Like Tree349Likes
 Old 03-13-2015, 09:27 AM   #41
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
buying axles from the drive shaft shop or whomever and then shipping them to greece is likely more expensive and a headache so I can see him making axles as a better option so please think about the entire picture.
 Old 03-13-2015, 10:08 AM   #42
Jarods7920's Avatar
Posts: 1,415   (View Stats)
So are the rear axles from the states made by driveshaft shop or are they custom parts made on your side of the pond?
They look to be DSS based on the pictures and parts used on them.
Questions i have are... what do you percieve the advantage to be for the diffcuff? I have seen things used on the inside of the trans, but never the outside of a case like you have done. So, if you dont mind i would love some insight into your thoughts. Seems like a good idea.
Do you have any pictures of how you modified the CX-7 lateral arms? I had some one once tell me what i did was incorrect and would not work, so curious to see if you did somethign similar to what i did or went a different route.
Lastly, ABS does yours work in the rear? If so what did you do to get it to work? I have kicked around various ideas for it, but never settled on anything.
 Old 03-13-2015, 12:06 PM   #43
RE-ACTIONENGSPEED3's Avatar
Posts: 401   (View Stats)
Lets take it from the begining .The 2 rear axles are from driveshaft shop the rear left(driver side)is the same length as speed6 has the rear right(pass side)is custom order ,i have also changed the abs ring and put it at the same place the cx7 has it.If i buy oem axles for speed6 from my country is much expensive than buy the upgraded one`s from DSS .
As for the rear subframe . I start by put all the cx7 rear subframe as it is to see and mesure what it needs cut.So i cut the cx7 lower arms just near the bumb stops and shortened them and weld the again.Then i make the toe arms adjustable so that they can fit at whatever length i need.After, i finished with those i take camber arms from the ms3 and cut them and weld them(i have also mesure them so that they will fit correct).
As for the ABS i just weired the abs cables from the cx7 system (non magnetic) to the speed3 cables. I get no ABS faults.I also try yesterday that it is raining here and push the brake for instant stop from 60mph to 0 and the abs works normal(i`m not sure 100% if at the rear wheels really have abs) but since i try it and seems to work plus i have no fault lights i assume it is fine.
Finnaly my thought about the handcuf on the transfercase was that when you launch the car all the transmison parts streched so i try by some way to reduce that strech .
Have in mind that i have also put upgraded bearing cups in it and of course i have replaced all the bolts that tightens it with biger arp`s ..
ItsNox likes this.
2008 speed3
True red.
Pte 6466 & AWD Mode on !!!!
The Following 13 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
ButtholeRedMS3 (01-06-2016), chris323 (03-16-2015), daafisch (06-24-2015), Easter Bunny (03-13-2015), harryclay (03-21-2015), ItsNox (03-15-2015), JSmith (03-13-2015), maisonvi (03-13-2015), mituc (04-09-2015), redneck4Christ (07-10-2015), Rich990 (08-13-2015), stanley0910 (03-15-2015), torquemaniac (09-16-2015)
 Old 03-13-2015, 12:52 PM   #44
Jarods7920's Avatar
You wouldnt happen to have any picture of the the ABS rings and such that you used would you or pictures of the axles and how you installed the rings?
 Old 03-13-2015, 01:02 PM   #45
i do not have but next time i will raise the car i will take some photos to send you...
2008 speed3
True red.
The Following 2 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
chris323 (03-16-2015), Easter Bunny (03-13-2015)
 Old 03-13-2015, 01:12 PM   #46
Jarods7920's Avatar
That would be fantastic! I was not aware that both systems could play together like that...rings and magnetic.
 Old 03-13-2015, 04:06 PM   #47
SpencerC's Avatar
Posts: 2,159   (View Stats)
Most impressive. Wow.
 Old 03-13-2015, 04:15 PM   #48
Brandon@corksport's Avatar
Posts: 170   (View Stats)
Beyond words!
Cheers,
Brandon Johnson
CorkSport Mazda Performance
(360)260-2675 ext. 106
BrandonJ@corksport.com
 Old 03-14-2015, 07:17 AM   #49
Filthylookalike's Avatar
Posts: 39   (View Stats)
Filthylookalike is a name known to allFilthylookalike is a name known to allFilthylookalike is a name known to allFilthylookalike is a name known to allFilthylookalike is a name known to allFilthylookalike is a name known to all
you sir... are a rockstar!
Filthylookalike is offline   Reply With Quote
 Old 03-14-2015, 04:08 PM   #50
GiannhsAtenza's Avatar
Posts: 1   (View Stats)
GiannhsAtenza has a spectacular aura aboutGiannhsAtenza has a spectacular aura aboutGiannhsAtenza has a spectacular aura about
Theo , you and your crazy team behind your car never let us down ! I've known you and your car for some years and all i can say is just good luck with it ! I ll be there to see your efforts in to the 9 secs ! You deserve something like this !
Every Mazda owner in Greece is proud because of you ! Keep it up !
Who you choose to be around you , lets you know who you are....
GiannhsAtenza is offline   Reply With Quote
The Following 4 Users Say Thank You to GiannhsAtenza For This Useful Post:
ASHMS3 (03-14-2015), RE-ACTIONENGSPEED3 (03-15-2015), redneck4Christ (07-10-2015), Rich990 (08-13-2015)
 Old 03-15-2015, 07:27 AM   #51
stanley0910's Avatar
Posts: 364   (View Stats)
stanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the world
This is an awesome build, I really wish you luck breaking some records this year.
Need more parts.
stanley0910 is offline   Reply With Quote
 Old 03-15-2015, 08:41 AM   #52
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
Performance:
Stratified Tune in progress
 Old 03-15-2015, 09:30 AM   #53
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Sick build... AWD Speed 3 with all the built goodies and a 6466, definitely looking forward to seeing some passes in the 1/4
 Old 03-15-2015, 11:12 AM   #54
my2k13speed3's Avatar
Posts: 2,325   (View Stats)
@RE-ACTIONENGSPEED3; Μπράβο φίλε μου πολύ ωραίο
darkmx-6 likes this.
 Old 03-15-2015, 05:07 PM   #55
daytonabluez05's Avatar
Posts: 222   (View Stats)
daytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant future
subbed for progress, looks awesome
daytonabluez05 is offline   Reply With Quote
 Old 03-16-2015, 01:46 AM   #56
This weekend we have some body work done.Added a fiberglass rear trunk door with the oem windsield.Weight reduction for 9.2kg((20.2 pounds).Next comes some modification to the front bumper.
File Type: jpg image-4546329945c03f257c718dd7b0b87250e5853e5b03064cb38b30babcc35411be-V.jpg (230.2 KB, 94 views)
File Type: jpg image-9413402e2badae6d9c65cf71e043a23b3371bdfaa1a6bdece8514354625c45f2-V.jpg (175.8 KB, 96 views)
File Type: jpg image-5927ecea58d615af4b8663113ac2de82dd3c1851fbd88864036e913bec61639e-V.jpg (236.9 KB, 98 views)
File Type: jpg image-8bda163d493cbcd8dc13eef24d88a2f4422c61d1577d146276920cfb22a4bd6b-V.jpg (247.7 KB, 106 views)
File Type: jpg image-1dd975268a9d49ecaa84f624f0977e720eed0c9db9837d6e2291889526ef354b-V.jpg (227.5 KB, 98 views)
2008 speed3
True red.
The Following 35 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
ArmanRus (03-16-2015), aviator79 (04-09-2015), brandon3212 (03-18-2015), ButtholeRedMS3 (01-06-2016), chris323 (03-16-2015), Cpt_Rum-bo (03-16-2015), cshunter (03-16-2015), daafisch (06-24-2015), Easter Bunny (03-16-2015), harryclay (03-21-2015), Hush (03-16-2015), impossible (06-16-2015), ItsNox (03-16-2015), JgamB (03-26-2015), Jtaylor (03-16-2015), Justin@Freektune (03-21-2015), maisonvi (03-16-2015), Mattyhawk1 (03-16-2015), mazdakaps (03-16-2015), Mr Wilson (03-16-2015), ms3steeez (03-16-2015), mxlplx71 (03-28-2015), Pu Manchu (03-17-2015), punkk77 (03-17-2015), Scare Dem (03-16-2015), Shwaykid (03-26-2015), SpeedRebirth (03-16-2015), Swinger13 (03-16-2015), taf0422 (03-16-2015), TiGraySpeed6 (03-16-2015), torquemaniac (04-11-2015), trancehead (04-01-2015), Vansquish (03-16-2015), WA_MS6 (04-01-2015), [R]usty (09-14-2015)
 Old 03-16-2015, 07:04 PM   #57
Jtaylor's Avatar
Posts: 656   (View Stats)
Can't wait to see you make a pass in this thing! With thoughts of eventually revving till 8500, any concerns with the oil pump being able to hold oil pressure at those speeds?
08 MazdaSpeed3
 Old 03-16-2015, 07:09 PM   #58
Swinger13's Avatar
Groans: 53
That trunk looks exactly like OEM well done
Performance:
 Old 03-16-2015, 07:19 PM   #59
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
This is one impressive build. Definitely keep up the good work and keep us updated
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 03-17-2015, 01:35 AM   #60
I think(hope) it will be fine...
2008 speed3
True red.
 Old 03-26-2015, 11:16 PM   #61
JgamB's Avatar
Posts: 2,566   (View Stats)
10 days and no updates. I have a thirst for progress greater than a wanking teen scouring the web for Kate Upton nudes.
tom3mps, ItsNox and lolwrx like this.
The Following 4 Users Say Thank You to JgamB For This Useful Post:
Easter Bunny (03-28-2015), ItsNox (03-27-2015), Mauro_Penguin (03-28-2015), Vansquish (03-26-2015)
 Old 03-27-2015, 08:13 AM   #62
POE
POE's Avatar
Posts: 46   (View Stats)
POE is a glorious beacon of lightPOE is a glorious beacon of lightPOE is a glorious beacon of lightPOE is a glorious beacon of lightPOE is a glorious beacon of lightPOE is a glorious beacon of light
I want to hear this beast bark on a green light. We need an action video.
lolwrx likes this.
POE is offline   Reply With Quote
 Old 03-28-2015, 04:37 AM   #63
Today I changed my oil i have already make 450mp/h...Everything looks fine, no leaks....
I also have the abs light turned on and i was anxius to see what was wrong , so luckily the front right sensor(unhooked from his positionn) was touching the inner side of my tyre.So we cut it at the place it is damged and re wired it again and everything works just fine.I have also started to give some boost about 14psi and it looks very alive...
I will make another 200mp/h then change to High performance oil (Red Line 10-40) and start to pushing it hard...
I also find some time and weight my car, 3200lbs with full interior and oem wheels...
2008 speed3
True red.
The Following 18 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
09TrueRedGTX (03-28-2015), chris323 (03-28-2015), Code Monkey (03-28-2015), Cpt_Rum-bo (03-28-2015), daafisch (06-24-2015), ItsNox (03-28-2015), JgamB (03-29-2015), Justin@Freektune (03-28-2015), Mauro_Penguin (03-28-2015), mazdakaps (03-28-2015), mxlplx71 (03-28-2015), predapio (04-09-2015), Scare Dem (03-28-2015), Snyeed (03-28-2015), Swinger13 (03-28-2015), torquemaniac (04-11-2015), Vansquish (04-01-2015)
 Old 03-28-2015, 06:30 AM   #64
SyntheticAtmosphere's Avatar
Posts: 193   (View Stats)
SyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond repute
You sir have ascended to car god! I will use this thread to prove to people what this platform can do!
manu likes this.
SyntheticAtmosphere
'06 Speed6 Whitewater Pearl (COBB AP v2, CS s2 SRI/TIP, Autotech HPFP, Cp-e RMM&RDM, Fidanza/LuK, homebrew Testpipe&OCC) next...meth habit
If it feels good, do it...Even if you shouldn't!
SyntheticAtmosphere is offline   Reply With Quote
 Old 04-01-2015, 12:20 AM   #65
Make some more miles today, about 120mp/h ,i have started to give some boost ...
2008 speed3
True red.
The Following 15 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
1cms1 (04-02-2015), 2eatV8everyday (06-24-2015), chris323 (04-01-2015), Code Monkey (04-01-2015), Hammology (06-19-2015), ItsNox (04-01-2015), Jtaylor (04-04-2015), levon.mark (04-01-2015), MattyP617 (04-09-2015), mazdakaps (04-01-2015), predapio (04-09-2015), pyrophelia (04-02-2015), Scare Dem (04-01-2015), torquemaniac (04-11-2015), Vansquish (04-01-2015)
 Old 04-01-2015, 12:45 AM   #66
WA_MS6's Avatar
Posts: 459   (View Stats)
This is beautiful. You sir, are winning more than you think!
2007 Black Mica Mazdaspeed6
AutoTech HPFP Internals
CorkSport Front Mount Kit
CP-e CBE Single Exit Exhaust
Koni Yellows
 Old 04-01-2015, 01:00 AM   #67
Shwa's Avatar
Posts: 322   (View Stats)
And there's a dude who actually started a thread about being bored with his speed, when this is going on. Awd monster 3 and Enki deleting his IC are more than enough to keep me entertained, albeit vicariously.
Speed on you magnificent man, we're all behind you for support and reach around.
The Following 4 Users Say Thank You to Shwa For This Useful Post:
Easter Bunny (04-01-2015), JgamB (04-01-2015), manu (12-15-2016), Vansquish (04-01-2015)
 Old 04-01-2015, 01:23 AM   #68
Mastertrixter's Avatar
Posts: 386   (View Stats)
Mastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the world
Oh you beautiful fucking bastArd you!!!!!
I cannot wait to seevideo of this beast ripping through the gears at full boost!
2011 speed 3
BNR s3 v2
snow performance wmi
dammon occ, egr deletes
htp 3"
cx piping with tr6 core
ebay dp
corksport catback
autotech internals
grimmspeed 3port
turbosmart bpv
3bar
jbp ssp, weight, bushings, rmm, and rsb
koni oranges with road magnet springs
motegi mr116 18x8 +45
Powered by PURPLE DRANK
350/360 vdyno cf 1.01 on 91 pump only
Mastertrixter is offline   Reply With Quote
The Following User Says Thank You to Mastertrixter For This Useful Post:
 Old 04-01-2015, 07:09 AM   #69
Yatta's Avatar
Posts: 1,862   (View Stats)
Not just Greece, in awe from Colorado....
 Old 04-09-2015, 12:34 AM   #70
More body work this week .I relocate the battery under the rear seats with a custom welded box , i also make some drils on the front bumber for more air to fmic and made a custom air box to drive the air to the oil cooler...
Enjoy...
2008 speed3
True red.
The Following 33 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
09TrueRedGTX (04-10-2015), 2eatV8everyday (06-24-2015), ArmanRus (04-11-2015), ButtholeRedMS3 (01-06-2016), Code Monkey (04-09-2015), Cpt_Rum-bo (04-09-2015), daafisch (06-24-2015), Easter Bunny (04-09-2015), g00s3y (04-09-2015), Hammology (06-19-2015), harryclay (05-22-2015), Ingle (04-13-2015), ItsNox (04-09-2015), Jarods7920 (04-09-2015), JgamB (04-09-2015), JSmith (04-09-2015), Jtaylor (04-09-2015), manu (12-15-2016), Mattyhawk1 (04-13-2015), MattyP617 (04-09-2015), Mauro_Penguin (04-09-2015), mazdakaps (04-09-2015), Mr. T (04-09-2015), mxlplx71 (04-09-2015), predapio (04-09-2015), Raider (04-09-2015), Scare Dem (04-09-2015), Shwaykid (04-09-2015), Swinger13 (04-09-2015), tastysi2004 (07-25-2015), TiGraySpeed6 (04-09-2015), torquemaniac (04-11-2015), WA_MS6 (04-09-2015)
 Old 04-09-2015, 01:33 AM   #71
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Wait! So this build is the most extreme MS3/3MPS build ever done by my knowledge, right?
I can't not to remember Erich, Realgib, Lumperjack and possibly others who made it into the 700whp territory with a MS3, but I'm pretty sure this greek 3MPS will not make 6th gear burn-outs at 250Kmph.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
ItsNox (04-09-2015), RE-ACTIONENGSPEED3 (04-09-2015)
 Old 04-09-2015, 10:01 AM   #72
speed3 britz's Avatar
Posts: 1,155   (View Stats)
@maisonvi; you need ducting like this!
 Old 04-09-2015, 10:38 AM   #73
ItsNox's Avatar
Posts: 3,076   (View Stats)
I haven't wanted a speed 3 until now. Just incredible. Thank you for doing it right, sir. I have a permanent chub now.
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 04-09-2015, 10:52 AM   #74
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Βάλτε τους όρχεις σας στο τραπέζι
(You put your balls on the table.)
Well done
What a lovable bunch we are!!
ItsNox (04-09-2015), Rich990 (08-13-2015)
 Old 04-09-2015, 12:06 PM   #75
Swinger13's Avatar
Groans: 53
could be just my eyes and/or the pictures, but it looks like the battery box sitson the exhaust piping or into it?
Performance:
 Old 04-09-2015, 12:20 PM   #76
dan7225's Avatar
Posts: 511   (View Stats)
dan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the world
Groaned at 20 Times in 11 Posts
all of your dash lighting and display panel are blue/white as well, nice
dan7225 is offline   Reply With Quote
The Following User Says Thank You to dan7225 For This Useful Post:
 Old 04-09-2015, 12:53 PM   #77
mituc's Avatar
Groans: 111
Not that nice for long night drives, but easier to see in every condition.
 Old 04-09-2015, 01:45 PM   #78
The exhaust comes about 2 inch on the side of the battery box.
2008 speed3
True red.
 Old 04-09-2015, 05:06 PM   #79
aviator79's Avatar
Posts: 3,934   (View Stats)
HOW did you make this? amazing.
 Old 04-10-2015, 05:33 AM   #80
brandontrek's Avatar
Posts: 132   (View Stats)
brandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the world
do you have any more detailed pictures of the drivers side high beam intake duct?
brandontrek is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f541/pte-6466-awd-conversion-185595/
ClubC4 ? Vezi subiect - Fun This thread Refback 12-19-2015 01:37 AM
Articole interesante despre masini - Pagina 46 - Cafenea - Club Mazda This thread Refback 12-18-2015 10:34 PM
Pte 6466 & AWD conversion - Page 3 - Mazdaspeed Forums This thread Refback 06-24-2015 04:14 AM
?????? ?????? ?? Mazda 3 mps AWD This thread Refback 05-07-2015 04:11 AM
Articole interesante despre masini - Pagina 36 - Cafenea - Club Mazda This thread Refback 04-09-2015 12:46 PM
? View topic - Trying for a 9 !! 1/4 Mile in a MPS3 This thread Refback 03-15-2015 05:11 AM
Çàåçäû (÷àñòü 2 - íîâûé ñåçîí!) (Ñòð.314) / ×åëÿáèíñê — FFClub This thread Refback 03-12-2015 08:30 AM
di to pi conversion cbspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 7 04-05-2009 09:48 PM
HID Conversion Kit SpdFreak MazdaSpeed 3/6 - Car Audio & Electronics 62 01-27-2009 05:18 AM
Page generated in 0.58164 seconds with 48 queries
