  • 1 Post By buckeyepost
 Old 08-29-2011, 07:54 PM   #1
buckeyepost's Avatar
Posts: 295   (View Stats)
buckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond repute
Default Installed HPFP and now car won't start
Installed the AutoTech internals yesterday and fired it up before I put everything back together and it started/ran fine for a minute or so. I also cleaned my MSCAI filter so I had my wheel off, put my heat shields back on from when I put my DP, installed my SU rmm and rotated my tires. Did nothing electrical since it started last and after I finished all that it won't start. All the normal dash lights and chimes are there when I turn the key but it doesn't try to turn over. I took the IC back off and checked all connectors, disconnected the battery again to try and reset it, and visually checked the fuses, no luck..... I know this might be kinda vague but any ideas?
07 MS3 GT {DD} \\ 295whp 328wtq (pre E mix) \\ Cobb AP {Stage 2} \\ MS CAI & CBE \\ ATP DP/MP {catless} \\ Corksport TMIC \\ SURE TIH \\ TurboSmart Kompact BPV \\ AutoTech FP internals \\ Denso ITV22's \\ SU RMM \\ Ralco STS\\ Hawk HPS pads \\ StopTech rotors \\ Sensen dampers \\ Moog swaybar links \\ DashHawk \\ 225/45 Kuhmo Ecsta XS's on 18x7.5 Momo S-five's \\ 205/60-16 Dunlop Winter Sport 3D's on steelies
1:3 E85 mix Dizzy tuned by Boost_creep
...... sold :-(
buckeyepost is offline   Reply With Quote
 Old 08-29-2011, 08:02 PM   #2
Modelcsr08@yahoo.com's Avatar
Posts: 243   (View Stats)
Modelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond repute
Will it turn over or there is no power? If so you need to have your foot on the gas petal and turn it over at the same time because you have no fuel to pump into the block its almost like your priming the car.
Cobb AP: Stage2+SUR+TIH+IC 93|SURE: Aeros|Sidewinder|Charge Tubes|Return|ShortCut|CounterShift|M6 RacePipe|TorqR6 RMM|TurboSmart Dual Port BOV|CP-E TMIC|MagnaFlow CB 2.5'|StopTech D&S|HAWK HPS|AutoTech Internals|Denso ITV22|
Modelcsr08@yahoo.com is offline   Reply With Quote
The Following User Says Thank You to Modelcsr08@yahoo.com For This Useful Post:
TexasSpeed3 (08-29-2011)
 Old 08-29-2011, 08:04 PM   #3
TexasSpeed3's Avatar
Posts: 1,996   (View Stats)
TexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the world
Groans: 273
^^^ what he said
2011 Black Mica - Daily
JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp
TexasSpeed3 is offline   Reply With Quote
The Following User Says Thank You to TexasSpeed3 For This Useful Post:
Modelcsr08@yahoo.com (08-29-2011)
 Old 08-29-2011, 08:04 PM   #4
No, I have full power the engine just will not turn over. I was able to start it right after the HP internals so the fuel should be back and that's not the problem anyway. Almost something to do with clutch or starter?????
...... sold :-(
 Old 08-29-2011, 08:06 PM   #5
Is there a lot of clicking when you turn it over?
 Old 08-29-2011, 08:06 PM   #6
Groans: 273
well it will start but u didnt pressurize it dumb dumb. disconect ur coi packs with 1 yellow clip and crank the motor a few times check pressure with AP and then when u have about 500 it should be able to start
 Old 08-29-2011, 08:08 PM   #7
No, like I said, eveything sounds normal under the hood when the key is turned on. It's just like the starter won't engage.
...... sold :-(
 Old 08-29-2011, 08:10 PM   #8
Groans: 273
it it sounds normal while ur cranking thats the starter turning the motor... ur fuel pressure isnt there... u should have read all the steps
 Old 08-29-2011, 08:12 PM   #9
No, it is NOT cranking. I mean all the little ticks and buzzs that you hear when you turn the key to the on position. But after that nothing happens when you puch the clutch and try to start it...... nothing.
...... sold :-(
 Old 08-29-2011, 08:13 PM   #10
Groans: 273
CDFP internals upgrade
the last step... my bad its a black or grey connector
ah well hmmm thats random... fuel pump shouldnt have anything to do with the starter.
Last edited by TexasSpeed3; 08-29-2011 at 08:13 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-29-2011, 08:15 PM   #11
Plus, like I said (again)... I've already had it started since I installed the FP internals. I basically just buttoned things up tonight.
...... sold :-(
 Old 08-29-2011, 08:16 PM   #12
Groans: 273
u check all ur connections?
 Old 08-29-2011, 08:17 PM   #13
Ok it just sounds like there was not enough fuel to put in the block and now it starved itself. Once you get that thing turned over have your foot on that petal for a while so that fuel can get flowing.
 Old 08-29-2011, 08:17 PM   #14
Everything I was near.... I didn't check the starter so I might jack it up again and check those cables.
...... sold :-(
 Old 08-29-2011, 09:06 PM   #15
Groans: 273
check em if that doesnt work... take off a battery cable and leave it off for like 10 minutes... put it back on and then disconnect the coil packs and try cranking over a few
 Old 08-30-2011, 05:19 AM   #16
I tried that.... I guess I'll put it up in the air and see if the starter cable is loose. Read that might be the case in a couple other threads even though I wasn't even close to it.
...... sold :-(
 Old 08-30-2011, 05:25 AM   #17
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
i'd check any grounds in that area, i believe there is one right by the fuel pump that maybe you are missing.
 Old 08-30-2011, 05:28 AM   #18
That's what my buddy said too but I can't believe I would have accidentally pulled something off AFTER we already had it running once. I almost think it has to be a fuse or something. I gotta get her running soon b/c I have a track day at Mid-Ohio this Friday!
...... sold :-(
 Old 08-30-2011, 07:09 PM   #19
It was that little connector on the starter. Crammed my hand down in there from up top and jiggled around a little to free some corrosion. Fired right up after that. Just coincidental timing I guess. Freaked me out.... on with the track day!
XRJoe likes this.
...... sold :-(
The Following 4 Users Say Thank You to buckeyepost For This Useful Post:
jracer (08-31-2011), Modelcsr08@yahoo.com (08-31-2011), ScarMS3 (09-03-2011), TexasSpeed3 (08-30-2011)
 Old 08-31-2011, 07:53 AM   #20
Bob-o's Avatar
Posts: 1,312   (View Stats)
Glad to hear you got it working man!
The Following User Says Thank You to Bob-o For This Useful Post:
buckeyepost (12-26-2011)
autotech hpfp internals installed speedms6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 45 07-15-2012 06:59 AM
Autotech HPFP Internals Installed Jawnathin MazdaSpeed 3 - Engine, Transmission & Driveline 9 08-04-2011 12:20 PM
Just installed CP-E HPFP, heres a log for ya YZF-R6 2010 MS3 - ECU Computer Tuning 14 07-01-2011 01:10 PM
CPE HPFP Installed MS3_65 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 17 06-10-2010 04:22 PM
CPe HPFP installed vbt101 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 12 11-07-2009 05:40 PM
Page generated in 0.40385 seconds with 24 queries
