Mazdaspeed Forums
-   EdgeAutosport.com (http://www.mazdaspeedforum.org/forum/forum/f539/)
-   -   Motor Build Component Resource (http://www.mazdaspeedforum.org/forum/forum/f539/motor-build-component-resource-134973/)
EdgeAutosport.com 01-11-2013 10:28 AM
1 Attachment(s)
Hey guys, we get many requests to put lists together for motor builds and instead of creating it over and over again, we've decided to put a list together so you can more easily prepare for what you need.
We've broken it down into parts that you ABSOLUTELY need when rebuilding your motor, parts that we recommend you replace but sometimes aren't necessary depending on the condition once torn apart, and then the aftermarket options for building it to be able to handle more power.
Please let us know if you have any questions. We'll update this soon with other parts that have become available recently. Yes, Mahle makes a FULL bearing set for these motors now after I worked with one of their representatives to get them to make additional bearings than what was available. We'll also put pricing for short blocks since many blown motors go out the unfortunate way with a window in the block.
superskaterxes 01-11-2013 10:59 AM
timing chain should be under most important. i had 10k miles on my built motor and my chain was technically stretched.
also add pauter rods.
great job otherwise!!!!
EdgeAutosport.com 01-11-2013 11:35 AM
I actually thought of changing that but hadn't yet. I'll change it. Thanks Anthony.
Ayaritz 01-11-2013 12:01 PM
This is great! Thanks for sharing it.
trf5000 01-11-2013 12:21 PM
+1 for Pauters......
Page generated in 0.17268 seconds with 11 queries
