Like Tree36Likes
 Old 07-23-2015, 06:04 PM   #201
Kellerspeed3's Avatar
Posts: 2,518   (View Stats)
Kellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the world
Groans: 50
Groaned at 37 Times in 21 Posts
Thanks for making this thread!!
2010 Velocity Red w/tech package: Cobb AP, Cobb DP, Tr8L FMIC, Auto Tech internals, BNR S-4 turbo, JBR 3.5 aluminum intake, CPE stage 2 rmm, JBR 80 duro TMM, JBR 70 PMM, JBR SSP and bushings, JBR 5mm spacers, JBR RSB, JBR By Pass Tube, Magna-flow CBE with the "fix", NGK 6510's, JBR EBCS, SSP OCC(now Kozmic), JBR EGR delete, EGR deleted, JBR IM TIG, JBR TB TIG-coolant by-pass, Turbo smart BPV, built block with CP pistons, eagle rods, ported head, pinned cams, shimmed valve springs, Spec clutch stage 3, FordMoCo full syth transmission fluid, Eibach pro kit, ported IM with VCTS delete, ported exhaust mani, Werksracing strut tower brace, TB Performance front traction bar and mid-chassis brace, Corksport adjustable struts and shocks, slotted/drilled rotors, SS brake lines, and lots of TLC. FreekTuned Kotzur built 93/E-85 Prius killa.
Kellerspeed3 is offline   Reply With Quote
The Following User Says Thank You to Kellerspeed3 For This Useful Post:
jabeel00 (07-24-2015)
 Old 07-23-2015, 07:11 PM   #202
blue speed's Avatar
Posts: 237   (View Stats)
blue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond repute
Groaned at 4 Times in 1 Post
Originally Posted by jabeel00 View Post
Hello there. I'm a noob and hope I'm not thread-jacking but this is the intake thread I found. I just picked up an 08 ms3. I cannot for the life of me tell what intake system I have. Without knowing what I have I cannot determine if it's ok or if I should get something different. I noticed the the red hose (pictured) comes out differently than most of the others I have seen. I hope you guys can help me make sense of it. I will attempt to put photos below (crossing my fingers). Thank you in advance.
Looks like a Corksport to me.
Cobb shifter weight, CBE, RSB, knob Corksport BPV, boost tubes, SRI, TIP ,Ex hangers,80 Duro RMM & TMM insert CP-E TMIC, UR test pipe & catted DP, Hypertech, Autotechs. JBR Coolant bypass, intake gasket, air filter & BP hose.Konig wheels. Sure, FSB bushings.
blue speed is offline   Reply With Quote
The Following User Says Thank You to blue speed For This Useful Post:
 Old 07-24-2015, 10:46 AM   #203
jabeel00's Avatar
Posts: 100   (View Stats)
jabeel00 has a brilliant futurejabeel00 has a brilliant futurejabeel00 has a brilliant futurejabeel00 has a brilliant futurejabeel00 has a brilliant futurejabeel00 has a brilliant futurejabeel00 has a brilliant futurejabeel00 has a brilliant futurejabeel00 has a brilliant futurejabeel00 has a brilliant futurejabeel00 has a brilliant future
Thank you Blue Speed. I wasn't sure. I thought I remember issues with those?
Also, now I know I am threadjacking, last night I took our my TB and cleaned the crap out of it. Today my car is supper sluggish, hesitating, as if its on limp mode. I am worried that I messed up something opening the butterfly. Could someone kindly tell me how I can "reset" or "calibrate" it? I am worried I pushed the butterfly too far closed it too far or messed up it's alignment. I'm also getting a P0234 overboost condition. Any other ideas? I'm all ears :/
jabeel00 is offline   Reply With Quote
 Old 07-24-2015, 04:43 PM   #204
jabeel00's Avatar
EDIT: After burning out my brain for 30 hours straight on MSF, I am happy to report this was all a case of user error. One worm drive wasn't tightened. [Insert emoji banging his head on a wall here]
Needless to say, thank you MSF for all the learning I have done. I made a donation today, a small token of appreciation from me and my baby MS3.
Now If only I could figure out how to start a thread "why there is an orange/yellow wire drilled into my ecu coming from the plug, connected to the red wire in the harness?" I'd be in good shape.
 Old 01-10-2016, 11:43 AM   #205
rotarican21's Avatar
Posts: 30   (View Stats)
rotarican21 has a spectacular aura aboutrotarican21 has a spectacular aura aboutrotarican21 has a spectacular aura about
Idk if this would be considered jacking the thread but it is definitely intake related and thought it would be useful in case others have the same issue. I recently obtained a used cobb sf intake. When I was installing it, I noticed the maf air straightener inside was slightly curved or warped. Only on one side tho, not both. I was wondering if that would be an issue with the readings for the maf. I will post a pic of it later when I get a chance.
I considered getting a new maf housing but one made of aluminum instead of plastic so that wouldn't be a problem but they aren't exactly cheap and at that price I might as well get a whole new short ram. But when I post the pic I'll let you guys help me determine that.
Last edited by rotarican21; 01-10-2016 at 11:43 AM. Reason: MSF Database - Automerged Doublepost
rotarican21 is offline   Reply With Quote
 Old 01-10-2016, 12:06 PM   #206
my2k13speed3's Avatar
Posts: 2,325   (View Stats)
@rotarican21; you're better off picking up a new 3" intake and call it a day
 Old 01-28-2016, 05:05 PM   #207
michaelhanson96's Avatar
Posts: 15   (View Stats)
michaelhanson96 will become famous soon enoughmichaelhanson96 will become famous soon enough
Groaned at 9 Times in 3 Posts
Default Stock ecu with cai and tip
If I were to go with the corksport stage3 with the TIP do I need to tune it with the AP or can I run it like that for now until I buy the AP also does the corksport tip cause turbo smoking because I believe it's cp-e with the new tip that fixes that problem I could buy the corksport cai and a cp-e tip and be fine right? Will I need a tune?
michaelhanson96 is offline   Reply With Quote
 Old 01-29-2016, 07:10 AM   #208
blue speed's Avatar
Corksport also has the same option available. As far as a tune with just the intake yes you can however a tune would be better all around and depends on how much more you want to do to the car from here. And don't forget the internals.
 Old 01-29-2016, 08:05 AM   #209
Finchee's Avatar
Posts: 306   (View Stats)
Finchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond repute
You're better off getting the AP first. After that, you can get any intake you want and you won't be limited to a stock sized intake. You can even go for a 3 inch or 3.5 inch intake.
Also please add punctuation marks to your future posts.. It can be a little hard to understand what you're really asking, when you have like 4 questions in one very long sentence.
Liquidsilver likes this.
2013 Mazdaspeed3 with Tech Package
Autotech Fuel Pump Internals
Cobb Accessport V3
Continental ExtremeContact DWS06
CorkSport SRI, TIP
CP-E xFlex Stage 1 65A Rear Motor Mount
Damond Motorsports Short Shift Plate
ETS TMIC
James Barone Racing Thermal Insulating Throttle Body Gasket & Coolant Bypass Kit
Magnaflow CBE
NGK Iridium IX Step Colder Plugs
Dizzy Tune in progress...
Finchee is offline   Reply With Quote
The Following User Says Thank You to Finchee For This Useful Post:
aackthpt (01-29-2016)
 Old 01-30-2016, 04:19 PM   #210
StevenPThomas's Avatar
Posts: 201   (View Stats)
StevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant future
Groaned at 9 Times in 5 Posts
Default Feels slow
So I just installed my corksport stage 2 power series air intake and took it for a drive and it felt like my excelleration was slower than normal. Now I did have to replace the valve solenoid and I have not yet replaced the HPFP internals, but they seem to be good. Hitting 1759 psi at WOT. Any ideas?
StevenPThomas is offline   Reply With Quote
 Old 01-30-2016, 04:53 PM   #211
That's weird. Did you make sure all the piping was tight and secure? If something is lose then you'd deff be leaking air and would loose power. When I bought mine, the clamp right on the turbo from the inlet pipe was loose and leaking under boost. Double check everything. Intercooler piping as well
 Old 01-30-2016, 06:23 PM   #212
Thank you. Will do.
 Old 02-01-2016, 11:52 AM   #213
jabeel00's Avatar
Like rotarican mentioned, check ALL connections, hose clamps, plugs, etc. I know with my intake (same as yours) I had to Teflon tape the brass fitting that screws into in intake towards the turbo for the small hose to connect to, it was leaking.
Also be sure to check the actual MAF. With mine the o ring was cut, causing a leak. I replaced it and the second one got dislodged (half in/half out) creating a leak. I would always, when installing the MAF sensor, take the SRI off and hold it in your lap so that you can see the o-ring slide in properly. Also use lube, jokes aside, it helps the o-ring fit properly without cuts.
Good luck!
2008.5 MS3 GT- CS Stage II Power Series SRI- CP-E HPFP- JBR Stage II OCC-COBB RMM- COBB AP V2- COBB Tune Stage1+CS+TIH+93+v231
 Old 02-01-2016, 12:03 PM   #214
Thank you very much. I checked the tube over the brass fitting and it had come completely off. Ended up putting it back on with a clamp and its held perfectly. Even pushing to 130 mph never came off. I did lube up everything th first time. Helped sensor go in with ease. Thanks guys!
 Old 04-28-2016, 05:37 PM   #215
Civo93's Avatar
Posts: 1   (View Stats)
Civo93 is an unknown quantity at this point
I suggest making a note about the difference between the cp-e nano being for oem MAF sizes while the xcelXL will need a MAF calibration.
Pretty much something that will tell people nano is for stock turbo and xcelXL is for BT. Don't need any brownies saying "I installed my cpe xcelXL intake and now my car can barely idle and runs like crap"
What formula did you use to do a maf cal?
Civo93 is offline   Reply With Quote
 Old 06-13-2017, 01:40 AM   #216
Adam1234's Avatar
Posts: 2   (View Stats)
Adam1234 is an unknown quantity at this point
Hi, I'm new to the mazda mps and have heard a lot about the fuel pump internals, would it be fine to install an intake without upgrading the pump internals?
Sent from my SM-G935F using Tapatalk
Adam1234 is offline   Reply With Quote
 Old 06-13-2017, 08:04 AM   #217
 Old 06-13-2017, 09:32 AM   #218
Lulz
 Old 06-13-2017, 09:33 AM   #219
Adam1234's Avatar
No need to be cocky like, asking a genuine question
 Old 06-13-2017, 10:55 AM   #220
Beefstallion's Avatar
Posts: 9   (View Stats)
Beefstallion will become famous soon enoughBeefstallion will become famous soon enough
Please visit the MSF Knowledge Base Section - MSF KB - Read me First!
Sent from my XT1650 using Tapatalk
Beefstallion is offline   Reply With Quote
 Old 10-08-2017, 09:39 PM   #221
panaspeed3's Avatar
Posts: 68   (View Stats)
panaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to behold
Groaned at 23 Times in 11 Posts
jbr or coob intake?
panaspeed3 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/official-intake-thread-99462/
Foro Club Mazda España ? Ver Tema - Admisión directa mps 10 This thread Refback 07-07-2015 09:07 AM
THE OFFICIAL INTAKE THREAD!! - Mazdaspeed Forums This thread Refback 05-08-2015 06:54 PM
Picked up a 2007 Mazdaspeed6 last night. : mazda This thread Refback 04-09-2015 08:03 AM
Ver Tema - Admisión directa mps 10 This thread Refback 01-12-2014 10:21 AM
Club de Usuarios de Mazda ? Ver Tema - Admisión directa mps 10 This thread Refback 12-10-2013 03:00 PM
? View topic - SRI Help This thread Refback 02-19-2013 10:37 AM
Group buy HTP Turbo Inlet Pipe Mazdaspeed - Mazda 3 Quebec This thread Refback 12-01-2012 05:04 PM
Feeler pour achat HTP TIP - Mazda 3 Quebec This thread Refback 11-28-2012 12:39 PM
Club de Usuarios de Mazda • Ver Tema - Admisión directa mps 10 This thread Refback 07-31-2012 11:58 AM
SilverDemon/JM Fabrications Intake Manifold Interest Thread SilverDemon MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1707 02-25-2013 03:33 PM
MA Performance Product and Info Thread Rev 3 Intake Manifold maperformance Modern Automotive Performance 195 05-21-2012 02:28 PM
Official HID thread? supraman MazdaSpeed 3/6 - Appearance 22 03-23-2011 08:19 AM
Page generated in 0.42244 seconds with 34 queries
