![]() | | #121 | ![]() |
![]() Join Date: Sep 2011 Location: Mission Viejo, SoCal
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| The Following User Says Thank You to Forsworn71 For This Useful Post: | EdgeAutosport.com (07-30-2012) |
![]() | | #122 | ![]() |
| Not Ranked : 0 score Hard Parts Intake ~250 Big turbo inlet pipe - ? Intercooler ~ 600 Downpipe ~200-600 Catback Exhaust ~800 Bigger turbo -? Colder spark plugs - ? Motor mounts- ~500 for all? Injector Seals -? Manifold -? Upgraded boost controller -? HPFP/HPFP Internals -? Cobb AccessPort ~600 The tune -? Sorry for double post, but if someone could help a brownie out that would be awesome. Willing to donate soon I promise!!! Just waiting till I can finalize how much my tuition is! |
![]() | | #123 | ![]() |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
EDIT: And 250 is wayyy too much for an intake. Donate and get all this shiz for cheap in the f/s section.
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts | |
![]() | | #124 | ![]() |
AP 480-600 GT3071 $1500 or 900 used 3" Htp full intake 225ish Catless dp 200 Hpfp internals 350 3 gallons of e85 tune Freekn tappin
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following 7 Users Say Thank You to atvfreek For This Useful Post: | AZSPEED3 (11-24-2012), GunGuru727 (07-31-2012), helmetface (11-24-2012), lilred (07-27-2012), Neverlift (07-27-2012), rednofive (09-17-2012), smoogs12 (07-27-2012) |
![]() | | #125 | ![]() |
![]() Join Date: Dec 2010 Location: seattle, Wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 45
| Not Ranked : 0 score What's the stock clutch good for, whp wise? |
![]() | | #126 | ![]() |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score You don't need a catless DP...
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() | | #127 | ![]() |
| Not Ranked : 0 score It really all depends on your driving habits. If you are taking that 400 to to the strip, it won't last long, but just doing rolls on the highway, the stock clutch will handle 400+ Freekn tappin
![]() | | #128 | ![]() |
| Not Ranked : 0 score I mentioned catless because its cheaper. By a lot. Freekn tappin
![]() | | #129 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
| Not Ranked : 0 score Thanks for the list, Eric. Interesting that no meth is mentioned or required. Out of that list, I'm pretty much just missing the injector seals, motor mounts (except RMM), catback exhaust, MBC and the turbo. I have a TIP that came with the CS SRI - hoping that is sufficient. What about the GTX2867? Been hearing good things about it (how it spools nearly as fast as the stock turbo, and how it has good power).... edit: Turns out the GTX2867R can make 400, but is probably more comfortable around 350 - 370 (?). I'm cool with that... was really only planning for 350whp safely with insta-spool, and without meth (if possible). GTX2867!
__________________ [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to Elusivellama For This Useful Post: | EdgeAutosport.com (07-30-2012) |
![]() | | #130 | ![]() |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
| Not Ranked : 0 score I have a Fujita CAI for 100 to sell (:
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
![]() | | #131 | ![]() |
| Not Ranked : 0 score Great list, thank you for that. I was just curious because the OP said that this was 400whp for a DD. Im looking to go BT in a year or so, so I need to save up now and I wont have a second car so I'd have to be able to DD it. |
| The Following User Says Thank You to Forsworn71 For This Useful Post: | atvfreek (07-30-2012) |
![]() | | #132 | ![]() |
| Iron Man ![]() Join Date: Apr 2011 Location: Albuquerque, NM
Rep Power: 726 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,014
| Not Ranked : 0 score Bump! For the gayness
__________________ Precision 6266 Top mount Southbend Stage 3 Race clutch Water to Air Intercooler Methanol Injection-50/50 e85 mix Hulk Smash |
| The Following User Says Thank You to ABQ Speed6 For This Useful Post: | EdgeAutosport.com (09-17-2012) |
![]() | | #133 | ![]() |
![]() Join Date: Jan 2012 Location: Prince George, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,068
| Not Ranked : 0 score subbed for good info in the future.
__________________ Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed. [SIGPIC][/SIGPIC] |
![]() | | #134 | ![]() |
![]() Join Date: Aug 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 4 Times in 1 Post
| Not Ranked : 0 score I hollowed out my second cat today...was pretty easy. Took a drive and it wasn't bad...mid range was better but not all that. Everything else is bone stock. Did the walnut valve job about two weeks ago, my SSP catch is on it's way. My slow and steady quest for improvement will be over time since my MS3 speed is just my commute car to get to work. I mostly drive a CX-9 since I have a somewhat large family. |
![]() | | #135 | ![]() |
| Not Ranked : 0 score O_o Just buy a race pipe.
| The Following User Says Thank You to Domino81 For This Useful Post: | Onelovesoccer (09-17-2012) |
![]() | | #136 | ![]() |
(Thread Starter) | Not Ranked : 0 score bump up |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | Caveman4684 (11-24-2012) |
![]() | | #137 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 112
Groans: 53
Groaned at 56 Times in 18 Posts
| Not Ranked : 0 score Subd thanks for the I info. Sent from digital watch from future
__________________ 2012 MS3 VR COBB AP /// Autotech Internals /// CP-E Nano SRI /// CP-E TIP /// JBR Dogbone RMM /// JBR OCC Stage 2 /// RichTune |
![]() | | #138 | ![]() |
![]() Join Date: May 2011 Location: Johannesburg, South Africa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 783
| Not Ranked : 0 score Maybe iz coz drunk, but this thread is awesome
__________________ 2007 Velocity Red MS6 Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads Parts stockpile... Wiseco 88mm's / Manley H beams Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04 Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth) Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust 5500 ft altitude FTL MSF in South Africa |
| The Following User Says Thank You to Rich990 For This Useful Post: | xantho99 (08-08-2013) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/how-get-400whp-your-speed-3-practical-111319/ | ||||
| How can I make my speed3 close to 400whp? - Yahoo! Answers | This thread | Refback | 07-29-2013 04:25 AM | |
| My 400whp journey wcf | I Love Brownies | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 79 | 12-15-2011 12:12 PM |
| Realgib3 - GTX3076 - 400whp | Realgib3 | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 63 | 10-13-2011 02:57 PM |
| Mommies on Minivans: Practical, but where's the style? | Haltech | Automotive News | 0 | 01-21-2011 04:20 PM |
| The 400whp Club | gsrtype1 | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 16 | 09-26-2008 03:19 PM |
