(Thread Starter) | Not Ranked : 0 score From a road perspective, it is perfectly flat, in decent repair, and only has an 3' elevation over a .4 mile stretch of road. It runs north and south along a major freeway with posted 50mph speed, no driveways or cross-streets and perfect visibility. The road would seemingly provide consistent north to south or south to north datalog runs. I always noted some kr (~1.5) on the NB runs and never on the SB runs. I always chalked this up to different elevation resulting in different calculated load or something similar in the tune resulting in some true KR. Tonight, I stacked up a bunch of NB and SB logs and found something pretty interesting: The KR had a very unique characteristic on ALL of my NB runs. It would hit ~0.5kr @ ~3000, and then hit 1.4 @ ~5,000 and peak again at 1.4 @ 5200 with one little kr blip @ ~6200. The SB runs on the same road yielded none of these KR blips but had some characteristics of their own (0.5kr @ a few distinct RPMs). I started going through past months' logs and I'll be damned if this almost EXACT KR profile wasn't exhibited on a bunch of past months' runs. I traced it back to summer months even. I could tell which direction the run was simply by looking at the KR profile. The KR was due to bumps and/or noise from the road, not to my car. After studying the stretch of road on Google Earth, it confirmed what I saw. The road has very few repairs southbound and a bunch of patches northbound. So, kids, the moral of the story is, you may want to run a conservative tune and baseline a datalogging road before doing tuning runs on it. Otherwise, you end up fighting the road and not tuning your car. Now that I understand my road, I will only make runs southbound from here on out. Here are some examples. You can see what I am talking about; these are runs months apart from one another across different tunes. Again, none of these KR blips happen when travelling the road southbound.
| The Following 4 Users Say Thank You to dale_gribble For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score I kept trying to dial the timing back to see if these blips would ever go away and they never went away which is why realized it probably wasn't the tune and finally gave up and started looking over the logs...
![]() Join Date: Mar 2011 Location: Saddle Brook, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,589
Groans: 92
| Not Ranked : 0 score these cars are very sensitive when it comes to reading kr.
__________________ KILLAH BUILT PTE 5862 @29psi JMF MANI METH TUNED BY NISHAN 11.54@123 What does your new map trap |
| The Following User Says Thank You to amggilly305 For This Useful Post: | dale_gribble (12-28-2012) |
(Thread Starter) | Not Ranked : 0 score Ya, I agree completely. I think my aftermarket motor mounts play their part too... I think I am going to dump my AWR trans mount and just stick with the PMM and RMM. The NVH on the trans mount is pretty bad and that can't be good for KR.
Groans: 92
| Not Ranked : 0 score i have all 3 awr mounts and don't have an issue with kr at wot. find a smoother road
(Thread Starter) | Not Ranked : 0 score Ya, i got that... For the record, its a pretty damn smooth road overall, it isn't some beat up road in the sticks. Its good for others to read this so they don't tune phantom kr... I am sure i am not the only one. By the way, which duro bushings you running in the trans mount?
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 Last edited by dale_gribble; 12-28-2012 at 01:46 AM. Reason: MSF Database - Automerged Doublepost |
Groans: 92
| Not Ranked : 0 score @dale_gribble; 70 for all 3
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 | |
Groans: 111
| Not Ranked : 0 score Definitely the motor mounts + road noise (even stiffer dampers/springs may result in false knock). I've seen this before several times.
![]() Join Date: Jun 2008 Location: New Port Richey, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,984
Groans: 88
I see your Stratified Tuned....Doesn't the AP allow the adjusting of the knock sensors sensitivity? If so, could you adjust that accordingly and retest?
__________________ FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute JAM SESSION........US Amps (in Series w/ Stock Amp) using OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back) RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors - Acne Rear Bumper LED Reflectors | |
| handling observation - suspension sticky? | galens47 | 2010 MS3 - Suspension & Brakes | 1 | 10-30-2012 11:31 AM |
| jbr bushing install observation | Vinnie | 2010 MS3 - Engine, Transmission & Driveline | 13 | 05-03-2012 08:56 PM |
| Duty Cycle Observation/Question | kgb | Cobb ATR Support | 2 | 02-07-2010 08:09 PM |
| Interesting KR observation | johnnyspeed6 | MazdaSpeed 3/6 - ECU Computer Tuning | 21 | 01-20-2010 06:08 AM |
| Fuel Trims and BAT observation | chrisyng | Cobb Access Port/Maps | 3 | 08-19-2009 07:18 AM |
