Cobb LC/FFS conversion problems have done Stratified tune, and went to Cobb web to convert last @Lex; map with LC enabled at 2700 RPM, and FFS at default setting 6700RPM I beleive, LC/FFS default threshold at 6.21MPH, but have found when changing gears above 3000RPM I'm getting huge delay (at least 0.5 sec or even more) with adding gas. Actually I don't want FFS, just LC, but conversion tool on Cobb site don't allow me without putting FFS and FFS/LC threshold parameters, is there solution of just adding LC and fix with delay I got. Thanks. |
Set the FFS rev limiter to the rev limiter of the car at 6700 RPM to not have FFS enabled. |
Thanks Lex, I've actually done that in first. FFS is solved, but still have problems with gas pedal delay. |
Quote:
No. But found on your last few maps that RPMs goes for 100-150 in up when changing gears, dont know if you have done that for purpose. |
Have checked lines, everything seems OK, ECBS is clicking so I supose it work well. As I remember, we were three in car at that time in pretty inclined hill when it went 25PSI. Wonder how can I stop this happening. |
| All times are GMT -7. The time now is 12:06 AM. |
