| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
![]() Join Date: Oct 2013 Location: Nashville, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
(Thread Starter) | Not Ranked : 0 score I'll also be buying the V3 AP when I upgrade the internals. Thanks, I'm just a novice tuner. Would like to run Stage II soon. My order of upgrades: 1. borla 2. internals/AP 3. Corksport Stg II SRI, RMM, and colder plugs after that, I don't know. kevin |
| The Following User Says Thank You to rcisdrummer For This Useful Post: | EdgeAutosport.com (10-16-2013) |
| Not Ranked : 0 score If that Borla exhaust is a cat back only, it's not going to do much of anything for your back pressure, and shouldn't give you any issues. Add a test pipe and e-tune from one of the great tuners on here and you're done with the best bang-for-the-buck mods.
| The Following User Says Thank You to JgamB For This Useful Post: | EdgeAutosport.com (10-16-2013) |
![]() Join Date: Aug 2013 Location: Santa Fe, New Mexico
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 274
| Not Ranked : 0 score Welcome man! Internals is always good idea to install immediately for peace of mind. It just capable to push fuel more than the stock, which can enable you to mod more and make it more powerful without worrying the fuel pump isnt pumping fuel enough. You should be fine with the new internals and that mods. I havent got internals, since i dont have money now! haha, but it will be definitely my next upgrade. What RMM are you planning to run on?
__________________ 2008.5 Mazdaspeed3 GT MODS: ETS TMIC - Forge BPV - JBR Tru 3in Intake - JBR Boost/Bypass Hoses - Koni Yellows - Corksport CBE/Corksport Racepipe - Front Corksport FSB (Thanks Previous Owner) - JBR RSB - JBR STS/Heavy Weight Knob - Corksport Aluminum Skid Plate - JBR 88a RMM - Corksport LED Light Kit - Goodridge Braided SS Brake Lines - COBB AP - Corksport HPFP Running on Freektune OTS+ Map Possibly the first deaf MS3 owner here? hmmm... ![]() |
Last edited by rcisdrummer; 10-15-2013 at 12:29 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
| Not Ranked : 0 score No step colder plugs. I've said this at least a billion times on here. RUN THE HOTTEST PLUGS YOU CAN WITHOUT PRE IGNITION. If your plugs are too cold you will foul them out.
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts |
| The Following 4 Users Say Thank You to smoogs12 For This Useful Post: |
Thanks for the tip! | |
![]() Join Date: Jan 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 975
| Not Ranked : 0 score Nkg oem if you want I have used the autolites for a while and work just find. Go stock heat range. You r on right track. What car u have? Dont forget maintenance like tranny fluid and diff fluid if u have a 6. Leak test and clean ur valves. Compression/leakdown test will give u idea of engine health.
__________________ Black Mica 2006 Speed6 GT | 62,000 Miles Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1 ms6db.com I'm Registered. Are You? |
![]() Join Date: Oct 2012 Location: Arden, nc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
Groaned at 32 Times in 14 Posts
Groans: 423
Too much and you get pre ignition (get step colder). Too little and you get plug fouling (get step hotter). It all abou how far to either end of the spectrum you are. Every case is different.
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts | |
| The Following User Says Thank You to smoogs12 For This Useful Post: | Zpuhalla (10-15-2013) |
| Not Ranked : 0 score Ok, brand new car. Nice! FP, AP, Intake, a TP and an etune will get you cruisin!
| The Following User Says Thank You to jm211 For This Useful Post: | EdgeAutosport.com (10-16-2013) |
![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,219
Groans: 118
I do not have person experience with the stage 2 cpe do plan on moving to it over the winter. The JBR88 i helped install on a friends car. hardly any added NVH i was quite impressed
__________________ Damond Built Speed 6 | |
| The Following User Says Thank You to Deldran For This Useful Post: | EdgeAutosport.com (10-16-2013) |
![]() Join Date: Jun 2013 Location: Gilbertsville, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 201
| Not Ranked : 0 score Borla is an axleback for GenPu's BTW. I have the Corksport RMM and am impressed with it. 70d vibes less than stock almost, 80d vibrates but is not bad at all.
__________________ 2013 CWP Mazdaspeed3 |
__________________ 2008.5 Mazdaspeed3 GT MODS: ETS TMIC - Forge BPV - JBR Tru 3in Intake - JBR Boost/Bypass Hoses - Koni Yellows - Corksport CBE/Corksport Racepipe - Front Corksport FSB (Thanks Previous Owner) - JBR RSB - JBR STS/Heavy Weight Knob - Corksport Aluminum Skid Plate - JBR 88a RMM - Corksport LED Light Kit - Goodridge Braided SS Brake Lines - COBB AP - Corksport HPFP Running on Freektune OTS+ Map Possibly the first deaf MS3 owner here? hmmm... ![]() | |
| The Following User Says Thank You to rcisdrummer For This Useful Post: | lk250f (10-15-2013) |
| Not Ranked : 0 score haha, Genpu means Gen 2 ms3, and Genwon means gen 1 ms3
![]() Join Date: Nov 2012 Location: Moyock, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 72
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score OP I'm on same track as you. I'm getting ap and internals by next month. I think the wife would flip if I got them now. Edgeautosports has like a deal on getting both at the same time. |
| The Following User Says Thank You to zephgrave For This Useful Post: | EdgeAutosport.com (10-16-2013) |
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
| Not Ranked : 0 score Go with whatever exhaust you like. The Borla is only an axleback though. I recommended the Corksport rear mount. And Primus did suck, Les stopped that phrase in the mid 2000s. Good to see another fan, though!
![]() | | #21 | ![]() |
| Not Ranked : 0 score I don't have an opinion either way on the exhaust! I was more or less saying that if you need to pass emissions, leave the exhaust alone all together and get internals, ap, intake, and RMM and be happy for awhile. |
![]() | | #22 | ![]() |
Awesome! Glad to see a Primus fan as well. I threw the Sux out to see the response! I love it. Primus is my favorite band; certain albums mind you. I've been listening to them since "92 or so. I'm a drummer here in Nashville; day job then hit the skins off hours. Anyway, Tim Alexander is in the practice space again. He's been jamming for a month or so with them. I can't wait to see what comes of it. Last edited by rcisdrummer; 10-15-2013 at 03:47 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #23 | ![]() |
__________________ 2013 CWP Mazdaspeed3 | |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Lots of good info in here! Here is a modification guide on our site that might help you out with your research. Send me a PM and I'll get you setup with the combo deal for Autotechs/AP. |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | azazelthegreat (10-16-2013) |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Great info! Thanks everyone! And, three more posts to go... Last edited by rcisdrummer; 10-17-2013 at 06:57 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Yesss the info it's great |
![]() | | #27 | ![]() |
| The Following User Says Thank You to rcisdrummer For This Useful Post: | EdgeAutosport.com (10-18-2013) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score I was wanting to do that deal but I just bought my ap today all I need now is the internals |
| The Following User Says Thank You to zephgrave For This Useful Post: | EdgeAutosport.com (10-18-2013) |
![]() | | #29 | ![]() |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Rcisdrummer are you on that site on Facebook for the new or parts? It's a pretty good place for deals. I heard this is too but I haven't donated yet |
![]() | | #31 | ![]() |
![]() | | #32 | ![]() |
| Not Ranked : 0 score It's a Facebook page it's called mazdaspeed new/used parts |
![]() | | #33 | ![]() |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Yah I've had this car for a few months now and just been putting money away every paycheck. Now I've been buying parts and setting them aside to put them all on after I get the internals |
![]() | | #35 | ![]() |
![]() Join Date: Aug 2011 Location: Las Vegas, NV
| Not Ranked : 0 score Edge Auto has it well laid out but I would do additional reading and research as I dont feel it is as good as others advice. Originally Posted by jm211 View Post Ok, brand new car. Nice! FP, AP, Intake, a TP and an etune will get you cruisin! ^^ Thats on the $$^^ Exhaust isnt recommended until your making over 350(? correct me if I'm wrong). TP, and much later DP, is recommended on the exhaust side. So you need to let us know if its for the sound or performance. My TP keeps me sounding stock at idle and aggressive enough when moving or zoom-zooming. I much prefer the sound of the turbo from my SRI/TIP amd the BPV anyways. I bought turbo, not muscle. |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Yah I felt the same way. now I have SRI/TIP cobb, and a V2 ap on the way. In the next couple weeks I'll have internals on the way. The next upgrade I want after that is a DP and a TMIC after that. |
![]() | | #37 | ![]() |
I looked at the Borla, Cobb, and Cork exhausts; but like the ARK. I'd like a nice sound; a presence if you will. Not a fart box I hear running around Nashville; but low, tonal at idle but makes it self known. Tight and low I guess. Something that can lend itself for a little of both performance and sound. Listening to shit on youtube is hard to get a natural feel. I'm even using studio monitors to listen. | |
![]() | | #38 | ![]() |
| Not Ranked : 0 score That's what they all say... same with E85...
__________________ ATP GTX3067R, ATP Catted DP, HTP 3" Intake, UR FMIC, Stratified GA, Stratified EBCS, Bilstein B8's, Cobb Springs, JBR RSB, JBR Mudflaps, JBR OCC, GFB 50/50 BPV, Autotech Internals, JBR Shifter Bushing, Cobb RMM, Cobb AP |
![]() | | #39 | ![]() |
![]() | | #40 | ![]() |
yes... Once you taste the kool-aid, it's hard to resist..
__________________ ATP GTX3067R, ATP Catted DP, HTP 3" Intake, UR FMIC, Stratified GA, Stratified EBCS, Bilstein B8's, Cobb Springs, JBR RSB, JBR Mudflaps, JBR OCC, GFB 50/50 BPV, Autotech Internals, JBR Shifter Bushing, Cobb RMM, Cobb AP | |
| Autotech internals retainer question | Stingray69 | 2010 MS3 - Fuel, Nitrous & Water Injection | 1 | 02-16-2013 02:38 PM |
| Autotech internals question | kpsoerensen | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 34 | 12-28-2012 07:10 PM |
