Like Tree10Likes
  • 1 Post By zenit
  • 1 Post By NC-MS3Rob
  • 1 Post By Mazdazilla6
  • 2 Post By xfeejayx
  • 1 Post By EdgeAutosport.com
  • 3 Post By EdgeAutosport.com
  • 1 Post By mituc
 Old 04-05-2017, 10:13 AM   #1
Default Gen 2 GTX Bolt-on Turbos are now available for the Speed 3 and 6
Hey guys, just wanted to let you know that the Bolt-on Gen 2 GTX Turbos are now available for the Speed 3 and 6. We are adding them to our site now and I'll post the link when its up.
As for pricing, the Gen 2 option will be exactly $0.00 more than the Gen 1. I know that is going to be a little tough for some of you, but it is more than worth to upgrade to the Gen 2 wheel. Please let me take a moment to explain why...
<deep breath>
Basically, you can expect the Gen 2 GTX's to operate more efficiently than the Gen 1. This means less boost to make more power and lower adiabatic heat. When you turn it up, Garrett says you can make up to 20% more power on the GTX Gen 2 than you can the GTX Gen 1.
According to Garrett, this is all accomplished with better aerodynamics. These turbos will also feature a speed sensor port so you can keep an eye on your turbos ridiculously high revs/min.
First pic is of the Gen 2 Compressor map, and it is followed by the Gen 1 compressor map. Both of these are of the 3076 variety.
This should make for an extremely efficient/fun Turbo series, especially in the smaller varieties which can now out power their old counter parts without losing any spool time in the process...
Another cool feature that some of you top mount turbo dreamers will appreciate is that the Gen 2 GTX turbos are available in a reverse configuration meaning that you don't have to do any weird bends or have any valve cover clearance issues when you try to do a top mount turbo setup with these turbos.
ATP Bolt-on GTX2860R Gen 2 Turbo Kit - $1749
ATP Bolt-on GTX2867R Gen 2 Turbo Kit - $1749
ATP Bolt-on GTX3071R Gen 2 Turbo Kit
- $1849
ATP Bolt-on GTX3076R Gen 2 Turbo Kit - $1849
ATP Bolt-on GTX3576R Gen 2 Turbo Kit - $2349
The Following 8 Users Say Thank You to EdgeAutosport.com For This Useful Post:
JohnnyTightlips (04-05-2017), KiwiFlavor (04-05-2017), mituc (04-10-2017), rtabagaboy (04-06-2017), rymanmazda (04-06-2017), ThOrZwAr (04-05-2017), Tifosi42 (01-13-2018), Varomnia (04-05-2017)
 Old 04-05-2017, 11:15 AM   #2
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
Why must I see this...
2012 NASA Spaceship Gray MS3
 Old 04-05-2017, 11:43 AM   #3
ThOrZwAr's Avatar
Posts: 43   (View Stats)
Default Oh mi
Hnnnnnggg... *quietly chants* I don't need this, I don't need this, I don't need this...
 Old 04-05-2017, 04:12 PM   #4
zenit's Avatar
Posts: 1,364   (View Stats)
Honestly, those two compressor graphs are extremely close.
Plus, ain't no one running >3.5 p/r.
Jeff23spl likes this.
-feejay
-wetzel
 Old 04-05-2017, 05:45 PM   #5
NC-MS3Rob's Avatar
Posts: 87   (View Stats)
NC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant future
20% for $0.00?
You drive a hard bargain...........
AwAfrican likes this.
AP v3 -- Autotech -- HTP 3.5" Intake -- CS BPV -- JBR SSP -- COBB Shift Knob -- H&R RSB -- Custom E-cutout -- CP-e TMIC -- JBR IC Piping -- JBR Coolant Bypass -- DM TIGs -- CP-e DP -- JBR EGR Delete -- AEM 30-3000 WMI -- Akebono Ceramics -- Centric High Carbon Rotors -- s204 Lip
"The mind is like a parachute, it only works when open"
NC-MS3Rob is offline   Reply With Quote
 Old 04-06-2017, 12:29 AM   #6
rymanmazda's Avatar
Posts: 1,531   (View Stats)
Groans: 122
fuuuuuuu
Freektune: 400whp/387awtq
-Autocross Setup-
Other Rides:
 Old 04-06-2017, 06:04 AM   #7
zenit's Avatar
Where does Garret say that?
-feejay
-wetzel
 Old 04-07-2017, 08:33 AM   #8
Well, I'm not sure that they have it in literature anywhere. We work pretty closely with Revvolution and they tested the Gen 1 against the Gen 2 GTX on a built BRZ a few months ago. We actually got that info from Revvolution when he was dealing with them pre test. That car made 563 on the gen 1 then lifted a head on the gen 2 somewhere over 600 and is currently waiting on a motor to continue the test.
So I guess I should amend that to "word on the street" since we haven't heard it directly from Garrett.
zenit (04-07-2017)
 Old 04-07-2017, 09:03 AM   #9
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
Will you add the price for uggradding from a GT/GTX gen1 to gen2 (No hotside)?
20% more for 0$ is only good for peoples looking to order one without already running an old model.
Can you gives more infos about the test of Revvolution or a link to them. I'm curious to see what was done beside swapping turbo. (Sometimes a bunch of add-ons count for the upgrade power too)
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 04-07-2017, 09:25 AM   #10
They do say it on the front page of their website. Nothing technical though.
EdgeAutosport.com likes this.
 Old 04-07-2017, 01:18 PM   #11
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
For easier comparison.
-Wetz
QFT
The Following 2 Users Say Thank You to xfeejayx For This Useful Post:
Mauro_Penguin (04-09-2017), mituc (04-10-2017)
 Old 04-07-2017, 02:18 PM   #12
We'll be getting the pricing up on our site next week so I'll link those at that time.
For the BRZ, this is the link to their blog on it.
Revv BRZ
There isn't anything on it yet about the Gen 2 vs Gen 1 because of the head lift after they started turning it up with the Gen 2. All that was changed between the Gen 1 and Gen 2 turbos was injectors. They were near the top of what the injectors could do on the Gen 1 and would run out of fuel on the Gen 2 so they preemptively upgraded.
zenit likes this.
 Old 04-10-2017, 06:16 AM   #13
Jeff23spl's Avatar
Attachment 231773
I'm i right to say there seem to be a +/-5lbs/min upgrade for a pressure ratio of 2-2.8 where we could potentially be with that turbo on a flowing 2.3.? (+/-50hp potential)
Wife drive 2010 CX7
 Old 04-10-2017, 08:06 AM   #14
xfeejayx's Avatar
Groans: 78
Not that straight forward. Look at the efficiency, old wheel actually looks more efficient in that range. So it may be that new wheel can push more air, but it will be hotter. So power gain may depend on the flow restrictions in your system and cooling ability. But yes, that's likely why they're saying it can make more power.
IMO, it's clearly not worth "upgrading" to this over the old one if you want more power, but it does seem like it may produce a wider power band because of the low end, which I always like.
-Wetz
QFT
 Old 04-10-2017, 08:54 AM   #15
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Going from a gen1 to gen2 or to unobtanium compressor wheels won't do shit if you keep that altar boy choking throat on the ATP turbine side.
MD1032 (04-11-2017)
 Old 04-10-2017, 10:45 AM   #16
This is definitely true for the bigger turbos... GTX3076 and up probably...
But it will still be pretty beneficial for the smaller ones like the quicker spooling GTX28's which now have a power bump and still retain the quick spool.
 Old 04-10-2017, 04:05 PM   #17
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
Not seeing it on your website. Link?
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
 Old 04-11-2017, 09:16 AM   #18
Waiting on pictures before we make them view-able.
Cataphract_40 (04-11-2017)
 Old 04-26-2017, 06:55 AM   #19
Jeff23spl's Avatar
any updates ?
Wife drive 2010 CX7
 Old 04-26-2017, 10:11 AM   #20
Here are the links to where you can purchase these turbos. Updated the OP as well...
- $1849
Cataphract_40 (04-26-2017)
 Old 05-15-2017, 11:34 PM   #21
Yangtze's Avatar
Posts: 1   (View Stats)
Yangtze has a little shameless behaviour in the past
Neutral  :  -1 score
i want to buy some mazadas's spare parts.for more information,please visit here.
Yangtze is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Yangtze For This Un-useful Post:
eliwwjd (05-23-2017), zenit (05-16-2017)
 Old 05-25-2017, 10:19 PM   #22
darrenab's Avatar
darrenab is an unknown quantity at this point
nice.
darrenab is offline   Reply With Quote
 Old 05-27-2017, 07:56 PM   #23
Groans: 30
Edge,
It looks like ATP has altered the construction of the coolant line they provide (as seen here).
I especially like how they seem to be using higher quality silicone hose for the EGR connection. Compare and contrast to the gen1 coolant line as see here:
Can you show us how this redesigned coolant line fits on the turbo? (Orientation, etc.) I was not a huge fan of how ATP jerry-rigged the coolant line on the gen1 GTX turbos.
1995 Miata
 Old 01-08-2018, 08:40 AM   #24
Jeff23spl's Avatar
Just 1 year after gtx gen2 release, Garrett release another new improved turbo, the G series
Will you have Mazdaspeed kits for them ?
IT seem to have a 54mm turbine like a GT28 can the ATP GT28 hotside fit those new design ?
https://www.turbobygarrett.com/turbo...series-g25-660
Wife drive 2010 CX7
 Old 01-08-2018, 09:17 AM   #25
Bob Ross Fanclub
Tomas's Avatar
fuck those like noice.
 Old 01-08-2018, 09:19 PM   #26
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
FINALLY AN O RING ON THE COMPRESSOR HOUSING
but yeah, i just briefly looked over it, but they look really good.
Last edited by aaronc7; 01-08-2018 at 09:19 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-09-2018, 10:19 AM   #27
Jeff23spl's Avatar
i read a reviews and my understanding (I may be wrong) The GTX gen1 and 2 was more about the compressor wheel than turbine wheel
and now, that revision upgraded both.....?
Wife drive 2010 CX7
 Old 01-09-2018, 11:58 AM   #28
aaronc7's Avatar
Groans: 370
Yeah about everything looks brand new
 Old 01-11-2018, 09:17 AM   #29
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Holey shet that compressor map...!
That turbo is efficient past 65% almost everywhere! Even though the 25-660 wheel sizes match a 3067 it pushes more air than a 3071 gen2.
pamzrdude likes this.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-11-2018, 10:12 AM   #30
Jeff23spl's Avatar
i would say more between 2567-2867 because 30 exaust is 60mm and this one is just 54mm with a 67mm compressor....
If we just look at flow potential we are close to be able to compare these:
Model............GT3582r = GTX3076r (Gen1) = GTX3071r (GenII) = G25-660 (G2567r)
Turbine size....68mm T. .....60mm T. ................60mm T. ...................54mm T
Comp. size.....82mm C. .....76mm C. ................71mm C. ...................67mm C
Rated hp.......400-675hp...360-640hp ..............340-650hp.................350-660hp
Release time......old.............200X.................Fal l.. 2016.....................Fall 2017
Wife drive 2010 CX7
mituc (01-11-2018)
 Old 03-11-2018, 09:43 AM   #31
KamloopsDan's Avatar
Posts: 64   (View Stats)
KamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to all
[MENTION @EdgeAutosport.com
I just wanted to let you know that when you filter parts by car (in my case 2007 MSP6) these new Gen 2 turbos do not show up. You have to search by MSP3 in order for them to appear.
Just thought I'd let you know.
KamloopsDan is offline   Reply With Quote
Tips on removing turbo mount bolt on speed 6 Tuff Gong Mazdaspeed3/6 General Discussion 10 03-09-2017 04:43 PM
ATP Bolt On Turbos At EdgeAutosport EdgeAutosport.com EdgeAutosport.com 60 09-17-2015 01:29 PM
ATP bolt on turbos + tunes Lex Stratified Automotive Controls 3 11-01-2014 08:18 PM
V6 6-speed Accord vs bolt on MS3 J30VTEC Street Racing Stories ( Bench Racing ) 13 10-16-2012 05:45 AM
Page generated in 0.50280 seconds with 36 queries
