Like Tree38Likes
 Old 04-29-2015, 01:51 PM   #41
sho
sho's Avatar
Posts: 537   (View Stats)
sho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the world
Originally Posted by davebigenz1 View Post
Sweet ride man! This is an inspirational thread to say the least.
I do have a question: did you ever get your gauges working again? I know that in the earlier post you stated that you removed the sammich plate. Only reason why I ask is because I am looking to get a plate and I don't know if I should buy glowshift or prosport?
The Gauges do not work. All the senders failed 3 times, and then I gave up on them. DO NOT get the pro sport Gauges. I've yet to see them last on anyone's car
2007 ms3 GT, sunlight silver
Manley platinum series 88mm pistons, Manley h beam rods, L19 head studs, custom cometic mlx head gasket, massive speed balance shaft delete, massive speed oil pan baffle, OEM Rod and Main bearings, vband pte 5862 .82AR journal bearing turbo, Cp-e exhaust manifold, custom 3" vband downpipe, 3" cnt Catback, pw46 ewg, tr1235 fmic, tial Q BOV on hotside pipe, 3" cold side piping, JMF V2 w/ PI, CS big TB, PERM pcv plate with jbr sealed can and ebay VTA can, custom VC vent with VTA can, SP63 gen 1 vc breather cap, Cp-e injector seals, mazdaspeed accessory coilovers, Hotchkis 32mm fsb and rsb, Damond Motorsports RMM, TMM & PMM.
FD wheels
E48 mix
Tuned by Realgib3
Purchased 8/3/12 - 25,314 miles on chassis and motor
6/21/18- 234,700 miles on chassis, 73,200 on built motor
sho is offline   Reply With Quote
 Old 04-29-2015, 02:26 PM   #42
pmartz16's Avatar
Posts: 1,140   (View Stats)
There is a kit from Damon motorsports that will extend the factory oil pressure sensor out and then T it off so you can add in a gauge. Sammich plate is a pain from my experience.
2014 Mz3 MG
 Old 04-29-2015, 02:43 PM   #43
davebigenz1's Avatar
Posts: 17   (View Stats)
davebigenz1 is a jewel in the roughdavebigenz1 is a jewel in the roughdavebigenz1 is a jewel in the rough
@sho, Noted! I got some glowshift gauges because many of the members in different post have said the same about prosport. Some even call them poopsport. I figured that would be something to stay away from.
@pmartz I will have to look into this. I was going to get a oil conversion spin-on, which I read is a really good mod to do on the 07's.
davebigenz1 is offline   Reply With Quote
 Old 04-29-2015, 02:45 PM   #44
pmartz16's Avatar
Yep sho and I both have the conversion. Makes oil changes much easier. Also for future reference when tagging someone put @ before their name and a semi colon ; after. Like @davebigenz1;
2014 Mz3 MG
The Following 2 Users Say Thank You to pmartz16 For This Useful Post:
CMajor (07-21-2015), sho (04-29-2015)
 Old 05-05-2015, 05:29 PM   #45
sho
sho's Avatar
Rolled 145k miles today. 20k since going BT. Did a compression test as well
FD wheels
E48 mix
Tuned by Realgib3
The Following User Says Thank You to sho For This Useful Post:
Realgib3 (05-05-2015)
 Old 05-07-2015, 06:50 AM   #46
pmartz16's Avatar
True testament to the strength of that engine, cylinder #3 is higher than the rest. Weird, defies all logic.
2014 Mz3 MG
The Following User Says Thank You to pmartz16 For This Useful Post:
sho (05-07-2015)
 Old 05-20-2015, 09:09 AM   #47
sho
sho's Avatar
I just want to say, I love this Fucking turbo
FD wheels
E48 mix
Tuned by Realgib3
 Old 05-25-2015, 08:46 AM   #48
sho
sho's Avatar
Did an autox yesterday. Strange course with odd spacing of the slaloms and such, but still had fun.
FD wheels
E48 mix
Tuned by Realgib3
Realgib3 (05-25-2015)
 Old 06-01-2015, 08:10 PM   #49
sho
sho's Avatar
I know I already posted pics from ENM, but I forgot to add these after raider ripped my side moldings off
FD wheels
E48 mix
Tuned by Realgib3
The Following 4 Users Say Thank You to sho For This Useful Post:
09TrueRedGTX (06-03-2015), ItsNox (06-03-2015), pmartz16 (06-02-2015), TRBLSM (06-23-2015)
 Old 06-27-2015, 10:09 PM   #50
sho
sho's Avatar
One step closer to moar power. The cobb fmic piping sucks, as far as routing goes. Soo...picked up new hot side piping from @pmartz16; . And soon will be picking up a cold side from Kevin tapped for meth injection, as well as a meth kit that will be supplying 1000cc of methanol for aux fueling and we'll see how far we can push this old and tired beast.
Dem pipes
FD wheels
E48 mix
Tuned by Realgib3
 Old 07-06-2015, 09:15 AM   #51
sho
sho's Avatar
My timing chain has finally loosened up, so new timing gear has been ordered and likely will be replaced this week. Kinda scared to open up the 154k+ motor. But it needs done...
FD wheels
E48 mix
Tuned by Realgib3
 Old 07-06-2015, 09:18 AM   #52
pmartz16's Avatar
I'm about to molest that unicorn!
2014 Mz3 MG
sho (07-06-2015)
 Old 07-06-2015, 10:13 AM   #53
sho
sho's Avatar
Please be gentle with her, sir!
FD wheels
E48 mix
Tuned by Realgib3
 Old 07-13-2015, 08:45 PM   #54
sho
sho's Avatar
Lots of things done over the past 2 days.
Timing chain, vvt, and all that good stuff replaced Sunday at 155.2k miles. Everything was fairly clean inside the motor and the vvt actuator definitely had some play in it and the chain was a bit loose. Thanks @pmartz16; for doing the timing job.
Checked the turbo, and zero shaft play after 30k miles on it!
Also found these gnarly holes in the stupid Cobb v1 piping
Sooo...went "custom"and used cx racing hot side piping and pieces of random Cobb piping to make the cold side
FD wheels
E48 mix
Tuned by Realgib3
Last edited by sho; 07-13-2015 at 08:47 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to sho For This Useful Post:
pmartz16 (07-13-2015), Realgib3 (07-14-2015)
 Old 07-28-2015, 02:26 PM   #55
sho
sho's Avatar
Last night the coolant line going to the oil cooler broke off at the male/male coupler from when the BT swap went down and the line was rerouted.
Pulled into a gas station and must've run something over as the coupler snapped and I also had a dent and hole in the oil filter. Got her patched up in a few hours with some new line, clamps and oil filter. Scared the shit out of me as I was letting the car idle down before I shut it off and all of a sudden smoke started pouring out of the hood and coolant was pissing out the front of the car.
Here's the aftermath. .
Realgib3 likes this.
FD wheels
E48 mix
Tuned by Realgib3
 Old 08-07-2015, 04:13 PM   #56
sho
sho's Avatar
Soooooo...there's this:
SP63 pro series pistons and oem mazda parts also on their way.
FD wheels
E48 mix
Tuned by Realgib3
pmartz16 (08-10-2015)
 Old 08-07-2015, 04:28 PM   #57
zjnspeed3's Avatar
Posts: 1,436   (View Stats)
You're waiting on their pistons too? Lol we are in the same boat! Love the progress by the way!
The Following 2 Users Say Thank You to zjnspeed3 For This Useful Post:
pmartz16 (08-10-2015), sho (08-07-2015)
 Old 08-10-2015, 12:12 PM   #58
sho
sho's Avatar
Some clips from a fun run @Lewis7789; and I did yesterday to and from a meet.
Also got to meet up with @ms3blackmica; and Norm at Summit Racing on their way back from the DSM shootout! Good weekend!
FD wheels
E48 mix
Tuned by Realgib3
Last edited by sho; 08-10-2015 at 12:19 PM. Reason: MSF Database - Automerged Doublepost
ms3blackmica (08-10-2015)
 Old 08-11-2015, 09:13 AM   #59
Lewis7789's Avatar
Posts: 290   (View Stats)
Lewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the world
I thought videos with corners were banned from MSF? trolol.
T'was a good time indeed, buddy. We'll have to do it again on a weekday with less traffic, Corvettes and Harleys.
2006 MS6 aka "Fatty". Only 278hp but I'll catch you in the corners.
Lewis7789 is offline   Reply With Quote
 Old 08-14-2015, 11:37 AM   #60
sho
sho's Avatar
Small update:
Getting a crank from @Realgib3;
Pistons will hopefully be here next week. Once they are here, can drop em off to the machine shop for boring and final hone. Then assembly time!
FD wheels
E48 mix
Tuned by Realgib3
Realgib3 (08-14-2015)
 Old 08-20-2015, 06:44 PM   #61
sho
sho's Avatar
Motor should be ready and in the car next weekend!
Realgib3 and pmartz16 like this.
FD wheels
E48 mix
Tuned by Realgib3
SpeedRebirth (08-21-2015)
 Old 08-20-2015, 10:26 PM   #62
zjnspeed3's Avatar
Which pistons did you switch to since SP63's are backordered? And how did you find out about the backordering?
 Old 08-21-2015, 02:02 AM   #63
shaneski's Avatar
Posts: 505   (View Stats)
They be Manley pistons by the look of it. I thought SP63 had new stock of their Mahles.
The Following User Says Thank You to shaneski For This Useful Post:
sho (08-21-2015)
 Old 08-21-2015, 06:09 AM   #64
zjnspeed3's Avatar
They did... Then the wrist pins were the wrong size.. Now no more pistons.
The Following User Says Thank You to zjnspeed3 For This Useful Post:
shaneski (08-21-2015)
 Old 08-21-2015, 07:05 AM   #65
sho
sho's Avatar
Sp63 cancelled my order early this week for the Mahle pistons even though they were supposedly in stock when the order was placed. Ended up calling edgeautosport and scooping up their last set of 88mm Manley platinum series.
FD wheels
E48 mix
Tuned by Realgib3
 Old 08-21-2015, 07:11 AM   #66
zjnspeed3's Avatar
Damn.. I might have to do that now..
 Old 08-24-2015, 12:16 PM   #67
sho
sho's Avatar
Grabbed a new thermostat yesterday. All thats left is for the shortblock to be back from the machine shop and to assemble. The anticipation is killing me, especially since im taking friday through Monday off from work.
zjnspeed3 likes this.
FD wheels
E48 mix
Tuned by Realgib3
pmartz16 (08-25-2015), Realgib3 (08-24-2015)
 Old 08-28-2015, 08:30 PM   #68
sho
sho's Avatar
Eventful day.
Long block was assembled minus the manifolds and turbo. Stock block and trans pulled with 161.5k miles (still running strong with 180+ compression).
Tomorrow, manifolds, turbo, and trans will be out on the new block and dropped into the car!
FD wheels
E48 mix
Tuned by Realgib3
pmartz16 (08-28-2015), SpeedRebirth (08-29-2015), TJM216 (08-29-2015), TRBLSM (08-29-2015)
 Old 08-29-2015, 10:33 PM   #69
sho
sho's Avatar
Motor is in and has 75 miles on it now. Have a small coolant leak on the small line going to the thermostat, up near the clamp; that starts to drip once the car has been shut off for a few minutes and then stops. Will just need to cut the hose where it is torn from the clamp and reattach. Otherwise, just need to put some miles on this thing and get it broken in!
FD wheels
E48 mix
Tuned by Realgib3
pmartz16 (08-30-2015)
 Old 08-31-2015, 04:06 PM   #70
sho
sho's Avatar
Moar update. Coolant leak is now fixed! Also, yesterday once I hit 200 miles, I started to get into boost a little bit...and got a bad cylinder 1 misfire. Tracking back to everything done during the swap, I remembered that my injector for cylinder 1 got stuck in the soft ass aluminum cp-e injector hammer and that we replaced it with a spare injector. Swapped the injector out as well as the harness and issue is gone! Just about 400 miles on her now. Will do 4th oil change at 500 miles and then do a compression test later in the week and see what's what. Vacuum is sitting at a nice -10.27psi at idle now.
FD wheels
E48 mix
Tuned by Realgib3
Etipp98 (08-31-2015), pmartz16 (08-31-2015)
 Old 09-07-2015, 03:00 PM   #71
sho
sho's Avatar
Welp, went to do a WOT log this afternoon and my dip stick popped out and sprayed oil everywhere lol. Time to vent some crankcase pressure. In the mean time, til I get that done...no WOT for me
FD wheels
E48 mix
Tuned by Realgib3
 Old 09-08-2015, 07:06 PM   #72
sho
sho's Avatar
Soooo...dipstick popped out yesterday at 22psi...got oil on everything. My map sensor has also been acting up and giving very erratic readings since the night before. Pulled the intake mani to clean up the fuel rail, all connectors, etc from all the oil.
Map sensor was doused on the outside with oil. Cleaned it and all connections with q-tips (no chemicals), put the car back together and she runs well, however MAP reads -6psi all the time and 122BAT at all times now with the clean connectors. Looks like I'll be Picking up a new map sensor here shortly....and hopefully the pnp harness is alright. Thanks to @Enki; for helping troubleshoot online with me.
FD wheels
E48 mix
Tuned by Realgib3
Enki (09-09-2015), Realgib3 (09-09-2015)
 Old 09-09-2015, 08:35 PM   #73
sho
sho's Avatar
Grabbed another 3 bar this afternoon from a local friend, swapped it out out....aannnd same issue. Was suggested to check the wires on the pnp harness as another person in Ohio had a similar issue which was caused by a loose wire.
So, checked continuity on each wire on the pnp harness and found this bastard wire that's circled had nothing..
Pulled the plug apart and found the wire wasn't even touching the connector. Ended up having to add some length, solder it in and heatshrink the added wire until I get another harness in the mail, but it works now...no more whacky readings or it being stuck at 122 BAT and -6psi all the time! Don't mind the high LTFT, I had reflashed and cleared the codes it was throwing for the map sensor right after getting everything back together
Now to vent this crankcase pressure so I can go WOT and get some logs in. Hopefully will have that sorted this weekend
FD wheels
E48 mix
Tuned by Realgib3
 Old 09-09-2015, 11:23 PM   #74
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
If the dipstick popped you may need to check the PCV and make sure it's not leaking oil like nuts in the intake, and also do a compression/leakdown test. 22PSI is a bit early for the dipstick to pop out, mine didn't pop at 28-29, and not only that it did not pop, I could barely see any oil on that o-ring from the top end...
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 09-10-2015, 05:46 AM   #75
sho
sho's Avatar
The intake manifold was clean and dry inside when I pulled it to clean everything, it likely didn't help that I didn't realize that the dipstick popped out and drove probably 15-20 miles to get e85 with it popped out.
Compression test will be happening this weekend
FD wheels
E48 mix
Tuned by Realgib3
 Old 09-17-2015, 09:48 PM   #76
sho
sho's Avatar
Compression test done this evening.
190-190-190-191
Also got the crankcase pressure issue solved last night. VTA setup ftw. was able to take a WOT log without popping the dipstick out, and this bitch is flowing some air!
FD wheels
E48 mix
Tuned by Realgib3
aackthpt (09-18-2015), Realgib3 (09-18-2015)
 Old 09-28-2015, 10:05 AM   #77
sho
sho's Avatar
Tuning is underway! Experiencing a little boost creep up top, which I don't have the fuel for...but, we'll get it figured out. I need to sell my body so I can afford some aux fueling
FD wheels
E48 mix
Tuned by Realgib3
The Following 3 Users Say Thank You to sho For This Useful Post:
impossible (02-02-2016), pmartz16 (09-28-2015), Realgib3 (09-28-2015)
 Old 10-14-2015, 07:52 PM   #78
sho
sho's Avatar
CS PMM is absolutely driving me insane. Was tolerable on worn bushings, but after 3k miles on new bushings, I can't hear myself thinking in the car. Getting pulled out this weekend until I can get my hands on some DM or cp-e side mounts
FD wheels
E48 mix
Tuned by Realgib3
 Old 10-14-2015, 08:42 PM   #79
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Buy my 80 duro JBR. Profit. LOL
Silver 2007 Speed3 GT
 Old 10-15-2015, 08:34 AM   #80
aackthpt's Avatar
Posts: 1,450   (View Stats)
...said as we all thank Raider for the loosened rules...
2013 'speed3, silver
Stage Bro
Why would I not want a K04 for my project? sac02 Mazdaspeed3/6 General Discussion 52 09-09-2014 02:28 PM
Project 11s 2XS (From OZ) MazdaSpeed 3 - Engine, Transmission & Driveline 33 07-27-2010 04:05 AM
Page generated in 0.59622 seconds with 28 queries
