![]() Join Date: Feb 2018 Location: Alberta, Canada
Rep Power: 0 ![]() Thanks: 0
Groaned at 4 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score Car starts up then dies after the rpms just drop and only way you can catch them is putting the gas in all the way anything less and nothing happens, anyone have any solutions, everything on the motor has been replaced everything is basically brand new ,wiring, fuses, relays everything Sent from my iPhone using Tapatalk |
![]() Join Date: Sep 2016 Location: Ringgold, Georgia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 411
| Not Ranked : 0 score What mods are you toting? And other than a built bottom end, was any mods added to the mix? Assuming you upgraded to a different intake during this conversion, try unplugging the MAF sensor and see if it'll run without too much issue. If that's the case, and you haven't gotten the new intake tuned, get a tune. We got lots of good e-tuners here who can tune on either Accessport or Versatuner.
__________________ ETS TMIC, Cobb TBE, Intake, TIP, AT Internals, JBR trilogy mounts, EBCS, EGR Delete/blockoff, Bosch 3.5 MAP Bar sensor, Stripped interior #racecar |
(Thread Starter) | Not Ranked : 0 score Running big turbo, st intake mani, 3.5” intake, fullrace manifold, 3” DP , 3.5 bar map sensor, 3Port BC , DW300c In tank pump, HPFP internals,fmic , corksport big Throttle body.Car will start up and can sometimes idle for little with pedal 3/4 in but if you lift of it dies Sent from my iPhone using Tapatalk |
__________________ ETS TMIC, Cobb TBE, Intake, TIP, AT Internals, JBR trilogy mounts, EBCS, EGR Delete/blockoff, Bosch 3.5 MAP Bar sensor, Stripped interior #racecar | |
(Thread Starter) | Not Ranked : 0 score All on , Car been in out for while trying to solve a fuel pressure issue which took roughly 4 months. Now that the pressure is good the car just won’t stay alive Sent from my iPhone using Tapatalk It’s been a battle to get this car running Sent from my iPhone using Tapatalk Last edited by Hunts_ms3; 12-12-2018 at 09:28 PM. Reason: MSF Database - Automerged Doublepost |
| Not Ranked : 0 score There is another thread beside yours with similar problems and good tips. You may take a look
![]() Join Date: May 2016 Location: Sarastoa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
| Not Ranked : 0 score Is the MAF calibration correct for your mods? As Varomnia mentioned, the tune needs to know how big the intake is.
__________________ 2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub Other Mods: FIAMM 72112 Low Note Horn alongside stock Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks |
(Thread Starter) | Not Ranked : 0 score Engine hasn’t even been broken in yet, every time the cars starts, it’s starts up like cold start for about 6 seconds then dies. Sent from my iPhone using Tapatalk |
| Not Ranked : 0 score If that MAF tune is not correct for your intake, it likely won't run at all or will just die after starting. Has your computer been tuned for your mods? Whether or not the engine is broken in doesn't matter. in fact, if you're not tuned, you can't break in your engine, cause it won't run.
(Thread Starter) | Not Ranked : 0 score Ok what do you suggest I do Sent from my iPhone using Tapatalk |
| Not Ranked : 0 score Good point, you can't run a stock tune with different sensors range. Usually when you get extanded range sensors is because you understand the need and how it works. The 0-5v signal remain 0-5 but 5v means a lot more than before and the ecu need to know it. The MAF would peg on positive LTFT/STFT but cannot compensate for a huge change like that. when it read 100g/s it pass about 175g/s....It probably get even worst at iddle speed... Similar for the map You either need a special maps for your mods that will need to be made again after break-in (Etuner usually help for this) Or you can switch back to oem map and maf hosing for the break in period but make sure to stay low boost to avoid pegging the sensors.
| Not Ranked : 0 score You need to get a tune for your size intake, preferably for your particular one, or return to a stock size. Diameter is the primary variable, but there are others.
(Thread Starter) | Not Ranked : 0 score MAF is all good not the problem, thinking of pulling the motor and again Sent from my iPhone using Tapatalk |
(Thread Starter) | Not Ranked : 0 score By passed the whole maf and still having same problems Sent from my iPhone using Tapatalk |
Groans: 60
| Not Ranked : 0 score Your new MAF housing means that for a given voltage you're actually flowing almost 62% more air. Without a proper tune the ecm will not be injecting enough fuel for it to stay running. Getting the idle calibration close enough to run isnt very hard at all. Multiply the original maf calibration by 1.619, and you'll be close enough for it to idle. Then you just do a normal maf calibation to fine tune it.
You MAF and MAP need to be addressed together. Even if you find a way to keep the car idling, it won't be safe to drive it this way.
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... Last edited by Jeff23spl; 12-17-2018 at 07:07 AM. Reason: MSF Database - Automerged Doublepost | ||
(Thread Starter) | Not Ranked : 0 score Pulled motor back out , reassembling it. The that built motor was stupid so hopefully when valve cover comes off we can see the issue right away. Sent from my iPhone using Tapatalk |
| Build my engine or built longblock? Built trans? | Mustangkr500 | Mazdaspeed3/6 General Discussion | 24 | 07-22-2016 12:17 PM |
| Best Places to have bottom end built? | onetechyguy | MazdaSpeed 3 - Engine, Transmission & Driveline | 1 | 05-05-2012 08:24 AM |
