 Old 08-21-2017, 12:47 PM   #1
AlwayzSpeedn1985's Avatar
Posts: 17   (View Stats)
AlwayzSpeedn1985 has a little shameless behaviour in the past
Default OBD Port Replacement
My OBD port keeps losing power/connection when i try to hook anything up on to it. I went to my local Mazda dealer and they are telling me id haveto order a whole new wiring harness. That there isnt a specific part number for just the OBD port and that its a 16pin connection but its only a 6pin on my 07 MS6. Anyone know where i might be able to find the the replacement port i would need? Thanks
AlwayzSpeedn1985 is offline   Reply With Quote
 Old 08-21-2017, 01:11 PM   #2
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Groaned at 18 Times in 8 Posts
Hmm....you would almost be better off having someone try to repair the existing plug? On my old honda the connections had separated inside the main relay due to heat during summer. I had to open it up and re-solder the connections.
Hard to find someone to repair something specific like that, however I imagine it is just a lose wire or two where the wire meets the pins...
Check this thread out, fairly certain this will resolve your issue:
https://mazdaspeeds.org/index.php?th...ose-pins.2502/
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Last edited by Bexar; 08-21-2017 at 01:11 PM. Reason: MSF Database - Automerged Doublepost
Bexar is offline   Reply With Quote
 Old 08-21-2017, 01:12 PM   #3
Ya the pins inside the clip seem very loose thats why im thinking i need a new clip and it would be fine. But as for finding an MS6 in a junk yard in the area i live in would be like finding a needle in a haystack. Do you have any clue as to how far the wires run to where its actually connected at?
 Old 08-21-2017, 01:28 PM   #4
Bexar's Avatar
Check the thread I linked, it shows the pins as being very close to the dash, seems easily accessible and shows you how to remove. The thread is for MS3, but I assume most cars including MS6 are the same.
Join the Facebook groups for selling mazda parts and no doubt there are people parting out MS6's that will ship any parts to you if you indeed do need them.
I believe one of the groups is called mazdaspeed new/used parts
JBR:
The Following User Says Thank You to Bexar For This Useful Post:
AlwayzSpeedn1985 (08-21-2017)
 Old 08-21-2017, 01:52 PM   #5
I checked out the thread its different for the MS6 and luckily i dont haveto take the dash apart to access it. The port is right above the gas pedal. My clip ia just hanging there the braket is missing. Was like that when i bought it so makes me think the last owner might have had a problem with it also. Im going to try to tighten them and see how it goes but i dont have anything to hook up to it at the moment. My AP was stolen earlier this yr waiting to save up and get a new one. Thanks for the help!
Thoughts on this AUX Port Replacement SasquatchMS3 MazdaSpeed 3/6 - Car Audio & Electronics 4 02-04-2014 07:32 PM
E85 + 5th Port = win? chuckms6 MazdaSpeed 3/6 - E85 Fueling 2 09-28-2012 07:48 PM
Grimmspeed 3 Port In 2 Port Mode on IWG? bewsted MazdaSpeed 3/6 - ECU Computer Tuning 1 12-21-2011 08:59 AM
Serpentine Belt Replacement, GM Replacement Parts For Older Cars, Fixing A Radiator Fan, Rebuilt Brake Calipers: Mike Al Haltech Automotive News 0 03-27-2009 02:30 PM
Page generated in 0.26645 seconds with 21 queries
