![]() Join Date: Aug 2018
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Hello everybody, i believe you could help me... I have Mazda 6 MPS 2006 with a weird engine problem: Cold start is ok, engine is running about several minutes, when it get a little bit warm, then "dies" (turns itself off). I can start it again withnout problems, but after a few seconds engine dies again. Then again, and again... Engine goes into high revs without any problems (when is running)... Anybody idea, what could do this problem? - tank is in a half - cranshaft sensor replaced - throttle body replaced - air mass sensor replaced |
![]() Join Date: Oct 2011 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 601
Groans: 106
| Not Ranked : 0 score Do you have a method of data logging? Also, you can search this site quite a bit better by using the below in whatever search engine. site:www.mazdaspeedforum.org/forum "Search term here" |
(Thread Starter) | Not Ranked : 0 score Yes, I have Delphi (Autocom) diag tool. No DTC errors. Something to focus on measuring data? Now, after almost 20h engine runs about 5 min mins and then died again. Then start, engine runs 15s, suddenly no reaction on gas pedal and engine turn itself off... |
![]() Join Date: Aug 2014 Location: Monroe, Mi
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score Gonna have to Accessport and log because with as many things as it could be we'll all waste tons of time and probably your money trying to figure it out. Just for shits I'd check your fuel pump and anything you replaced before it started acting up Secondly, want to post an intro? |
(Thread Starter) | Not Ranked : 0 score SOLVED ![]() Fuel Pump resistor - located under the air filter box. A lot of corrosion and overheat, cables damaged. I´ve just tried to bypass this resistor - just connected these two wires together. Everything seems to be OK now, 45km driven and no more problems at all... Pictures attached |
| The Following User Says Thank You to mirak For This Useful Post: | JSmith (08-30-2018) |
| Weird misfire problem | Speed3Pedro | Mazdaspeed3/6 General Discussion | 34 | 08-27-2016 08:40 AM |
| Weird problem | Woodyspeed3 | Gen2 MS3 General Discussion | 5 | 06-05-2015 08:04 PM |
| Weird Problem | danfbh | CX-7 > Issues & Troubleshooting | 12 | 06-11-2014 03:09 PM |
| Another weird problem with shifting into first | Mazdaspeed3KHP | 2010 MS3 - Engine, Transmission & Driveline | 6 | 05-20-2013 09:15 PM |
| Weird start up problem | Mazdaspeed3KHP | 2010 MS3 - Engine, Transmission & Driveline | 17 | 05-20-2013 10:57 AM |
