Like Tree5Likes
 Old 01-01-2013, 06:34 PM   #1
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
Default CP-e Stage 2 pistons compared to stock for some discussion
After Ant had problems with his motor I started to question my build. Luckily I haven't assembled the motor yet so it allowed for some measurements to be taken.
Anyone that has assembled these motors knows the skirts on Wiseco's causes interference with the oil squirters so they have to be bent ever so slightly for clearance. We have two local motors done this way and making big power without issues in Djuosnteisn and Papasmurf. The situation was brought up that the CP-E skirts were even longer on the stage 2 Genpu copy pistons even though they are made by Wiseco. I took some pics and what I see says otherwise.
First, the skirts are no longer than stock from a few different measurements. Overall they are shorter top to bottom seen here:
Gen Juan:
Genpu, which is the longest:
CP-E:
From the bottom of the wrist pin hole to the bottom of the skirt the CP-E pistons are slightly shorter as well. I had to use a flat piece of metal running across the piston to get this measurement then just held it up for pictures.
Gen Juan:
Genpu, longest again:
CP-E:
The stock piston skirts are also the same depth their whole width while the CP-E pistons come down with a wider skirt to start and then taper to the lowest part.
Gen Juan:
Widest part of CP-E:
Narrow part of CP-E:
Realizing I didn't take picture of the side with oil squirter notches, here is the info:
Compared Notches:
Width of Genpu skirt including oil squirter notch:
Width of CP-E including notch:
Width of Genpu notch:
Width of CP-E notch:
Depth of Genpu notch:
Depth of CP-E notch:
Now the big difference
Comparing Genpu bottom of notch to bottom of wrist pin you will see it is about as close to inline as possible:
While the CP-E wrist pin to bottom of notch shows the notch isn't quite as deep:
While that doesn't seem to be an issue it is different. The problem comes with the internal shape that Pablo posted and I still stand by bending the squirters to clear.
The next issue was with clearance for the valves. The CP-E pistons are the same compression ration as stock so they have to have higher areas somewhere to make up for the deep wide Genpu dish copy. This is where some things get questionable to me.
Gen Juan top has small intake valve reliefs and no exhaust reliefs:
Genpu:
Needs pic still
CP-E top. Notice they have much deeper intake valve reliefs, but still no exhaust reliefs:
Top of Gen Juan piston to top of wrist pin hole:
Top of Genpu piston to top of wrist pin hole, oddly enough is shorter than Gen Juan:
Top of CP-E to top of wrist pin hole and they are taller than both here:
Then I measured top of piston to bottom of the wrist pins.
Gen Juan:
Genpu:
CP-E:
I measured the CP-E wrist pin at 22.47 to the Gen Juan at 22.46 to the Genpu at 22.47 like the CP-E. The important thing is that the tops are higher on the CP-E and their are no exhaust valve reliefs. Web was contacted and said that the aggressiveness of the cams, even in the Tomas grind is enough to cause that tiny amount of interference on the exhasut side with these pistons. A larger grind will contact more. Wiseco is going to notch some exhaust valve reliefs for us.
silvapain and rfinkle2 like this.
The Following 40 Users Say Thank You to jmhinkle For This Useful Post:
06Speed6 (01-01-2013), Alpha (01-01-2013), atvfreek (01-01-2013), AZSPEED3 (01-01-2013), BigRedSpecial (01-03-2013), BlueStreak (01-01-2013), Boosted Beluga (01-02-2013), BrianB6 (01-01-2013), cld12pk2go (04-03-2013), Code Monkey (01-01-2013), cymen (01-12-2013), Dano (01-13-2013), djuosnteisn (01-01-2013), doubleflusher (01-02-2013), Downmented (01-01-2013), Easter Bunny (01-01-2013), forcedinduktion (01-04-2013), GartzSpeed (01-04-2013), KusteLokal (01-01-2013), magicka (01-01-2013), Micha (03-29-2013), mituc (01-02-2013), Mizzle (01-18-2013), ms3blackmica (01-05-2013), NJSPEED3 (01-01-2013), Payne Racing 67 (01-01-2013), phate (01-01-2013), Poohster (01-01-2013), psychophyr (01-04-2013), Realgib3 (01-01-2013), rfinkle2 (01-04-2013), SarcasticOne (01-01-2013), silvapain (01-04-2013), Snap Off (01-04-2013), Speed3eak (01-01-2013), taf0422 (01-12-2013), TiGraySpeed6 (01-01-2013), Tomas (01-01-2013), Voltwings (01-16-2013), Zdraveca (01-04-2013)
 Old 01-01-2013, 08:17 PM   #2
Payne Racing 67's Avatar
Posts: 4,483   (View Stats)
Payne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the world
Groaned at 64 Times in 49 Posts
@jmhinkle; thanks for making this thread. Smart idea. This should be stickied. Keep us posted. Definitely good/interesting info
Sent from my GS3
Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq.
#HAR Hidden Agendas Racing
Payne Racing 67 is offline   Reply With Quote
The Following User Says Thank You to Payne Racing 67 For This Useful Post:
jmhinkle (01-01-2013)
 Old 01-01-2013, 08:22 PM   #3
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Man I called it on the skirt being at least oem, I dont have squirter clearance probs on my motor.
I also dont remember my piston looking like yours, but maybe I am remembering wrong.
2006 Mazdaspeed 6
The Following 3 Users Say Thank You to 06Speed6 For This Useful Post:
jmhinkle (01-01-2013), Payne Racing 67 (01-01-2013), rfinkle2 (01-04-2013)
 Old 01-01-2013, 08:25 PM   #4
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
Let me start off saying you can't match up a gen1 piston to cp-e gen2 Style piston.
You will need to have a gen2 oem piston match it up with cp-e piston. As far the exhaust reliefs
you don't need them if you not going with bigger exhaust cams.
As for the oil Squirter you can either bend them back or have a Mech shop take some material off.
The squirter clearance between the piston and the squirter is .005 vs weisco shelf piston with have about .012 something that.
SPEED6 KILLAH is offline   Reply With Quote
The Following 3 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
06Speed6 (01-01-2013), ms3blackmica (01-05-2013), Realgib3 (01-01-2013)
 Old 01-01-2013, 08:28 PM   #5
Speeeeeed
06Speed6's Avatar
And somehow I managed to not get a pic of my pistons but I swear they had exhaust reliefs
2006 Mazdaspeed 6
 Old 01-01-2013, 08:30 PM   #6
They don't come with exhaust reliefs unless you have there stage 3 piston lol
The Following User Says Thank You to SPEED6 KILLAH For This Useful Post:
 Old 01-01-2013, 08:33 PM   #7
Axle Breaker
jmhinkle's Avatar
Groans: 162
If you have Stage 2 they should look like these. Only odd thing on mine is I got fucked out of the skirt coating. Everyone else should have the skirt coating on theirs. I was going to get them coated with cerakote locally, but our machinist liked my clearances a lot and said he doesn't think I need the coating at all so I left them alone. Right now, I'm mostly worried that the Stage 2 should have exhaust reliefs in them.
The Following 5 Users Say Thank You to jmhinkle For This Useful Post:
06Speed6 (01-01-2013), atvfreek (01-01-2013), djuosnteisn (01-01-2013), Realgib3 (01-01-2013), rfinkle2 (01-04-2013)
 Old 01-01-2013, 08:39 PM   #8
I seen couple of cp-e piston with out the coated. But you should get it coated dude trust me as for you machinist say something like that is crazy my op
 Old 01-01-2013, 08:46 PM   #9
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
The cpe's do have more squish area than oem, and that only increases the likelihood of clearance issues.
And Pablo, he's gonna run the same cams as ant, so that's why he's sweating and measuring everything, lol.
I'll drop a puston off tomorrow joel... (see what i did there...)
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
06Speed6 (01-01-2013), jmhinkle (01-01-2013), rfinkle2 (01-04-2013), silvapain (01-04-2013), SPEED6 KILLAH (01-01-2013)
 Old 01-01-2013, 08:47 PM   #10
Axle Breaker
jmhinkle's Avatar
Groans: 162
Yes you can and that is why I did. If you are raising the height of the outer part of the piston top in relation to the wrist pin, you will create valve clearance issues possibly even with a stock cam. You should know that. These aren't a Genpu copy. They just mimic the dish.
You will have to match up a gen2 oem piston with cp-e piston. As far the exhaust reliefs
I will be matching them to Genpu pistons, as I stated, when I pick it up tomorrow. I can tell you that Genpu has no exhaust reliefs, but again these aren't exact Genpu copies. Don't get confused on that part. Also, I have the same cams as Anthony which can be an even bigger problem.
They have to be bent no matter what. They aren't in the right place if not bent. Machining will not fix the issue.
The ones we had made contact on Wiseco's. Machining would be idiotic.
Answered per line.
The Following 2 Users Say Thank You to jmhinkle For This Useful Post:
phate (01-02-2013), rfinkle2 (01-04-2013)
 Old 01-01-2013, 08:47 PM   #11
Captain
Also pablo, did you post pics of the contact on anthony's pistons? I've been out of the loop lately and missed them if you did. What part of the piston did the valves contact?
www.permtuning.com
 Old 01-01-2013, 08:49 PM   #12
Axle Breaker
jmhinkle's Avatar
Groans: 162
Coated pistons are quite new and good machinists have been building without them for years. If done right, it's not needed. It's a nice feature and I am pissed that I got fucked out of it, but it isn't needed at all. It's is only a nice to have.
Replacing the diamond crusted washers on the crank and cam bolts is far more important than having skirt coating.
The Following 4 Users Say Thank You to jmhinkle For This Useful Post:
06Speed6 (01-01-2013), phate (01-02-2013), rfinkle2 (01-04-2013), silvapain (01-04-2013)
 Old 01-01-2013, 08:56 PM   #13
Axle Breaker
jmhinkle's Avatar
Groans: 162
Here
The Following 7 Users Say Thank You to jmhinkle For This Useful Post:
06Speed6 (01-01-2013), djuosnteisn (01-01-2013), Easter Bunny (01-02-2013), phate (01-02-2013), rfinkle2 (01-04-2013), silvapain (01-04-2013), Speed3eak (01-01-2013)
 Old 01-01-2013, 08:58 PM   #14
Captain
Pow.... right in the squisher baby...
If you do end up having reliefs machined in, that's a great pic to show them. It wouldn't take much at all honestly, just a very very subtle dish if anything.
www.permtuning.com
 Old 01-01-2013, 09:09 PM   #15
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Stock cams: exhaust valve fully opens 20* before bottom dead center. Or 160* after top dead center. After that it starts closing and at 16* before top dead center it's closed all the way.
216/209 web cams: ex valve fully open 32.5* before bottom dead center or 147.5* after TDC. After that it starts closing and at 3.5* before TDC its fully closed.
Yes, there is a smaller non-interference window with the 209 EX cam but IMO it's still plenty. If the ex valves touch the piston crowns during operation it's probably a problem originating someplace else.
If you deck the block and/or shave the head far enough it could be the ex valves can touch the crowns even when fully closed.
The Following 6 Users Say Thank You to Tomas For This Useful Post:
06Speed6 (01-02-2013), djuosnteisn (01-01-2013), jmhinkle (01-01-2013), ms3blackmica (01-05-2013), rfinkle2 (01-04-2013), SPEED6 KILLAH (01-01-2013)
 Old 01-01-2013, 09:18 PM   #16
Here are some picture of the gen1 piston and gen 2 piston
as you can see the gen 2 side skirt and width is alittle large then the gen1
Note: Look at the side skirt coated you can see some coated on them coating primary intent is to reduce friction and increase
usable power and reduces engine heat
Here is a picture of cp-e gen 2 piston vs oem gen 2
Now what weisco did is went aggressive on the intake side and on the pocket which they had to raise it couple thousand to make up for the CR.
06Speed6 (01-02-2013), ms3blackmica (01-05-2013), rfinkle2 (01-04-2013)
 Old 01-01-2013, 09:32 PM   #17
Axle Breaker
jmhinkle's Avatar
Groans: 162
I think these pistons are only barely clearing the stock cams. The deeper intake reliefs tells me that the higher tops were an issue on the stock cam as is. With the aftermarket cam the higher tops contact the exhaust side now. Looking at Ant's picture, it looks like a minute amount of contact over a long period of time more than a huge contact in a short period. I think dishing these particular pistons for any aftermarket exhaust cam is entirely neccessary at this point.
06Speed6 (01-02-2013), Boosted Beluga (01-02-2013), djuosnteisn (01-02-2013), rfinkle2 (01-04-2013)
 Old 01-01-2013, 09:47 PM   #18
Axle Breaker
jmhinkle's Avatar
Groans: 162
The coating on the skirts of pistons is strictly for friction. It will hold a thin film of oil that helps with cold start up. That's it. Once the engine is running it isn't doing anything extra at all. It's only starting to come into play on stock pistons and even less on aftermarket ones. Coated tops are where the heat reflection comes in to help with more complete burn from less hot spot issues. We don't have that stock so it's not part of the discussion.
 Old 01-01-2013, 10:21 PM   #19
Snice this thread is not discussion on piston side skirt coated.
Here something you will be interested cp-e installed check out the clearance bewteen the oil squirter and the piston
The Following 7 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
06Speed6 (01-02-2013), djuosnteisn (01-02-2013), jmhinkle (01-01-2013), ms3blackmica (01-05-2013), psychophyr (01-04-2013), rfinkle2 (01-04-2013), taf0422 (01-12-2013)
 Old 01-01-2013, 10:34 PM   #20
Axle Breaker
jmhinkle's Avatar
Groans: 162
Yup, it's the inner design where the problem still lies. That looks like contact in that picture as we saw with normal Wiseco's. The way you guys were talking in Ant's thread made it sound like you were saying the skirts were too long and cutting the tubes off. That is definitely not the case. This is the normal contact due to a different internal shape of the pistons that the tubes were designed for. That's an easy fix with a minor bend. Thanks for that picture. Helps with the skirt discussion greatly.
The Following User Says Thank You to jmhinkle For This Useful Post:
 Old 01-01-2013, 10:44 PM   #21
I forgot this picture you can see the marks that oil Squirt left on the piston but didn't break off
Also here is a picture of a off the shelf wiseco piston you can see the Clearance and thickness of the piston side.
The Following 11 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
06Speed6 (01-02-2013), BigRedSpecial (01-03-2013), Boosted Beluga (01-02-2013), djuosnteisn (01-02-2013), Easter Bunny (01-02-2013), jmhinkle (01-01-2013), jracer (01-04-2013), ms3blackmica (01-05-2013), psychophyr (01-04-2013), rfinkle2 (01-04-2013), taf0422 (01-12-2013)
 Old 01-04-2013, 02:19 PM   #22
Axle Breaker
jmhinkle's Avatar
Groans: 162
Original Post updated with interesting Genpu info and other info from Web cams.
The Following 3 Users Say Thank You to jmhinkle For This Useful Post:
06Speed6 (01-04-2013), phate (01-04-2013), rfinkle2 (01-04-2013)
 Old 01-04-2013, 03:10 PM   #23
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
So say we have a built motor already and decide on bigger cams could we take the pistons out and get exhaust valve reliefs machined? And for good measure get the intake valve reliefs machined out some more?
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 01-04-2013, 03:16 PM   #24
Speeeeeed
06Speed6's Avatar
If I send my pistons to Wiseco will they machine them or do I need to find a shop?
2006 Mazdaspeed 6
 Old 01-04-2013, 03:23 PM   #25
Axle Breaker
jmhinkle's Avatar
Groans: 162
If you have the CP-E Stage 2 pistons and get cams you will need to have the exhaust valve reliefs machined in them. The intake side is good with the Tomas grind. I'm not sure how big of an intake cam change would take needing the intake valve reliefs changed as they are fairly large already compared to stock. The only known issue so far is with the exhaust side.
Wiseco is supposed to take care of it. I don't have the complete details yet. I put in a call at noon my time, 2PM East coat and have not heard back from them. Since it is Friday and 5:20 on the East coast, I probably won't hear back today.
06Speed6 (01-04-2013), Boosted Beluga (01-04-2013), rfinkle2 (01-04-2013)
 Old 01-04-2013, 03:30 PM   #26
Guys, besides the exhaust valve contact marks on Anthony's piston, is the cross hatching on the crown part of the original machining process?
 Old 01-04-2013, 03:34 PM   #27
Axle Breaker
jmhinkle's Avatar
Groans: 162
I don't remember cross hatching on his piston pictures. There was discussion about the cross hatch on his block. If you look at the top of mine in the pic about halfway through the 1st post you seem some machine marks. This is to be expected.
 Old 01-04-2013, 03:34 PM   #28
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
No. That looks to me like somebody cleaned it up a bit with a pad or something.
Tapadatass
The Following 4 Users Say Thank You to silvapain For This Useful Post:
Easter Bunny (01-04-2013), jmhinkle (01-04-2013), phate (01-04-2013), rfinkle2 (01-04-2013)
 Old 01-04-2013, 03:36 PM   #29
Axle Breaker
jmhinkle's Avatar
Groans: 162
Just looked at the picture again and agree with Silvapain
 Old 01-04-2013, 03:37 PM   #30
Groans: 50
I have cp pistons. Idk of any cuts would need to be made but measurement would need to be required.
I wonder if you could get every aftermarket piston and take measurements.
08 Mazdaspeed 3
 Old 01-04-2013, 03:40 PM   #31
Axle Breaker
jmhinkle's Avatar
Groans: 162
Are CP pistons like the original Wiseco's and basically a copy of the original stock design? If that is the case then I suspect it buys you a lot of clearance. The CP-E Stage 2 issue comes from mimicking the dish of the Genpu design and having a significantly taller outer crown area than others to keep the correct compression ratio.
If I had each I could add it to the post. It would be nice for comparison. If someone wants to send me the pics of measurements of theirs I can add the data as well.
 Old 01-04-2013, 03:58 PM   #32
Groans: 50
Yes they are
08 Mazdaspeed 3
 Old 01-04-2013, 04:13 PM   #33
Ugh this sucks i have to build a motor in the next few months and now I dont know wtf to do -____- going with carrillo rods but idk what as far as pistons now
Sent from my GS3
 Old 01-04-2013, 06:35 PM   #34
Axle Breaker
jmhinkle's Avatar
Groans: 162
Actually you are in good shape now. If you wanted these and are going to run aftermarket cams, just tell them you want them with exhaust reliefs.
 Old 01-04-2013, 06:54 PM   #35
Nah im staying stock cams
Sent from my GS3
 Old 01-04-2013, 06:58 PM   #36
Axle Breaker
jmhinkle's Avatar
Groans: 162
Then you are fine with any pistons made.
Payne Racing 67 (01-04-2013)
 Old 01-04-2013, 07:22 PM   #37
MarineMazda's Avatar
Posts: 354   (View Stats)
MarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the world
I know the 3 sets of Stage 2 piston that are going in the builds here in Canada did not come with the Skirt Coatings... Maybe CPe has stopped having them produced with this? 1 set was ordered roughly a year ago and the other 2 were this summer.
MarineMazda is offline   Reply With Quote
 Old 01-04-2013, 08:25 PM   #38
BlueStreak's Avatar
Posts: 1,467   (View Stats)
Is Wiseco being proactive and giving us a little more on the valve reliefs in case more aggressive cams come out in the future? It will save people from having to swap pistons when swapping cams... again...
'07 CWP MS3
Forged.
 Old 01-05-2013, 12:40 AM   #39
Axle Breaker
jmhinkle's Avatar
Groans: 162
No, just normal false advertising on their part. Great concept of product, fuck the customer in the end is always my experience with them. I wanted mine swapped and they said no.
Good question. You can probably specify how much you want. I know I'm not going more aggressive than this and will only need minor reliefs. More relief will lower compression since they weren't designed this way. I would only go as much as you are sure you would need.
BlueStreak (01-05-2013)
 Old 01-05-2013, 02:24 AM   #40
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Excellent.
Thanks jmhinkle.
@SPEED6 KILLAH; the oil squirter clearance on the off-the-shelf piston you posted is far more suitable
www.tunedbynishan.com
AP OTS Stage1+CS+TIH 93--> Compared to Stock rtekkam 2010 MS3 - ECU Computer Tuning 10 12-03-2011 11:33 AM
Stock is SO slow compared to stage 2! ms3brendan Mazdaspeed3/6 General Discussion 13 04-17-2011 09:10 PM
CPE stage 2 pistons available now ! jracer Mazdaspeed3/6 General Discussion 0 03-22-2011 09:37 AM
Stock pistons Buildabong MazdaSpeed 3 - Engine, Transmission & Driveline 0 01-27-2009 08:10 AM
Page generated in 0.67068 seconds with 31 queries
