 Old 03-16-2016, 06:06 PM   #1
07MS6driver's Avatar
Posts: 1   (View Stats)
07MS6driver is an unknown quantity at this point
Default I've searched and I've googled without luck..power window don't work?
Ok I am new to the forums ..I have owed the 07 MS6 for about 6 months and I am having an issue with the power windows. The 30 amp fuse keeps blowing whenever I plug the driver side master switch in. I bought a new switch installed it and replaced the fuse and yep it blew again. None of the Windows work. Took it to the dealership today and they said I needed a new window switch(witch I just replaced)and wanted to charge me $280. I'm out on that option.
Any help would be much appreciated ?
07MS6driver is offline   Reply With Quote
 Old 03-17-2016, 12:22 PM   #2
Wild_Bill's Avatar
Posts: 120   (View Stats)
Wild_Bill has a reputation beyond reputeWild_Bill has a reputation beyond reputeWild_Bill has a reputation beyond reputeWild_Bill has a reputation beyond reputeWild_Bill has a reputation beyond reputeWild_Bill has a reputation beyond reputeWild_Bill has a reputation beyond reputeWild_Bill has a reputation beyond reputeWild_Bill has a reputation beyond reputeWild_Bill has a reputation beyond reputeWild_Bill has a reputation beyond repute
Short to ground maybe? You could start by inspecting the harness that goes through the door. Testing for continuity between wires that are otherwise not suppose to be connected. That's something you'd have to go through methodically.
I'm not a master certified mechanic however that's where I would start.
Wild_Bill is offline   Reply With Quote
Searched, and got little if no results... MoparGo Mazdaspeed3/6 General Discussion 3 08-29-2011 03:07 PM
FD RX7 wheels on a MS6.....Yes I've searched!!!! Josh Whitehead MazdaSpeed 3/6 - Wheels & Tires 10 08-10-2011 02:34 AM
P2187 (I have searched) Duo Maxwell MazdaSpeed 3/6 - ECU Computer Tuning 5 01-18-2011 08:31 PM
Dr. Murray's Home Searched Haltech Celeberty Smut 0 07-28-2009 10:50 AM
Page generated in 0.22684 seconds with 21 queries
