| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
![]() | | #41 | ![]() |
| Not Ranked : 0 score
| The Following User Says Thank You to jdmage_mx5 For This Useful Post: | Mauro_Penguin (02-13-2015) |
![]() | | #42 | ![]() |
| Not Ranked : 0 score Ps picture of the goods.
| The Following 3 Users Say Thank You to jdmage_mx5 For This Useful Post: |
![]() | | #43 | ![]() |
![]() ![]() ![]() Join Date: Nov 2012 Location: Temecula, CA
Rep Power: 2724 ![]() Thanks: 3,896
Do not go below the minimum recommendation, it's there for a reason. You go any less you risk running piston and cyl wall scoring from the gap being too tight. P2W is generally chosen based on power goals and boost levels, but 99% of forged Piston minimum p2w is .0035 Sent from my iPhone using Tapatalk
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 | |
| The Following 4 Users Say Thank You to LumberJack For This Useful Post: | jdmage_mx5 (02-12-2015), Justin@Freektune (03-10-2015), Mauro_Penguin (02-13-2015), The Nut (02-12-2015) |
![]() | | #44 | ![]() |
| Not Ranked : 0 score Are these made of 2618 or 4032? Edit: Never mind it's in the first sentence of the add....
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | EdgeAutosport.com (02-27-2015) |
![]() | | #45 | ![]() |
![]() Join Date: Feb 2011 Location: Forth Worth TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,715
Groans: 104
Groaned at 45 Times in 36 Posts
| Not Ranked : 0 score I bought I set of these with the rods from Edge and will hopefully have my car up and running next week for the break end period. So hopefully all good.
__________________ [SIGPIC][/SIGPIC] 2007 Cosmic Blue Built HTA 3076 Corn Fed with shot of Meth and Freektuned |
| The Following 3 Users Say Thank You to Mikey For This Useful Post: |
![]() | | #46 | ![]() |
![]() Join Date: Jul 2010 Location: Lunenburg Mass
Rep Power: 2310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,516
| Not Ranked : 0 score 800 miles on my set have yet to check compressions but car is feeling strong @18psi
__________________ 2006 Black MS6 531HP 486TQ FREEKBUILT -- FreekTune BW S300sx 62mm -- Twin TIAL 38mm EWG -- Perm Top Mount Twin Scroll Turbo Manifold -- Perm 4" Intake TR1035FMIC -- JBR TB and IM thermal spacers -- JBR OCC -- Bosch 3.5 Bar MAP -- Greddy BOV-- CP-E Injector seals Perm Downpipe -- 3" Magnaflow CBE -- Autotech Fuel Pump Internals -- Grimmspeed EBCS -- NGK Iridium Ported Head and Intake Manifold -- Snow Performance Meth Injection D10 and D12 -- balance shaft delete -- EGR delete ACT 6 Puck -- ISC Coilovers -- Sure Torq R6 -- Sure Juggernaught -- Sure Dreadnaught -- Sure Anchors -- Sure Shift Knob 2006 CWP MS6 313HP 319TQ FreekTune ATP GTX3076r -- TIAL 38mm EWG -- HTP 3" Intake System -- CPE Single Exit Exhaust-- ATP Catless Down Pipe CPE Differential Mount -- CPE Top Mount Intercooler -- JBR 80D Trilogy Mount Package -- Grimmspeed EBCS Autotech Internals -- Bosch 3 Bar Map Sensor -- Bit Wise Plug n Play -- GFB Hybrid BOV Bilstein Struts -- H&R Sport Lowering Springs -- Cobb v3 -- e85 1990 Nissan Skyline GTR ![]() 1991 White BMW 325ic Scorpion catback -- Short shifter -- Bilstein HD -- HR Springs -- Intake -- NRG Wheel -- Chassis and strut tower brace -- Sway bars |
| The Following 4 Users Say Thank You to Lakespeed6 For This Useful Post: | EdgeAutosport.com (03-02-2015), JgamB (03-10-2015), Justin@Freektune (03-10-2015), Mikey (03-02-2015) |
![]() | | #47 | ![]() |
| Not Ranked : 0 score Good to hear! Let us know if anything does develop! |
![]() | | #48 | ![]() |
![]() Join Date: Apr 2012 Location: Los Angeles
Rep Power: 426 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 956
| Not Ranked : 0 score That pretty common to break in forged internal at higher (even slightly) than stock boost levels?
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: |
![]() | | #49 | ![]() |
I am following the instructions from Freek. Worked my way up to spring pressure/maxing out the stock injectors after 500 miles. Hopefully I will get my meth running again, do a compression check, and start turning up the boost soon.
__________________ 2006 Black MS6 531HP 486TQ FREEKBUILT -- FreekTune BW S300sx 62mm -- Twin TIAL 38mm EWG -- Perm Top Mount Twin Scroll Turbo Manifold -- Perm 4" Intake TR1035FMIC -- JBR TB and IM thermal spacers -- JBR OCC -- Bosch 3.5 Bar MAP -- Greddy BOV-- CP-E Injector seals Perm Downpipe -- 3" Magnaflow CBE -- Autotech Fuel Pump Internals -- Grimmspeed EBCS -- NGK Iridium Ported Head and Intake Manifold -- Snow Performance Meth Injection D10 and D12 -- balance shaft delete -- EGR delete ACT 6 Puck -- ISC Coilovers -- Sure Torq R6 -- Sure Juggernaught -- Sure Dreadnaught -- Sure Anchors -- Sure Shift Knob 2006 CWP MS6 313HP 319TQ FreekTune ATP GTX3076r -- TIAL 38mm EWG -- HTP 3" Intake System -- CPE Single Exit Exhaust-- ATP Catless Down Pipe CPE Differential Mount -- CPE Top Mount Intercooler -- JBR 80D Trilogy Mount Package -- Grimmspeed EBCS Autotech Internals -- Bosch 3 Bar Map Sensor -- Bit Wise Plug n Play -- GFB Hybrid BOV Bilstein Struts -- H&R Sport Lowering Springs -- Cobb v3 -- e85 1990 Nissan Skyline GTR ![]() 1991 White BMW 325ic Scorpion catback -- Short shifter -- Bilstein HD -- HR Springs -- Intake -- NRG Wheel -- Chassis and strut tower brace -- Sway bars | |
| The Following 5 Users Say Thank You to Lakespeed6 For This Useful Post: | EdgeAutosport.com (03-02-2015), JgamB (03-02-2015), Justin@Freektune (03-10-2015), shaneski (03-02-2015), The Nut (03-02-2015) |
![]() | | #50 | ![]() |
| Not Ranked : 0 score Best bet for engine break in is to do what your builder tells you too. |
| The Following 6 Users Say Thank You to EdgeAutosport.com For This Useful Post: | ASHMS3 (03-02-2015), Hammology (03-11-2015), Justin@Freektune (03-10-2015), LumberJack (03-04-2015), The Nut (03-02-2015), Tokay444 (03-02-2015) |
![]() | | #51 | ![]() |
![]() Join Date: Jan 2011 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
| Not Ranked : 0 score Any update with oil squirter clearance issues with these? I am about to click purchase on @EdgeAutosport.com; Was going to go with the Wiseco's but was unsure if their clearance issues have been resolved. Also like the Gen2 design of these better
__________________ 08 MazdaSpeed3 | Cobb AP | MS Intake | CS TIP | CP-E FMIC | CNT Catless TBE | ITV22 | | AutoTech Internals | TurboSmart BOV | BC Racing Coilovers | CS RMM | CS TMM | | Black Powdercoated Stockers | Built Motor | | Mahle 88mm Pistons | Manley H-Beam Rods | |
![]() | | #52 | ![]() |
Click away. They are badass Pistons and yes they clear! Sent from my iPhone using Tapatalk
| The Following 6 Users Say Thank You to LumberJack For This Useful Post: | EdgeAutosport.com (03-11-2015), Frottage75 (11-22-2015), JgamB (03-10-2015), Jtaylor (03-10-2015), Mauro_Penguin (03-10-2015), The Nut (03-10-2015) |
![]() | | #53 | ![]() |
![]() Join Date: Oct 2013 Location: Tustin California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
![]() | | #54 | ![]() |
![]() Join Date: Jul 2013 Location: Williamsport, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Mine should be here tomorrow and hopefully going in this weekend. Just have to hone the cylinders, clean it out, and reassembling starts.
__________________ 07 Sunlight Silver MS3 GT: JBR 3.5", CS Race Pipe, M2 DP, CNT Racing CBE, SURE Shortcut, Autotech Internals, Forge V1, Cobb AP, FREEK tuned, JBR 88a RMM, CXRacing FMIC w/ TR8 core, BNR S3, PG V2 Exhaust Manifold, and Devil's Own DVC-30 Stage 2 w/ 100% meth. Best 1/4 mile: 12.18 @ 115.48 06 Speed 6 GT, rescued from a vented block. Pu motor, Fujita CAI, Autotech Internals, RMM, ATP Catted DP, GHL Catback, AP, FREEK OTS+ in progress |
| The Following 2 Users Say Thank You to SilverMS307 For This Useful Post: | EdgeAutosport.com (03-11-2015), JgamB (03-11-2015) |
![]() | | #55 | ![]() |
| Not Ranked : 0 score I think these bad boys will eventually become the fav for builders and buildees alike. On every other platform that has had these pistons for a long while now, these are the elite. They cost way less than CP-E's and they're def going into my car when I can afford to build.
| The Following 3 Users Say Thank You to The Nut For This Useful Post: |
![]() | | #56 | ![]() |
| Not Ranked : 0 score I'm in the middle of filing/gapping the rings for mine right now.
| The Following User Says Thank You to jdmage_mx5 For This Useful Post: | JgamB (03-11-2015) |
![]() | | #57 | ![]() |
| Not Ranked : 0 score They might've arrived with little fanfare, but it looks like they are making their way to the head of the line. My build sheet has these penciled in as well.
| The Following 3 Users Say Thank You to JgamB For This Useful Post: |
![]() | | #58 | ![]() |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
(Thread Starter) | Not Ranked : 0 score Mine arrived as well, i like the extra length/metal of the skirts, the cylinder walls will enjoy not getting slapped.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
| The Following 2 Users Say Thank You to shaneski For This Useful Post: | JgamB (03-11-2015), LumberJack (03-11-2015) |
![]() | | #59 | ![]() |
| Not Ranked : 0 score What specs are you going with? I just ordered mine
![]() | | #60 | ![]() |
| Ring gaps will depend on your power goals or the recommendation of your builder or machine shop same with your p2w clearance. Sent from my iPhone using Tapatalk
| The Following 3 Users Say Thank You to LumberJack For This Useful Post: |
![]() | | #61 | ![]() |
| Not Ranked : 0 score Does anyone have like 5 G's I can borrow?
![]() | | #62 | ![]() |
| Not Ranked : 0 score G G G G G You can have mine ^^^.
| The Following User Says Thank You to jdmage_mx5 For This Useful Post: | The Nut (03-11-2015) |
![]() | | #63 | ![]() |
| Not Ranked : 0 score Thanks brother! Somebody start my build!
| The Following User Says Thank You to The Nut For This Useful Post: | jdmage_mx5 (03-11-2015) |
![]() | | #64 | ![]() |
Groans: 104
| Not Ranked : 0 score I should be driving mine next week for the break in period. Would of been this week but damn Kozmic oil feed line started leaking. need to call Edge tomorrow and get here and get on the road... It started like a champ on first turn though.
| The Following 4 Users Say Thank You to Mikey For This Useful Post: |
![]() | | #65 | ![]() |
(Thread Starter) | Not Ranked : 0 score Engine builder that has hold of mine is concerned the top ring land on Manleys has no gas pockets compared to CPE ones he has used previously.
![]() | | #66 | ![]() |
| Not Ranked : 0 score This is the first I've heard of this being an issue. |
![]() | | #67 | ![]() |
| Same. These are being used in many builds with mild horsepower to lots of damn power. They're going in my build and I'll be back over 800+ and Justin has no concerns about these Pistons or there design. Sent from my iPhone using Tapatalk
![]() | | #68 | ![]() |
| Not Ranked : 0 score Getting some ductile sleeving done sir?
![]() | | #69 | ![]() |
| ImageUploadedByTapatalk1426742104.206218.jpg Wayyyyy ahead you broski. Sent from my iPhone using Tapatalk
![]() | | #70 | ![]() |
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: | |
![]() | | #71 | ![]() |
| Not Ranked : 0 score Little update on my Manley pistons. Engine has ~1500 miles and is currently @24psi with a D12 meth. ~400HP Compression check is 190 +/-1psi ![]() Can't wait to get this turbo actually spinning.
| The Following 10 Users Say Thank You to Lakespeed6 For This Useful Post: | BLKSTIG (03-23-2015), Easter Bunny (03-22-2015), EdgeAutosport.com (03-23-2015), JgamB (03-22-2015), Justin@Freektune (03-22-2015), Mauro_Penguin (03-22-2015), shaneski (03-21-2015), smoogs12 (03-22-2015), The Nut (03-21-2015), Tokay444 (03-21-2015) |
![]() | | #72 | ![]() |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score That Freek build.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| The Following 6 Users Say Thank You to Tokay444 For This Useful Post: | Easter Bunny (03-22-2015), EdgeAutosport.com (03-23-2015), JgamB (03-22-2015), Justin@Freektune (03-22-2015), smoogs12 (03-22-2015), The Nut (03-21-2015) |
![]() | | #73 | ![]() |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
| Not Ranked : 0 score Will anyone ever make 4032 pistons for us?
__________________ |
| The Following 4 Users Say Thank You to Tomas For This Useful Post: | Easter Bunny (03-22-2015), EdgeAutosport.com (03-23-2015), Justin@Freektune (03-22-2015), Mauro_Penguin (03-22-2015) |
![]() | | #74 | ![]() |
| Not Ranked : 0 score Is there a need? I was under the impression we were running out of fuel before hitting the limits of these beautiful fuckers? Please, someone more learned chime in on this.
| The Following User Says Thank You to The Nut For This Useful Post: | EdgeAutosport.com (03-23-2015) |
![]() | | #75 | ![]() |
![]() Join Date: Jun 2011 Location: Beach Park Illinois
Rep Power: 2610 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46,278
| Not Ranked : 0 score We have fueling options now. So running out of fuel is in the past. It just costs a bunch of moolah.
__________________ I am slow again. 2017 Lightning Blue SuperCab Raptor ordered 1/3/17. Built 2/3/17. Delivered 2/8/17. I modded it a little. |
| The Following 2 Users Say Thank You to Micha For This Useful Post: | Easter Bunny (03-22-2015), EdgeAutosport.com (03-23-2015) |
![]() | | #76 | ![]() |
| Approved MSF Vendor ![]() Join Date: Mar 2014
Rep Power: 2489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,022
With 4032 you can run tighter PWC clearance as it doesn't expand as much. This would last much longer, especially in a street driven car. Realistically 2618 should only be used in legit race engines that have frequent overhaul intervals. But that's all we have. So it's what we use. What I really like about these manley Pistons is the longer skirts they use which is very similar to the length of an Oem piston. And then the top ring thickness is much thicker than what wiseco offers.
__________________ Custom Tuning for Mazdaspeed, Ford, and Subaru ![]() Website- http://www.freektune.com/ PTE 6062 633HP/523TQ First gen2 in 10's- 10.93@137 Atco NJ 11/14/15 ![]() Quickest/Fastest Mazdaspeed First Gen 1 in the 9's 9.94@149.5 4/22/2017 New England Dragway Last edited by Justin@Freektune; 03-22-2015 at 03:28 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 7 Users Say Thank You to Justin@Freektune For This Useful Post: | 802MS3 (03-22-2015), Easter Bunny (03-22-2015), EdgeAutosport.com (03-23-2015), Mauro_Penguin (03-22-2015), Micha (03-22-2015), SpeedRebirth (03-22-2015), The Nut (03-22-2015) |
![]() | | #77 | ![]() |
__________________ 2010 Mazdaspeed 3 Liquid Silver Metallic HTA 3076 | HTP 4" Intake, battery tray, under mount piping | CPE Exhaust Manifold, downpipe, FMIC & Stage 2 RMM | MD TMM and PMM | Tial MV-R ewg w/ Kozmic dump tube | VCTS delete/Ported IM | JBR OCC, EGR delete, BSD w/ oil pan baffle & RSB | SP63 Oil Cap Breather | Synapse SB BPV | UR CBE | Autotech HPFP | H & R Coilovers | Whiteline Endlinks | Manley Pistons & Rods | L19 Head Studs | Kozmic 6th Port w/ DW65c ITFP | Snow Performance Stg 2 Meth | JMF Manifold | SouthBend Stg 3 Endurance Clutch | Tuned with | |
![]() | | #78 | ![]() |
how long do we got doc?.. give it to me straight.. | |
![]() | | #79 | ![]() |
| Not Ranked : 0 score This all depends on how tolerant you are to blow by and piston slap . I don't see 60k miles as a problem and probably more. They won't break, they will just have more blowby, consume more oil and may become noisier.
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #80 | ![]() |
Groans: 793
| Not Ranked : 0 score Manley also recommends stacking the ring gap in reverse, with the larger gap on the top ring. This explains the lack of expansion groove.
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | EdgeAutosport.com (03-23-2015), Mauro_Penguin (03-22-2015) |
| Wiseco pistons question pistons squirters clearance | JDMCRX | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 11-27-2013 05:23 PM |
| Official: Mercedes-Petronas AMG W04 launched to little fanfare, lot of pressure [w/video] | Haltech | Automotive News | 0 | 02-05-2013 12:50 PM |
| LA 2009: 2011 Ford Mustang V6 on show floor with little fanfare | Haltech | Automotive News | 0 | 12-02-2009 05:10 PM |
