![]() Join Date: Mar 2018
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score If I change the headgasket is there a way to keep the timing in check without retiming the engine? or once i take the head off i'll need to retime? I'm wondering if there's a way to just mark everything and line it all back up when i put the head back on |
| Not Ranked : 0 score You can mark it, but if you're a few degrees off, you'll get a CEL.
| Not Ranked : 0 score More than likely you’ll end up needing to time it again.
(Thread Starter) | Not Ranked : 0 score Thank you all <3 |
| Injector Seals or Headgasket? | Mazdaspeedler | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 04-13-2015 09:07 AM |
| wrong headgasket??? | burntmushu | MazdaSpeed 6 - Engine, Transmission & Driveline | 12 | 01-18-2012 07:00 PM |
| Has anyone done a Headgasket repair? | gt5 | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 01-02-2011 05:22 PM |
