 Old 02-19-2018, 06:33 AM   #1
Xxblinddzxx's Avatar
Posts: 126   (View Stats)
Xxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud of
Groaned at 26 Times in 11 Posts
Default Overboost WGDC 0
Hey guys,
I just got my mazdaspeed back after installing a GTX3076R on it and since then i've noticed some overboost over +/- at 4500RPM (28 Psi). I have a safe map from freektune that I believe the boost is limited to 12-13 PSI and from the logs i see that the WGDC is at 0 during all the WOT. Any advice? faulty EBCS or maybe the Wastegate?
Thanks
Xxblinddzxx is offline   Reply With Quote
 Old 02-19-2018, 08:01 AM   #2
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Originally Posted by Xxblinddzxx View Post
Hey guys,
Thanks
It looks like a bad case of 'boost creep' from running an IWG, mixed with cold ambient temperatures. The only solution is to port out the WG in the turbine housing, or go with an EWG. Another thing, are you sure you have the 3 port EBCS routed correctly?
Based on what I can see in that log, don't go WOT anymore until you figure this out. You're completely maxing out the injectors, fuel pressure is dropping, running very lean, with very high counts of knock.
What mods do you have and what fuel are you running?
 Old 02-19-2018, 09:03 AM   #3
ATP GTX3076R, 4" HTP
OEM Intake manifold ported
Built bloc (wiseco & K1) with L19 (stock head)
Full race exhaust manifold
3" CPE downpipe
Upgraded HPFP
TR8 frount mount intercooler with JBR piping
Yes i've double checked from grimmspeed website to make sure it is.
What if i plug the IWG to the boost source directly? that way i should be able to see if the WG is not working?
 Old 02-19-2018, 09:09 AM   #4
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
sure you shouldn't redo that, not even once....i did a lot less than this for 2 logs in third gear (few second) and i blew a ringland!!! You must look at boost and knock and lift off as soon as you see that!
If you really need to drive the car, maybe you can disconnect the BOV/BPV vaccuum to cancel any high boost and adjust your gaz pedal to avoid any overboost...
Before grinding the WG, i would find an air tank with a pressure regulator and adjust it to 20-30 psi to activate the wastegate and make sure it open properly
To make sure the creep isn't because of a vaccuum piping error, i would connect a pressure hose directly from a pressure source to the wastegate. (removing the EBCS completly)
If EBCS is blocking the boost path going to WG even if the tune say 0wgdt, it is like 2000% WGduty...Then test it slowly looking at boost and knock (Maybe in higher gears) and stop as soon as boost exeed let say 18-20 psi
Do you know what was the rating of your WG spring ?
Winter and gt30 IWG = creep but it is a bit large to be juste a matter of WG size...unless you got a 25psi wg spring....(My gt28 catless was mecannically overboosting of about 1psi maybe 1.5 at the worst worst case with a 17psi spring rate)
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 02-19-2018, 05:50 PM   #5
3" CPE downpipe
Upgraded HPFP
That's what I was thinking. You could take the EBCS out of the equation by connecting the boost source directly to the WG actuator and see if exceeds 13 psi, but let off the throttle as soon as it does
All of those flow mods with an IWG are a recipe for boost creep in these cold temps.
WGDC at 0 redspeed30521 MazdaSpeed 3/6 - Turbo Induction 16 10-26-2014 04:35 PM
WGDC Inconsistencies with Boost Tuning - Random flatline and no wgdc compensation phate 2010 MS3 - ECU Computer Tuning 38 02-10-2013 01:49 PM
No change in boost from 0% WGDC to 100% WGDC phate MazdaSpeed 3 - Engine, Transmission & Driveline 30 12-12-2011 03:27 AM
.33% WGDC at CL WorstEpEver MazdaSpeed 3/6 - ECU Computer Tuning 0 08-18-2011 07:09 PM
help with WGDC turboneil
Cobb ATR Support
11 05-29-2010 11:09 PM
Page generated in 0.26274 seconds with 23 queries
