Front Mount Intercooler (red piping and black core)
-Custom 2-piece 3" Catless Vband Downpipe with Top Portion Ceramic Coated
-Secondary O2 Sensor Delete
-Forge V1 Bypass Valve
-Mazdaspeed Accessory Catback Exhaust
-COBB AccessPort v3
-Cp-e Stage 1 75 duro Rear Motor Mount
-PnP Intake Manifold with VTCS Delete
-Sikky Manufacturing Thermal Insulating Intake Manifold Gasket
-James Barone Racing EGR Blockoff
-Kozmic Primary EGR Delete with Coolant Line Plug
-Kozmic Screamer Pipe
-Precision 5858CEA Journal Bearing Turbo with 4" Ported S Compressor and 2.5" Vband Outlet
-Precision 46mm External Wastegate
-Cp-e Vband Exhaust Manifold (Ceramic Coated)
-Cp-e Safe Seal Injector Seals
-James Barone Racing Stage 2 Oil Catch Can
-James Barone Racing 80d Passenger Motor Mount
-DIY Throttle Body Coolant Bypass
-James Barone Racing Thermal Insulating Throttle Body Gasket
-Bosch 3bar MAP sensor
-Grimmspeed 3 Port EBCS
-Perm PCV Plate
-Vented 2nd OCC
-PTP 1950psi Relief Valve
-Tune by Realgib3
Here's some pics i've collected along the way:
Compression test at 109.5k miles
FMIC install
Everything connected and TMIC ducting removed from hood
Jakey and V trimming my bumper as the piping was hitting some portions and not allowing the bumper to go back on the car
It fits!
Crazy routing for the piping
Hot and cold pipes so close, we took a silicone coupler and cut it and taped it to the hot pipe to keep it from rubbing on the cold pip/bpv flange
Bumper back on...stealth black core
My Rice
DVM17 and Mazdaspeed3_1993 like this.
2007 ms3 GT, sunlight silver
Manley platinum series 88mm pistons, Manley h beam rods, L19 head studs, custom cometic mlx head gasket, massive speed balance shaft delete, massive speed oil pan baffle, OEM Rod and Main bearings, vband pte 5862 .82AR journal bearing turbo, Cp-e exhaust manifold, custom 3" vband downpipe, 3" cnt Catback, pw46 ewg, tr1235 fmic, tial Q BOV on hotside pipe, 3" cold side piping, JMF V2 w/ PI, CS big TB, PERM pcv plate with jbr sealed can and ebay VTA can, custom VC vent with VTA can, SP63 gen 1 vc breather cap, Cp-e injector seals, mazdaspeed accessory coilovers, Hotchkis 32mm fsb and rsb, Damond Motorsports RMM, TMM & PMM.
FD wheels
E48 mix
Tuned by Realgib3
Purchased 8/3/12 - 25,314 miles on chassis and motor
6/21/18- 234,700 miles on chassis, 73,200 on built motor
sho is offline   Reply With Quote
The Following 6 Users Say Thank You to sho For This Useful Post:
chemmedic (06-28-2015), DVM17 (10-20-2014), J'sSpeed3 (09-22-2014), Micha (12-03-2014), pmartz16 (10-20-2014), warjunkies (11-28-2014)
Why would I not want a K04 for my project? sac02 Mazdaspeed3/6 General Discussion 52 09-09-2014 02:28 PM
Project 11s 2XS (From OZ) MazdaSpeed 3 - Engine, Transmission & Driveline 33 07-27-2010 04:05 AM
Page generated in 0.79865 seconds with 32 queries
