| MazdaSpeed 3/6 - Build Diaries MazdaSpeed 3/6 - General Build Threads/Diaries |
![]() Join Date: Sep 2017
Rep Power: 0 ![]() Thanks: 14
(Thread Starter) | Not Ranked : 0 score Two weeks ago on a Sunday I bought a 2006 Mazdaspeed 6 with 103k miles that lost compression on one of the cylinders. The car was 3 hours (around 180 miles) away from my location. So I called the guy up, asked to send me a few pictures, made a deal for $1,500 and arranged a meeting time. I am keeping the car at my buddy's place because he has a large garage and I don't, so I also asked him if we could use his F150 and a trailer to get the car back home. He borrowed a trailer from one his friends and off we went. On the way there, we got pulled over by a cop because we almost lost one of the ramps from the trailer, and this set the stage for the rest of the day. We got to the guys place, looked over the car, drove it, loaded it and were back on our way home. We decided to grab some food, so we stopped in town after driving maybe 10 miles. I looked at the trailer because I saw the car was sitting weird and found this: ![]() Trailer was cracking because it was improperly welded. Luckily it didn't break while on the way home. So, I decided to drive the car back on three cylinders. Stopped for gas, picked up a few quarts of oil, filled up the tires with air and was on my way. Trip back took us about 5 hours because the car was burning through about a quart of oil every 50 miles, but the car is at his garage and is currently being disassembled for the engine removal. It took 5 quarts to get the car back. The plan is to rebuild and reseal the engine, replace all the piston rings and see what kind of damage there is on cylinder 3. So far the other issues with the car are a leaking AC, three bad front LCA ball joint boots, CD player does not work and the driver side door panel has a melted region because the window switch melted. Luckily, the guy put in a new switch, but it still doesn't work. Other issues with the engine include a leaking oil pan and a stripped oil drain plug thread. The rear arches do have rust developing on them, too. This car will be my full time winter vehicle and will share daily driving responsibilities with my 2015 Mustang GT PP. I do not plan on building the engine or adding much more power to the car (that is reserved for the Mustang). I may throw in H-beams into the engine just so the connecting rods are not a worry if the car gets a torque increase. Anyways, here are some pictures of it. I should have the engine out of it this Sunday! Stay tuned ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| Not Ranked : 0 score Welp if you plan on doing rods you're going to have to do Pistons unless you plan on getting those fancy Carrillo rods that cost about 1k.
| Not Ranked : 0 score Nope.
![]() Join Date: Mar 2017 Location: Guelph, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Little more research. Can’t remember off top of my head but some rods will fit with a little grinding. The width of aftermarket rods where wrist pin is are wider than the oe pistons allow. Sent from my iPhone using Tapatalk
__________________ '06 MS6 GT VRM |
(Thread Starter) | Not Ranked : 0 score Got you. Yeah, I need to do a bit more research and see how much the stock rods can hold. I may end up just using stock internals because I do not plan on increasing power that much. I think my upper limit would be 285-300 whp, but I'm more worried about the torque. |
| Not Ranked : 0 score Stock rods will hold a lot. Lots of people are making well over 300. Just need to tune to ensure you’re not cramming a shit ton of boost into engine below 3k rpm. Ease into boost after 3k. You’ll be fine. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to BN00249 For This Useful Post: | mindys (10-09-2017) |
Groans: 211
| Not Ranked : 0 score Its not much more to go with forged internals. I would. But to each his own. Nice find. Looks great other than the rust. Nice and straight. Where are you located?
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles |
Thanks! Yeah other than the rust on the arches the car looks pretty good! I'm located in the Chicago area. | |
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor | |
| Not Ranked : 0 score Ah okay I have family there.
(Thread Starter) | Not Ranked : 0 score Finally. Now just need need to start ripping the engine apart: |
| The Following User Says Thank You to kevace1 For This Useful Post: | mindys (10-10-2017) |
![]() Join Date: Nov 2015 Location: nyc
Groaned at 64 Times in 26 Posts
| Not Ranked : 0 score Nice build
__________________ TopFlightInc! NYC 2011 speed 3 GT daily driver Mods: big turbo , fuel internals , sure short shifter , forge BOV , FMIC , JBR motor mounts all around , BC coil overs , staggered advan wheels 18 x9.5 25+ offset front 18x 10.5 15+ offset rear , 3in catless down pipe , occ , Custom 3inch intake , Cobb strut bar ,Cobb v3 ,vtcs delete stock intake mani , |
(Thread Starter) | Not Ranked : 0 score A little update. Got everything apart and found a bit more damage than I anticipated. This is the piston from cylinder 3 (no compression cylinder): ![]() An entire chunk of the ringland is gone. No surprise there, this was what I was kinda expecting. Now what I was not expecting is cracks between the top two rings on pistons 2 and 4 (which had good compression): ![]() ![]() Basically, will be replacing all four pistons even though piston 1 is ok, but I bet it would fail soon too. Will most likely go stock just because I am not planning on large power ever being put out by this engine. Luckily, bore on cylinder 3 is not damaged too bad, just a few scratches that I cannot even feel with my fingernail: ![]() Sadly, two bearing surfaces on the crankshaft have a bit of marring, but hopefully the machine shop I will be taking the head and block to will be able to fix it. |
| Not Ranked : 0 score Well hate to be the one to say it but you’ll need aftermarket overbore pistons if you plan on using that block. Those cylinders will need to be bored out to fix the damage. Even if there wasn’t damage I’m betting those cylinders probably wouldn’t be within spec for an oem piston anyway just due to mileage.
![]() | | #19 | ![]() |
| Not Ranked : 0 score Pffff. Dingleball hone and chuck ‘er back together. No seriously though. Machine shop. Ensure the sleeves are all ok. You don’t want to screw around with it if one or more of the sleeves are cracked or something. And ya used bare block should be able to find in that price range but that also comes with risks as well. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to BN00249 For This Useful Post: | mindys (11-01-2017) |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Alright boys, got the head, cams, crank and block to a machine shop today. They will get it measured up and make suggestions. I'm not too happy about the journals for the cams and the crank. By the looks of it the cylinders will be over bored to 88 mm so I am looking for new pistons. Your suggestions are welcome. Right now I am thinking the SP63 4032 pistons and Manley H-beams. I think that 4032 material pistons will be the best choice for me to be daily driven. Any other suggestions? Doesn't seem like much choice for 4032. |
![]() | | #21 | ![]() |
| Not Ranked : 0 score Exact set up I’m going with.
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score Nice! It seems like that is the best piston solution for a daily driver. For it will be overkill for my application, but it will good to have the reassurance that the engine can hold a lot more power than stock (when I get the HPFP internals). When swapping pistons and rods and keeping the compression ratio the same, no retune is necessary, correct? |
![]() | | #23 | ![]() |
| The Following User Says Thank You to Djohns For This Useful Post: | mindys (11-01-2017) |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score You got a point there. I will consider it once I get the car running again. Thanks for your continual input. |
![]() | | #25 | ![]() |
![]() Join Date: Jan 2016
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score Good luck with the build. Sorry to rain on your parade, but the front of the trailer was overloaded. The tongue weight must have been very high because the car was much too far forward. |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Possibly. This trailer was already damaged before and was not welded fully as per the owner. We loaded the car as well as we could. There was not much space left in the rear, so I doubt we could have loaded any better. Either way, it's a moot point now. Definitely a learning experience. |
![]() | | #27 | ![]() |
Groans: 111
| Not Ranked : 0 score Just order them, I think it's the best choice for daily driven medium power cars.
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well, I have some new things to consider: Since I do not plan on increasing the power much, I could just get OE replacements pistons and rods that the machinist is suggesting as an alternative for $250. It is difficult to justify $1000 for pistons and rods that are meant for power levels that I will never run on this car. Need to consider my options. |
![]() | | #31 | ![]() |
| Not Ranked : 0 score What did the cylinders measure at? I’m shocked you’ll be able to use OE pistons and not need to bore.
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Overbore OE replacement pistons? I’ve never heard of that.
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
Groans: 111
Simply because we don't know about it means you will most probably end up with shitty pistons, and with this stroke you simply don't want to cheap out on pistons (or anything from the rotating assembly). Get 88mm 4032 alloy pistons.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
![]() | | #36 | ![]() |
![]() Join Date: Feb 2011 Location: Chicago
Rep Power: 365 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
Groans: 74
| Not Ranked : 0 score Get quality pistons this isn't a regular 3.
__________________ 2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE 2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too. |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yup will be going with SP63. Now just need to work out if I should get them treated and what are the correct PTW clearances since it seems there has been some confusion on what the correct specs are in the post here: Let's Talk About Forged Piston Alloys |
![]() | | #38 | ![]() |
Groans: 111
| Not Ranked : 0 score You don't need them treated in any way, they original coating is just perfect. SP63 machines them to spec, no matter if we speak of 88mm pistons or factory sized 87.5mm pistons. I know, because I had 3 sets from them so far, all 3 flawless.
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score What PTW clearances did you run? I saw that a guy posted a Wiseco spec sheet in the thread that I mentioned and said that the his builder used those numbers. Did you use these too? |
![]() | | #40 | ![]() |
| Not Ranked : 0 score Noooo don’t use anything a wiseco uses. It’s totally different alloys. I spoke with mahle (company who makes those pistons for SP) and I believe they recommended .025 for clearance.
| 06 Speed 6 - Daily fun build | Flying_NEB | MazdaSpeed 3/6 - Build Diaries | 18 | 09-28-2017 04:26 PM |
| GT3071R MS6 Daily Driver Build | JDMCRX | MazdaSpeed 3/6 - Big Turbo Builds | 5 | 06-18-2014 07:29 AM |
| MAPerformance Build Your Mazdaspeed 3 | maperformance | Modern Automotive Performance | 235 | 01-28-2014 05:53 PM |
| help needed for mazdaspeed 6 build | saint340 | MazdaSpeed 3/6 - Build Diaries | 21 | 06-02-2013 10:26 PM |
