| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
![]() | | #81 | ![]() |
| Not Ranked : 0 score PS, terrible with the Gimp.
__________________ |
| The Following 6 Users Say Thank You to Enki For This Useful Post: | BigRedSpecial (04-19-2012), Monotonous ONE (04-27-2012), mzr0818 (04-19-2012), rfinkle2 (04-19-2012), Scoobs (04-19-2012), Ziggo (04-19-2012) |
![]() | | #82 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
The critical factors probably have less to do with the smaller diameter and forged wheel, and more to do with the bearings and how precisely the wheels are balanced. Also I bet the gtx wheel is simply more efficient at higher so it makes sense to map it out further. IMO, a gtx and a gt2871R (ball bearing) should be mechanically able to spin to the same rpms. However when talking about the gt2871 journal bearing unit in my BNR, I bet 127k vs 150k is more reasonable. In the journal bearing, when you exceed the rated rpms, you can push past the shear strength of the oil bearing and get contact between the shaft and the guide, eventually you will wear it down, get shaft play, and oil leaking past it (sound familiar?) ball bearings are much less sensitive to axial loads, probably the leading reliability factor for the ball bearings is temperature.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
| The Following 9 Users Say Thank You to Ziggo For This Useful Post: | atvfreek (04-30-2012), BigjohnB20 (04-19-2012), cld12pk2go (04-19-2012), Easter Bunny (06-26-2012), FistPump20fo7 (06-26-2012), Lex (04-25-2012), Monotonous ONE (04-28-2012), rfinkle2 (04-25-2012), Scoobs (04-19-2012) |
![]() | | #83 | ![]() |
![]() Join Date: Oct 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,548
Groans: 30
| Not Ranked : 0 score Still nothing on your website about this kit...
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks |
| The Following 2 Users Say Thank You to Cataphract_40 For This Useful Post: | EdgeAutosport.com (04-25-2012), leon78 (04-25-2012) |
![]() | | #84 | ![]() |
(Thread Starter) | Not Ranked : 0 score We have a list on what needs to be added to the site. Sorry about the delay we will work on that today |
| The Following 5 Users Say Thank You to EdgeAutosport.com For This Useful Post: | atvfreek (04-30-2012), blkspeed307 (04-25-2012), breakfstincluded (04-25-2012), Cataphract_40 (04-25-2012), rfinkle2 (04-25-2012) |
![]() | | #85 | ![]() |
Groans: 30
| Not Ranked : 0 score Dunno if anyone has mentioned this yet. It's an alternative to the ATP turbo inlet. 3" and very nice quality. HTP 3" Mazdaspeed Turbo Inlet (Polished) - Hi-Tuned Performance Products
![]() | | #86 | ![]() |
| Not Ranked : 0 score Just recieved my gtx2867 yesterday. I'm looking forward to being able to run @ least 20 psi to redline. Thank you JP and Eric for excellent customer service. |
| The Following 17 Users Say Thank You to rfinkle2 For This Useful Post: | 08.5MS3 (04-27-2012), atvfreek (04-29-2012), AZSPEED3 (05-01-2012), BigjohnB20 (04-27-2012), breakfstincluded (01-06-2014), Broxer (04-27-2012), bstover17 (01-05-2014), charlesfist (04-27-2012), cld12pk2go (04-29-2012), EdgeAutosport.com (04-27-2012), Fobio (04-27-2012), JasonMzdSpd3 (04-27-2012), Monotonous ONE (04-27-2012), Scoobs (04-30-2012), skeurton (04-27-2012), wolly6973 (04-28-2012), Ziggo (04-27-2012) |
![]() | | #87 | ![]() |
![]() Join Date: Mar 2011 Location: Hampton, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,760
You get an exhaust mani, Rob?
__________________ 2011 MAZDASPEED 3 BNR: 352 hp / 342 ft-lbs K04: 296 hp / 343 ft-lbs BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges | |
![]() | | #88 | ![]() |
I know I should get an exhaust manifold, but it wasn't on my list right now. If I was going to buy one, I think I would go Full race though. | |
![]() | | #89 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,795
Groans: 89
| The Following User Says Thank You to 08.5MS3 For This Useful Post: | rfinkle2 (04-27-2012) |
![]() | | #90 | ![]() |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | 08.5MS3 (04-27-2012) |
![]() | | #91 | ![]() |
Groans: 89
![]() | | #92 | ![]() |
![]() Join Date: Feb 2012 Location: Parker
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,067
Groaned at 10 Times in 9 Posts
Thanks EdgeAutosport for the deal. Sent from Epic 4G via tap & touch 2.
__________________ 2012 Speed3 Tech~ Liquid Silver~ Mods - AP, CP-E Xcel 3.25 Maf Intake, ATP Catless DP, CP-E Triton 3" SS CBE, AT Internals, NGK 1 step colder plugs, TurboSmart BPV, GTX 2867r, 3 bar map, GS EBCS, HTP 3" TIP, JBR stage 2 OCC, CP-E Delta core FMIC, JBR Trilogy, JBR Solid Shifter Bushings Ordered Mods - Planned mods -safe seals. SSP oil return, CObb V3, Denso step colder plugs. My car hates NGK for some reason. Mods here but not installed- Purple Drank tuned! Tinted 15% all the way around, 5% hatch. ------------------------------------------------------------------------------------------- I think the internet needs more Cowbell! | |
| The Following User Says Thank You to JasonMzdSpd3 For This Useful Post: | EdgeAutosport.com (04-27-2012) |
![]() | | #93 | ![]() |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | atvfreek (04-29-2012) |
![]() | | #94 | ![]() |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | EdgeAutosport.com (04-27-2012) |
![]() | | #95 | ![]() |
![]() | | #96 | ![]() |
I'm pretty excited, although I do need to piece things together. I posted in the Full Race thread. Skeurton has me looking @ exhaust manis now. LOL. | |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | Monotonous ONE (04-28-2012), skeurton (04-27-2012) |
![]() | | #97 | ![]() |
![]() Join Date: Sep 2011 Location: St. Johns, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,014
Groans: 56
| Not Ranked : 0 score Does anyone know what the spool time is on these yet? Is it the same ~300 later than the K04 as the 2871?
__________________ 2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals Winter Beater: 96 GMC K1500 5 speed 4x4 Needed: Driver mod [SIGPIC][/SIGPIC] |
![]() | | #98 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // | |
| The Following User Says Thank You to m4tic For This Useful Post: | rfinkle2 (04-27-2012) |
![]() | | #99 | ![]() |
| Not Ranked : 0 score No EWG for me, but I appreciate your offer, as well as your help with Windows yesterday. |
![]() | | #100 | ![]() |
Zigatapatalka
| The Following User Says Thank You to Ziggo For This Useful Post: | BigRedSpecial (04-27-2012) |
![]() | | #101 | ![]() |
Groans: 56
| Not Ranked : 0 score Nice! I also realize that the ~300 later number I quoted would depend on A/R, that's just the number I've always heard quoted.
![]() | | #102 | ![]() |
![]() Join Date: Feb 2011 Location: Cleveland TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,751
Groans: 90
| Not Ranked : 0 score Hells ya man! You must do a build thread! I want impressions and data ASAP! Wish you lived closer, I'd love to help you out with the install.
__________________ 2012 Triumph Street Triple SOLD -- 2010 Velocity Mica Red MS3 ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM |
| The Following 3 Users Say Thank You to Broxer For This Useful Post: |
![]() | | #103 | ![]() |
I have been trolling your thread, as well as cld12pk2go, ziggo, and skeurton's thread for helpful tips. I think I may as well get a manifold while everything is going to be apart. | |
| The Following 3 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #104 | ![]() |
![]() | | #105 | ![]() |
![]() Join Date: Dec 2009 Location: Minneapolis, MN
Rep Power: 390 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,607
I am curious as to why you ended up with this turbo vs. the BNR or 3071? All 3 of these so far seem to be a pretty good fit for our motors, each with their own pros and cons. (I realize no one has probably ran the gtx2867 yet, but sounds like it should be comparable to the 2871 only better.) Personally I think the BNR S3 beats this turbo FOR ME based almost solely on the price comparison. Seems like either one shoudl give you an easy 350+ with the BNR allowing use of stock/aftermarket parts I already have and costs a little less to begin with. Either way, I think you should see really good results and can't wait to see what you are able to do with this.
__________________ 2006 BCM MS6 GT CS SRI/TIP Jbarone SSP/bushings cp-e RMM, TMIC, Stiff Diff AP KMD V2.whatever Ebay Catless DP Grom Ipod | |
![]() | | #106 | ![]() |
Groans: 90
__________________ 2012 Triumph Street Triple SOLD -- 2010 Velocity Mica Red MS3 ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM | |
| The Following 2 Users Say Thank You to Broxer For This Useful Post: | BigjohnB20 (04-27-2012), EdgeAutosport.com (04-27-2012) |
![]() | | #107 | ![]() |
(Thread Starter) | Not Ranked : 0 score @BigjohnB20 Remember you are going to be really hard pressed to make 350awhp on a bnr3 in an ms6. You are really going to have to run that turbo hard to make that power imo |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | BigjohnB20 (04-27-2012) |
![]() | | #108 | ![]() |
| Not Ranked : 0 score yea, I always forget we are at a disadvantage power wise with the AWD. Of course there are some benefits that come with it as well, lol. ![]() I'm so used to seeing all these 3's putting up great numbers lately and have to remember I can't directly compare to them. I was making the same mistake pouring over the VD thread and wondering why the hell my car wasn't putting up the same numbers as a lot of people in there. I do have easy access to E85 though and like to think I could squeeze 350ish out of a BNR without gettign too crazy. Either way, I don't even have my DP installed that I bought 6 months ago so its not like I have to worry about a turbo upgrade yet. I just like to live vicariously though all you guys and think one day I will do it.
| The Following User Says Thank You to BigjohnB20 For This Useful Post: | EdgeAutosport.com (04-27-2012) |
![]() | | #109 | ![]() |
| The Following User Says Thank You to Ziggo For This Useful Post: | BigjohnB20 (04-27-2012) |
![]() | | #110 | ![]() |
Groans: 30
| Not Ranked : 0 score Less talk moar turbo pron
| The Following 5 Users Say Thank You to Cataphract_40 For This Useful Post: | BigjohnB20 (04-27-2012), Broxer (04-27-2012), Deldran (04-28-2012), Easter Bunny (05-02-2012), Eighty8 (04-29-2012) |
![]() | | #111 | ![]() |
![]() Join Date: Jul 2008 Location: Raeford, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 154
Just by reading the compressor map, it is still a 0.6 a/r, and with the aluminum blade it should be Good for 43-44 lbs/min. Anyways, I plan on pushing this turbo to the limit, so we shall see.
__________________ 2012 Mazdaspeed3 LSM Should have gotten a speed6 2008 Mazdaspeed3 GT Black Mica [sold] Built motor, Etc. 383 hp 401 tq GTX2867R @ 25 psi | |
![]() | | #112 | ![]() |
| The Following 2 Users Say Thank You to Ziggo For This Useful Post: | 7mileshome (04-28-2012), breakfstincluded (01-06-2014) |
![]() | | #113 | ![]() |
| Not Ranked : 0 score Not sure if it was just me, but the coupler ATP sent was a 45 Deg, 2" to 2" Most intercooler kits have 2.25" piping so I needed this.. 45 (or 90 deg) 2" to 2.25" coupler (Blue is from ATP) Not to mention the compressor outlet is farther down since the compressor housing is smaller than the GT2871. It seems like ATP wielded the same outlet as the GT2871. So a longer coupler is generally required anyways.
| The Following User Says Thank You to 7mileshome For This Useful Post: | Cataphract_40 (04-28-2012) |
![]() | | #114 | ![]() |
| Not Ranked : 0 score @rfinkle2 I will post of up some pics as well on Monday when mine finally arrives.. I am very curious to see how this spools as well. I went the simple cheap route... Not sure there is a way with these cars though lol.. But I might put it in this week if the weather is good enough for me to ride..
![]() | | #115 | ![]() |
| Not Ranked : 0 score While not absolutely required, it is highly recommended to get the mani when doing the turbo swap. Saves mucho work later and helps balance the backpressure/EGT between the cylinders.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
![]() | | #116 | ![]() |
Looks as if function>form on this one. | |
![]() | | #117 | ![]() |
During the turbo swap is the perfect time to tap the Ex mani... I would be very interested in seeing how much more choked up the smaller hot side is as indicated by the EGT...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
![]() | | #118 | ![]() |
| Not Ranked : 0 score I was contemplating it. I'm going to talk to Eric about having Full Race weld a bung in for me. |
![]() | | #119 | ![]() |
| The Following 9 Users Say Thank You to skeurton For This Useful Post: | 08.5MS3 (04-30-2012), atvfreek (04-30-2012), AZSPEED3 (05-01-2012), BigRedSpecial (04-30-2012), cld12pk2go (04-30-2012), EdgeAutosport.com (04-30-2012), JacksonMS30 (04-30-2012), JasonMzdSpd3 (04-30-2012), TriO (04-30-2012) |
![]() | | #120 | ![]() |
Just let me know what runner and where | |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | rfinkle2 (04-30-2012) |
