Like Tree25Likes
 Old 10-07-2013, 12:56 PM   #1
Default MZR Motor Build Kits
MZR Motor Build Kit
With all the motor builds that have been going on lately we decided to put a few motor build kits together for you guys. One of the most difficult parts to building your motor is figuring out what all OEM parts you need to get to go with your rods and pistons. So with the MZR Motor Build Kit, we make it easy for you by putting them all together where they can be purchased with the click of one button. There are three kits to choose from depending on what all you need or want to do with your build.
The Stage 1 kit includes the following.
  • Rod Bearings
  • Main Bearings
  • Thrust Bearing
  • Rear Main Seal
  • Gasket Set
  • Crank Pully Bolt
  • Friction Washers x3
  • Flywheel Bolts x6
You get to choose between OEM, Clevite AL, and Clevite H series (trimetal) bearings, and you can add a Cometic Head gasket if you want. This kit includes the essentials for a bare minimum motor build.
The Stage 2 Kit includes the following.
  • Rod Bearings
  • Main Bearings
  • Thrust Bearing
  • Rear Main Seal
  • Gasket Set
  • Crank Pully Bolt
  • Flywheel Bolts x6
  • Timing Chain
  • Chain Guide
  • Tensioner Guide
  • Chain Tensioner
It builds on the stage 1 kit while adding a few more parts that are advisable to replace at the time of your motor build. The Stage 2 kit will also give you the option to add the OEM VVT, cam bolt, and cam washer for a VVT replacement.
The Stage 3 Kit includes the following.
  • Rod Bearings
  • Main Bearings
  • Thrust Bearing
  • Rear Main Seal
  • Gasket Set
  • Crank Pully Bolt
  • Flywheel Bolts x6
  • Timing Chain
  • Chain Guide
  • Tensioner Guide
  • Chain Tensioner
  • Oil Pump
  • Oil Pump Gear
  • Oil Pump Chain
  • Oil Pump Chain Tensioner
Again, it builds on the Stage 1 and 2 kits and adds all of the Oil Pump assembly. It is wise to replace higher mileage oil pumps as well as any oil pump that has been subject to a blown motor or even a spun bearing as any metal shavings that get picked up can ruin your new motor.
The Stage 1 MZR Motor Build Kit is $772.57
The Stage 2 MZR Motor Build Kit is $949.40
The Stage 3 MZR Motor Build Kit is $1246.11
All three stages will vary in price depending on which bearing options you go with as well the other options that are available for you to add.
The VIP coupon code applies to this so if you don't have it message me for details
Bonus:
We also created a VVT Replacement Kit for you guys! It comes with all the parts necessary to replace your VVT.
MZR VVT Replacement Kit MS3 / MS6 2006 to 2013 is $404.17
Raider, Bob-o, atvfreek and 9 others like this.
The Following 66 Users Say Thank You to EdgeAutosport.com For This Useful Post:
802MS3 (10-14-2013), Agent_Orange (10-07-2013), alaskazero (10-08-2013), atvfreek (10-08-2013), Bob-o (10-07-2013), Boost_creep (10-08-2013), bspau45 (10-07-2013), captain slow (10-07-2013), cbspd3flip (10-14-2013), chomorro (03-21-2014), CJM (10-07-2013), Clannad (10-07-2013), Code Monkey (10-07-2013), dale_gribble (10-07-2013), Dead Ms3 (10-08-2013), DISIindahead (10-08-2013), Easter Bunny (10-07-2013), econman (10-07-2013), El_Diablo (10-07-2013), ESA (10-14-2013), faeker (10-07-2013), Format (10-07-2013), GartzSpeed (10-08-2013), helmetface (10-07-2013), hihosilver (10-07-2013), Hush (10-07-2013), ibcrusn (10-07-2013), JgamB (10-07-2013), Jh8909 (10-08-2013), jm211 (10-08-2013), JSmith (10-07-2013), julienjj (10-07-2013), lilred (10-07-2013), Losymis (04-09-2018), m.a.vega1 (01-12-2014), magicka (10-07-2013), Mauro_Penguin (03-21-2014), Mazdazilla6 (10-07-2013), memin (10-08-2013), mituc (10-08-2013), moomooz12 (10-08-2013), mxlplx71 (10-07-2013), naoandlater (10-07-2013), nortigid (10-07-2013), PapaSmurf (10-07-2013), Pointless (10-07-2013), Raider (10-07-2013), rob ms6gt (10-08-2013), robertof (10-07-2013), RobT2009 (03-24-2014), Roddiy (10-07-2013), SarcasticOne (10-07-2013), skiptowncat (10-07-2013), Sleepin6 (07-17-2018), smoogs12 (10-07-2013), snailD (08-15-2014), SparkySparks (10-08-2013), SpeedRebirth (10-07-2013), speed_freak91 (10-07-2013), stevehuff (10-08-2013), taf0422 (10-07-2013), trancehead (10-08-2013), trf5000 (10-08-2013), Voltwings (10-07-2013), WetzMS3 (10-07-2013), xI Leveler Ix (10-07-2013)
 Old 10-07-2013, 01:17 PM   #2
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
@pmartz16;
 Old 10-07-2013, 01:19 PM   #3
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
@Mazda_ladaay;
 Old 10-07-2013, 02:02 PM   #4
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Does the stage 1 come with a gasket kit directly from mazda? As in are they oem gaskets?
700HP CLUB
11.479@124mph
#DIX
 Old 10-07-2013, 02:11 PM   #5
Yes all the gaskets and seals are OEM.
The Following 6 Users Say Thank You to EdgeAutosport.com For This Useful Post:
atvfreek (10-08-2013), El_Diablo (10-07-2013), jm211 (10-08-2013), Mauro_Penguin (03-21-2014), Pointless (10-07-2013), Raider (10-07-2013)
 Old 10-07-2013, 02:07 PM   #6
JgamB's Avatar
Posts: 2,566   (View Stats)
I'm hoping it's quite some time before I need this service, but it sure is nice to have it simplified for when the day comes.
 Old 10-07-2013, 02:21 PM   #7
Dahouse702's Avatar
Posts: 487   (View Stats)
Dahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the world
@LatinKraze
2007 MS3 Black Mica-Totaled @98500 on 09/2014
Current Car...
2009 MS3 Black Mica GT JBR TRU 3.0 Widepath full intake, BNR S3 v1, GS EBCS, 3 BAR , Forge BPV V2, Autotech internals , Denso Itv22, CNT Downpipe, CX-Racing piping with Cobb v2 core, Cobb AP v2, JBR RMM, JBR PMM, JBR TMM, JBR Oil Catch Can, EGR Delete, JBR TIG, Toyota Seals, HTP battery tray, DashHAWK
Zoom Zoom
Dahouse702 is offline   Reply With Quote
 Old 10-07-2013, 03:01 PM   #8
pmartz16's Avatar
Posts: 1,140   (View Stats)
thanks Jon, I have seen these and thanks edge for making it easy. Hopefully its not necessary for me to replace everything
2014 Mz3 MG
The Following User Says Thank You to pmartz16 For This Useful Post:
EdgeAutosport.com (10-07-2013)
 Old 10-07-2013, 03:07 PM   #9
El_Diablo's Avatar
Groans: 769
Might aswell... Cheap insurance.
jm211 (10-08-2013)
 Old 10-07-2013, 03:48 PM   #10
pmartz16's Avatar
Already a member
2014 Mz3 MG
 Old 10-07-2013, 08:06 PM   #11
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Already a member
It's almost as if you're referencing membership in a certain "club" that doesn't appear to be referred to in any of the posts (currently displayed) before yours...
I wonder why that could be.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 9 Users Say Thank You to Nliiitend1 For This Useful Post:
Chuthor (10-07-2013), Downmented (10-08-2013), Easter Bunny (10-08-2013), Gladcow (10-07-2013), Micha (10-07-2013), naoandlater (10-07-2013), obijack (10-07-2013), silvapain (10-08-2013), Speed_j23 (10-08-2013)
 Old 10-07-2013, 03:57 PM   #12
Matrix311's Avatar
Posts: 2,133   (View Stats)
+1 on this kit.
 Old 10-07-2013, 04:00 PM   #13
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Nicely done Edge....Nicely done
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 10-07-2013, 04:53 PM   #14
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
This is so awesome.
Stage 3 kit + Rods + Pistons + some machine work and you got yourself a built motor for under $3k
I like...
2010 LSM Speed3
#BakeryTuned
The Following User Says Thank You to Roddiy For This Useful Post:
 Old 10-07-2013, 05:22 PM   #15
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
Originally Posted by Roddiy View Post
This is so awesome.
I like...
lol @ thinking you can have a built motor under 3k
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
The Following 22 Users Say Thank You to superskaterxes For This Useful Post:
alaskazero (10-08-2013), atvfreek (10-08-2013), dereeek (10-07-2013), DISIindahead (10-08-2013), doubleflusher (10-07-2013), Downmented (10-07-2013), Easter Bunny (10-08-2013), Hanzodurrr (10-08-2013), He Hate Me (10-07-2013), helmetface (10-07-2013), Manny (10-08-2013), Mauro_Penguin (03-21-2014), memin (10-08-2013), Micha (10-07-2013), mxlplx71 (10-07-2013), obijack (10-07-2013), pmartz16 (10-07-2013), rob ms6gt (10-08-2013), Sid3wayS (10-07-2013), silvapain (10-08-2013), SIXual Panda (10-08-2013), taf0422 (10-07-2013)
 Old 10-07-2013, 05:48 PM   #16
Roddiy's Avatar
Groans: 279
Don't crush my dreams bro
2010 LSM Speed3
#BakeryTuned
The Following 4 Users Say Thank You to Roddiy For This Useful Post:
atvfreek (10-08-2013), Easter Bunny (10-08-2013), Mauro_Penguin (03-21-2014), superskaterxes (10-07-2013)
 Old 10-07-2013, 05:51 PM   #17
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Yeah, the bigger turbo, PI/meth kit, intake Mani, T3/T4/tial conversion... All that shit adds up
 Old 10-07-2013, 05:06 PM   #18
hihosilver's Avatar
Posts: 136   (View Stats)
hihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the world
Wow, this is excellent. Way to go edge!
2012 Black MS3
CS SRI+TIP//CS Race RMM//Cobb AP (self-tune)//Autotech HPFP Internals//Catless UR Testpipe//GFB Respons//DDM HIDs//Prosport Halo Boost Gauge
Up next: Upgraded TMIC/FMIC, RichTune, NGK 1 Step Colder Plugs, other shit
hihosilver is offline   Reply With Quote
 Old 10-07-2013, 07:40 PM   #19
wake2011's Avatar
Posts: 411   (View Stats)
wake2011 is the leader of the worldwake2011 is the leader of the worldwake2011 is the leader of the worldwake2011 is the leader of the worldwake2011 is the leader of the worldwake2011 is the leader of the worldwake2011 is the leader of the worldwake2011 is the leader of the worldwake2011 is the leader of the worldwake2011 is the leader of the worldwake2011 is the leader of the world
you might beable to have a short block for around 3k, but a completely longblock would be like 5-8k depending on parts selection and application for the motor.
F-16 Crew Dog
wake2011 is offline   Reply With Quote
The Following User Says Thank You to wake2011 For This Useful Post:
superskaterxes (10-08-2013)
 Old 10-07-2013, 08:19 PM   #20
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Censorship is always the best policy
Damond Built Speed 6
The Following 8 Users Say Thank You to Deldran For This Useful Post:
Chuthor (10-07-2013), Easter Bunny (10-08-2013), Gladcow (10-07-2013), Micha (11-03-2013), naoandlater (10-07-2013), Nliiitend1 (10-07-2013), silvapain (10-08-2013), Speed_j23 (10-08-2013)
 Old 10-07-2013, 08:59 PM   #21
pmartz16's Avatar
Was refering to when it was suggested to join mazdaspeed motorsports to get these same parts for 40% off by phate. Hence why I said I am already a member.
2014 Mz3 MG
The Following 4 Users Say Thank You to pmartz16 For This Useful Post:
Easter Bunny (10-08-2013), Gladcow (10-07-2013), Micha (11-03-2013), Nliiitend1 (10-07-2013)
 Old 10-07-2013, 09:09 PM   #22
Nliiitend1's Avatar
I know.
2008 MS3 GT
2016 MX-5 Club
The Following 5 Users Say Thank You to Nliiitend1 For This Useful Post:
breakfstincluded (10-07-2013), Easter Bunny (10-08-2013), Gladcow (10-07-2013), Micha (11-03-2013), silvapain (10-08-2013)
 Old 10-07-2013, 09:21 PM   #23
Little John's Avatar
Posts: 494   (View Stats)
Little John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the world
Groans: 55
Awesome setup!!! @LumberJack;
Little John is offline   Reply With Quote
The Following User Says Thank You to Little John For This Useful Post:
LumberJack (10-07-2013)
 Old 10-07-2013, 11:04 PM   #24
LumberJack's Avatar
@EdgeAutosport.com; why is the 2006-2011 one price, but the 2012 option is $220 dollars more? I don't see it showing any difference or am I missing something?
10.36@148 Fastest Gen 2
 Old 10-08-2013, 07:14 AM   #25
lilred's Avatar
Posts: 5,792   (View Stats)
Because fuck you that's why haha ???
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
Koke382 (07-17-2015), LumberJack (10-08-2013)
 Old 10-08-2013, 09:55 AM   #26
For some weird reason, if we order the 2012 or 2013 engine gasket kit, which has it's own unique part number, it costs way more. I'm not sure what the differences are so I'll call Mazda today to get a breakdown of the parts included in the kit. I know the 2010-2011 kits will fit with the 2012-2013 but there might be more parts in the newer gasket kit. Hang tight. I'll have an answer today.
LumberJack likes this.
atvfreek (10-08-2013), Easter Bunny (10-08-2013), El_Diablo (10-08-2013), Jh8909 (10-08-2013), LumberJack (10-08-2013)
 Old 10-08-2013, 10:40 AM   #27
@LumberJack;
Okay here are the differences.
Gasket kit listed for 2010-2011 Year Models MS3 includes:
- Exhaust Valve Seals (8)
- Intake Valve Seals (8)
- HPFP Cam Housing Gasket (to head)
- PCV Gasket
- Valve Cover Gasket
- Head Gasket
- Front Oil Seal
- Intake Manifold Gasket (to head)
- Fuel Injector O-Ring (on top side of injector)
- Exhaust Manifold Gasket (to head)
- Oil Pump Pickup Tube O-Ring
- Oil Drain Tube Inlet Gasket (turbo)
- Oil Drain Tube Outlet Gasket (turbo)
- Oil Filter Housing Gasket (to block)
- Water Pump Gasket (internal)
- Water Pump Gasket (to inlet)
- Water Pump Gasket (to outlet)
- EGR Gasket
The 2012-2013 Gasket Kit comes with all those parts PLUS:
- O-Rings for fuel rail hard feed line (3)
- Grommets for fuel injectors (4 per injector)
- Gasket for turbo inlet (manifold to turbo)
- Gasket for turbo outlet (turbo to downpipe)
- Gaskets for oil feed line (4, to turbo)
- Gaskets for water feed and drain lines (4, to turbo)
So really, you can order either one depending on what gaskets you want to get. They fit all generations. It's just a matter of what gaskets you want.
Jh8909 likes this.
802MS3 (10-14-2013), El_Diablo (10-08-2013), Jh8909 (10-08-2013), LumberJack (10-08-2013), SarcasticOne (10-08-2013), silvapain (10-08-2013)
 Old 10-08-2013, 10:56 AM   #28
LumberJack's Avatar
@LumberJack;
- PCV Gasket
- Head Gasket
- Front Oil Seal
- EGR Gasket
Sweet deal. Really appreciate the fast response and clarification. Edge rocks as always
Sent from my SPH-L900 using Tapatalk 4
Jh8909 likes this.
The Following 3 Users Say Thank You to LumberJack For This Useful Post:
EdgeAutosport.com (10-09-2013), Jh8909 (10-08-2013), memin (10-14-2013)
 Old 10-08-2013, 07:41 AM   #29
thieves's Avatar
Posts: 54   (View Stats)
thieves is a name known to allthieves is a name known to allthieves is a name known to allthieves is a name known to allthieves is a name known to allthieves is a name known to all
Nice!
thieves is offline   Reply With Quote
 Old 10-08-2013, 09:05 AM   #30
Hey guys, we did censor this, not trying to hide anything. We know and understand there are other options out there and we never criticize people for going to someone else. However, it doesn't make sense for us to pay MSF to have the privilege to post up in our own section and then have members tell everyone to go somewhere else inside of here.
Anyone is more than welcome to shop around but no one has made it this easy to understand and purchase what is required to go build a motor successfully. We get calls on a weekly basis asking, "what do I need to build my motor?" and this is designed to help those people.
Just to clarify, if Mazda Motorsports offers better prices, by all means, you have the right to purchase from them. We don't get the same pricing they do. We have an account with a local Mazda dealership that we buy our OEM parts from. We charge much less than MSRP which is what most people would have to pay for walking into a dealership AND we pay for the shipping.
I just want to make sure everyone understands why we deleted that post. If anything, it's a legitimate post but it just belongs in a different section. Hopefully that makes sense.
atvfreek, Koke382 and Sleepin6 like this.
The Following 13 Users Say Thank You to EdgeAutosport.com For This Useful Post:
atvfreek (10-08-2013), chomorro (03-21-2014), Code Monkey (10-08-2013), Easter Bunny (10-08-2013), G Sp33dy (04-20-2014), Gitcherex (12-15-2015), Koke382 (07-17-2015), Mauro_Penguin (03-21-2014), memin (10-14-2013), Nliiitend1 (10-08-2013), rob ms6gt (10-08-2013), superskaterxes (10-08-2013), trancehead (10-08-2013)
 Old 10-08-2013, 09:19 AM   #31
Deldran's Avatar
Groans: 118
This is exactly why you will more than likely still sell these kits. Some people are either to lazy, feel its to hard for them to understand, or just dont have the time to do it the harder cheaper way. There are tons and tons of threads on motor builds and what is needed for them. Some people just dont want to spend the time or effort.
I highy doubt that post would have made any dent in the sales of this kits. which is why i question your censorship. Sure this is your section that you pay for you can do whatever you like as long as its inside your agreement. I just dont see a need to delete it when its more than likely not going to hurt your sales. Usually you are pretty stand up guys trying to steer people in the best direction for them. That post deletion seemed out of Character for what i normally see from edge
The Following 3 Users Say Thank You to Deldran For This Useful Post:
EdgeAutosport.com (10-08-2013), Nliiitend1 (10-08-2013), SarcasticOne (10-08-2013)
 Old 10-08-2013, 10:13 AM   #32
pmartz16's Avatar
Do apologize for getting off topic. Even if there may be a discount elsewhere I would have to source everything. This makes it unbelievably easy. Thanks edge
2014 Mz3 MG
 Old 10-08-2013, 12:04 PM   #33
alaskazero's Avatar
Posts: 195   (View Stats)
alaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond repute
Groans: 34
Groaned at 55 Times in 18 Posts
Sweet Stuff
alaskazero is offline   Reply With Quote
The Following User Says Thank You to alaskazero For This Useful Post:
 Old 10-14-2013, 08:23 PM   #34
azazelthegreat's Avatar
Posts: 596   (View Stats)
azazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the world
very nice, this will make it easier on people.
I wish this was available a month ago.
azazelthegreat is offline   Reply With Quote
The Following User Says Thank You to azazelthegreat For This Useful Post:
EdgeAutosport.com (10-15-2013)
 Old 03-21-2014, 02:10 PM   #35
We keep the OEM stuff that makes up this kit in stock and ready to ship! Let us know if you need anything!
 Old 08-05-2014, 04:34 PM   #36
Anybody looking to build their motor soon? Make sure you have all the parts you need ahead of time to save on down time and unnecessary headaches!
pmartz16 (08-06-2014)
 Old 08-15-2014, 04:00 PM   #37
If you are worried about all the little bits you need to put your engine built or OEM back together, you can stop. We have done the work for you!
LumberJack and ItsNox like this.
 Old 08-21-2014, 01:31 AM   #38
dale_gribble's Avatar
Posts: 4,720   (View Stats)
You guys should do a Staqe 4 with OEM head and main bolts. I'll be in touch to order one of these setups soon I think.
MINI H1 6.0 - CAR LED TAILS
 Old 08-21-2014, 07:48 AM   #39
We could add that as an option to all the kits.
dale_gribble (08-21-2014), magicka (08-21-2014)
 Old 08-21-2014, 07:53 AM   #40
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
I agree on the stage 4. In about two weeks I will be looking to order this with pistons and rods.
What You Need to Know to Build a Motor TWOptSL0W Mazda MZR DISI Engine Builds (2006-2013) 73 07-26-2019 03:57 PM
What You Need to Know to Build a Motor TWOptSL0W MSF KB - Mazdaspeed 3/6 - Engine/Turbo Builds 14 09-26-2012 03:33 PM
HOW TO build an mzr motor!! qtrmile beast MazdaSpeed 6 - Engine, Transmission & Driveline 4 09-12-2012 05:07 AM
everything neded to build motor? ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 15 05-04-2009 11:14 PM
Build A 9v Battery Connector, Turn Signals Won't Work, Shop Safety, Diesel Engines, HHO Kits: Mike Allen's Weekly Online Haltech Automotive News 0 10-10-2008 03:10 PM
Page generated in 0.64942 seconds with 43 queries
