 Old 05-01-2009, 07:37 PM   #1
ptperformance's Avatar
Posts: 4,123   (View Stats)
Neutral  +1 score
So, why do we blow our motors?
Well, its not from over boosting (proven by several).
Its not from to much fuel (DI can not put enough into the cyl's to hydro lock the motor)
The rods are forged (as you will see in the pictures)
The motor design is crap crap crap crap!
Here we go...
We have found that of the dozen or so motors that people have sent us parts on the rods appear to be bent and bending from hydrolocking. This would be impossible with the direct injection and several don't even have WI on thier cars. So the cause, I will get to here soon. The problem is oil control, and the intake filling up with oil on long trips at a particular RPM (cruise at 3000 rpm seems to be the key point that causes the oil build up).
We have the first motor that I have seen with out blowing apart and destroying the rods or block, this gave us a rare opritunity to see what happened. So here it is.
The pictures show that the rods bent, no cast rod will bend like this... so for those that questioned that, they are forged. Now there was zero crank damage and all the bearings checked out good, so how is this possible. I checked the thrust bearing, dead on according to the specs in the book. Its almost like it hydrolocked and then everything was OK, which I have no idea how this is possible but please read on.
During tear down there was oil everywhere, the turbo was leaking oil (inside the turbine housing), intake manifold was leaking oil, even the tops of the pistons had oil on them. I never thought anything about this and just figured it was because we put a hole in the top of the piston, to my suprise there were no holes in the pistons. I never put the two together until I started looking at the pictures, the damn motor hydro locked on oil. But how? We have some ideas but it all comes down to oil control in the motor. There are some things showing that the oil is lighting off in the motor (catching fire in the upper cylinders near the pistons, pictures shown). If that much oil is getting into the combustion chambers, that could be reason for the knock we get under light throttle, or the heavy knock after you get off the freeway or after a long drive. Again, I suspect that there is a bad RPM that causes oil to build up in the intake manifold due to the very very poor design of the PCV system and the oil control in the pan. I will dive into this a little bit, but until we can get a few locals cars running the oil control fix, I don't really want to speculate much on it. The next part will explain more about the oil control issues.
The pistons are showing errosion in the oil control ring land. As you can see by the pictures the pistons are melting (yes melting, which should take around 880 degrees). This melting can only be one thing, diluted fuel in the oil lighting off under pressure. How, I have no idea but its the only way you could get pistons to melt at this point. Thats the only way to get the heat into the pistons in such a small location in order to melt them. The pictures show a good unit vs a bad one and all the pistons had signs of this on the exhaust side. This is bad since I have never in all my years seen something like this. Even nitro and alchy cars don't have melt points this far down the skirts, not only that but none of the ring lands showed any signs of ring blowby or that the heat could be getting to the oil ring from the top of the piston. Its all from under the piston that is causing the light off.
What does all this mean?
One, we need to get the PCV system and oil under control in these motors. We have a few ideas that we are going to test out, but don't really want to discuss them here on the forums. A few locals have heard what I have to say about this and so far they agree. I will have a Ford engineer taking look at these pictures here in the next few days to give me his input as well. He is very smart and does engine dyno cell testing and data applications for motor design and improvment. If anyone has a good idea about what is happening, he will.
The cyl head is still playing a part in the motors going boom, and like I posted 4 months ago its a fix for some of the problems (not all of them but it cuts down on the heat which you can see the rods and crank are blue from heat). The cyl head will also make for better ring seal and keep localized hot spots in the head under control thus keeping a better ring seal on the pistons (this plays into the oil control issues with this motor).
Last, we have plans with 3 locals cars to start testing with full data logging of the changes that we have planned. One car is fairly stock, the others are modded heavily, one with an SST. My car is going to go into a full build status (so much for getting rid of it) and we will be showing you all that the SST can make the power and hope to break the 400 + WHP mark with a shot of spray with a DI meth set up. This is a different thread, so keeping with this one.... I hope you have questions and are looking for a fix like I am.
Pictures are
1. Yes this is a flat bench, and they are all bent
2. Not only did we bend them on the axis of the rod but also the beam and the flat
3. Pretty hey, they are sitting in order from right to left cly 1 to 4
4. These are the two bad ones
5. Again the two worse of the group
6. Scorched and melted below the oil control
7. Another one with melted oil control
8. This is what they are suppose to look like
9. This one is starting to go
10. This the 2nd worse one we could find
DutchPhenom likes this.
The Following 24 Users Say Thank You to ptperformance For This Useful Post:
AdriH (02-13-2010), ANGRYEAGLE (11-07-2009), ATC_MS3 (09-16-2009), bmfms3 (07-08-2010), danielbogdan (05-31-2009), DirtyHuevos (05-10-2010), dougefresh_ (05-24-2010), FearUndersteer (10-07-2009), IneptSideKick (01-21-2010), KayWhy (05-03-2009), kramer (07-07-2009), Log's Ms3 (09-24-2009), mike8748 (03-03-2010), mituc (07-16-2009), mrFanel (05-10-2010), mr_mazda329 (11-07-2009), PunjabiPlaya (07-05-2010), QuickSpool (05-20-2009), ReD BoY (07-06-2010), redspeed (06-03-2009), Shiftandgo (04-26-2010), SpeedSixxx (03-06-2010), yz007 (05-05-2010), _Toxic_ (07-09-2010)
The Following 2 Users Say NO Thank You to ptperformance For This Un-useful Post:
 Old 05-01-2009, 09:49 PM   #2
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
very interesting
 Old 05-01-2009, 09:53 PM   #3
I also forgot to mention that the BS assembly (yes it was still in the motor because we were getting ready to sell the car, was in fact sticky at one point in its rotation. I think this is because the rod hit the side of it but not 100% sure on that. BS delete is a must for every MS owner if they are going to up the boost.
One more thing to add, the rods bent in order from worse to less worse based on the firing order and intake valve opening events. This also leads me to belive that the fluid that formed the hydrolock came from the intake so how. The only thing that could be in there is oil, unless my pump is leaking fuel into the motor oil all the sudden (oil level was good when we checked it and the motor oil was clean, didn't smell like fuel).
The Following 4 Users Say Thank You to ptperformance For This Useful Post:
bmfms3 (07-08-2010), m4tic (05-01-2009), predapio (05-01-2009), SpeedSixxx (03-06-2010)
 Old 05-01-2009, 09:58 PM   #4
yang_jackson's Avatar
Posts: 432   (View Stats)
yang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the world
Groaned at 56 Times in 24 Posts
if this is the case, does it mean all ms3's will eventually 'blow'?
chief moped rider..... i just never let my friends see the moped. mopeds are great. they will do anything!
yang_jackson is offline   Reply With Quote
The Following User Says Thank You to yang_jackson For This Useful Post:
 Old 05-01-2009, 10:00 PM   #5
andrew88's Avatar
Posts: 36   (View Stats)
andrew88 has a spectacular aura aboutandrew88 has a spectacular aura about
Groaned at 20 Times in 3 Posts
Neutral  -1 score
you are an idiot.. if you have ever actually gone under the car you will realize that their are more fomoco parts that there are mazda. ford sucks plain and simple... im jk lol. about ford that is. there really is alot of ford parts though
andrew88 is offline   Reply With Quote
The Following User Says Thank You to andrew88 For This Useful Post:
The Following 5 Users Say NO Thank You to andrew88 For This Un-useful Post:
 Old 05-01-2009, 10:03 PM   #6
bova's Avatar
Groans: 45
um right relevant post?
The Following 2 Users Say Thank You to bova For This Useful Post:
phillyb (05-02-2009), SpeedSixxx (03-06-2010)
 Old 05-01-2009, 10:06 PM   #7
708
Erich's Avatar
Posts: 4,274   (View Stats)
BTW, those pictures don't do the bending in those rods justice. Seeing them in person my reaction was "Holy Shit"
The Following 2 Users Say Thank You to Erich For This Useful Post:
 Old 05-01-2009, 10:31 PM   #8
I am going to have to say yes but... we are going to be doing some side by side testing and photos to see if parts are the same between years. I suspect that they are and we are all screwed. I think that the driving style plays more of a part on the blown motors then the motor itself. By driving style I don't mean WOT driving, just around town or freeway cruise driving. Check the blown motor thread and you will see that a lot of those motors have blown after a long drive, or getting off the freeway after a drive of XX miles. Its oil control and the hydrolocking is caused from oil getting into the combustion chambers.
bmfms3 (07-08-2010), predapio (05-01-2009), SpeedSixxx (03-06-2010), yearzero (02-16-2010)
 Old 05-01-2009, 10:33 PM   #9
Thanks, the pictures never do justice to the damage.
The Following User Says Thank You to ptperformance For This Useful Post:
bmfms3 (07-08-2010)
 Old 05-01-2009, 10:36 PM   #10
Very interesting. My question is, if the rods are considered forged, how come this event isnt re-occurring on rebuilds?
Catch cans are not solving the oil problem in these engines either. There has to be a better solution to stop the over oiling and puddling occurring through the intake tract.
Lightnings have a similar problem as these cars. What we did was plugged the passenger side intake hose with a small round piece of metal, little larger then a dime. We then used a 1990-93 Mustang GT 5.0 PVC in the valve covers. Solved the problem. We would blow blue smoke out at startup and pull oil into the intake tract. The worse sign of oil puddling occurs below the intercooler. This occurs during the deceleration process with heavy vac pulling the oil through.
The oil seperator fix is outlined below:
The Following 11 Users Say Thank You to Haltech For This Useful Post:
Anklh (05-04-2009), badams118 (05-04-2009), bioevolve (05-05-2009), Dash08 (05-06-2009), gamblore (05-06-2009), Log's Ms3 (09-24-2009), predapio (05-01-2009), RocketScientist (05-05-2009), SLOMS3 (05-06-2009), SpeedSixxx (03-06-2010), xcoldricex (05-06-2009)
 Old 05-01-2009, 10:44 PM   #11
bova's Avatar
Groans: 45
 Old 05-01-2009, 10:58 PM   #12
Better quality forgings and higher quality material. Remember not all rods are created equal.
Nope, the cheaper catch cans are not going to work, you will have to spend the money to get a separated can with a media filter built into them. This should help. We are going to be doing a relocate kit for the PCV system that takes the PCV valve out of the side of the block and puts it back up into the valve cover. Very similar to the fix you have outlined here in your post, it might cause a little puff on start up, but the only other option is what we have pictures of here.
I don't think its a heavy vacuum either, its more of a splash and overfill of the current design. The system just cannot keep the oil under control in its current configuration. I will have more to report back on here very soon.
bmfms3 (07-08-2010), predapio (05-01-2009), SLOMS3 (05-06-2009), SpeedSixxx (03-06-2010)
 Old 05-01-2009, 10:59 PM   #13
Lots of people viewing but not very many posts, interesting.
bmfms3 (07-08-2010), FearUndersteer (10-07-2009), SLOMS3 (05-06-2009), SpeedSixxx (03-06-2010)
 Old 05-01-2009, 11:02 PM   #14
JumpingJackson's Avatar
Posts: 967   (View Stats)
W/I Injection = help or hurt this issue?
 Old 05-01-2009, 11:07 PM   #15
It will help with cleaning the internals from all the oil, our fix will keep the oil out of the intake and the WI will work with cleaning and keeping the knock under control.
The Following 5 Users Say Thank You to ptperformance For This Useful Post:
bmfms3 (07-08-2010), predapio (05-01-2009), silverspd3 (05-03-2009), SLOMS3 (05-06-2009), volodya84 (05-06-2010)
 Old 05-01-2009, 11:12 PM   #16
Please don't forget to hit the thanks button if you appreciate what we have done so far, thanks.
The Following 136 Users Say Thank You to ptperformance For This Useful Post:
23 marine (05-03-2009), 3mazdaspeed (07-05-2010), 6262ms3 (05-02-2009), 802MS3 (05-04-2009), Adam is so pro (05-07-2010), Addikted To Boost (05-02-2009), AdriH (02-13-2010), albone (05-20-2009), ASIC_BSEE (08-06-2009), ATC_MS3 (09-16-2009), atenza_freak (10-05-2009), austin102085 (05-27-2009), babcockxmx (05-02-2009), badams118 (05-04-2009), bbogue4 (05-04-2009), Bitner16 (08-15-2009), blacksin (07-04-2010), bmfms3 (07-08-2010), boosted3 (05-02-2009), ByeByeG35 (05-07-2010), Caldazar (06-08-2010), conkus (05-05-2009), Crossbow (05-02-2009), curlcd (03-28-2010), Dash08 (05-06-2009), david097 (05-04-2009), DeadWayt (05-12-2009), djkemistry (07-06-2010), djthom (07-22-2009), DLWILSON (11-09-2009), Docnox (05-05-2009), doizumi (02-12-2010), dougefresh_ (05-24-2010), eddelgado (05-04-2009), eronenris (07-05-2010), FearUndersteer (10-07-2009), flz33 (05-02-2009), fywdyl (07-06-2010), gamblore (05-06-2009), ganque (06-01-2010), gfather (05-08-2009), glocK23 (05-02-2009), gsrtype1 (07-12-2010), H3llfir3 (05-20-2009), herks6 (02-16-2010), hnda etr (08-19-2009), JacksonMS30 (02-15-2010), jainsworth123 (01-14-2010), Jessed87 (05-31-2009), JGard (07-09-2009), jmhinkle (05-06-2009), jtspells (05-05-2009), kgb (05-02-2009), kore2000 (05-05-2009), kramer (07-07-2009), kyoo (02-11-2010), late8 (05-06-2009), lidokrantz (05-02-2009), LiEast (05-30-2010), madboost28 (05-06-2009), magoo (05-02-2009), matzilla14 (05-13-2009), mazdamx3freak (06-12-2010), michael.fetner (02-25-2014), mike8748 (05-01-2009), MiSbrigo3 (05-02-2009), mizboo102 (07-05-2009), mpsanger6 (06-27-2009), mroclimbr (05-10-2013), mr_mazda329 (11-07-2009), MS3 Ventura (05-02-2009), ms3boost (05-02-2009), MS6 Sanchez (04-09-2010), mtnrunner (05-02-2009), Murse (05-04-2009), Mzspeed (05-04-2009), nighthawk358 (05-02-2009), Nitro (11-14-2009), norcal707 (05-05-2010), Ozark (07-12-2010), ozzzzz (07-05-2009), PaPaSpeed (05-05-2009), PerryMS3 (05-10-2009), phantom3 (05-03-2009), pipe (05-21-2009), predapio (05-01-2009), psi (05-03-2009), psychophyr (05-02-2009), RacingToaster (06-08-2010), Refonbass (05-02-2009), RGV_MS3 (05-21-2009), RocketScientist (05-05-2009), rossisboss07 (03-28-2010), RUMBLEFISH (05-05-2009), s-retire (05-28-2009), sadak (03-01-2013), Sal's_MS6 (06-06-2010), samsel450r (05-02-2009), senor blanco ms3 (06-04-2009), serium (05-02-2009), Shady (09-02-2009), SharkDiver (05-04-2009), sherbel6 (08-28-2009), shock6 (05-08-2009), silverspd3 (05-03-2009), Sixburgher (05-24-2010), SLOMS3 (05-06-2009), smakdown61 (05-02-2009), snowms3 (10-23-2009), Speed freak (05-03-2009), SpeedNess (10-05-2009), SpeedSixxx (03-06-2010), spnkr21 (05-03-2009), Spoolme (01-13-2010), SpyNaldo (12-28-2009), Stealth01 (03-03-2010), stevessvt (05-02-2009), Strawberry (05-06-2009), superskaterxes (05-02-2009), Superstretch18 (05-04-2009), taf0422 (05-11-2009), Tender Vittles (02-14-2010), thanox2 (05-13-2009), ThEsHoCkEr (05-08-2009), Tiz (05-10-2009), Tommyspeed3 (06-11-2010), TruboPower (05-03-2009), turboneil (06-27-2009), turtleman321 (05-14-2009), volodya84 (05-06-2010), xcoldricex (05-06-2009), YammerR1 (05-04-2009), yang_jackson (05-01-2009), yearzero (02-16-2010), Zimmer (05-07-2009), _Toxic_ (07-09-2010)
The Following User Says NO Thank You to ptperformance For This Un-useful Post:
 Old 05-01-2009, 11:18 PM   #17
MadOzodi's Avatar
Posts: 686   (View Stats)
MadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the world
Took a while to read. I noticed on my way to work earlier this week, I was merging from one highway onto another after cruising and when I accelerated I got massive knock...KR reading on my gauge showed 7.3. I actually saw a nice thick cloud of smoke out my rearview mirror. Couldn't tell what color it was cuz my windows are tinted, but it reminded me of diesel exhaust.
To add insult to injury, CELs P2187 and P0455 a day or two later. Thanks for posting your findings. Would you say that once a small "event" happens, there's no way to stop it since the damage is already done?
07 COSMIC BLUE MS3 GT
00 OBSIDIAN BLACK TRIUMPH LEGEND TT 900 - gone, but not forgotten
09 PACIFIC BLUE TRIUMPH SPRINT ST 1050 - SOLD
11 BLACK SUZUKI GSX-R750 - totaled
11 BLACK SUZUKI GSX-R750 - totaled...again
*OFFICIALLY RETIRED FROM TWO WHEELS*
MadOzodi is offline   Reply With Quote
 Old 05-01-2009, 11:23 PM   #18
m4tic's Avatar
Posts: 4,928   (View Stats)
its friday night
so, how much $$$ for this preventive modding....
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 05-01-2009, 11:25 PM   #19
Cosmic3MPS's Avatar
Posts: 355   (View Stats)
Cosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the world
Groans: 31
Groaned at 22 Times in 10 Posts
Anyone looking into these issues deserves our thanks. Your comments make a lot of sense and I think you are on the money. Mine blew about a week ago under the exact circumstances you describe. Driving for about three hours on a highway, slowing down to pass through a small town, accelerating back up on the way out of town in 5th and kaboom! No 4 cylinder and fist sized hole through the block. Oil right through the exhaust and melted piston through the turbo. The event happened under such gentle acceleration that I think there is much more going on here than the 'leaning out' suspicion that has been blamed for so much. Really hope you get to the bottom of this one.
How to deflower virgins:
At the crucial point the guy bites her on the ear. Distracts from the pain. Ever try that?
Mitch: Hell no, I sock 'em in the jaw and yell, "Pop goes the weasel."
Cosmic3MPS is offline   Reply With Quote
The Following 7 Users Say Thank You to Cosmic3MPS For This Useful Post:
23 marine (05-03-2009), 802MS3 (05-04-2009), atenza_freak (10-05-2009), bioevolve (05-05-2009), Ferdball (05-02-2009), SpeedSixxx (03-06-2010), Tiz (05-10-2009)
 Old 05-01-2009, 11:28 PM   #20
kingpin748's Avatar
Posts: 2,611   (View Stats)
Groans: 78
This is probably too technical for most people here. While I understand what you're saying I can't add much because this is my first build. Looks like a good theory though. I hope this issue gets figured out.
In reality I love lenny
kingpin748 is offline   Reply With Quote
The Following User Says Thank You to kingpin748 For This Useful Post:
martyxattack (05-01-2009)
 Old 05-01-2009, 11:50 PM   #21
stevessvt's Avatar
Posts: 163   (View Stats)
stevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond repute
Would there be any outword tell tale signs of this happening? Like oil level going down over the course of so many miles? I have an 09, will you be looking in to any 09's to see if anything has been corrected on them? How many 09's have popped?
stevessvt is offline   Reply With Quote
 Old 05-02-2009, 12:05 AM   #22
Scatt Nasty's Avatar
Posts: 1,204   (View Stats)
Scatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the world
Groans: 94
Groaned at 43 Times in 33 Posts
Neutral  -1 score
this kind of makes sense. I took a road trip to PHX about a week ago, its in the 90's there. After the trip was the first time since owning the car that I heard audible engine knock and hit a 5.9 on the AP.
321 HP/348TQ-- 13.940 @ 106 /3kft ASL
Scatt Nasty is offline   Reply With Quote
 Old 05-02-2009, 12:12 AM   #23
ElBartoRex's Avatar
Posts: 1,186   (View Stats)
ElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the world
Hey PT-
I know you guys have a lot of experience w/ the NSRT-4 and DSMs-- those guys run OCCs with an extra industrial check valve (not an OEM valve but a McMaster/Carr or Grainger) to contain the issue of the PCV leaking under boost. Have you ever done this on a MS3/6 do you think it would make a difference? All I see is MS3 guys running secondary stock PCVs.
I have a McM/Carr viton seal check valve w/ .3psi cracking pressure ready to install with my catch can and I am curious if anyone has done anything like this yet.
What about installing a secondary can on the VC/intake line? Anyone done this yet?
2007 Mazdaspeed3 Sport, True Red
ElBartoRex is offline   Reply With Quote
 Old 05-02-2009, 12:34 AM   #24
smakdown61's Avatar
Posts: 1,069   (View Stats)
smakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the world
Groaned at 37 Times in 23 Posts
Well I can tell you that before I got my catch can (saikou michi) I would get a good amount of part throttle knock and right as I was going WOT I would smoke puff out the exhaust. Ever since I put in the occ, rarely any part throttle knock and zero oil puffs out the exhaust.
smakdown61 is offline   Reply With Quote
 Old 05-02-2009, 12:43 AM   #25
glocK23's Avatar
Posts: 1,753   (View Stats)
glocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the world
Groans: 701
Groaned at 655 Times in 620 Posts
Nice breakdown, although this is pretty much foreign to me!
glocK23 is offline   Reply With Quote
 Old 05-02-2009, 08:04 AM   #26
serium's Avatar
Posts: 448   (View Stats)
serium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the world
Groaned at 34 Times in 12 Posts
long trips in ms3 ftmfl....take girlfriends car ftmfw
2008.5 Red Mazdaspeed 3
Performance Mods: OBX RP | SURE Intake | SU-TMIC | Cobb TIH | Turbosmart Hybrid BOV | JBR 80 Duro RMM | Hypertech
Appearance Mods: 15% tint | Blacked-out Emblems, Side Markers and Side Reflectors
Monitoring: Dashhawk
serium is offline   Reply With Quote
The Following 2 Users Say Thank You to serium For This Useful Post:
802MS3 (05-04-2009), Sport6 (05-07-2009)
 Old 05-02-2009, 08:19 AM   #27
BaseballD2's Avatar
Posts: 196   (View Stats)
BaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant future
this is great info, so a baffled oil catch can, egr delete oil is still getting in the IM? Even you you clean it frequently?
06 MazdaspeeD 6 Black Mica
Drowned
BaseballD2 is offline   Reply With Quote
 Old 05-02-2009, 08:24 AM   #28
GQ_WhiteMS3's Avatar
Posts: 658   (View Stats)
GQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the world
Well .. this is good news that we are seeing a likely situation ... but bad news if we can't get a fix.
GQ_WhiteMS3 is offline   Reply With Quote
 Old 05-02-2009, 08:31 AM   #29
bova's Avatar
Groans: 45
so is this puff of smoke good or bad off start up? cause right now if my car sits for the evening then i start it up the next morning i usually get a puff of smoke.
 Old 05-02-2009, 09:13 AM   #30
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
LMAO! Note to self: NO ROAD TRIPS!
Where's Whoosh?
He manipulated several of these oil/emissions control apparatuses on his car, did he not?
I knew this stuff was responsible for alot of the KR, but never thought it'd be solely responsible for Zoom Zoom Boom.
The Following User Says Thank You to I<3Groceries For This Useful Post:
 Old 05-02-2009, 09:42 AM   #31
MrMcCrackin's Avatar
Posts: 1   (View Stats)
MrMcCrackin is an unknown quantity at this point
interesting - here for additional results and possible fix
MrMcCrackin is offline   Reply With Quote
 Old 05-02-2009, 09:46 AM   #32
No road trips is right ... I was planning on taking the speed for an 8 hour drive to Minneapolis ... but now it'll be the wifes santa fe.
 Old 05-02-2009, 09:51 AM   #33
Ghost Rider's Avatar
Posts: 248   (View Stats)
Ghost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the world
i would suspect that many people drive their disi mzr engined cars for long trips at cruising speeds. should not there be more blown motors, especially with the length of time some of these cars have been out (ms6)? if this is truly a design flaw on all of these engines we should see much more blown motors, yes? I would think with the number of so equipped vehicles this would be more prevalent.
Ghost Rider is offline   Reply With Quote
The Following 6 Users Say Thank You to Ghost Rider For This Useful Post:
atenza_freak (10-05-2009), jax ms3gt (06-07-2009), jayspeed3 (06-01-2009), sadak (03-01-2013), Speedee3 (05-06-2010), SpeedSixxx (03-06-2010)
 Old 05-02-2009, 09:58 AM   #34
stevessvt's Avatar
what's the number of stock or nearly stock cars popping? All I have is a Hybrid BOV and second cat delete.
 Old 05-02-2009, 10:10 AM   #35
Crossbow's Avatar
Posts: 709   (View Stats)
Crossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the world
I would assume that if there is a flaw, certain types of modding will "accelerate" the effect of said flaw, and increase the chance of it happening.
There has been a few "stock" engine blown claims, but we all know how easy it is to "demod" a car rather quickly. For all we know some of those characters were running 20+ psi outta the stock turbo. Plus haven't heard of any of those issues in a few long time.
My questions are of course...
Was one of the car running the windage tray and a catch can? Weren't those two items supposed to help resolve oiling issues? And if one of these car's had the BSD, that's #2 blown BSD motor that we know of.
Crossbow is offline   Reply With Quote
The Following 3 Users Say Thank You to Crossbow For This Useful Post:
mik3y (11-10-2009), SpeedSixxx (03-06-2010), Sport6 (05-07-2009)
 Old 05-02-2009, 10:46 AM   #36
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
Where's Whoosh?
i'm here watching all this get figured out "again" lol
no offense John, but the oil in the mani is an old news kind of thing
a correct OCC with extra pcv or check valve and deleted egr kept my intake clean as a whistle
I never had knock on my no tune set up
additionally, the reason I opened up the rear of the valve cover and vented it to a different OCC (vented/filter on top) is because I didn't want any oily vapor entering the intake tract when boosting as I was at or above 20psi
no BS it's a full time job to keep this engine clean
I cleaned or replaced plugs often, changed my fuel sheared oil every 2500 miles with PP and kept my OCC empty all the time (every weekend)
2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008)
2008 Caliber SRT4 / 11.8 @ 120
whoosh@Realtune is offline   Reply With Quote
The Following 10 Users Say Thank You to whoosh@Realtune For This Useful Post:
802MS3 (05-04-2009), bykeryder4life (05-03-2009), gamblore (05-06-2009), jayspeed3 (06-01-2009), kgb (05-02-2009), kore2000 (05-05-2009), kramer (07-07-2009), Murse (05-04-2009), phillyb (05-02-2009), SpeedSixxx (03-06-2010)
 Old 05-02-2009, 11:05 AM   #37
whoosh, were you fully built? did you push your car?
I think there are too many people who are abusing their modded cars with out any noticeable issues, some with high mileage, to just say, oh, its all engines and it is a design flaw.
The Following User Says Thank You to Ghost Rider For This Useful Post:
 Old 05-02-2009, 11:08 AM   #38
bova's Avatar
Groans: 45
deadman just took his car on a 6 hour road trip a month ago and was just fine.
and yes whoosh was fully bolted.
The Following User Says Thank You to bova For This Useful Post:
 Old 05-02-2009, 11:14 AM   #39
m4tic's Avatar
hey whoosh..... i remember you doing this.... i need to find your threads, and where can i get a egr block off plate?
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 05-02-2009, 11:18 AM   #40
TrueSleeper's Avatar
Posts: 2   (View Stats)
TrueSleeper will become famous soon enoughTrueSleeper will become famous soon enough
Hi to all.
I´m new here so haven´t read other theads about this knockin problem.
I live in finland and we have all togeher about 50 Mazdaspeed 3:s and about same of the Mazdaspeed 6 (they call them 3MPS and 6MPS here).
I´we been logging knock retard among other stuff with my dashhawk, and driving on a motorway in 6:th gear I get Knock retard between 2 to 6 on cruise control at 3000 to 4000 RPM. But when I touch the gas pedal or brake, knockin is instantly at 0.
I haven´t seen any smoke at all when knockin but I´m little consern about this.
We haven´t had eny motor breakdowns here at my knowing, but does this sound similar what U guys are having.
I know there are some differents between our and your models.
Have there been any Mazdaspeeds blowing engine that are under warranty?
I would think that Mazda would fix this kind of problem very quickly if something that big is wrong in our engines?
TrueSleeper is offline   Reply With Quote
The Following 2 Users Say Thank You to TrueSleeper For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/why-does-your-motor-blow-26996/
How much can 2.3 T stand - Page 5 This thread Refback 07-05-2012 12:23 PM
Another Monster Build? - Colorado Mazda Club This thread Refback 03-04-2010 08:12 AM
How much can 2.3 T stand - Page 3 This thread Pingback 12-25-2009 06:13 PM
OzMPSclub - Australia's fastest growing Mazda MPS forum - Blown engine theory This thread Refback 08-26-2009 02:00 AM
Mazda 3 MPS Blown motor theory (1st Gen) - OzMazdaClub.com - Australia's Best Mazda Car Club and Forum This thread Refback 08-14-2009 12:30 AM
2.3disi Turbo Engine Blow - Club Mazda This thread Refback 07-17-2009 03:47 PM
smoking but turbo seal good? PCV issues? - Mazda6 / Atenza This thread Refback 06-10-2009 01:39 PM
Why does our motor blow?... - Mazda6 / Atenza This thread Refback 05-22-2009 08:24 AM
MS3/ATR: partial throttle knock - TorontoMazda3 This thread Refback 05-13-2009 08:44 AM
Thinking of trading the GTI in for an MS3........ - Page 3 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 05-12-2009 07:38 AM
Tuoreimmat viestit This thread Refback 05-10-2009 12:16 PM
Mazda 3 MPS This thread Refback 05-10-2009 11:43 AM
Tuning a MPS - Page 2 - OzMazdaClub.com - Australia's Best Mazda Car Club and Forum This thread Refback 05-08-2009 04:19 PM
Thinking of trading the GTI in for an MS3........ - Page 3 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 05-07-2009 02:42 PM
Problems with the 2.0T - GenCoupe.com Forums Post #4 Pingback 05-04-2009 01:23 PM
It's time to know - Mazda6 / Atenza This thread Refback 05-02-2009 09:14 AM
The Official: Mazdaspeed 3 Thread - Page 88 - NASIOC This thread Refback 05-02-2009 08:31 AM
Blown motor theory - OzMazdaClub.com - Australia's Best Mazda Car Club and Forum This thread Refback 05-01-2009 11:41 PM
Blown engine theory - OzMPSclub - Australia's fastest growing Mazda MPS community Post #4 Pingback 05-01-2009 11:30 PM
Why does your motor blow thread, look inside. ptperformance Mazdaspeed3/6 General Discussion 207 08-16-2009 12:01 PM
Why did Mark's motor blow? MarkyMark Mazdaspeed3/6 General Discussion 61 05-20-2009 01:33 PM
Will i blow? Grim MazdaSpeed 3 - Engine, Transmission & Driveline 26 02-20-2009 10:22 AM
Is my engine going to blow? toprock MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 01-19-2009 10:38 PM
Page generated in 0.74432 seconds with 45 queries
