![]() Join Date: Jul 2011 Location: graham, wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
Groaned at 8 Times in 3 Posts
(Thread Starter) | Not Ranked : 0 score Ok so after try number three i am convinced im missing something.. I opened up my headlights to add angel eyes, and black out the chrome.. Drivers side light is perfect, passengers side leaks like crazy.. Both lights were sealed using OEM Butyl rubber purchased from nissan. has anyone had there lights leak anywhere besides the lense? My wires enter the light behind the high beam bulb socket.. could it leak here? thanks
__________________ PTP windage tray/ BSD|PTP CDFP|Cobb SRI| JBR RMM|JBR SSP|CS TIP|Cobb AP+OTS tune |
![]() Join Date: Jun 2011 Location: Coeur 'D' Alene, ID
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,418
Groans: 186
| Not Ranked : 0 score is is getting condensation or is water actually getting into it?
__________________ 2012 BM MS3 w/ tech. Cobb AP V2b: Autotech CDFP internals: JBR 88d RMM: SURE 3" Aeros full intake: Ebay test pipe: Corksport TMIC: Turbosmart BPV: Bridgestone Potenza 235/40 tires: self tuned |
![]() Join Date: Feb 2010 Location: Daphne, Alabama
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
| Neutral : +1 score Get some windshield sealant and cover the entire area where the lens and housing come together. Should solve all your troubles. |
![]() Join Date: Feb 2010 Location: Seattle, WA
Rep Power: 2233 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 142
Groaned at 58 Times in 37 Posts
| Not Ranked : 0 score sounds to me like your driver's side headlight fluid needs to be refilled.....
__________________ Zoom-Zoom-Coons on 05/10/16 ![]() 2011 Mazdaspeed3 Celestial Blue Mica BUILT BY CORKSPORT CP-e Catted Downpipe || CP-e HPFP || Corksport Turbo || Corksport 3-bar Map Sensor || Corksport EBCS|| Corksport SRI || Corksport TIP || Corksport CBE || Corksport Boost Cut Killer || Corksport FMIC || Corksport SSP || Corksport MM Inserts || Corksport Blue Shift Knob || Corksport Injector Seals || DM Full EGR Delete Kit || Corksport License Plate Relocation Kit || Snyapse Engineering Synchronic BOV || Cobb V3 Accessport (PD Tune in progress) |
(Thread Starter) | Not Ranked : 0 score its just condensation.. but a lot of it.. builds up along the bottom half of the lense... what is this "windshield sealent" you speak of? @Worbit: thanks for being an ass
| The Following User Says Thank You to MS3kid08 For This Useful Post: | Worbit (11-27-2011) |
| Neutral : +1 score Should be at your local parts store. Worked great when I painted mine. |
then another weekend of bumper removal fun lol Did you just put it on the outside of where the housing meets the lense?
__________________ PTP windage tray/ BSD|PTP CDFP|Cobb SRI| JBR RMM|JBR SSP|CS TIP|Cobb AP+OTS tune | |
| Not Ranked : 0 score Yup, just applied it around the entire area where the lens and housing connect. |
(Thread Starter) | Not Ranked : 0 score i will be trying this, thanks man
![]() Join Date: Jul 2009
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score Reviving an old thread but did any one that tried using that window sealant have success? |
| leaky, leaky | wette460 | MazdaSpeed 3/6 - Turbo Induction | 16 | 09-09-2011 04:12 PM |
| Is my leaky DP the cause of this? | Fatguy729 | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 07-27-2011 09:02 AM |
| CEL p2188 - leaky injector? | bmylez | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 85 | 04-23-2011 07:12 PM |
| Need Help with Leaky Transfer Case | Mfinlay04 | MazdaSpeed 6 - Engine, Transmission & Driveline | 3 | 03-11-2011 05:41 PM |
| Leaky stock bpv | LiEast | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 10-20-2009 05:25 PM |
