![]() Join Date: May 2016
Rep Power: 53 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
(Thread Starter) | Not Ranked : 0 score I've been using a quart every hundred miles, did the turbo and pcv valve. Nothing. Just had a compression and leakdown test done and I'm confused on the results Cyl 1 150. 15% Cyl 2 150. 15% Cyl 3 130. 15% Cyl 4 150. 5% The mechanic that did it also said cyl 4 had oil on the plug, but that seems like the best numbers wise. Cylinder 3 possible cracked ringlands? Sent from my XT1565 using Tapatalk |
| Not Ranked : 0 score Oil in the cylinder seems like it would improve compression and leak down tests by sealing up the gaps. So if your good results are from the oily cylinder, expect poor results if that cylinder was dry.
(Thread Starter) | Not Ranked : 0 score Any idea what the culprit is? Rings or valves stem seals? Sent from my XT1565 using Tapatalk |
Groans: 143
| Not Ranked : 0 score A leakdown test will tell you where the leakage is occurring. The technician is supposed to listen for where the air is leaking from. If I had to guess, yes, I would say the problem is likely in the bottom end, likely cracked ringlands. 15% leakdown on a stock motor is a lot.
| Confusing electrical problem | ShintaroIchi | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 10 | 08-02-2015 01:30 AM |
| Mostly good compression but shit leakdown results | VA2010MS3 | 2010 MS3 - Engine, Transmission & Driveline | 1 | 07-23-2015 09:43 PM |
| Bad Leakdown | Mofford12 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 15 | 10-29-2014 04:26 PM |
| Leakdown test question | torq | MazdaSpeed 3/6 - Turbo Induction | 0 | 08-09-2013 08:29 PM |
