 Old 08-27-2017, 02:12 PM   #1
njdurkin's Avatar
Posts: 68   (View Stats)
njdurkin is an unknown quantity at this point
Default Where is the injector driver module?
In a post I found for doing a compression test, it says to remove the injector driver module connectors. Does anyone know where this is? Can't find any information on it. And sometimes when I do find info it shows pictures but the pictures are always photobucket pictures that say something about 3rd party access not allowed.
njdurkin is offline   Reply With Quote
 Old 08-27-2017, 02:16 PM   #2
tom10122's Avatar
Posts: 116   (View Stats)
tom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to all
Just push the accelerator to the floor while cranking and that will turn off the injectors
Sent from my XT1565 using Tapatalk
tom10122 is offline   Reply With Quote
 Old 08-27-2017, 02:59 PM   #3
Djohns's Avatar
Posts: 3,944   (View Stats)
Yea no need to fuck with that, pull the fuse for the fuel pump, start it up and let it run till it dies then disconnect the coilpacks and pull them out with spark plugs and then do your test.
2010 black mica speed3
Soon:built motor
SAS control module, where is it? RACER_X Gen2 MS3 General Discussion 1 08-03-2016 04:57 PM
Injector seals - need to replace injector/fuel line O-rings? TheRealDefman 2010 MS3 - Engine, Transmission & Driveline 3 03-02-2014 09:35 PM
Page generated in 0.23449 seconds with 22 queries
