 Old 11-08-2013, 09:07 AM   #1
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Default Clutch Reccomendation
Hey I was browsing the clutches on your site and really don't know which is best for my application and use. Reaching out before I hit the "buy" button.
My car is a daily driven wtih medium turbo gtx2867. Looking for somethign that will hold the abuse but not feel like I'm doing leg presses to change gears. Something good for a daily driven car.
EdgeAutosport.com (11-08-2013)
 Old 11-08-2013, 09:21 AM   #2
For daily driven comfort on a medium turbo like that, I would go with a stage 2+ clutch kit from spec.
You will need to get a flywheel because this one won't fit with the stock flywheel. You could also do a Stage 3 plus self ratcheting clutch and keep your flywheel. These are the most leg friendly clutch kits...
El_Diablo (11-18-2013), LumberJack (11-08-2013)
 Old 11-08-2013, 09:29 AM   #3
NCspecV81's Avatar
Which would be the best option for a future build? Let's say maximum 500whp or so? Still retain driveability. Only want to replace the clutch once.
 Old 11-11-2013, 10:39 AM   #4
Like others have said, the OEM clutch is not a bad option but if you are looking for high power/tq, you will probably want aftermarket. If your future goals are that high, I would go with a stage 3 + Spec. The stronger the clutch the less daily drive ability. Wear on a clutch is hard to specify because the driver has a lot to do with determing how long a clutch will last.
 Old 11-08-2013, 09:36 AM   #5
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
Edge and other folks, correct me if i'm wrong, but once you upgrade the clutch, the higher clamping force=the faster the clutch breaks down. So it theareticly won't last as long as the stock clutch.
Also, I'm pretty sure that clutches rely more on Tq numbers and not so much the HP numbers.
99 miata: sold
The Following 2 Users Say Thank You to Mortose For This Useful Post:
Big_Burd (01-05-2014), Boosted Beluga (11-12-2013)
 Old 11-08-2013, 06:03 PM   #6
LumberJack's Avatar
You really need to take into consideration what your future goals are if you have them since you're about to replace your clutch. My recommendation is get something that will support your "future" power goals if you have some, as well as not getting a clutch that will just "barely" cover your goals that's how clutches wear out extremely fast. Overkill is extremely underrated when building a car and especially with clutches. IMO get something that's rated for more power then your long term goals will be and you will have no worries whatsoever. Hope this helps in some way. @EdgeAutosport.com; I'm sure can help you with your decision
10.36@148 Fastest Gen 2
CWP_MS3 (11-13-2013), El_Diablo (11-18-2013)
 Old 11-08-2013, 07:23 PM   #7
mzr0818's Avatar
Groans: 221
stock
EMWNM 2013
2008 mazdaspeed 3 true red
Tuned by Nishan
The Following 8 Users Say Thank You to mzr0818 For This Useful Post:
alaskazero (01-07-2014), bstover17 (01-05-2014), EdgeAutosport.com (11-11-2013), El_Diablo (11-18-2013), jm211 (11-17-2013), SamiChicago (01-06-2014), silvapain (11-08-2013), zpele (11-09-2013)
 Old 11-09-2013, 07:19 AM   #8
Speed3in215's Avatar
Posts: 459   (View Stats)
Speed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond repute
I was thinking about the luk oem replacement with fidanza flywheel combo. Stock clutch is slipping at wot since my etune and mods are in sig. You guys think it's a good combo? I want something to last longer! Can't believe clutch is going at 30k guess it happens when you mod and drive it hard.
2012 Mazdaspeed3~~Cobb AP~Corksport SRI+Tip~CNT cbe~JBR Red Spherical Knob~JBR SSP w/bushings~Autotech Internals ~ JBR 88 duro RMM~ Ultimate Racing Race Pipe ~Ultimate racing catless downpipe ~ forge v1 BPV~ denso ivt22 one step colder plugs~Rokblokz mud flaps
Freek tuned on 93 pump gas
Virtual Dyno - 3rd gear 285whp 326tq
4th gear 270whp 352tq
Speed3in215 is offline   Reply With Quote
 Old 11-09-2013, 10:52 AM   #9
Karmat's Avatar
Posts: 1,179   (View Stats)
I would personally consider another OEM clutch. I've been at 350awtq for about 25k miles and the clutch has close to 60k miles. Still holding just fine.
2002 Corvette Z06 (Black)
The Following 7 Users Say Thank You to Karmat For This Useful Post:
alaskazero (01-07-2014), Big_Burd (11-09-2013), CWP_MS3 (11-13-2013), dereeek (11-12-2013), El_Diablo (11-18-2013), SamiChicago (01-06-2014), Tomas (11-09-2013)
 Old 11-09-2013, 12:18 PM   #10
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I replaced the clutch recently. The OEM clutch hold like a champ until it gave up and started slipping lightly at WOT.
I went for a new OEM LUK flywheel and the Spec Stage2+ self-ratcheting clutch kit (SZ033H) which I also purchased from Edge sometime last year (I don't remember). This one bites pretty hard and now the car is a bit more difficult to drive slow in bumper to bumper traffic, but it gets better every day. The pedal feel is similar to stock, if I didn't drive the car the same day with both clutches installed I would not have been able to tell the difference.
Clutch may be slipping, need some advice
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 11-09-2013, 01:32 PM   #11
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
New OEM Luk flywheel? Was the original one bad? Those things hold a lot of abuse and a new OEM flywheel is mucho dorrah. I would use a fidanza one if the OEM goes bad.
 Old 11-09-2013, 01:35 PM   #12
mituc's Avatar
Groans: 111
The original FW was not bad at all, but it was resting on the travel limiters. And I didn't want a single mass FW.
 Old 11-09-2013, 02:47 PM   #13
mzr0818's Avatar
Groans: 221
I have scuffed the surface and cleaned 4 oem flywheels @around 100k each and I have never had an issue.
EMWNM 2013
Tuned by Nishan
The Following 2 Users Say Thank You to mzr0818 For This Useful Post:
atvfreek (11-16-2013), Tomas (11-09-2013)
 Old 11-12-2013, 03:30 PM   #14
NCspecV81's Avatar
Spec stage 3 it is. Or is the act 6 pucks a better choice? I like the fact the ACT's replace the flywheel.
 Old 11-12-2013, 03:33 PM   #15
Mortose's Avatar
Groans: 39
personall experiance, so far, i love my 6 puck with street lite FW. Its stiffer than stock, but not horrible to daily drive. and iirc, they are rated for 470 wtq.
99 miata: sold
The Following User Says Thank You to Mortose For This Useful Post:
 Old 11-12-2013, 03:54 PM   #16
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
I called ACT about a month ago and they say they rate it at 450tq at the crank.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
Mortose (11-12-2013)
 Old 11-12-2013, 04:23 PM   #17
Mortose's Avatar
Groans: 39
They told me the 6 puck is good for 517 at the crank?! lol
I'll have to pull up the email that they said that, but ACT website says 470 tq
ZX4-HDG6 // Advanced Clutch Technology
Originally Posted by boostdmazda3 View Post
My act 6 puck with the streelight disk is being installed tmrw. Not looking forward to it.
Its seriously not that bad. Unless your talking about paying for the install. lol
99 miata: sold
Last edited by Mortose; 11-12-2013 at 04:23 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-12-2013, 04:30 PM   #18
boostdmazda3's Avatar
Posts: 1,177   (View Stats)
I got the homie hookup next door at mazda and its still expensive. I just look forward to not have my clutch slip.
boostdmazda3 is offline   Reply With Quote
The Following User Says Thank You to boostdmazda3 For This Useful Post:
 Old 11-12-2013, 03:38 PM   #19
 Old 11-12-2013, 03:49 PM   #20
Koke382's Avatar
Posts: 4,361   (View Stats)
Lol @ not looking forward to it. I dd my stiff ass clutch on traffic. Ull get used to it.
sent from my peepee
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
The Following 3 Users Say Thank You to Koke382 For This Useful Post:
blam1 (01-05-2014), Boosted Beluga (11-12-2013), Vader (11-13-2013)
 Old 11-12-2013, 04:00 PM   #21
sent from my peepee
Which clutch?
 Old 11-12-2013, 04:01 PM   #22
How about the CPE Stg1? Organic sprung disc is what you want for daily driveability.
CP-E MZR 2.3 DISI Stage1 Clutch Kit MS3/MS6 2006-2013
I haven't seen any reviews of this clutch however.
 Old 11-12-2013, 04:24 PM   #23
Groans: 50
Oh. Lol idk that's just what they told me.
@Lex; I was thinking of trying a cpe clutch but they don't have tq specs that I can find.
08 Mazdaspeed 3
 Old 11-12-2013, 04:32 PM   #24
Mortose's Avatar
Groans: 39
my local mazda quoted me $1k for install. no parts, just install.
99 miata: sold
 Old 11-12-2013, 08:08 PM   #25
ManiacMx3's Avatar
Posts: 256   (View Stats)
ManiacMx3 is the leader of the worldManiacMx3 is the leader of the worldManiacMx3 is the leader of the worldManiacMx3 is the leader of the worldManiacMx3 is the leader of the worldManiacMx3 is the leader of the worldManiacMx3 is the leader of the worldManiacMx3 is the leader of the worldManiacMx3 is the leader of the worldManiacMx3 is the leader of the worldManiacMx3 is the leader of the world
Groaned at 6 Times in 1 Post
Personal experience, I would recommend the same thing as what @EdgeAutosport.com; recommended. I have the spec stage 3+ with the fidanza flywheel and I absolutely love it. I drive the car pretty often and it feels exactly like the factory clutch.
Yes, it's more expensive, but much more friendly. Makes you not hate driving your car.
Current mods.......Starting Over...Bigger and better!
ManiacMx3 is offline   Reply With Quote
The Following User Says Thank You to ManiacMx3 For This Useful Post:
EdgeAutosport.com (11-13-2013)
 Old 11-12-2013, 09:17 PM   #26
There doing it for me for $400 granted i work next door. Did you replace the master and the slave cylinder?
 Old 11-12-2013, 09:23 PM   #27
Mortose's Avatar
Groans: 39
they replaced my slave......right after it blew up after the test drive. lol. i was out the door for my install at $623
99 miata: sold
 Old 11-14-2013, 12:16 PM   #28
Did they do the master and slave? Or just slave? Because the Master is on back order so they can only do the slave.
 Old 11-12-2013, 09:24 PM   #29
Koke382's Avatar
I have a stage 3
sent from my peepee
I had a stage 2 in my gti. Ghey.
sent from my peepee
1993 Red Na6
Last edited by Koke382; 11-12-2013 at 09:24 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-12-2013, 09:28 PM   #30
shit i want to replace my master and slave but dont know if they stock the parts...any break in you did? 3-4 slips and a long drive or anything?
 Old 11-12-2013, 09:44 PM   #31
Mortose's Avatar
Groans: 39
~200 of low throttle city driving with alot of clutch play, then i did a long trip to denver. then started some more spirited driving. I'm just over 400 miles now, and going wot from time to time.
99 miata: sold
 Old 11-13-2013, 10:09 AM   #32
The Stage 3 will probably be more friendly to your leg... But either one will be able to support some pretty goo power.
 Old 01-05-2014, 03:36 PM   #33
2012FailWheelDrive's Avatar
Posts: 327   (View Stats)
Whats the difference between the stage 3 and 3+?
"under construction"
 Old 01-05-2014, 06:55 PM   #34
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Plus Sign?
The Following 3 Users Say Thank You to hnda etr For This Useful Post:
bo0okert (01-08-2014), Boosted Beluga (01-05-2014), Micha (01-05-2014)
 Old 01-06-2014, 04:09 PM   #35
The pad material is one difference, but the 3 (carbon graphite) is a six pad design and the 3+ (carbon semi metalic) is a solid disc.
Big_Burd (01-06-2014), Boosted Beluga (01-06-2014)
 Old 01-06-2014, 04:25 PM   #36
So would the 3+ have a better life span?
 Old 11-13-2013, 11:33 AM   #37
Groans: 50
@EdgeAutosport.com; any tq specs on the cpe clutches?
08 Mazdaspeed 3
 Old 11-13-2013, 02:13 PM   #38
I've never seen any for the cpe clutchs, but I do know their stage 2 kit is on one of their customer cars making over 450tq. I'll see if I can get anymore info on this for you though!
The Following 6 Users Say Thank You to EdgeAutosport.com For This Useful Post:
boostdmazda3 (11-14-2013), Boosted Beluga (11-13-2013), El_Diablo (11-18-2013), jeopardy98 (01-12-2014), LumberJack (11-13-2013), Mortose (11-13-2013)
 Old 11-14-2013, 11:05 AM   #39
My act 6 puck with streelight disk is in. Dosn't feel nearly as bad as other people made it out to be. However, on my way home my slave cylinder went out. FYI if you get a stiffer clutch change dat shit.
The Following 2 Users Say Thank You to boostdmazda3 For This Useful Post:
EdgeAutosport.com (11-14-2013), Mortose (11-14-2013)
 Old 11-14-2013, 12:38 PM   #40
hnda etr's Avatar
Groans: 90
I had the same problem when I had the street disk... Slave took a shit a few months after install.... Got the revised (orange boot) slave and no problems so far, even after the 6 puck install...
FYI - I don't think there's any clutch and l/w flywheel setup that's less $ than the ACT kit... So if you want a l/w flywheel with your upgraded clutch, stick to the ACT setup.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f539/clutch-reccomendation-158701/
[ACT] Need a new clutch! - Page 2 This thread Refback 11-19-2013 08:34 PM
How many miles on your ACT Clutch or Aftermarket Clutch? Matrix311 MazdaSpeed 3 - Engine, Transmission & Driveline 5 07-29-2013 10:34 AM
Clutch disc snapped - new CM clutch experience Absolut1l MazdaSpeed 6 - Engine, Transmission & Driveline 4 05-08-2013 05:07 AM
Will a DIY clutch adjustment help a slipping clutch? Greekfreak MazdaSpeed 6 - Engine, Transmission & Driveline 1 09-20-2012 05:53 PM
Getting tires need reccomendation SleeperHatch MazdaSpeed 3/6 - Wheels & Tires 29 02-28-2012 11:14 PM
clutch vibration at top of clutch PLEASE HELP livetoskate06 MazdaSpeed 3 - Engine, Transmission & Driveline 84 03-06-2010 06:53 PM
Page generated in 0.62188 seconds with 36 queries
